path: root/net/netfilter/nf_conntrack_l3proto_generic.c
2008-04-14[NETFILTER]: nf_conntrack: use bool type in struct nf_conntrack_l3protoJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-01-28[NETFILTER]: nf_conntrack: remove print_conntrack function from l3protosPatrick McHardy
Its unused and unlikely to ever be used. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-14[NETFILTER]: nf_conntrack: mark protocols __read_mostlyPatrick McHardy
Also remove two unnecessary EXPORT_SYMBOLs and move the nf_conntrack_l3proto_ipv4 declaration to the correct file. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-14[NETFILTER]: nf_conntrack: make l3proto->prepare() generic and renames itYasuyuki Kozakai
The icmp[v6] l4proto modules parse headers in ICMP[v6] error to get tuple. But they have to find the offset to transport protocol header before that. Their processings are almost same as prepare() of l3proto modules. This makes prepare() more generic to simplify icmp[v6] l4proto module later. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: Convert DEBUGP to pr_debugPatrick McHardy
Convert DEBUGP to pr_debug and fix lots of non-compiling debug statements. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: nf_conntrack: remove old memory allocator of conntrackYasuyuki Kozakai
Now memory space for help and NAT are allocated by extension infrastructure. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[NETFILTER]: Fix whitespace errorsYOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: nf_conntrack: /proc compatibility with old connection trackingPatrick McHardy
This patch adds /proc/net/ip_conntrack, /proc/net/ip_conntrack_expect and /proc/net/stat/ip_conntrack files to keep old programs using them working. The /proc/net/ip_conntrack and /proc/net/ip_conntrack_expect files show only IPv4 entries, the /proc/net/stat/ip_conntrack shows global statistics. Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: nf_conntrack: move extern declaration to header filesPatrick McHardy
Using extern in a C file is a bad idea because the compiler can't catch type errors. Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: nf_conntrack: rename struct nf_conntrack_protocolMartin Josefsson
Rename 'struct nf_conntrack_protocol' to 'struct nf_conntrack_l4proto' in order to help distinguish it from 'struct nf_conntrack_l3proto'. It gets rather confusing with 'nf_conntrack_protocol'. Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se> Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-04-24[NETFILTER]: nf_conntrack: Fix module refcount dropping too farYasuyuki Kozakai
If nf_ct_l3proto_find_get() fails to get the refcount of nf_ct_l3proto_generic, nf_ct_l3proto_put() will drop the refcount too far. This gets rid of '.me = THIS_MODULE' of nf_ct_l3proto_generic so that nf_ct_l3proto_find_get() doesn't try to get refcount of it. It's OK because its symbol is usable until nf_conntrack.ko is unloaded. This also kills unnecessary NULL pointer check as well. __nf_ct_proto_find() allways returns non-NULL pointer. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-09[NETFILTER]: Add nf_conntrack subsystem.Yasuyuki Kozakai
The existing connection tracking subsystem in netfilter can only handle ipv4. There were basically two choices present to add connection tracking support for ipv6. We could either duplicate all of the ipv4 connection tracking code into an ipv6 counterpart, or (the choice taken by these patches) we could design a generic layer that could handle both ipv4 and ipv6 and thus requiring only one sub-protocol (TCP, UDP, etc.) connection tracking helper module to be written. In fact nf_conntrack is capable of working with any layer 3 protocol. The existing ipv4 specific conntrack code could also not deal with the pecularities of doing connection tracking on ipv6, which is also cured here. For example, these issues include: 1) ICMPv6 handling, which is used for neighbour discovery in ipv6 thus some messages such as these should not participate in connection tracking since effectively they are like ARP messages 2) fragmentation must be handled differently in ipv6, because the simplistic "defrag, connection track and NAT, refrag" (which the existing ipv4 connection tracking does) approach simply isn't feasible in ipv6 3) ipv6 extension header parsing must occur at the correct spots before and after connection tracking decisions, and there were no provisions for this in the existing connection tracking design 4) ipv6 has no need for stateful NAT The ipv4 specific conntrack layer is kept around, until all of the ipv4 specific conntrack helpers are ported over to nf_conntrack and it is feature complete. Once that occurs, the old conntrack stuff will get placed into the feature-removal-schedule and we will fully kill it off 6 months later. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
