commit ba062ebb2cd561d404e0fba8ee4b3f5ebce7cbfc upstream.
Three attributes are currently not verified, thus can trigger KMSAN
warnings such as :
BUG: KMSAN: uninit-value in __arch_swab32 arch/x86/include/uapi/asm/swab.h:10 [inline]
BUG: KMSAN: uninit-value in __fswab32 include/uapi/linux/swab.h:59 [inline]
BUG: KMSAN: uninit-value in nfqnl_recv_config+0x939/0x17d0 net/netfilter/nfnetlink_queue.c:1268
CPU: 1 PID: 4521 Comm: syz-executor120 Not tainted 4.17.0+ #5
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x185/0x1d0 lib/dump_stack.c:113
kmsan_report+0x188/0x2a0 mm/kmsan/kmsan.c:1117
__msan_warning_32+0x70/0xc0 mm/kmsan/kmsan_instr.c:620
nfnetlink_rcv_msg+0xb2e/0xc80 net/netfilter/nfnetlink.c:212
netlink_rcv_skb+0x37e/0x600 net/netlink/af_netlink.c:2448
nfnetlink_rcv+0x2fe/0x680 net/netfilter/nfnetlink.c:513
netlink_unicast_kernel net/netlink/af_netlink.c:1310 [inline]
netlink_unicast+0x1680/0x1750 net/netlink/af_netlink.c:1336
netlink_sendmsg+0x104f/0x1350 net/netlink/af_netlink.c:1901
sock_sendmsg_nosec net/socket.c:629 [inline]
sock_sendmsg net/socket.c:639 [inline]
___sys_sendmsg+0xec8/0x1320 net/socket.c:2117
__sys_sendmsg net/socket.c:2155 [inline]
__do_sys_sendmsg net/socket.c:2164 [inline]
__se_sys_sendmsg net/socket.c:2162 [inline]
__x64_sys_sendmsg+0x331/0x460 net/socket.c:2162
do_syscall_64+0x15b/0x230 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x43fd59
RSP: 002b:00007ffde0e30d28 EFLAGS: 00000213 ORIG_RAX: 000000000000002e
RAX: ffffffffffffffda RBX: 00000000004002c8 RCX: 000000000043fd59
RDX: 0000000000000000 RSI: 0000000020000080 RDI: 0000000000000003
RBP: 00000000006ca018 R08: 00000000004002c8 R09: 00000000004002c8
R10: 00000000004002c8 R11: 0000000000000213 R12: 0000000000401680
R13: 0000000000401710 R14: 0000000000000000 R15: 0000000000000000
Uninit was created at:
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:279 [inline]
kmsan_internal_poison_shadow+0xb8/0x1b0 mm/kmsan/kmsan.c:189
kmsan_kmalloc+0x94/0x100 mm/kmsan/kmsan.c:315
kmsan_slab_alloc+0x10/0x20 mm/kmsan/kmsan.c:322
slab_post_alloc_hook mm/slab.h:446 [inline]
slab_alloc_node mm/slub.c:2753 [inline]
__kmalloc_node_track_caller+0xb35/0x11b0 mm/slub.c:4395
__kmalloc_reserve net/core/skbuff.c:138 [inline]
__alloc_skb+0x2cb/0x9e0 net/core/skbuff.c:206
alloc_skb include/linux/skbuff.h:988 [inline]
netlink_alloc_large_skb net/netlink/af_netlink.c:1182 [inline]
netlink_sendmsg+0x76e/0x1350 net/netlink/af_netlink.c:1876
Fixes: fdb694a01f1f ("netfilter: Add fail-open support")
Fixes: 829e17a1a602 ("[NETFILTER]: nfnetlink_queue: allow changing queue length through netlink")
Reported-by: syzbot <syzkaller@googlegroups.com>
When skb is queued to userspace it leaves softirq/rcu protection.
skb->nfct (via conntrack extensions such as helper) could then reference
modules that no longer exist if the conntrack was not yet confirmed.
nf_ct_iterate_destroy() will set the DYING bit for unconfirmed
conntracks, we therefore solve this race as follows:
1. take the queue spinlock.
2. check if the conntrack is unconfirmed and has dying bit set.
In this case, we must discard skb while we're still inside
rcu read-side section.
