path: root/net/netfilter/nf_conntrack_standalone.c
2008-05-02netfilter: assign PDE->fops before gluing PDE into /proc treeDenis V. Lunev
Replace create_proc_entry with specially created for this purpose proc_create. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-14[NETFILTER]: nf_conntrack: add tuplehash l3num/protonum accessorsPatrick McHardy
Add accessors for l3num and protonum and get rid of some overly long expressions. Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-04-14[NETFILTER]: nf_conntrack: less hairy ifdefs around proc and sysctlAlexey Dobriyan
Patch splits creation of /proc/net/nf_conntrack, /proc/net/stat/nf_conntrack and net.netfilter hierarchy into their own functions with dummy ones if PROC_FS or SYSCTL is not set. Also, remove dead "ret = 0" write while I'm at it. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-03-27Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/rndis_host.c drivers/net/wireless/b43/dma.c net/ipv6/ndisc.c
2008-03-27[NETFILTER]: Replate direct proc_fops assignment with proc_create call.Denis V. Lunev
This elliminates infamous race during module loading when one could lookup proc entry without proc_fops assigned. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-29[NETFILTER/RXRPC]: Don't use seq_release_private where inappropriate.Pavel Emelyanov
Some netfilter code and rxrpc one use seq_open() to open a proc file, but seq_release_private to release one. This is harmless, but ambiguous. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: nf_conntrack: fix sparse warningPatrick McHardy
Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: nf_conntrack: annotate l3protos with constJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: nf_conntrack: naming unificationPatrick McHardy
Rename all "conntrack" variables to "ct" for more consistency and avoiding some overly long lines. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: nf_conntrack: use RCU for conntrack hashPatrick McHardy
2008-01-31[NETFILTER]: conntrack: get rid of sparse warningsStephen Hemminger
Teach sparse about locking here, and fix signed/unsigned warnings. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nf_conntrack: make print_conntrack function optional for l4protosPatrick McHardy
Allows to remove five empty implementations. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nf_conntrack: remove print_conntrack function from l3protosPatrick McHardy
Its unused and unlikely to ever be used. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Switch to using ctl_paths in nf_queue and conntrack modulesPavel Emelyanov
This includes the most simple cases for netfilter. The first part is tne queue modules for ipv4 and ipv6, on which the net/ipv4/ and net/ipv6/ paths are reused from the appropriate ipv4 and ipv6 code. The conntrack module is also patched, but this hunk is very small and simple. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETFILTER]: Make netfilter code use the seq_open_privatePavel Emelyanov
Just switch to the consolidated calls. ipt_recent() has to initialize the private, so use the __seq_open_private() helper. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-19Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (25 commits) [TG3]: Fix msi issue with kexec/kdump. [NET] XFRM: Fix whitespace errors. [NET] TIPC: Fix whitespace errors. [NET] SUNRPC: Fix whitespace errors. [NET] SCTP: Fix whitespace errors. [NET] RXRPC: Fix whitespace errors. [NET] ROSE: Fix whitespace errors. [NET] RFKILL: Fix whitespace errors. [NET] PACKET: Fix whitespace errors. [NET] NETROM: Fix whitespace errors. [NET] NETFILTER: Fix whitespace errors. [NET] IPV4: Fix whitespace errors. [NET] DCCP: Fix whitespace errors. [NET] CORE: Fix whitespace errors. [NET] BLUETOOTH: Fix whitespace errors. [NET] AX25: Fix whitespace errors. [PATCH] mac80211: remove rtnl locking in ieee80211_sta.c [PATCH] mac80211: fix GCC warning on 64bit platforms [GENETLINK]: Dynamic multicast groups. [NETLIKN]: Allow removing multicast groups. ...
