commit c58d6c93680f28ac58984af61d0a7ebf4319c241 upstream.
If nlh->nlmsg_len is zero then an infinite loop is triggered because
'skb_pull(skb, msglen);' pulls zero bytes.
The calculation in nlmsg_len() underflows if 'nlh->nlmsg_len <
NLMSG_HDRLEN' which bypasses the length validation and will later
trigger an out-of-bound read.
If the length validation does fail then the malformed batch message is
copied back to userspace. However, we cannot do this because the
nlh->nlmsg_len can be invalid. This leads to an out-of-bounds read in
netlink_ack:
[ 41.455421] ==================================================================
[ 41.456431] BUG: KASAN: slab-out-of-bounds in memcpy+0x1d/0x40 at addr ffff880119e79340
[ 41.456431] Read of size 4294967280 by task a.out/987
[ 41.456431] =============================================================================
[ 41.456431] BUG kmalloc-512 (Not tainted): kasan: bad access detected
[ 41.456431] -----------------------------------------------------------------------------
[ 41.456431] Bytes b4 ffff880119e79310: 00 00 00 00 d5 03 00 00 b0 fb fe ff 00 00 00 00 ................
[ 41.456431] Object ffff880119e79320: 20 00 00 00 10 00 05 00 00 00 00 00 00 00 00 00 ...............
[ 41.456431] Object ffff880119e79330: 14 00 0a 00 01 03 fc 40 45 56 11 22 33 10 00 05 .......@EV."3...
[ 41.456431] Object ffff880119e79340: f0 ff ff ff 88 99 aa bb 00 14 00 0a 00 06 fe fb ................
^^ start of batch nlmsg with
nlmsg_len=4294967280
[ 41.456431] Memory state around the buggy address:
[ 41.456431] ffff880119e79400: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 41.456431] ffff880119e79480: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
[ 41.456431] >ffff880119e79500: 00 00 00 00 fc fc fc fc fc fc fc fc fc fc fc fc
[ 41.456431] ^
[ 41.456431] ffff880119e79580: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 41.456431] ffff880119e79600: fc fc fc fc fc fc fc fc fc fc fb fb fb fb fb fb
Fix this with better validation of nlh->nlmsg_len and by setting
NFNL_BATCH_FAILURE if any batch message fails length validation.
CAP_NET_ADMIN is required to trigger the bugs.
Fixes: 9ea2aa8b7dba ("netfilter: nfnetlink: validate nfnetlink header from batch")
Signed-off-by: Phil Turnbull <phil.turnbull@oracle.com>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
skbuff clones
If we attach the sk to the skb from nfnetlink_rcv_batch(), then
netlink_skb_destructor() will underflow the socket receive memory
counter and we get warning splat when releasing the socket.
$ cat /proc/net/netlink
sk Eth Pid Groups Rmem Wmem Dump Locks Drops Inode
ffff8800ca903000 12 0 00000000 -54144 0 0 2 0 17942
Rmem above shows an underflow.
And here below the warning splat:
[ 1363.815976] WARNING: CPU: 2 PID: 1356 at net/netlink/af_netlink.c:958 netlink_sock_destruct+0x80/0xb9()
[ 1363.816152] CPU: 2 PID: 1356 Comm: kworker/u16:1 Tainted: G W 4.4.0-rc1+ #153
[ 1363.816155] Hardware name: LENOVO 23259H1/23259H1, BIOS G2ET32WW (1.12 ) 05/30/2012
[ 1363.816160] Workqueue: netns cleanup_net
[ 1363.816163] 0000000000000000 ffff880119203dd0 ffffffff81240204 0000000000000000
[ 1363.816169] ffff880119203e08 ffffffff8104db4b ffffffff813d49a1 ffff8800ca771000
[ 1363.816174] ffffffff81a42b00 0000000000000000 ffff8800c0afe1e0 ffff880119203e18
[ 1363.816179] Call Trace:
[ 1363.816181] <IRQ> [<ffffffff81240204>] dump_stack+0x4e/0x79
[ 1363.816193] [<ffffffff8104db4b>] warn_slowpath_common+0x9a/0xb3
[ 1363.816197] [<ffffffff813d49a1>] ? netlink_sock_destruct+0x80/0xb9
skb->sk was only needed to lookup for the netns, however we don't need
this anymore since 633c9a840d0b ("netfilter: nfnetlink: avoid recurrent
netns lookups in call_batch") so this patch removes this manual socket
assignment to resolve this problem.