3. If nf_ct_iterate_destroy() is called right after the packet is queued
to userspace, it will be removed from the queue via
nf_ct_iterate_destroy -> nf_queue_nf_hook_drop.
When userspace sends the verdict (nfnetlink takes rcu read lock), there
are two cases to consider:
1. nf_ct_iterate_destroy() was called while packet was out.
In this case, skb will have been removed from the queue already
and no reinject takes place as we won't find a matching entry for the
packet id.
2. nf_ct_iterate_destroy() gets called right after verdict callback
found and removed the skb from queue list.
In this case, skb->nfct is marked as dying but it is still valid.
The skb will be dropped either in nf_conntrack_confirm (we don't
insert DYING conntracks into hash table) or when we try to queue
the skb again, but either events don't occur before the rcu read lock
is dropped.
This patch removes duplicate rcu_read_lock().
1. IPVS part:
According to Julian Anastasov's mention, contexts of ipvs are described
at: http://marc.info/?l=netfilter-devel&m=149562884514072&w=2, in summary:
- packet RX/TX: does not need locks because packets come from hooks.
- sync msg RX: backup server uses RCU locks while registering new
connections.
- ip_vs_ctl.c: configuration get/set, RCU locks needed.
- xt_ipvs.c: It is a netfilter match, running from hook context.
As result, rcu_read_lock and rcu_read_unlock can be removed from:
- ip_vs_core.c: all
- ip_vs_ctl.c:
- only from ip_vs_has_real_service
- ip_vs_ftp.c: all
- ip_vs_proto_sctp.c: all
- ip_vs_proto_tcp.c: all
- ip_vs_proto_udp.c: all
- ip_vs_xmit.c: all (contains only packet processing)
2. Netfilter part:
There are three types of functions that are guaranteed the rcu_read_lock().
First, as result, functions are only called by nf_hook():
- nf_conntrack_broadcast_help(), pptp_expectfn(), set_expected_rtp_rtcp().
- tcpmss_reverse_mtu(), tproxy_laddr4(), tproxy_laddr6().
- match_lookup_rt6(), check_hlist(), hashlimit_mt_common().
- xt_osf_match_packet().
Second, functions that caller already held the rcu_read_lock().
- destroy_conntrack(), ctnetlink_conntrack_event().
- ctnl_timeout_find_get(), nfqnl_nf_hook_drop().
Third, functions that are mixed with type1 and type2.
These functions are called by nf_hook() also these are called by
ordinary functions that already held the rcu_read_lock():
- __ctnetlink_glue_build(), ctnetlink_expect_event().
- ctnetlink_proto_size().
Applied files are below:
- nf_conntrack_broadcast.c, nf_conntrack_core.c, nf_conntrack_netlink.c.
- nf_conntrack_pptp.c, nf_conntrack_sip.c, nfnetlink_cttimeout.c.
- nfnetlink_queue.c, xt_TCPMSS.c, xt_TPROXY.c, xt_addrtype.c.
- xt_connlimit.c, xt_hashlimit.c, xt_osf.c
Detailed calltrace can be found at:
http://marc.info/?l=netfilter-devel&m=149667610710350&w=2
Signed-off-by: Taehee Yoo <ap420073@gmail.com>
Acked-by: Julian Anastasov <ja@ssi.bg>
Pablo Neira Ayuso says:
Netfilter updates for net-next
The following patchset contains Netfilter updates for your net-next
tree. This batch contains connection tracking updates for the cleanup
iteration path, patches from Florian Westphal:
X) Skip unconfirmed conntracks in nf_ct_iterate_cleanup_net(), just set
dying bit to let the CPU release them.
X) Add nf_ct_iterate_destroy() to be used on module removal, to kill
conntrack from all namespace.
X) Restart iteration on hashtable resizing, since both may occur at
the same time.
X) Use the new nf_ct_iterate_destroy() to remove conntrack with NAT
mapping on module removal.
X) Use nf_ct_iterate_destroy() to remove conntrack entries helper
module removal, from Liping Zhang.
X) Use nf_ct_iterate_cleanup_net() to remove the timeout extension
if user requests this, also from Liping.
X) Add net_ns_barrier() and use it from FTP helper, so make sure
no concurrent namespace removal happens at the same time while
the helper module is being removed.
