path: root/net/netfilter/nfnetlink_log.c
2008-03-27[NETFILTER]: Replate direct proc_fops assignment with proc_create call.Denis V. Lunev
This elliminates infamous race during module loading when one could lookup proc entry without proc_fops assigned. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-10[NETFILTER]: nfnetlink_log: fix EPERM when binding/unbinding and instance 0 ↵Patrick McHardy
exists When binding or unbinding to an address family, the res_id is usually set to zero. When logging instance 0 already exists and is owned by a different process, this makes nfunl_recv_config return -EPERM without performing the bind operation. Since no operation on the foreign logging instance itself was requested, this is incorrect. Move bind/unbind commands before the queue instance permissions checks. Also remove an incorrect comment. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-10[NETFILTER]: nfnetlink_log: fix computation of netlink skb sizeEric Leblond
This patch is similar to nfnetlink_queue fixes. It fixes the computation of skb size by using NLMSG_SPACE instead of NLMSG_ALIGN. Signed-off-by: Eric Leblond <eric@inl.fr> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: nfnetlink_log: sparse warning fixesStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: nfnetlink_log: fix typoPatrick McHardy
It should use htonl for the GID, not htons. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nfnetlink_log: include GID in netlink messagePatrick McHardy
Similar to Maciej Soltysiak's ipt_LOG patch, include GID in addition to UID in netlink message. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nfnetlink_log: use endianness-aware attribute functionsPatrick McHardy
2008-01-28[NETFILTER]: nfnetlink_{queue,log}: return proper error codes in instance_createPatrick McHardy
Currently we return EINVAL for "instance exists", "allocation failed" and "module unloaded below us", which is completely inapproriate. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nfnetlink_log: remove excessive debuggingPatrick McHardy
2008-01-28[NETFILTER]: nfnetlink_{queue,log}: return ENOTSUPP for unknown cfg commandsPatrick McHardy
2008-01-28[NETFILTER]: nfnetlink_log: fix checks in nfulnl_recv_configPatrick McHardy
Similar to the nfnetlink_queue fixes: The peer_pid must be checked in all cases when a logging instance exists, additionally we must check whether an instance exists before attempting to configure it to avoid NULL ptr dereferences. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: nf_log: constify struct nf_logger and nf_log_packet loginfo argPatrick McHardy
2008-01-28[NETFILTER]: nf_log: move logging stuff to seperate headerPatrick McHardy
2007-10-10[NETFILTER]: Make netfilter code use the seq_open_privatePavel Emelyanov
Just switch to the consolidated calls. ipt_recent() has to initialize the private, so use the __seq_open_private() helper. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETFILTER]: nfnetlink_log: fix some constantsMichal Miroslaw
Fix timeout (one second is 1 * HZ) and convert max packet copy length to #defined constant. Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETFILTER]: nfnetlink_log: fix instance_create() failure pathMichal Miroslaw
Fix memory leak on instance_create() while module is being unloaded. Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETFILTER]: nfnetlink_log: fix styleMichal Miroslaw
Fix function definition style to match other functions in nfnetlink_log.c. Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETFILTER]: nfnetlink_log: flush queue earlyMichal Miroslaw
If queue is filled to its threshold, then flush it right away instead of waiting for timer or next packet. Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETFILTER]: nfnetlink_log: kill duplicate codeMichal Miroslaw
Kill some cut'n'paste effect. Just after __nfulnl_send() returning, inst->skb is always NULL. Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETFILTER]: nfnetlink_log: use netlink policyPatrick McHardy
Also remove unused nfula_min array. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETFILTER]: nfnetlink: rename functions containing 'nfattr'Patrick McHardy
There is no struct nfattr anymore, rename functions to 'nlattr'. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETFILTER]: nfnetlink: convert to generic netlink attribute functionsPatrick McHardy
Get rid of the duplicated rtnetlink macros and use the generic netlink attribute functions. The old duplicated stuff is moved to a new header file that exists just for userspace. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NETFILTER]: nfnetlink: make subsystem and callbacks constPatrick McHardy
2007-10-10[NET]: Wrap hard_header_parseStephen Hemminger