Reported-by: Arturo Borrero Gonzalez <arturo.borrero.glez@gmail.com>
Reported-by: Ben Hutchings <ben@decadent.org.uk>
Tested-by: Arturo Borrero Gonzalez <arturo.borrero.glez@gmail.com>
Pass the net pointer to the call_batch callback functions so we can skip
recurrent lookups.
net/netfilter/xt_TEE.c
Pablo Neira Ayuso says:
Netfilter fixes for net
The following patchset contains Netfilter fixes for your net tree,
they are:
1) Fix crash when TEE target is used with no --oif, from Eric Dumazet.
2) Oneliner to fix a crash on the redirect traffic to localhost
infrastructure when interface has not yet an address, from
Munehisa Kamata.
3) Oneliner not to request module all the time from nfnetlink due to
wrong type value, from Florian Westphal.
I'll make sure these patches 1 and 2 hit -stable.
The conflict in net/netfilter/xt_TEE.c was minor, a change
to the 'oif' selection overlapping a function signature
change for the nf_dup_ipv{4,6}() routines.
nfnetlink_bind request_module()s all the time as nfnetlink_get_subsys()
shifts the argument by 8 to obtain the subsys id.
So using type instead of type << 8 always returns NULL.
Fixes: 03292745b02d11 ("netlink: add nlk->netlink_bind hook for module auto-loading")
This patch makes lockdep_nfnl_is_held return bool to improve
readability due to this particular function only using either
one or zero as its return value.
No functional change.
Signed-off-by: Yaowei Bai <bywxiaobai@163.com>
The convention in nfnetlink is to use network byte order in every header field
as well as in the attribute payload. The initial version of the batching
infrastructure assumes that res_id comes in host byte order though.
The only client of the batching infrastructure is nf_tables, so let's add a
workaround to address this inconsistency. We currently have 11 nfnetlink
subsystems according to NFNL_SUBSYS_COUNT, so we can assume that the subsystem
2560, ie. htons(10), will not be allocated anytime soon, so it can be an alias
of nf_tables from the nfnetlink batching path when interpreting the res_id
field.
Based on original patch from Florian Westphal.
Reported-by: Florian Westphal <fw@strlen.de>
After a fresh boot with no modules in place at all and a large rulesets, the
existing nfnetlink_rcv_batch() funcion can take long time to commit the ruleset
due to the many abort path. This is specifically a problem for the existing
client of this code, ie. nf_tables, since it results in several
synchronize_rcu() call in a row.
This patch changes the policy to keep full batch processing on missing modules
errors so we abort only once.
Reported-by: Eric Leblond <eric@regit.org>
netfilter updates for net-next
The following patchset contains netfilter updates for net-next, just a
bunch of cleanups and small enhancement to selectively flush conntracks
in ctnetlink, more specifically the patches are:
1) Rise default number of buckets in conntrack from 16384 to 65536 in
systems with >= 4GBytes, patch from Marcelo Leitner.
2) Small refactor to save one level on indentation in xt_osf, from
Joe Perches.
3) Remove unnecessary sizeof(char) in nf_log, from Fabian Frederick.
4) Another small cleanup to remove redundant variable in nfnetlink,
from Duan Jiong.
5) Fix compilation warning in nfnetlink_cthelper on parisc, from
Chen Gang.
6) Fix wrong format in debugging for ctseqadj, from Gao feng.
7) Selective conntrack flushing through the mark for ctnetlink, patch
from Kristian Evensen.
8) Remove nf_ct_conntrack_flush_report() exported symbol now that is
not required anymore after the selective flushing patch, again from
Kristian.
netfilter/ipvs fixes for net
The following patchset contains netfilter/ipvs fixes, they are:
1) Small fix for the FTP helper in IPVS, a diff variable may be left
unset when CONFIG_IP_VS_IPV6 is set. Patch from Dan Carpenter.
2) Fix nf_tables port NAT in little endian archs, patch from leroy
christophe.
3) Fix race condition between conntrack confirmation and flush from
userspace. This is the second reincarnation to resolve this problem.
4) Make sure inner messages in the batch come with the nfnetlink header.
5) Relax strict check from nfnetlink_bind() that may break old userspace
applications using all 1s group mask.
6) Schedule removal of chains once no sets and rules refer to them in
the new nf_tables ruleset flush command. Reported by Asbjoern Sloth
Toennesen.
Note that this batch comes later than usual because of the short
winter holidays.