X) Use NFPROTO_MAX in layer 3 conntrack protocol array, to reduce
module size. Same thing in nf_tables.
Updates for the nf_tables infrastructure:
X) Prepare usage of the extended ACK reporting infrastructure for
nf_tables.
X) Remove unnecessary forward declaration in nf_tables hash set.
X) Skip set size estimation if number of element is not specified.
X) Changes to accomodate a (faster) unresizable hash set implementation,
for anonymous sets and dynamic size fixed sets with no timeouts.
X) Faster lookup function for unresizable hash table for 2 and 4
bytes key.
And, finally, a bunch of asorted small updates and cleanups:
X) Do not hold reference to netdev from ipt_CLUSTER, instead subscribe
to device events and look up for index from the packet path, this
is fixing an issue that is present since the very beginning, patch
from Xin Long.
X) Use nf_register_net_hook() in ipt_CLUSTER, from Florian Westphal.
X) Use ebt_invalid_target() whenever possible in the ebtables tree,
from Gao Feng.
X) Calm down compilation warning in nf_dup infrastructure, patch from
stephen hemminger.
X) Statify functions in nftables rt expression, also from stephen.
X) Update Makefile to use canonical method to specify nf_tables-objs.
From Jike Song.
X) Use nf_conntrack_helpers_register() in amanda and H323.
X) Space cleanup for ctnetlink, from linzhang.
Pass down struct netlink_ext_ack as parameter to all of our nfnetlink
subsystem callbacks, so we can work on follow up patches to provide
finer grain error reporting using the new infrastructure that
2d4bc93368f5 ("netlink: extended ACK reporting") provides.
No functional change, just pass down this new object to callbacks.
It seems like a historic accident that these return unsigned char *,
and in many places that means casts are required, more often than not.
Make these functions (skb_put, __skb_put and pskb_put) return void *
and remove all the casts across the tree, adding a (u8 *) cast only
where the unsigned char pointer was used directly, all done with the
following spatch:
expression SKB, LEN;
typedef u8;
identifier fn = { skb_put, __skb_put };
- *(fn(SKB, LEN))
+ *(u8 *)fn(SKB, LEN)
expression E, SKB, LEN;
type T;
- E = ((T *)(fn(SKB, LEN)))
+ E = fn(SKB, LEN)
which actually doesn't cover pskb_put since there are only three
users overall.
A handful of stragglers were converted manually, notably a macro in
drivers/isdn/i4l/isdn_bsdcomp.c and, oddly enough, one of the many
instances in net/bluetooth/hci_sock.c. In the former file, I also
had to fix one whitespace problem spatch introduced.
Netfilter/IPVS updates for net-next
tree. A large bunch of code cleanups, simplify the conntrack extension
codebase, get rid of the fake conntrack object, speed up netns by
selective synchronize_net() calls. More specifically, they are:
1) Check for ct->status bit instead of using nfct_nat() from IPVS and
Netfilter codebase, patch from Florian Westphal.
2) Use kcalloc() wherever possible in the IPVS code, from Varsha Rao.
3) Simplify FTP IPVS helper module registration path, from Arushi Singhal.
4) Introduce nft_is_base_chain() helper function.
5) Enforce expectation limit from userspace conntrack helper,
from Gao Feng.
6) Add nf_ct_remove_expect() helper function, from Gao Feng.
7) NAT mangle helper function return boolean, from Gao Feng.
8) ctnetlink_alloc_expect() should only work for conntrack with
helpers, from Gao Feng.
9) Add nfnl_msg_type() helper function to nfnetlink to build the
netlink message type.
10) Get rid of unnecessary cast on void, from simran singhal.
11) Use seq_puts()/seq_putc() instead of seq_printf() where possible,
also from simran singhal.
12) Use list_prev_entry() from nf_tables, from simran signhal.
13) Remove unnecessary & on pointer function in the Netfilter and IPVS
code.
14) Remove obsolete comment on set of rules per CPU in ip6_tables,
no longer true. From Arushi Singhal.
15) Remove duplicated nf_conntrack_l4proto_udplite4, from Gao Feng.