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19[NET] NETFILTER: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-07-10[NET]: Make all initialized struct seq_operations const.Philippe De Muyter
Make all initialized struct seq_operations in net/ const Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: Convert DEBUGP to pr_debugPatrick McHardy
Convert DEBUGP to pr_debug and fix lots of non-compiling debug statements. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: nf_conntrack_expect: introduce nf_conntrack_expect_max sysctPatrick McHardy
As a last step of preventing DoS by creating lots of expectations, this patch introduces a global maximum and a sysctl to control it. The default is initialized to 4 * the expectation hash table size, which results in 1/64 of the default maxmimum of conntracks. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: nf_conntrack: move expectaton related init code to ↵Patrick McHardy
nf_conntrack_expect.c Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: nf_conntrack: use hlists for conntrack hashPatrick McHardy
Convert conntrack hash to hlists to reduce its size and cache footprint. Since the default hashsize to max. entries ratio sucks (1:16), this patch doesn't reduce the amount of memory used for the hash by default, but instead uses a better ratio of 1:8, which results in the same max. entries value. One thing worth noting is early_drop. It really should use LRU, so it now has to iterate over the entire chain to find the last unconfirmed entry. Since chains shouldn't be very long and the entire operation is very rare this shouldn't be a problem. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: Remove changelogs and CVS IDsPatrick McHardy
2007-02-14[PATCH] sysctl: remove insert_at_head from register_sysctlEric W. Biederman
The semantic effect of insert_at_head is that it would allow new registered sysctl entries to override existing sysctl entries of the same name. Which is pain for caching and the proc interface never implemented. I have done an audit and discovered that none of the current users of register_sysctl care as (excpet for directories) they do not register duplicate sysctl entries. So this patch simply removes the support for overriding existing entries in the sys_sysctl interface since no one uses it or cares and it makes future enhancments harder. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Howells <dhowells@redhat.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Andi Kleen <ak@muc.de> Cc: Jens Axboe <axboe@kernel.dk> Cc: Corey Minyard <minyard@acm.org> Cc: Neil Brown <neilb@suse.de> Cc: "John W. Linville" <linville@tuxdriver.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Jan Kara <jack@ucw.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: David Chinner <dgc@sgi.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[NETFILTER]: Fix whitespace errorsYOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 8Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-02[NETFILTER]: nf_conntrack: EXPORT_SYMBOL cleanupPatrick McHardy
- move EXPORT_SYMBOL next to exported symbol - use EXPORT_SYMBOL_GPL since this is what the original code used Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: Add NAT support for nf_conntrackJozsef Kadlecsik
Add NAT support for nf_conntrack. Joint work of Jozsef Kadlecsik, Yasuyuki Kozakai, Martin Josefsson and myself. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[NETFILTER]: conntrack: add '_get' to {ip, nf}_conntrack_expect_findYasuyuki Kozakai
We usually uses 'xxx_find_get' for function which increments reference count. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: nf_conntrack: /proc compatibility with old connection trackingPatrick McHardy
This patch adds /proc/net/ip_conntrack, /proc/net/ip_conntrack_expect and /proc/net/stat/ip_conntrack files to keep old programs using them working. The /proc/net/ip_conntrack and /proc/net/ip_conntrack_expect files show only IPv4 entries, the /proc/net/stat/ip_conntrack shows global statistics. Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: nf_conntrack: move conntrack protocol sysctls to individual modulesPatrick McHardy
2006-12-02[NETFILTER]: nf_conntrack: move extern declaration to header filesPatrick McHardy
Using extern in a C file is a bad idea because the compiler can't catch type errors. Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: nf_conntrack: remove ASSERT_{READ,WRITE}_LOCKMartin Josefsson
Remove the usage of ASSERT_READ_LOCK/ASSERT_WRITE_LOCK in nf_conntrack, it didn't do anything, it was just an empty define and it uglified the code. Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se> Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: nf_conntrack: rename struct nf_conntrack_protocolMartin Josefsson
Rename 'struct nf_conntrack_protocol' to 'struct nf_conntrack_l4proto' in order to help distinguish it from 'struct nf_conntrack_l3proto'. It gets rather confusing with 'nf_conntrack_protocol'. Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se> Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: nf_conntrack: split out protocol handlingMartin Josefsson