Relax the checking that was introduced in 97840cb ("netfilter:
nfnetlink: fix insufficient validation in nfnetlink_bind") when the
subscription bitmask is used. Existing userspace code code may request
to listen to all of the existing netlink groups by setting an all to one
subscription group bitmask. Netlink already validates subscription via
setsockopt() for us.
Make sure there is enough room for the nfnetlink header in the
netlink messages that are part of the batch. There is a similar
check in netlink_rcv_skb().
Actually after netlink_skb_clone() is called, the nskb and
skb will point to the same thing, but they are used just like
they are different, sometimes this is confusing, so i think
there is no necessary to keep nskb anymore.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
Signed-off-by: Pablo Neira Ayuso <pablo@soleta.eu>
Netlink families can exist in multiple namespaces, and for the most
part multicast subscriptions are per network namespace. Thus it only
makes sense to have bind/unbind notifications per network namespace.
To achieve this, pass the network namespace of a given client socket
to the bind/unbind functions.
Also do this in generic netlink, and there also make sure that any
bind for multicast groups that only exist in init_net is rejected.
This isn't really a problem if it is accepted since a client in a
different namespace will never receive any notifications from such
a group, but it can confuse the family if not rejected (it's also
possible to silently (without telling the family) accept it, but it
would also have to be ignored on unbind so families that take any
kind of action on bind/unbind won't do unnecessary work for invalid
clients like that.
Make sure the netlink group exists, otherwise you can trigger an out
of bound array memory access from the netlink_bind() path. This splat
can only be triggered only by superuser.
[ 180.203600] UBSan: Undefined behaviour in ../net/netfilter/nfnetlink.c:467:28
[ 180.204249] index 9 is out of range for type 'int [9]'
[ 180.204697] CPU: 0 PID: 1771 Comm: trinity-main Not tainted 3.18.0-rc4-mm1+ #122
[ 180.205365] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.7.5-0-ge51488c-20140602_164612-nilsson.home.kraxel.org
+04/01/2014
[ 180.206498] 0000000000000018 0000000000000000 0000000000000009 ffff88007bdf7da8
[ 180.207220] ffffffff82b0ef5f 0000000000000092 ffffffff845ae2e0 ffff88007bdf7db8
[ 180.207887] ffffffff8199e489 ffff88007bdf7e18 ffffffff8199ea22 0000003900000000
[ 180.208639] Call Trace:
[ 180.208857] dump_stack (lib/dump_stack.c:52)
[ 180.209370] ubsan_epilogue (lib/ubsan.c:174)
[ 180.209849] __ubsan_handle_out_of_bounds (lib/ubsan.c:400)
[ 180.210512] nfnetlink_bind (net/netfilter/nfnetlink.c:467)
[ 180.210986] netlink_bind (net/netlink/af_netlink.c:1483)
[ 180.211495] SYSC_bind (net/socket.c:1541)
Moreover, define the missing nf_tables and nf_acct multicast groups too.
Reported-by: Andrey Ryabinin <a.ryabinin@samsung.com>
drivers/net/usb/r8152.c
Both r8152 and nfnetlink conflicts were simple overlapping changes.
This allows us to access the original content of the batch from
the commit and the abort paths.
We have to wait until the full batch has been processed to deliver the
netlink error messages to userspace. Otherwise, we may deliver
duplicated errors to userspace in case that we need to abort and replay
the transaction if any of the required modules needs to be autoloaded.
A simple way to reproduce this (assumming nft_meta is not loaded) with
the following test file:
add table filter
add chain filter test
add chain bad test # intentional wrong unexistent table
add rule filter test meta mark 0
Then, when trying to load the batch:
# nft -f test
test:4:1-19: Error: Could not process rule: No such file or directory
add chain bad test
add chain bad test
The error is reported twice, once when the batch is aborted due to
missing nft_meta and another when it is fully processed.
drivers/net/ethernet/altera/altera_sgdma.c
net/sched/cls_api.c
net/sched/sch_api.c
The netlink conflict dealt with moving to netlink_capable() and
netlink_ns_capable() in the 'net' tree vs. supporting 'tc' operations
in non-init namespaces. These were simple transformations from
netlink_capable to netlink_ns_capable.
The Altera driver conflict was simply code removal overlapping some
void pointer cast cleanups in net-next.
This bug manifests when calling the nft command line tool without
nf_tables kernel support.
kernel message:
[ 44.071555] Netfilter messages via NETLINK v0.30.