16) Remove unnecessary nested rcu_read_lock() in
__nf_nat_decode_session(). Code running from hooks are already
guaranteed to run under RCU read side.
17) Remove deadcode in nf_tables_getobj(), from Aaron Conole.
18) Remove double assignment in nf_ct_l4proto_pernet_unregister_one(),
also from Aaron.
19) Get rid of unsed __ip_set_get_netlink(), from Aaron Conole.
20) Don't propagate NF_DROP error to userspace via ctnetlink in
__nf_nat_alloc_null_binding() function, from Gao Feng.
21) Revisit nf_ct_deliver_cached_events() to remove unnecessary checks,
from Gao Feng.
22) Kill the fake untracked conntrack objects, use ctinfo instead to
annotate a conntrack object is untracked, from Florian Westphal.
23) Remove nf_ct_is_untracked(), now obsolete since we have no
conntrack template anymore, from Florian.
24) Add event mask support to nft_ct, also from Florian.
25) Move nf_conn_help structure to
include/net/netfilter/nf_conntrack_helper.h.
26) Add a fixed 32 bytes scratchpad area for conntrack helpers.
Thus, we don't deal with variable conntrack extensions anymore.
Make sure userspace conntrack helper doesn't go over that size.
Remove variable size ct extension infrastructure now this code
got no more clients. From Florian Westphal.
27) Restore offset and length of nf_ct_ext structure to 8 bytes now
that wraparound is not possible any longer, also from Florian.
28) Allow to get rid of unassured flows under stress in conntrack,
this applies to DCCP, SCTP and TCP protocols, from Florian.
29) Shrink size of nf_conntrack_ecache structure, from Florian.
30) Use TCP_MAX_WSCALE instead of hardcoded 14 in TCP tracker,
from Gao Feng.
31) Register SYNPROXY hooks on demand, from Florian Westphal.
32) Use pernet hook whenever possible, instead of global hook
registration, from Florian Westphal.
33) Pass hook structure to ebt_register_table() to consolidate some
infrastructure code, from Florian Westphal.
34) Use consume_skb() and return NF_STOLEN, instead of NF_DROP in the
SYNPROXY code, to make sure device stats are not fooled, patch
from Gao Feng.
35) Remove NF_CT_EXT_F_PREALLOC this kills quite some code that we
don't need anymore if we just select a fixed size instead of
expensive runtime time calculation of this. From Florian.
36) Constify nf_ct_extend_register() and nf_ct_extend_unregister(),
from Florian.
37) Simplify nf_ct_ext_add(), this kills nf_ct_ext_create(), from
Florian.
38) Attach NAT extension on-demand from masquerade and pptp helper
path, from Florian.
39) Get rid of useless ip_vs_set_state_timeout(), from Aaron Conole.
40) Speed up netns by selective calls of synchronize_net(), from
Florian Westphal.
41) Silence stack size warning gcc in 32-bit arch in snmp helper,
from Florian.
42) Inconditionally call nf_ct_ext_destroy(), even if we have no
extensions, to deal with the NF_NAT_MANIP_SRC case. Patch from
Liping Zhang.
nf_unregister_net_hook(s) can avoid a second call to synchronize_net,
provided there is no nfqueue active in that net namespace (which is
the common case).
This also gets rid of the extra arg to nf_queue_nf_hook_drop(), normally
this gets called during netns cleanup so no packets should be queued.
For the rare case of base chain being unregistered or module removal
while nfqueue is in use the extra hiccup due to the packet drops isn't
a big deal.
Pass the new extended ACK reporting struct to all of the generic
netlink parsing functions. For now, pass NULL in almost all callers
(except for some in the core.)
Remove & from function pointers to conform to the style found elsewhere
in the file. Done using the following semantic patch
// <smpl>
@r@
identifier f;
f(...) { ... }
identifier r.f;
- &f
+ f
// </smpl>
Signed-off-by: Arushi Singhal <arushisinghal19971997@gmail.com>
Add and use nfnl_msg_type() function to replace opencoded nfnetlink
message type. I suggested this change, Arushi Singhal made an initial
patch to address this but was missing several spots.
We must call security_release_secctx to free the memory returned by
security_secid_to_secctx, otherwise memory may be leaked forever.
