This patch generalizes nf_ct_l4proto_net by splitting it into chunks and
moving the corresponding protocol part to where it really belongs to.
To clarify, note that we follow two different approaches to support per-net
depending if it's built-in or run-time loadable protocol tracker.
Acked-by: Gao feng <gaofeng@cn.fujitsu.com>
Merge udpv4_net_init and udpv6_net_init into udp_net_init to
remove redundant code now that we have the u_int16_t proto
parameter.
And use nf_proto_net.users to identify if it's the first time
we use the nf_proto_net, in that case, we initialize it.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
l4proto->init contain quite redundant code. We can simplify this
by adding a new parameter l3proto.
This patch prepares that code simplification.
This patch fixes the compilation of the TCP and UDP trackers with sysctl
compilation disabled:
net/netfilter/nf_conntrack_proto_udp.c: In function ‘udp_init_net_data’:
net/netfilter/nf_conntrack_proto_udp.c:279:13: error: ‘struct nf_proto_net’ has no member named
‘user’
net/netfilter/nf_conntrack_proto_tcp.c:1606:9: error: ‘struct nf_proto_net’ has no member named
‘user’
net/netfilter/nf_conntrack_proto_tcp.c:1643:9: error: ‘struct nf_proto_net’ has no member named
‘user’
Reported-by: Fengguang Wu <wfg@linux.intel.com>
This patch adds namespace support for cttimeout.
Acked-by: Eric W. Biederman <ebiederm@xmission.com>
Since the sysctl data for l[3|4]proto now resides in pernet nf_proto_net.
We can now remove this unused fields from struct nf_contrack_l[3,4]proto.
This patch adds namespace support for UDP protocol tracker.
These macros contain a hidden goto, and are thus extremely error
prone and make code hard to audit.
This patch adds the infrastructure to add fine timeout tuning
over nfnetlink. Now you can use the NFNL_SUBSYS_CTNETLINK_TIMEOUT
subsystem to create/delete/dump timeout objects that contain some
specific timeout policy for one flow.
The follow up patches will allow you attach timeout policy object
to conntrack via the CT target and the conntrack extension
infrastructure.
This patch defines a new interface for l4 protocol trackers:
unsigned int *(*get_timeouts)(struct net *net);
that is used to return the array of unsigned int that contains
the timeouts that will be applied for this flow. This is passed
to the l4proto->new(...) and l4proto->packet(...) functions to
specify the timeout policy.
This interface allows per-net global timeout configuration
(although only DCCP supports this by now) and it will allow
custom custom timeout configuration by means of follow-up
patches.
Use one array to store the UDP timeouts instead of two variables.
Use IS_ENABLED(CONFIG_FOO)
instead of defined(CONFIG_FOO) || defined (CONFIG_FOO_MODULE)
Signed-off-by: Igor Maravić <igorm@etf.rs>
The error handlers might need the template to get the conntrack zone
introduced in the next patches to perform a conntrack lookup.
Split up the IPCT_STATUS event into an IPCT_REPLY event, which is generated
when the IPS_SEEN_REPLY bit is set, and an IPCT_ASSURED event, which is
generated when the IPS_ASSURED bit is set.
In combination with a following patch to support selective event delivery,
this can be used for "sparse" conntrack replication: start replicating the
conntrack entry after it reached the ASSURED state and that way it's SYN-flood
resistant.
Now that sys_sysctl is a compatiblity wrapper around /proc/sys
all sysctl strategy routines, and all ctl_name and strategy
entries in the sysctl tables are unused, and can be
revmoed.
In addition neigh_sysctl_register has been modified to no longer
take a strategy argument and it's callers have been modified not
to pass one.
Cc: "David Miller" <davem@davemloft.net>
Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org>
Cc: netdev@vger.kernel.org
Signed-off-by: Holger Eitzenberger <holger@eitzenberger.org>
Moving the structure definitions to the corresponding IPvX specific header files.
I want to compile out proc_* and sysctl_* handlers totally and
stub them to NULL depending on config options, however usage of &
will prevent this, since taking adress of NULL pointer will break
compilation.
So, drop & in front of every ->proc_handler and every ->strategy
handler, it was never needed in fact.
net.netfilter.nf_conntrack_log_invalid sysctl
sysctl
not skb
This is cleaner, we already know conntrack to which event is relevant.
Again, it's deducible from skb, but we're going to use it for
nf_conntrack_checksum and statistics, so just pass it from upper layer.
and (try to) consistently use u_int8_t for the L3 family.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Rename all "conntrack" variables to "ct" for more consistency and
avoiding some overly long lines.