[ 44.072253] BUG: unable to handle kernel NULL pointer dereference at 0000000000000119
[ 44.072264] IP: [<ffffffff8171db1f>] netlink_getsockbyportid+0xf/0x70
[ 44.072272] PGD 7f2b74067 PUD 7f2b73067 PMD 0
[ 44.072277] Oops: 0000 [#1] SMP
[ 44.072369] Call Trace:
[ 44.072373] [<ffffffff8171fd81>] netlink_unicast+0x91/0x200
[ 44.072377] [<ffffffff817206c9>] netlink_ack+0x99/0x110
[ 44.072381] [<ffffffffa004b951>] nfnetlink_rcv+0x3c1/0x408 [nfnetlink]
[ 44.072385] [<ffffffff8171fde3>] netlink_unicast+0xf3/0x200
[ 44.072389] [<ffffffff817201ef>] netlink_sendmsg+0x2ff/0x740
[ 44.072394] [<ffffffff81044752>] ? __mmdrop+0x62/0x90
[ 44.072398] [<ffffffff816dafdb>] sock_sendmsg+0x8b/0xc0
[ 44.072403] [<ffffffff812f1af5>] ? copy_user_enhanced_fast_string+0x5/0x10
[ 44.072406] [<ffffffff816dbb6c>] ? move_addr_to_kernel+0x2c/0x50
[ 44.072410] [<ffffffff816db423>] ___sys_sendmsg+0x3c3/0x3d0
[ 44.072415] [<ffffffff811301ba>] ? handle_mm_fault+0xa9a/0xc60
[ 44.072420] [<ffffffff811362d6>] ? mmap_region+0x166/0x5a0
[ 44.072424] [<ffffffff817da84c>] ? __do_page_fault+0x1dc/0x510
[ 44.072428] [<ffffffff812b8b2c>] ? apparmor_capable+0x1c/0x60
[ 44.072435] [<ffffffff817d6e9a>] ? _raw_spin_unlock_bh+0x1a/0x20
[ 44.072439] [<ffffffff816dfc86>] ? release_sock+0x106/0x150
[ 44.072443] [<ffffffff816dc212>] __sys_sendmsg+0x42/0x80
[ 44.072446] [<ffffffff816dc262>] SyS_sendmsg+0x12/0x20
[ 44.072450] [<ffffffff817df616>] system_call_fastpath+0x1a/0x1f
Signed-off-by: Denys Fedoryshchenko <nuclearcat@nuclearcat.com>
net/netfilter/nfnetlink.c: In function ‘nfnetlink_rcv’:
net/netfilter/nfnetlink.c:371:14: warning: unused variable ‘net’ [-Wunused-variable]
It is possible by passing a netlink socket to a more privileged
executable and then to fool that executable into writing to the socket
data that happens to be valid netlink message to do something that
privileged executable did not intend to do.
To keep this from happening replace bare capable and ns_capable calls
with netlink_capable, netlink_net_calls and netlink_ns_capable calls.
Which act the same as the previous calls except they verify that the
opener of the socket had the desired permissions as well.
Reported-by: Andy Lutomirski <luto@amacapital.net>
Have the netlink per-protocol optional bind function return an int error code
rather than void to signal a failure.
This will enable netlink protocols to perform extra checks including
capabilities and permissions verifications when updating memberships in
multicast groups.
In netlink_bind() and netlink_setsockopt() the call to the per-protocol bind
function was moved above the multicast group update to prevent any access to
the multicast socket groups before checking with the per-protocol bind
function. This will enable the per-protocol bind function to be used to check
permissions which could be denied before making them available, and to avoid
the messy job of undoing the addition should the per-protocol bind function
fail.
The netfilter subsystem seems to be the only one currently using the
per-protocol bind function.
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Remove duplicity and simplify code flow by moving the rcu_read_unlock() above
the condition and let the flow control exit naturally at the end of the
function.
Add a lockdep_nfnl_is_held() function and a nfnl_dereference() macro for
RCU dereferences protected by a NFNL subsystem mutex.
Commit 0628b123c96d ("netfilter: nfnetlink: add batch support and use it
from nf_tables") introduced a bug leading to various crashes in netlink_ack
when netlink message with invalid nlmsg_len was sent by an unprivileged
user.
Signed-off-by: Jiri Benc <jbenc@redhat.com>
This patch adds a batch support to nfnetlink. Basically, it adds
two new control messages:
* NFNL_MSG_BATCH_BEGIN, that indicates the beginning of a batch,
the nfgenmsg->res_id indicates the nfnetlink subsystem ID.