Fixes: ef493bd930ae ("netfilter: nfnetlink_queue: add security context information")
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
ktime is a union because the initial implementation stored the time in
scalar nanoseconds on 64 bit machine and in a endianess optimized timespec
variant for 32bit machines. The Y2038 cleanup removed the timespec variant
and switched everything to scalar nanoseconds. The union remained, but
become completely pointless.
Get rid of the union and just keep ktime_t as simple typedef of type s64.
The conversion was done with coccinelle and some manual mopping up.
Make struct pernet_operations::id unsigned.
There are 2 reasons to do so:
1)
This field is really an index into an zero based array and
thus is unsigned entity. Using negative value is out-of-bound
access by definition.
2)
On x86_64 unsigned 32-bit data which are mixed with pointers
via array indexing or offsets added or subtracted to pointers
are preffered to signed 32-bit data.
"int" being used as an array index needs to be sign-extended
to 64-bit before being used.
void f(long *p, int i)
g(p[i]);
roughly translates to
movsx rsi, esi
mov rdi, [rsi+...]
call g
MOVSX is 3 byte instruction which isn't necessary if the variable is
unsigned because x86_64 is zero extending by default.
Now, there is net_generic() function which, you guessed it right, uses
"int" as an array index:
static inline void *net_generic(const struct net *net, int id)
ptr = ng->ptr[id - 1];
And this function is used a lot, so those sign extensions add up.
Patch snipes ~1730 bytes on allyesconfig kernel (without all junk
messing with code generation):
add/remove: 0/0 grow/shrink: 70/598 up/down: 396/-2126 (-1730)
Unfortunately some functions actually grow bigger.
This is a semmingly random artefact of code generation with register
allocator being used differently. gcc decides that some variable
needs to live in new r8+ registers and every access now requires REX
prefix. Or it is shifted into r12, so [r12+0] addressing mode has to be
used which is longer than [r8]
However, overall balance is in negative direction:
function old new delta
nfsd4_lock 3886 3959 +73
tipc_link_build_proto_msg 1096 1140 +44
mac80211_hwsim_new_radio 2776 2808 +32
tipc_mon_rcv 1032 1058 +26
svcauth_gss_legacy_init 1413 1429 +16
tipc_bcbase_select_primary 379 392 +13
nfsd4_exchange_id 1247 1260 +13
nfsd4_setclientid_confirm 782 793 +11
put_client_renew_locked 494 480 -14
ip_set_sockfn_get 730 716 -14
geneve_sock_add 829 813 -16
nfsd4_sequence_done 721 703 -18
nlmclnt_lookup_host 708 686 -22
nfsd4_lockt 1085 1063 -22
nfs_get_client 1077 1050 -27
tcf_bpf_init 1106 1076 -30
nfsd4_encode_fattr 5997 5930 -67
Total: Before=154856051, After=154854321, chg -0.00%
This field is only useful for nf_queue, so store it in the
nf_queue_entry structure instead, away from the core path. Pass
hook_head to nf_hook_slow().
Since we always have a valid entry on the first iteration in
nf_iterate(), we can use 'do { ... } while (entry)' loop instead.
As the comment indicates, the data at the end of nfqnl_instance struct is
written on every queue/dequeue, so it should reside in its own cacheline.
Before this change, 'lock' was in first cacheline so we dirtied both.
The netfilter hook list never uses the prev pointer, and so can be trimmed to
be a simple singly-linked list.
In addition to having a more light weight structure for hook traversal,
struct net becomes 5568 bytes (down from 6400) and struct net_device becomes
2176 bytes (down from 2240).
Signed-off-by: Aaron Conole <aconole@bytheb.org>
All of the callers of nf_hook_slow already hold the rcu_read_lock, so this
cleanup removes the recursive call. This is just a cleanup, as the locking
code gracefully handles this situation.
There are some codes of netfilter module which did not check the return
value of register_netdevice_notifier. Add the checks now.
Signed-off-by: Gao Feng <fgao@ikuai8.com>
Like NFQNL_MSG_VERDICT_BATCH do, we should also reject the verdict
request when the portid is not same with the initial portid(maybe
from another process).
