file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Normally, each connection needs a unique identity. Conntrack zones allow
to specify a numerical zone using the CT target, connections in different
zones can use the same identity.
Example:
iptables -t raw -A PREROUTING -i veth0 -j CT --zone 1
iptables -t raw -A OUTPUT -o veth1 -j CT --zone 1
Base versions handle constant folding now.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This patch adds the macro MODULE_ALIAS_NFCT_HELPER that defines a
way to provide generic and persistent aliases for the connection
tracking helpers.
This next patch requires this patch.
Make per-netns a) expectation hash and b) expectations count.
Expectations always belongs to netns to which it's master conntrack belong.
This is natural and doesn't bloat expectation.
Proc files and leaf users are stubbed to init_net, this is temporary.
and (try to) consistently use u_int8_t for the L3 family.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
The H.245 helper is not registered/unregistered, but assigned to
connections manually from the Q.931 helper. This means on unload
existing expectations and connections using the helper are not
cleaned up, leading to the following oops on module unload:
CPU 0 Unable to handle kernel paging request at virtual address c00a6828, epc == 802224dc, ra == 801d4e7c
Oops[#1]:
Cpu 0
$ 0 : 00000000 00000000 00000004 c00a67f0
$ 4 : 802a5ad0 81657e00 00000000 00000000
$ 8 : 00000008 801461c8 00000000 80570050
$12 : 819b0280 819b04b0 00000006 00000000
$16 : 802a5a60 80000000 80b46000 80321010
$20 : 00000000 00000004 802a5ad0 00000001
$24 : 00000000 802257a8
$28 : 802a4000 802a59e8 00000004 801d4e7c
Hi : 0000000b
Lo : 00506320
epc : 802224dc ip_conntrack_help+0x38/0x74 Tainted: P
ra : 801d4e7c nf_iterate+0xbc/0x130
Status: 1000f403 KERNEL EXL IE
Cause : 00800008
BadVA : c00a6828
PrId : 00019374
Modules linked in: ip_nat_pptp ip_conntrack_pptp ath_pktlog wlan_acl wlan_wep wlan_tkip wlan_ccmp wlan_xauth ath_pci ath_dev ath_dfs ath_rate_atheros wlan ath_hal ip_nat_tftp ip_conntrack_tftp ip_nat_ftp ip_conntrack_ftp pppoe ppp_async ppp_deflate ppp_mppe pppox ppp_generic slhc
Process swapper (pid: 0, threadinfo=802a4000, task=802a6000)
Stack : 801e7d98 00000004 802a5a60 80000000 801d4e7c 801d4e7c 802a5ad0 00000004
00000000 00000000 801e7d98 00000000 00000004 802a5ad0 00000000 00000010
801e7d98 80b46000 802a5a60 80320000 80000000 801d4f8c 802a5b00 00000002
80063834 00000000 80b46000 802a5a60 801e7d98 80000000 802ba854 00000000
81a02180 80b7e260 81a021b0 819b0000 819b0000 80570056 00000000 00000001
Call Trace:
[<801e7d98>] ip_finish_output+0x0/0x23c
[<801d4e7c>] nf_iterate+0xbc/0x130
[<801d4f8c>] nf_hook_slow+0x9c/0x1a4
One way to fix this would be to split helper cleanup from the unregistration
function and invoke it for the H.245 helper, but since ctnetlink needs to be
able to find the helper for synchonization purposes, a better fix is to
register it normally and make sure its not assigned to connections during
helper lookup. The missing l3num initialization is enough for this, this
patch changes it to use AF_UNSPEC to make it more explicit though.
Reported-by: liannan <liannan@twsz.com>
path
Properly free h323_buffer when helper registration fails.
function call
Directly call IPv4 and IPv6 variants where the address family is
easily known.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Add accessors for l3num and protonum and get rid of some overly long
expressions.
Introduce expectation classes and policies. An expectation class
is used to distinguish different types of expectations by the
same helper (for example audio/video/t.120). The expectation
policy is used to hold the maximum number of expectations and
the initial timeout for each class.
The individual classes are isolated from each other, which means
that for example an audio expectation will only evict other audio
expectations.
logical-bitwise & confusion
Signed-off-by: Roel Kluin <12o3l@tiscali.nl>
Constify data tables (predominantly in nf_conntrack_h323_types.c, but
also a few in nf_conntrack_h323_asn1.c) and use const qualifiers on
variables where possible in the h323 sources.
With the RCU conversion only write_lock usages of nf_conntrack_lock are
left (except one read_lock that should actually use write_lock in the
H.323 helper). Switch to a spinlock.
A few netfilter modules provide their own union of IPv4 and IPv6
address storage. Will unify that in this patch series.
(1/4): Rename union nf_conntrack_address to union nf_inet_addr and
move it to x_tables.h.
nf_conntrack_h323 needs ip6_route_output for the call forwarding filter.
Add a ->route function to nf_afinfo and use that to avoid pulling in the
ipv6 module.
Fix the #ifdef for the IPv6 code while I'm at it - the IPv6 support is
only needed when IPv6 conntrack is enabled.
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
Convert DEBUGP to pr_debug and fix lots of non-compiling debug statements.
Don't spam the ringbuffer with decoding errors. The only printks remaining
are for dropped packets when we're certain they are H.323.
Since conntrack currently allows to use masks for every bit of both
helper and expectation tuples, we can't hash them and have to keep
them on two global lists that are searched for every new connection.
This patch removes the never used ability to use masks for the
destination part of the expectation tuple and completely removes
masks from helpers since the only reasonable choice is a full
match on l3num, protonum and src.u.all.
Currently there is a wild mix of nf_conntrack_expect_, nf_ct_exp_,
expect_, exp_, ...
Consistently use nf_ct_ as prefix for exported functions.
Add missing process of T.120 address in OpenLogicalChannelAck signal.
Signed-off-by: Jing Min Zhao <zhaojingmin@vivecode.com>
According to the implementation of H.323, it's not necessary to check
the addresses in Information signals.
Update get_h225_addr() to meet the changes in ASN.1 types. It was using
field ip6 to access IPv6 TransportAddress, it should be ip according the
ASN.1 definition.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Add IPv4 and IPv6 capable nf_conntrack port of the H.323 conntrack/NAT helper.