* NFNL_MSG_BATCH_END, that results in the invocation of the
ss->commit callback function. If not specified or an error
ocurred in the batch, the ss->abort function is invoked
instead.
The end message represents the commit operation in nftables, the
lack of end message results in an abort. This patch also adds the
.call_batch function that is only called from the batch receival
path.
This patch adds atomic rule updates and dumps based on
bitmask generations. This allows to atomically commit a set of
rule-set updates incrementally without altering the internal
state of existing nf_tables expressions/matches/targets.
The idea consists of using a generation cursor of 1 bit and
a bitmask of 2 bits per rule. Assuming the gencursor is 0,
then the genmask (expressed as a bitmask) can be interpreted
as:
00 active in the present, will be active in the next generation.
01 inactive in the present, will be active in the next generation.
10 active in the present, will be deleted in the next generation.
gencursor
Once you invoke the transition to the next generation, the global
gencursor is updated:
01 active in the present, needs to zero its future, it becomes 00.
10 inactive in the present, delete now.
gencursor
If a dump is in progress and nf_tables enters a new generation,
the dump will stop and return -EBUSY to let userspace know that
it has to retry again. In order to invalidate dumps, a global
genctr counter is increased everytime nf_tables enters a new
generation.
This new operation can be used from the user-space utility
that controls the firewall, eg.
nft -f restore
The rule updates contained in `file' will be applied atomically.
cat file
add filter INPUT ip saddr 1.1.1.1 counter accept #1
del filter INPUT ip daddr 2.2.2.2 counter drop #2
-EOF-
Note that the rule 1 will be inactive until the transition to the
next generation, the rule 2 will be evicted in the next generation.
There is a penalty during the rule update due to the branch
misprediction in the packet matching framework. But that should be
quickly resolved once the iteration over the commit list that
contain rules that require updates is finished.
Event notification happens once the rule-set update has been
committed. So we skip notifications is case the rule-set update
is aborted, which can happen in case that the rule-set is tested
to apply correctly.
This patch squashed the following patches from Pablo:
* nf_tables: atomic rule updates and dumps
* nf_tables: get rid of per rule list_head for commits
* nf_tables: use per netns commit list
* nfnetlink: add batch support and use it from nf_tables
* nf_tables: all rule updates are transactional
* nf_tables: attach replacement rule after stale one
* nf_tables: do not allow deletion/replacement of stale rules
* nf_tables: remove unused NFTA_RULE_FLAGS
Get rid of the confusing mix of pid and portid and use portid consistently
for all netlink related socket identities.
Signed-off-by: Hong Zhiguo <honkiko@gmail.com>
Since commit c14b78e7decd0d1d5add6a4604feb8609fe920a9 ("netfilter:
nfnetlink: add mutex per subsystem") building nefnetlink.o without
CONFIG_PROVE_RCU set, triggers this GCC warning:
net/netfilter/nfnetlink.c:65:22: warning: ‘nfnl_get_lock’ defined but not used [-Wunused-function]
The cause of that warning is, in short, that rcu_lockdep_assert()
compiles away if CONFIG_PROVE_RCU is not set. Silence this warning by
open coding nfnl_get_lock() in the sole place it was called, which
allows to remove that function.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
This patch replaces the global lock to one lock per subsystem.
The per-subsystem lock avoids that processes operating
with different subsystems are synchronized.
Allow an unpriviled user who has created a user namespace, and then
created a network namespace to effectively use the new network
namespace, by reducing capable(CAP_NET_ADMIN) and
capable(CAP_NET_RAW) calls to be ns_capable(net->user_ns,
CAP_NET_ADMIN), or capable(net->user_ns, CAP_NET_RAW) calls.
Allow creation of af_key sockets.
Allow creation of llc sockets.
Allow creation of af_packet sockets.
Allow sending xfrm netlink control messages.
Allow binding to netlink multicast groups.
Allow sending to netlink multicast groups.
Allow adding and dropping netlink multicast groups.
Allow sending to all netlink multicast groups and port ids.
Allow reading the netfilter SO_IP_SET socket option.
Allow sending netfilter netlink messages.
Allow setting and getting ip_vs netfilter socket options.
This patch defines netlink_kernel_create as a wrapper function of
__netlink_kernel_create to hide the struct module *me parameter
(which seems to be THIS_MODULE in all existing netlink subsystems).
Suggested by David S. Miller.
nfnetlink_rcv_msg() might call a NULL callback which will cause NULL pointer
dereference.
Signed-off-by: Tomasz Bursztyka <tomasz.bursztyka@linux.intel.com>
This patch adds a hook in the binding path of netlink.