Fixes: 97d32cf9440d ("netfilter: nfnetlink_queue: batch verdict support")
Signed-off-by: Liping Zhang <liping.zhang@spreadtrum.com>
Reviewed-by: Florian Westphal <fw@strlen.de>
Netfilter fixes for net
The following patchset contains Netfilter fixes for your net tree,
they are:
1) Fix incorrect timestamp in nfnetlink_queue introduced when addressing
y2038 safe timestamp, from Florian Westphal.
2) Get rid of leftover conntrack definition from the previous merge
window, oneliner from Florian.
3) Make nf_queue handler pernet to resolve race on dereferencing the
hook state structure with netns removal, from Eric Biederman.
4) Ensure clean exit on unregistered helper ports, from Taehee Yoo.
5) Restore FLOWI_FLAG_KNOWN_NH in nf_dup_ipv6. This got lost while
generalizing xt_TEE to add packet duplication support in nf_tables,
from Paolo Abeni.
6) Insufficient netlink NFTA_SET_TABLE attribute check in
nf_tables_getset(), from Phil Turnbull.
7) Reject helper registration on duplicated ports via modparams.
Florian Weber reported:
> Under full load (unshare() in loop -> OOM conditions) we can
> get kernel panic:
> BUG: unable to handle kernel NULL pointer dereference at 0000000000000008
> IP: [<ffffffff81476c85>] nfqnl_nf_hook_drop+0x35/0x70
> task: ffff88012dfa3840 ti: ffff88012dffc000 task.ti: ffff88012dffc000
> RIP: 0010:[<ffffffff81476c85>] [<ffffffff81476c85>] nfqnl_nf_hook_drop+0x35/0x70
> RSP: 0000:ffff88012dfffd80 EFLAGS: 00010206
> RAX: 0000000000000008 RBX: ffffffff81add0c0 RCX: ffff88013fd80000
> Call Trace:
> [<ffffffff81474d98>] nf_queue_nf_hook_drop+0x18/0x20
> [<ffffffff814738eb>] nf_unregister_net_hook+0xdb/0x150
> [<ffffffff8147398f>] netfilter_net_exit+0x2f/0x60
> [<ffffffff8141b088>] ops_exit_list.isra.4+0x38/0x60
> [<ffffffff8141b652>] setup_net+0xc2/0x120
> [<ffffffff8141bd09>] copy_net_ns+0x79/0x120
> [<ffffffff8106965b>] create_new_namespaces+0x11b/0x1e0
> [<ffffffff810698a7>] unshare_nsproxy_namespaces+0x57/0xa0
> [<ffffffff8104baa2>] SyS_unshare+0x1b2/0x340
> [<ffffffff81608276>] entry_SYSCALL_64_fastpath+0x1e/0xa8
> Code: 65 00 48 89 e5 41 56 41 55 41 54 53 83 e8 01 48 8b 97 70 12 00 00 48 98 49 89 f4 4c 8b 74 c2 18 4d 8d 6e 08 49 81 c6 88 00 00 00 <49> 8b 5d 00 48 85 db 74 1a 48 89 df 4c 89 e2 48 c7 c6 90 68 47
The simple fix for this requires a new pernet variable for struct
nf_queue that indicates when it is safe to use the dynamically
allocated nf_queue state.
As we need a variable anyway make nf_register_queue_handler and
nf_unregister_queue_handler pernet. This allows the existing logic of
when it is safe to use the state from the nfnetlink_queue module to be
reused with no changes except for making it per net.
The syncrhonize_rcu from nf_unregister_queue_handler is moved to a new
function nfnl_queue_net_exit_batch so that the worst case of having a
syncrhonize_rcu in the pernet exit path is not experienced in batch
mode.
Reported-by: Florian Westphal <fw@strlen.de>
Acked-by: Florian Westphal <fw@strlen.de>
Since 4.4 we erronously use timestamp of the netlink skb (which is zero).
Bugzilla: https://bugzilla.netfilter.org/show_bug.cgi?id=1066
Fixes: b28b1e826f818c30ea7 ("netfilter: nfnetlink_queue: use y2038 safe timestamp")
The following patchset contains the first batch of Netfilter updates for
your net-next tree.
1) Define pr_fmt() in nf_conntrack, from Weongyo Jeong.
2) Define and register netfilter's afinfo for the bridge family,
this comes in preparation for native nfqueue's bridge for nft,
from Stephane Bryant.
