path: root/net/netfilter/nf_conntrack_h323_main.c
2008-11-17netfilter: nf_conntrack: connection tracking helper name persistent aliasesPablo Neira Ayuso
This patch adds the macro MODULE_ALIAS_NFCT_HELPER that defines a way to provide generic and persistent aliases for the connection tracking helpers. This next patch requires this patch. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-29net: replace %p6 with %pI6Harvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28netfilter: replace uses of NIP6_FMT with %p6Harvey Harrison
2008-10-08netfilter: netns nf_conntrack: H323 conntracking in netnsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: netns nf_conntrack: per-netns expectationsAlexey Dobriyan
Make per-netns a) expectation hash and b) expectations count. Expectations always belongs to netns to which it's master conntrack belong. This is natural and doesn't bloat expectation. Proc files and leaf users are stubbed to init_net, this is temporary. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: Use unsigned types for hooknum and pf varsJan Engelhardt
and (try to) consistently use u_int8_t for the L3 family. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-06-17netfilter: nf_conntrack_h323: fix module unload crashPatrick McHardy
The H.245 helper is not registered/unregistered, but assigned to connections manually from the Q.931 helper. This means on unload existing expectations and connections using the helper are not cleaned up, leading to the following oops on module unload: CPU 0 Unable to handle kernel paging request at virtual address c00a6828, epc == 802224dc, ra == 801d4e7c Oops[#1]: Cpu 0 $ 0 : 00000000 00000000 00000004 c00a67f0 $ 4 : 802a5ad0 81657e00 00000000 00000000 $ 8 : 00000008 801461c8 00000000 80570050 $12 : 819b0280 819b04b0 00000006 00000000 $16 : 802a5a60 80000000 80b46000 80321010 $20 : 00000000 00000004 802a5ad0 00000001 $24 : 00000000 802257a8 $28 : 802a4000 802a59e8 00000004 801d4e7c Hi : 0000000b Lo : 00506320 epc : 802224dc ip_conntrack_help+0x38/0x74 Tainted: P ra : 801d4e7c nf_iterate+0xbc/0x130 Status: 1000f403 KERNEL EXL IE Cause : 00800008 BadVA : c00a6828 PrId : 00019374 Modules linked in: ip_nat_pptp ip_conntrack_pptp ath_pktlog wlan_acl wlan_wep wlan_tkip wlan_ccmp wlan_xauth ath_pci ath_dev ath_dfs ath_rate_atheros wlan ath_hal ip_nat_tftp ip_conntrack_tftp ip_nat_ftp ip_conntrack_ftp pppoe ppp_async ppp_deflate ppp_mppe pppox ppp_generic slhc Process swapper (pid: 0, threadinfo=802a4000, task=802a6000) Stack : 801e7d98 00000004 802a5a60 80000000 801d4e7c 801d4e7c 802a5ad0 00000004 00000000 00000000 801e7d98 00000000 00000004 802a5ad0 00000000 00000010 801e7d98 80b46000 802a5a60 80320000 80000000 801d4f8c 802a5b00 00000002 80063834 00000000 80b46000 802a5a60 801e7d98 80000000 802ba854 00000000 81a02180 80b7e260 81a021b0 819b0000 819b0000 80570056 00000000 00000001 ... Call Trace: [<801e7d98>] ip_finish_output+0x0/0x23c [<801d4e7c>] nf_iterate+0xbc/0x130 [<801d4e7c>] nf_iterate+0xbc/0x130 [<801e7d98>] ip_finish_output+0x0/0x23c [<801e7d98>] ip_finish_output+0x0/0x23c [<801d4f8c>] nf_hook_slow+0x9c/0x1a4 One way to fix this would be to split helper cleanup from the unregistration function and invoke it for the H.245 helper, but since ctnetlink needs to be able to find the helper for synchonization purposes, a better fix is to register it normally and make sure its not assigned to connections during helper lookup. The missing l3num initialization is enough for this, this patch changes it to use AF_UNSPEC to make it more explicit though. Reported-by: liannan <liannan@twsz.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-17netfilter: nf_conntrack_h323: fix memory leak in module initialization error ↵Patrick McHardy
path Properly free h323_buffer when helper registration fails. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14[NETFILTER]: nf_conntrack: replace NF_CT_DUMP_TUPLE macro indrection by ↵Jan Engelhardt
function call Directly call IPv4 and IPv6 variants where the address family is easily known. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack: add tuplehash l3num/protonum accessorsPatrick McHardy
Add accessors for l3num and protonum and get rid of some overly long expressions. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-03-25[NETFILTER]: nf_conntrack: introduce expectation classes and policiesPatrick McHardy