This patch splits out L3/L4 protocol handling into its own file nf_conntrack_proto.c Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se> Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: nf_conntrack: split out the event cacheMartin Josefsson
This patch splits out the event cache into its own file nf_conntrack_ecache.c Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se> Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-12-02[NETFILTER]: nf_conntrack: split out expectation handlingMartin Josefsson
This patch splits out expectation handling into its own file nf_conntrack_expect.c Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se> Signed-off-by: Patrick McHardy <kaber@trash.net>
2006-09-22[NETFILTER]: kill listhelp.hPatrick McHardy
Kill listhelp.h and use the list.h functions instead. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETFILTER]: Change tunables to __read_mostlyBrian Haley
Change some netfilter tunables to __read_mostly. Also fixed some incorrect file reference comments while I was in there. (this will be my last __read_mostly patch unless someone points out something else that needs it) Signed-off-by: Brian Haley <brian.haley@hp.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-07-24[NETFILTER]: conntrack: fix SYSCTL=n compileAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[SECMARK]: Add secmark support to conntrackJames Morris
Add a secmark field to IP and NF conntracks, so that security markings on packets can be copied to their associated connections, and also copied back to packets as required. This is similar to the network mark field currently used with conntrack, although it is intended for enforcement of security policy rather than network policy. Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[NETFILTER]: conntrack: add sysctl to disable checksummingPatrick McHardy
2006-04-09[NETFILTER]: Fix section mismatch warningsPatrick McHardy
Fix section mismatch warnings caused by netfilter's init_or_cleanup functions used in many places by splitting the init from the cleanup parts. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-28[NETFILTER]: Rename init functions.Andrew Morton
Every netfilter module uses `init' for its module_init() function and `fini' or `cleanup' for its module_exit() function. Problem is, this creates uninformative initcall_debug output and makes ctags rather useless. So go through and rename them all to $(filename)_init and $(filename)_fini. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-22[NETFILTER]: nf_conntrack: support for layer 3 protocol load on demandPablo Neira Ayuso
x_tables matches and targets that require nf_conntrack_ipv[4|6] to work don't have enough information to load on demand these modules. This patch introduces the following changes to solve this issue: o nf_ct_l3proto_try_module_get: try to load the layer 3 connection tracker module and increases the refcount. o nf_ct_l3proto_module put: drop the refcount of the module. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NETFILTER] nf_conntrack: clean up to reduce size of 'struct nf_conn'Harald Welte
This patch moves all helper related data fields of 'struct nf_conn' into a separate structure 'struct nf_conn_help'. This new structure is only present in conntrack entries for which we actually have a helper loaded. Also, this patch cleans up the nf_conntrack 'features' mechanism to resemble what the original idea was: Just glue the feature-specific data structures at the end of 'struct nf_conn', and explicitly re-calculate the pointer to it when needed rather than keeping pointers around. Saves 20 bytes per conntrack on my x86_64 box. A non-helped conntrack is 276 bytes. We still need to save another 20 bytes in order to fit into to target of 256bytes. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-12[NETFILTER] x_tables: Abstraction layer for {ip,ip6,arp}_tablesHarald Welte
This monster-patch tries to do the best job for unifying the data structures and backend interfaces for the three evil clones ip_tables, ip6_tables and arp_tables. In an ideal world we would never have allowed this kind of copy+paste programming... but well, our world isn't (yet?) ideal. o introduce a new x_tables module o {ip,arp,ip6}_tables depend on this x_tables module o registration functions for tables, matches and targets are only wrappers around x_tables provided functions o all matches/targets that are used from ip_tables and ip6_tables are now implemented as xt_FOOBAR.c files and provide module aliases to ipt_FOOBAR and ip6t_FOOBAR o header files for xt_matches are in include/linux/netfilter/, include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers around the xt_FOOBAR.h headers Based on this patchset we're going to further unify the code, gradually getting rid of all the layer 3 specific assumptions. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