3) Add new attributes to store layer 2 and VLAN headers to nfqueue,
also from Stephane Bryant.
4) Parse new NFQA_VLAN and NFQA_L2HDR nfqueue netlink attributes
coming from userspace, from Stephane Bryant.
5) Use net->ipv6.devconf_all->hop_limit instead of hardcoded hop_limit
in IPv6 SYNPROXY, from Liping Zhang.
6) Remove unnecessary check for dst == NULL in nf_reject_ipv6,
from Haishuang Yan.
7) Deinline ctnetlink event report functions, from Florian Westphal.
This makes nf queues use NFQA_VLAN and NFQA_L2HDR in verdict to modify the
original skb
Signed-off-by: Stephane Bryant <stephane.ml.bryant@gmail.com>
to userspace
- This creates 2 netlink attribute NFQA_VLAN and NFQA_L2HDR.
- These are filled up for the PF_BRIDGE family on the way to userspace.
- NFQA_VLAN is a nested attribute, with the NFQA_VLAN_PROTO and the
NFQA_VLAN_TCI carrying the corresponding vlan_proto and vlan_tci
fields from the skb using big endian ordering (and using the CFI
bit as the VLAN_TAG_PRESENT flag in vlan_tci as in the skb)
fails
When netlink unicast fails to deliver the message to userspace, we
should also check if the NFQA_CFG_F_FAIL_OPEN flag is set so we reinject
the packet back to the stack.
I think the user expects no packet drops when this flag is set due to
queueing to userspace errors, no matter if related to the internal queue
or when sending the netlink message to userspace.
The userspace application will still get the ENOBUFS error via recvmsg()
so the user still knows that, with the current configuration that is in
place, the userspace application is not consuming the messages at the
pace that the kernel needs.
Reported-by: "Yigal Reiss (yreiss)" <yreiss@cisco.com>
Tested-by: "Yigal Reiss (yreiss)" <yreiss@cisco.com>
reverts commit 3ab1f683bf8b ("nfnetlink: add support for memory mapped
netlink")'
Like previous commits in the series, remove wrappers that are not needed
after mmapped netlink removal.
NFQA_CFG_F_CONNTRACK config flag
This patch enables to load nf_conntrack_netlink module if
NFQA_CFG_F_CONNTRACK config flag is specified.
Signed-off-by: Ken-ichirou MATSUZAWA <chamas@h4.dion.ne.jp>
This patch stops processing options for unknown command.
This patch stops processing after destroying a queue instance.
Check that dependencies are fulfilled before updating the queue
instance, otherwise we can leave things in intermediate state on errors
in nfqnl_recv_config().
Adapt callsites to avoid recurrent lookup of the netns pointer.
Commit 3bfe049807c2403 ("netfilter: nfnetlink_{log,queue}:
Register pernet in first place") reorganised the initialisation
order of the pernet_subsys to avoid "use-before-initialised"
condition. However, in doing so the cleanup logic in nfnetlink_queue
got botched in that the pernet_subsys wasn't cleaned in case
nfnetlink_subsys_register failed. This patch adds the necessary
cleanup routine call.
Fixes: 3bfe049807c2403 ("netfilter: nfnetlink_{log,queue}: Register pernet in first place")
Signed-off-by: Nikolay Borisov <kernel@kyup.com>
Several ARM default configurations give us warnings on recent
compilers about potentially uninitialized variables in the
nfnetlink code in two functions:
net/netfilter/nfnetlink_queue.c: In function 'nfqnl_build_packet_message':
net/netfilter/nfnetlink_queue.c:519:19: warning: 'nfnl_ct' may be used uninitialized in this function [-Wmaybe-uninitialized]
if (ct && nfnl_ct->build(skb, ct, ctinfo, NFQA_CT, NFQA_CT_INFO) < 0)
Moving the rcu_dereference(nfnl_ct_hook) call outside of the
conditional code avoids the warning without forcing us to
preinitialize the variable.
Fixes: a4b4766c3ceb ("netfilter: nfnetlink_queue: rename related to nfqueue attaching conntrack info")
We don't care if module is being unloaded anymore since hook unregister
handling will destroy queue entries using that hook.