Allows to remove five empty implementations.
The IPv4 and IPv6 hook values are identical, yet some code tries to figure
out the "correct" value by looking at the address family. Introduce NF_INET_*
values for both IPv4 and IPv6. The old values are kept in a #ifndef __KERNEL__
section for userspace compatibility.
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
No one has bothered to set strategy routine for the the netfilter sysctls that
return jiffies to be sysctl_jiffies.
So it appears the sys_sysctl path is unused and untested, so this patch
removes the binary sysctl numbers.
Which fixes the netfilter oops in 2.6.23-rc2-mm2 for me.
Cc: Patrick McHardy <kaber@trash.net>
There is no struct nfattr anymore, rename functions to 'nlattr'.
This patch cleans up duplicate includes in
net/netfilter/
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Also remove two unnecessary EXPORT_SYMBOLs and move the
nf_conntrack_l3proto_ipv4 declaration to the correct file.
The nf_conntrack_netlink config option is named CONFIG_NF_CT_NETLINK,
but multiple files use CONFIG_IP_NF_CONNTRACK_NETLINK or
CONFIG_NF_CONNTRACK_NETLINK for ifdefs.
Fix this and reformat all CONFIG_NF_CT_NETLINK ifdefs to only use a line.
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
- move EXPORT_SYMBOL next to exported symbol
- use EXPORT_SYMBOL_GPL since this is what the original code used
This patch adds an option to keep the connection tracking sysctls visible
under their old names.
Rename 'struct nf_conntrack_protocol' to 'struct nf_conntrack_l4proto' in
order to help distinguish it from 'struct nf_conntrack_l3proto'. It gets
rather confusing with 'nf_conntrack_protocol'.
Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se>
This patch splits out the event cache into its own file
nf_conntrack_ecache.c
Change some netfilter tunables to __read_mostly. Also fixed some
incorrect file reference comments while I was in there.
(this will be my last __read_mostly patch unless someone points out
something else that needs it)
Signed-off-by: Brian Haley <brian.haley@hp.com>
Acked-by: Patrick McHardy <kaber@trash.net>
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose
checksum still needs to be completed) and CHECKSUM_COMPLETE (for
incoming packets, device supplied full checksum).
Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3.
Besides removing lots of duplicate code, all converted users benefit
from improved HW checksum error handling. Tested with and without HW
checksums in almost all combinations.
If skb->ip_summed is CHECKSUM_HW here, skb->csum includes checksum
of actual IPv6 header and extension headers. Then such excess
checksum must be subtruct when nf_conntrack calculates TCP/UDP checksum
with pseudo IPv6 header. Spotted by Ben Skeggs.
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
The connection tracking timeout variables are unsigned long, but
proc_dointvec_jiffies is used with sizeof(unsigned int) in the sysctl
tables. Since there is no proc_doulongvec_jiffies function, change the
timeout variables to unsigned int.
The existing connection tracking subsystem in netfilter can only
handle ipv4. There were basically two choices present to add
connection tracking support for ipv6. We could either duplicate all
of the ipv4 connection tracking code into an ipv6 counterpart, or (the
choice taken by these patches) we could design a generic layer that
could handle both ipv4 and ipv6 and thus requiring only one sub-protocol
(TCP, UDP, etc.) connection tracking helper module to be written.
In fact nf_conntrack is capable of working with any layer 3
protocol.
The existing ipv4 specific conntrack code could also not deal
with the pecularities of doing connection tracking on ipv6,
which is also cured here. For example, these issues include:
1) ICMPv6 handling, which is used for neighbour discovery in
ipv6 thus some messages such as these should not participate
in connection tracking since effectively they are like ARP
messages
2) fragmentation must be handled differently in ipv6, because
the simplistic "defrag, connection track and NAT, refrag"
(which the existing ipv4 connection tracking does) approach simply
isn't feasible in ipv6
3) ipv6 extension header parsing must occur at the correct spots
before and after connection tracking decisions, and there were
no provisions for this in the existing connection tracking
design
4) ipv6 has no need for stateful NAT
The ipv4 specific conntrack layer is kept around, until all of
the ipv4 specific conntrack helpers are ported over to nf_conntrack
and it is feature complete. Once that occurs, the old conntrack
stuff will get placed into the feature-removal-schedule and we will
fully kill it off 6 months later.
Signed-off-by: Harald Welte <laforge@netfilter.org>
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
