This patch uses the new variable length conntrack extensions.
Instead of using union nf_conntrack_help that contain all the
helper private data information, we allocate variable length
area to store the private helper data.
This patch includes the modification of all existing helpers.
It also includes a couple of include header to avoid compilation
warnings.
When both the server and the client are NATed, the set-link-info control
packet containing the peer's call-id field is not properly translated.
I have verified that it was working in 2.6.16.13 kernel previously but
due to rewrite, this scenario stopped working (Not knowing exact version
when it stopped working).
Signed-off-by: Sanket Shah <sanket.shah@elitecore.com>
Following error is raised (and other similar ones) :
net/ipv4/netfilter/nf_nat_standalone.c: In function ‘nf_nat_fn’:
net/ipv4/netfilter/nf_nat_standalone.c:119:2: warning: case value ‘4’
not in enumerated type ‘enum ip_conntrack_info’
gcc barfs on adding two enum values and getting a not enumerated
result :
case IP_CT_RELATED+IP_CT_IS_REPLY:
Add missing enum values
CC: David Miller <davem@davemloft.net>
Normally, each connection needs a unique identity. Conntrack zones allow
to specify a numerical zone using the CT target, connections in different
zones can use the same identity.
Example:
iptables -t raw -A PREROUTING -i veth0 -j CT --zone 1
iptables -t raw -A OUTPUT -o veth1 -j CT --zone 1
drivers/net/wimax/i2400m/usb-notif.c
This patch combines Greg Bank's dprintk() work with the existing dynamic
printk patchset, we are now calling it 'dynamic debug'.
The new feature of this patchset is a richer /debugfs control file interface,
(an example output from my system is at the bottom), which allows fined grained
control over the the debug output. The output can be controlled by function,
file, module, format string, and line number.
for example, enabled all debug messages in module 'nf_conntrack':
echo -n 'module nf_conntrack +p' > /mnt/debugfs/dynamic_debug/control
to disable them:
echo -n 'module nf_conntrack -p' > /mnt/debugfs/dynamic_debug/control
A further explanation can be found in the documentation patch.
Signed-off-by: Greg Banks <gnb@sgi.com>
Signed-off-by: Jason Baron <jbaron@redhat.com>
Base versions handle constant folding now.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
This patch adds the macro MODULE_ALIAS_NFCT_HELPER that defines a
way to provide generic and persistent aliases for the connection
tracking helpers.
This next patch requires this patch.
Base infrastructure to enable per-module debug messages.
I've introduced CONFIG_DYNAMIC_PRINTK_DEBUG, which when enabled centralizes
control of debugging statements on a per-module basis in one /proc file,
currently, <debugfs>/dynamic_printk/modules. When, CONFIG_DYNAMIC_PRINTK_DEBUG,
is not set, debugging statements can still be enabled as before, often by
defining 'DEBUG' for the proper compilation unit. Thus, this patch set has no
affect when CONFIG_DYNAMIC_PRINTK_DEBUG is not set.
The infrastructure currently ties into all pr_debug() and dev_dbg() calls. That
is, if CONFIG_DYNAMIC_PRINTK_DEBUG is set, all pr_debug() and dev_dbg() calls
can be dynamically enabled/disabled on a per-module basis.
Future plans include extending this functionality to subsystems, that define
their own debug levels and flags.
Usage:
Dynamic debugging is controlled by the debugfs file,
<debugfs>/dynamic_printk/modules. This file contains a list of the modules that
can be enabled. The format of the file is as follows:
<module_name> <enabled=0/1>
<module_name> : Name of the module in which the debug call resides
<enabled=0/1> : whether the messages are enabled or not
For example:
snd_hda_intel enabled=0
fixup enabled=1
driver enabled=0
Enable a module:
$echo "set enabled=1 <module_name>" > dynamic_printk/modules
Disable a module:
$echo "set enabled=0 <module_name>" > dynamic_printk/modules
Enable all modules:
$echo "set enabled=1 all" > dynamic_printk/modules
Disable all modules:
$echo "set enabled=0 all" > dynamic_printk/modules
Finally, passing "dynamic_printk" at the command line enables
debugging for all modules. This mode can be turned off via the above
disable command.
[gkh: minor cleanups and tweaks to make the build work quietly]
* make keymap list per-netns
* per-netns keymal lock (not strictly necessary)
* flush keymap at netns stop and module unload.
Make per-netns a) expectation hash and b) expectations count.
Expectations always belongs to netns to which it's master conntrack belong.
This is natural and doesn't bloat expectation.
Proc files and leaf users are stubbed to init_net, this is temporary.
* make per-netns conntrack hash
Other solution is to add ->ct_net pointer to tuplehashes and still has one
hash, I tried that it's ugly and requires more code deep down in protocol
modules et al.
* propagate netns pointer to where needed, e. g. to conntrack iterators.
function call
Directly call IPv4 and IPv6 variants where the address family is
easily known.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Add accessors for l3num and protonum and get rid of some overly long
expressions.
Introduce expectation classes and policies. An expectation class
is used to distinguish different types of expectations by the
same helper (for example audio/video/t.120). The expectation
policy is used to hold the maximum number of expectations and
the initial timeout for each class.
The individual classes are isolated from each other, which means
that for example an audio expectation will only evict other audio
expectations.
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
Convert DEBUGP to pr_debug and fix lots of non-compiling debug statements.
Since conntrack currently allows to use masks for every bit of both
helper and expectation tuples, we can't hash them and have to keep
them on two global lists that are searched for every new connection.
This patch removes the never used ability to use masks for the
destination part of the expectation tuple and completely removes
masks from helpers since the only reasonable choice is a full
match on l3num, protonum and src.u.all.
Currently there is a wild mix of nf_conntrack_expect_, nf_ct_exp_,
expect_, exp_, ...
Consistently use nf_ct_ as prefix for exported functions.
nf_conntrack_find_get
All callers pass NULL, this also doesn't seem very useful for modules.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
When an expected connection arrives, the NAT helper should be called to
set up NAT similar to the master connection. The PPTP conntrack helper
incorrectly checks whether the _expected_ connection has NAT setup before
calling the NAT helper (which is never the case), instead of checkeing
whether the _master_ connection is NATed.
Add nf_conntrack port of the PPtP conntrack/NAT helper. Since there seems
to be no IPv6-capable PPtP implementation the helper only support IPv4.
