path: root/net/netfilter/nf_conntrack_h323_types.c
2008-01-31[NETFILTER]: nf_conntrack_h323: constify and annotate H.323 helperJan Engelhardt
Constify data tables (predominantly in nf_conntrack_h323_types.c, but also a few in nf_conntrack_h323_asn1.c) and use const qualifiers on variables where possible in the h323 sources. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-24[NETFILTER]: nf_conntrack_h323: fix ASN.1 typesJing Min Zhao
1. Add support for decoding IPv6 address. I know it was manually added in the header file, but not in the template file. That wouldn't work. 2. Add missing support for decoding T.120 address in OLCA. 3. Remove unnecessary decoding of Information signal. Signed-off-by: Jing Min Zhao <zhaojingmin@vivecode.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: nf_conntrack/nf_nat: add H.323 helper portPatrick McHardy
Add IPv4 and IPv6 capable nf_conntrack port of the H.323 conntrack/NAT helper. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