This is used by ctnetlink to allow module autoloading for the case
in which one user executes:
conntrack -E
So far, this resulted in nfnetlink loaded, but not
nf_conntrack_netlink.
I have received in the past many complains on this behaviour.
This patch adds the following structure:
struct netlink_kernel_cfg {
unsigned int groups;
void (*input)(struct sk_buff *skb);
struct mutex *cb_mutex;
That can be passed to netlink_kernel_create to set optional configurations
for netlink kernel sockets.
I've populated this structure by looking for NULL and zero parameters at the
existing code. The remaining parameters that always need to be set are still
left in the original interface.
That includes optional parameters for the netlink socket creation. This allows
easy extensibility of this interface in the future.
This patch also adapts all callers to use this new interface.
Bug added in commit 6b75e3e8d664a9a (netfilter: nfnetlink: add RCU in
nfnetlink_rcv_msg())
Use of "unsigned int" is preferred to bare "unsigned" in net tree.
Remove all #inclusions of asm/system.h preparatory to splitting and killing
it. Performed with the following command:
perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *`
* 'for-linus' of git://selinuxproject.org/~jmorris/linux-security:
capabilities: remove __cap_full_set definition
security: remove the security_netlink_recv hook as it is equivalent to capable()
ptrace: do not audit capability check when outputing /proc/pid/stat
capabilities: remove task_ns_* functions
capabitlies: ns_capable can use the cap helpers rather than lsm call
capabilities: style only - move capable below ns_capable
capabilites: introduce new has_ns_capabilities_noaudit
capabilities: call has_ns_capability from has_capability
capabilities: remove all _real_ interfaces
capabilities: introduce security_capable_noaudit
capabilities: reverse arguments to security_capable
capabilities: remove the task from capable LSM hook entirely
selinux: sparse fix: fix several warnings in the security server cod
selinux: sparse fix: fix warnings in netlink code
selinux: sparse fix: eliminate warnings for selinuxfs
selinux: sparse fix: declare selinux_disable() in security.h
selinux: sparse fix: move selinux_complete_init
selinux: sparse fix: make selinux_secmark_refcount static
SELinux: Fix RCU deref check warning in sel_netport_insert()
Manually fix up a semantic mis-merge wrt security_netlink_recv():
- the interface was removed in commit fd7784615248 ("security: remove
the security_netlink_recv hook as it is equivalent to capable()")
- a new user of it appeared in commit a38f7907b926 ("crypto: Add
userspace configuration API")
causing no automatic merge conflict, but Eric Paris pointed out the
issue.
commit a9b3cd7f32 (rcu: convert uses of rcu_assign_pointer(x, NULL) to
RCU_INIT_POINTER) did a lot of incorrect changes, since it did a
complete conversion of rcu_assign_pointer(x, y) to RCU_INIT_POINTER(x,
y).
We miss needed barriers, even on x86, when y is not NULL.
CC: Stephen Hemminger <shemminger@vyatta.com>
CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Once upon a time netlink was not sync and we had to get the effective
capabilities from the skb that was being received. Today we instead get
the capabilities from the current task. This has rendered the entire
purpose of the hook moot as it is now functionally equivalent to the
capable() call.
Signed-off-by: Eric Paris <eparis@redhat.com>
When assigning a NULL value to an RCU protected pointer, no barrier
is needed. The rcu_assign_pointer, used to handle that but will soon
change to not handle the special case.
Convert all rcu_assign_pointer of NULL value.
//smpl
@@ expression P; @@
- rcu_assign_pointer(P, NULL)
+ RCU_INIT_POINTER(P, NULL)
// </smpl>
Goal of this patch is to permit nfnetlink providers not mandate
nfnl_mutex being held while nfnetlink_rcv_msg() calls them.
If struct nfnl_callback contains a non NULL call_rcu(), then
nfnetlink_rcv_msg() will use it instead of call() field, holding
rcu_read_lock instead of nfnl_mutex
CC: Florian Westphal <fw@strlen.de>
CC: Eric Leblond <eric@regit.org>
Make sure all printk messages have a severity level.
Documentation/feature-removal-schedule.txt
net/ipv6/netfilter/ip6t_REJECT.c
net/netfilter/xt_limit.c
This patch fixes a bug that allows to lose events when reliable
event delivery mode is used, ie. if NETLINK_BROADCAST_SEND_ERROR
and NETLINK_RECV_NO_ENOBUFS socket options are set.
