path: root/net/netfilter/nf_conntrack_timestamp.c
2012-04-20net: Convert all sysctl registrations to register_net_sysctlEric W. Biederman
This results in code with less boiler plate that is a bit easier to read. Additionally stops us from using compatibility code in the sysctl core, hastening the day when the compatibility code can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-19module_param: make bool parameters really bool (net & drivers/net)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. (Thanks to Joe Perches for suggesting coccinelle for 0/1 -> true/false). Cc: "David S. Miller" <davem@davemloft.net> Cc: netdev@vger.kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-19netfilter: nf_conntrack_tstamp: add flow-based timestamp extensionPablo Neira Ayuso
This patch adds flow-based timestamping for conntracks. This conntrack extension is disabled by default. Basically, we use two 64-bits variables to store the creation timestamp once the conntrack has been confirmed and the other to store the deletion time. This extension is disabled by default, to enable it, you have to: echo 1 > /proc/sys/net/netfilter/nf_conntrack_timestamp This patch allows to save memory for user-space flow-based loogers such as ulogd2. In short, ulogd2 does not need to keep a hashtable with the conntrack in user-space to know when they were created and destroyed, instead we use the kernel timestamp. If we want to have a sane IPFIX implementation in user-space, this nanosecs resolution timestamps are also useful. Other custom user-space applications can benefit from this via libnetfilter_conntrack. This patch modifies the /proc output to display the delta time in seconds since the flow start. You can also obtain the flow-start date by means of the conntrack-tools. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
