Add accessors for l3num and protonum and get rid of some overly long
expressions.
The conntracks subsystem has a similar infrastructure
to maintain ctl_paths, but since we already have it
on the generic level, I think it's OK to switch to
using it.
So, basically, this patch just replaces the ctl_table-s
with ctl_path-s, nf_register_sysctl_table with
register_sysctl_paths() and removes no longer needed code.
After this the net/netfilter/nf_sysctl.c file contains
the paths only.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Acked-by: Patrick McHardy <kaber@trash.net>
- make the following needlessly global variables static:
- core/rtnetlink.c: struct rtnl_msg_handlers[]
- netfilter/nf_conntrack_proto.c: struct nf_ct_protos[]
- make the following needlessly global functions static:
- core/rtnetlink.c: rtnl_dump_all()
- netlink/af_netlink.c: netlink_queue_skip()
The retrying after an allocation failure is not necessary anymore
since we're holding the mutex the entire time, for the same
reason the double allocation race can't happen anymore.
Now that we don't use nf_conntrack_lock anymore but a single mutex for
all protocol handling, no need to release and grab it again for sysctl
registration.
Remove ugly special-casing of nf_conntrack_l4proto_generic, all it
wants is its sysctl tables registered, so do that explicitly in an
init function and move the remaining protocol initialization and
cleanup code to nf_conntrack_proto.c as well.
The protocol lookups done by nf_conntrack are already protected by RCU,
there is no need to keep taking nf_conntrack_lock for registration
and unregistration. Switch to a mutex.
No caller checks the return value, and since its usually called within the
module unload path there's nothing a module could do about errors anyway,
so BUG on invalid conditions and return void.
nf_ct_protos/nf_ct_l3protos arrays
Replace preempt_{enable,disable} based RCU by proper use of the
RCU API and add missing rcu_read_lock/rcu_read_unlock calls in
all paths not obviously only used within packet process context
(nfnetlink_conntrack).
- move EXPORT_SYMBOL next to exported symbol
- use EXPORT_SYMBOL_GPL since this is what the original code used
This patch adds an option to keep the connection tracking sysctls visible
under their old names.
Add helper functions for sysctl registration with optional instantiating
of common path elements (like net/netfilter) and use it for support for
automatic registation of conntrack protocol sysctls.
registration/unregistration
Add some more sanity checks when registering/unregistering l3/l4 protocols.
Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se>
Rename 'struct nf_conntrack_protocol' to 'struct nf_conntrack_l4proto' in
order to help distinguish it from 'struct nf_conntrack_l3proto'. It gets
rather confusing with 'nf_conntrack_protocol'.
This patch splits out L3/L4 protocol handling into its own file