Introduce expectation classes and policies. An expectation class is used to distinguish different types of expectations by the same helper (for example audio/video/t.120). The expectation policy is used to hold the maximum number of expectations and the initial timeout for each class. The individual classes are isolated from each other, which means that for example an audio expectation will only evict other audio expectations. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-20[NETFILTER]: nf_conntrack_h323: logical-bitwise & confusion in process_setup()Roel Kluin
logical-bitwise & confusion Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: nf_conntrack_h323: constify and annotate H.323 helperJan Engelhardt
Constify data tables (predominantly in nf_conntrack_h323_types.c, but also a few in nf_conntrack_h323_asn1.c) and use const qualifiers on variables where possible in the h323 sources. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: nf_conntrack: switch rwlock to spinlockPatrick McHardy
With the RCU conversion only write_lock usages of nf_conntrack_lock are left (except one read_lock that should actually use write_lock in the H.323 helper). Switch to a spinlock. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Introduce nf_inet_addressJan Engelhardt
A few netfilter modules provide their own union of IPv4 and IPv6 address storage. Will unify that in this patch series. (1/4): Rename union nf_conntrack_address to union nf_inet_addr and move it to x_tables.h. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: constify nf_afinfoPatrick McHardy
2008-01-28[NETFILTER]: nf_ct_h323: remove ipv6 module dependencyPatrick McHardy
nf_conntrack_h323 needs ip6_route_output for the call forwarding filter. Add a ->route function to nf_afinfo and use that to avoid pulling in the ipv6 module. Fix the #ifdef for the IPv6 code while I'm at it - the IPv6 support is only needed when IPv6 conntrack is enabled. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-15[NETFILTER]: Replace sk_buff ** with sk_buff *Herbert Xu
With all the users of the double pointers removed, this patch mops up by finally replacing all occurances of sk_buff ** in the netfilter API by sk_buff *. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: Convert DEBUGP to pr_debugPatrick McHardy
Convert DEBUGP to pr_debug and fix lots of non-compiling debug statements. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: nf_conntrack_h323: turn some printks into DEBUGPsPatrick McHardy
Don't spam the ringbuffer with decoding errors. The only printks remaining are for dropped packets when we're certain they are H.323. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: nf_conntrack: reduce masks to a subset of tuplesPatrick McHardy
Since conntrack currently allows to use masks for every bit of both helper and expectation tuples, we can't hash them and have to keep them on two global lists that are searched for every new connection. This patch removes the never used ability to use masks for the destination part of the expectation tuple and completely removes masks from helpers since the only reasonable choice is a full match on l3num, protonum and src.u.all. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: nf_conntrack_expect: function naming unificationPatrick McHardy
Currently there is a wild mix of nf_conntrack_expect_, nf_ct_exp_, expect_, exp_, ... Consistently use nf_ct_ as prefix for exported functions. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[NETFILTER]: nf_conntrack_h323: add missing T.120 address in OLCAJing Min Zhao
Add missing process of T.120 address in OpenLogicalChannelAck signal. Signed-off-by: Jing Min Zhao <zhaojingmin@vivecode.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[NETFILTER]: nf_conntrack_h323: remove unnecessary process of Information signalJing Min Zhao
According to the implementation of H.323, it's not necessary to check the addresses in Information signals. Signed-off-by: Jing Min Zhao <zhaojingmin@vivecode.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[NETFILTER]: nf_conntrack_h323: fix get_h225_addr() for IPv6 address accessJing Min Zhao
Update get_h225_addr() to meet the changes in ASN.1 types. It was using field ip6 to access IPv6 TransportAddress, it should be ip according the ASN.1 definition. Signed-off-by: Jing Min Zhao <zhaojingmin@vivecode.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[NETFILTER]: Fix whitespace errorsYOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: nf_conntrack/nf_nat: add H.323 helper portPatrick McHardy
Add IPv4 and IPv6 capable nf_conntrack port of the H.323 conntrack/NAT helper. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