Wrap the hard_header_parse function to simplify next step of header_ops conversion. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Support multiple network namespaces with netlinkEric W. Biederman
Each netlink socket will live in exactly one network namespace, this includes the controlling kernel sockets. This patch updates all of the existing netlink protocols to only support the initial network namespace. Request by clients in other namespaces will get -ECONREFUSED. As they would if the kernel did not have the support for that netlink protocol compiled in. As each netlink protocol is updated to be multiple network namespace safe it can register multiple kernel sockets to acquire a presence in the rest of the network namespaces. The implementation in af_netlink is a simple filter implementation at hash table insertion and hash table look up time. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-09-20[NETFILTER]: nfnetlink_log: fix sending of multipart messagesEric Leblond
The following patch fixes the handling of netlink packets containing multiple messages. As exposed during netfilter workshop, nfnetlink_log was overwritten the message type of the last message (setting it to MSG_DONE) in a multipart packet. The consequence was libnfnetlink to ignore the last message in the packet. The following patch adds a supplementary message (with type MSG_DONE) af the end of the netlink skb. Signed-off-by: Eric Leblond <eric@inl.fr> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Make all initialized struct seq_operations const.Philippe De Muyter
Make all initialized struct seq_operations in net/ const Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nfnetlink_log: remove fallback to group 0Patrick McHardy
Don't fallback to group 0 if no instance can be found for the given group. This potentially confuses the listener and is not what the user configured. Also remove the ring buffer spamming that happens when rules are set up before the logging daemon is started. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: Use setup_timerPatrick McHardy
2007-04-25[NETFILTER]: nfnetlink_log: remove conditional lockingPatrick McHardy
This is gross, have the wrapper function take the lock. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nfnetlink_log: micro-optimization: inst->skb != NULL in ↵Michal Miroslaw
__nfulnl_send() No other function calls __nfulnl_send() with inst->skb == NULL than nfulnl_timer(). Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nfnetlink_log: iterator functions need iter_state * onlyMichal Miroslaw
get_*() don't need access to seq_file - iter_state is enough for them. Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nfnetlink_log: micro-optimization: don't modify destroyed instanceMichal Miroslaw
Simple micro-optimization: Don't change any options if the instance is being destroyed. Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nfnetlink_log: micro-optimization for inst==NULL in ↵Michal Miroslaw
nfulnl_recv_config() Simple micro-optimization: don't call instance_put() on known NULL pointers. Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nfnetlink_log: kill duplicate codeMichal Miroslaw
Kill some duplicate code in nfulnl_log_packet(). Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: nfnetlink_log: don't count max(a,b) twiceMichal Miroslaw
We don't need local nlbufsiz (skb size) as nfulnl_alloc_skb() takes the maximum anyway. Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: Remove changelogs and CVS IDsPatrick McHardy
2007-04-25[NETLINK]: Remove error pointer from netlink message handlerThomas Graf
The error pointer argument in netlink message handlers is used to signal the special case where processing has to be interrupted because a dump was started but no error happened. Instead it is simpler and more clear to return -EINTR and have netlink_run_queue() deal with getting the queue right. nfnetlink passed on this error pointer to its subsystem handlers but only uses it to signal the start of a netlink dump. Therefore it can be removed there as well. This patch also cleans up the error handling in the affected message handlers to be consistent since it had to be touched anyway. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: convert network timestamps to ktime_tEric Dumazet
We currently use a special structure (struct skb_timeval) and plain 'struct timeval' to store packet timestamps in sk_buffs and struct sock. This has some drawbacks : - Fixed resolution of micro second. - Waste of space on 64bit platforms where sizeof(struct timeval)=16 I suggest using ktime_t that is a nice abstraction of high resolution time services, currently capable of nanosecond resolution. As sizeof(ktime_t) is 8 bytes, using ktime_t in 'struct sock' permits a 8 byte shrink of this structure on 64bit architectures. Some other structures also benefit from this size reduction (struct ipq in ipv4/ip_fragment.c, struct frag_queue in ipv6/reassembly.c, ...) Once this ktime infrastructure adopted, we can more easily provide nanosecond resolution on top of it. (ioctl SIOCGSTAMPNS and/or SO_TIMESTAMPNS/SCM_TIMESTAMPNS) Note : this patch includes a bug correction in compat_sock_get_timestamp() where a "err = 0;" was missing (so this syscall returned -ENOENT instead of 0) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> CC: John find <linux.kernel@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-07[NETFILTER]: nfnetlink_log: fix crash on bridged packetPatrick McHardy
