path: root/net/netfilter/nf_conntrack_snmp.c
2011-01-18netfilter: nf_conntrack: nf_conntrack snmp helperJiri Olsa
Adding support for SNMP broadcast connection tracking. The SNMP broadcast requests are now paired with the SNMP responses. Thus allowing using SNMP broadcasts with firewall enabled. Please refer to the following conversation: http://marc.info/?l=netfilter-devel&m=125992205006600&w=2 Patrick McHardy wrote: > > The best solution would be to add generic broadcast tracking, the > > use of expectations for this is a bit of abuse. > > The second best choice I guess would be to move the help() function > > to a shared module and generalize it so it can be used for both. This patch implements the "second best choice". Since the netbios-ns conntrack module uses the same helper functionality as the snmp, only one helper function is added for both snmp and netbios-ns modules into the new object - nf_conntrack_broadcast. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