physoutdev is only set on purely bridged packet, when nfnetlink_log is used in the OUTPUT/FORWARD/POSTROUTING hooks on packets forwarded from or to a bridge it crashes when trying to dereference skb->nf_bridge->physoutdev. Reported by Holger Eitzenberger <heitzenberger@astaro.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-07[NETFILTER]: nfnetlink_log: zero-terminate prefixPatrick McHardy
Userspace expects a zero-terminated string, so include the trailing zero in the netlink message. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-05[NETFILTER]: nfnetlink_log: fix reference countingMichal Miroslaw
Fix reference counting (memory leak) problem in __nfulnl_send() and callers related to packet queueing. Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-05[NETFILTER]: nfnetlink_log: fix module reference countingPatrick McHardy
Count module references correctly: after instance_destroy() there might be timer pending and holding a reference for this netlink instance. Based on patch by Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-05[NETFILTER]: nfnetlink_log: fix possible NULL pointer dereferenceMichal Miroslaw
Eliminate possible NULL pointer dereference in nfulnl_recv_config(). Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-05[NETFILTER]: nfnetlink_log: fix NULL pointer dereferenceMichal Miroslaw
Fix the nasty NULL dereference on multiple packets per netlink message. BUG: unable to handle kernel NULL pointer dereference at virtual address 00000004 printing eip: f8a4b3bf *pde = 00000000 Oops: 0002 [#1] SMP Modules linked in: nfnetlink_log ipt_ttl ipt_REDIRECT xt_tcpudp iptable_nat nf_nat nf_conntrack_ipv4 xt_state ipt_ipp2p xt_NFLOG xt_hashlimit ip6_tables iptable_filter xt_multiport xt_mark ipt_set iptable_raw xt_MARK iptable_mangle ip_tables cls_fw cls_u32 sch_esfq sch_htb ip_set_ipmap ip_set ipt_ULOG x_tables dm_snapshot dm_mirror loop e1000 parport_pc parport e100 floppy ide_cd cdrom CPU: 0 EIP: 0060:[<f8a4b3bf>] Not tainted VLI EFLAGS: 00010206 (2.6.20 #5) EIP is at __nfulnl_send+0x24/0x51 [nfnetlink_log] eax: 00000000 ebx: f2b5cbc0 ecx: c03f5f54 edx: c03f4000 esi: f2b5cbc8 edi: c03f5f54 ebp: f8a4b3ec esp: c03f5f30 ds: 007b es: 007b ss: 0068 Process swapper (pid: 0, ti=c03f4000 task=c03bece0 task.ti=c03f4000) Stack: f2b5cbc0 f8a4b401 00000100 c0444080 c012af49 00000000 f6f19100 f6f19000 c1707800 c03f5f54 c03f5f54 00000123 00000021 c03e8d08 c0426380 00000009 c0126932 00000000 00000046 c03e9980 c03e6000 0047b007 c01269bd 00000000 Call Trace: [<f8a4b401>] nfulnl_timer+0x15/0x25 [nfnetlink_log] [<c012af49>] run_timer_softirq+0x10a/0x164 [<c0126932>] __do_softirq+0x60/0xba [<c01269bd>] do_softirq+0x31/0x35 [<c0104f6e>] do_IRQ+0x62/0x74 [<c01036cb>] common_interrupt+0x23/0x28 [<c0101018>] default_idle+0x0/0x3f [<c0101045>] default_idle+0x2d/0x3f [<c01010fa>] cpu_idle+0xa0/0xb9 [<c03fb7f5>] start_kernel+0x1a8/0x1ac [<c03fb293>] unknown_bootoption+0x0/0x181 ======================= Code: 5e 5f 5b 5e 5f 5d c3 53 89 c3 8d 40 1c 83 7b 1c 00 74 05 e8 2c ee 6d c7 83 7b 14 00 75 04 31 c0 eb 34 83 7b 10 01 76 09 8b 43 18 <66> c7 40 04 03 00 8b 53 34 8b 43 14 b9 40 00 00 00 e8 08 9a 84 EIP: [<f8a4b3bf>] __nfulnl_send+0x24/0x51 [nfnetlink_log] SS:ESP 0068:c03f5f30 <0>Kernel panic - not syncing: Fatal exception in interrupt <0>Rebooting in 5 seconds.. Panic no more! Signed-off-by: Micha Mirosaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-05[NETFILTER]: nfnetlink_log: fix use after freeMichal Miroslaw
Paranoia: instance_put() might have freed the inst pointer when we spin_unlock_bh(). Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-05[NETFILTER]: nfnetlink_log: fix reference leakMichal Miroslaw
Stop reference leaking in nfulnl_log_packet(). If we start a timer we are already taking another reference. Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[NETFILTER]: Fix whitespace errorsYOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[NETFILTER]: nf_log: minor cleanupsPatrick McHardy
- rename nf_logging to nf_loggers since its an array of registered loggers - rename nf_log_unregister_logger() to nf_log_unregister() to make it symetrical to nf_log_register() and convert all users Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