The idea of this series of patch is to attach conntrack information to
nflog like nfqueue has already done. nfqueue conntrack info attaching
basis is generic, rename those names to generic one, glue.
The __build_packet_message function fills a nfulnl_msg_packet_timestamp
structure that uses 64-bit seconds and is therefore y2038 safe, but
it uses an intermediate 'struct timespec' which is not.
This trivially changes the code to use 'struct timespec64' instead,
to correct the result on 32-bit architectures.
This is a copy and paste of Arnd's original patch for nfnetlink_log.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Now that we have integrated the ct glue code into nfnetlink_queue without
introducing dependencies with the conntrack code.
In "9cb0176 netfilter: add glue code to integrate nfnetlink_queue and ctnetlink"
the compilation with NF_CONNTRACK disabled is broken. This patch fixes this
issue.
I have moved the conntrack part into nfnetlink_queue_ct.c to avoid
peppering the entire nfnetlink_queue.c code with ifdefs.
I also needed to rename nfnetlink_queue.c to nfnetlink_queue_pkt.c
to update the net/netfilter/Makefile to support conditional compilation
of the conntrack integration.
This patch also adds CONFIG_NETFILTER_QUEUE_CT in case you want to explicitly
disable the integration between nf_conntrack and nfnetlink_queue.
Reported-by: Andrew Morton <akpm@linux-foundation.org>
User-space programs that receive traffic via NFQUEUE may mangle packets.
If NAT is enabled, this usually puzzles sequence tracking, leading to
traffic disruptions.
With this patch, nfnl_queue will make the corresponding NAT TCP sequence
adjustment if:
1) The packet has been mangled,
2) the NFQA_CFG_F_CONNTRACK flag has been set, and
3) NAT is detected.
There are some records on the Internet complaning about this issue:
http://stackoverflow.com/questions/260757/packet-mangling-utilities-besides-iptables
By now, we only support TCP since we have no helpers for DCCP or SCTP.
Better to add this if we ever have some helper over those layer 4 protocols.
This patch allows you to include the conntrack information together
with the packet that is sent to user-space via NFQUEUE.
Previously, there was no integration between ctnetlink and
nfnetlink_queue. If you wanted to access conntrack information
from your libnetfilter_queue program, you required to query
ctnetlink from user-space to obtain it. Thus, delaying the packet
processing even more.
Including the conntrack information is optional, you can set it
via NFQA_CFG_F_CONNTRACK flag with the new NFQA_CFG_FLAGS attribute.
Implement a new "fail-open" mode where packets are not dropped
upon queue-full condition. This mode can be enabled/disabled per
queue using netlink NFQA_CFG_FLAGS & NFQA_CFG_MASK attributes.
Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com>
Signed-off-by: Vivek Kashyap <vivk@us.ibm.com>
Signed-off-by: Sridhar Samudrala <samudrala@us.ibm.com>
Standardize the net core ratelimited logging functions.
Coalesce formats, align arguments.
Change a printk then vprintk sequence to use printf extension %pV.
These macros contain a hidden goto, and are thus extremely error
prone and make code hard to audit.
A userspace listener may send (bogus) NF_STOLEN verdict, which causes skb leak.
This problem was previously fixed via
64507fdbc29c3a622180378210ecea8659b14e40 (netfilter:
nf_queue: fix NF_STOLEN skb leak) but this had to be reverted because
NF_STOLEN can also be returned by a netfilter hook when iterating the
rules in nf_reinject.
Reject userspace NF_STOLEN verdict, as suggested by Michal Miroslaw.
This is complementary to commit fad54440438a7c231a6ae347738423cbabc936d9
(netfilter: avoid double free in nf_reinject).
Cc: Julian Anastasov <ja@ssi.bg>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
Introduces a new nfnetlink type that applies a given
verdict to all queued packets with an id <= the id in the verdict
message.
If a mark is provided it is applied to all matched packets.
This reduces the number of verdicts that have to be sent.
Applications that make use of this feature need to maintain
a timeout to send a batchverdict periodically to avoid starvation.
Packet identifier is currently setup in nfqnl_build_packet_message(),
using one atomic_inc_return().
Problem is that since several cpus might concurrently call
nfqnl_enqueue_packet() for the same queue, we can deliver packets to
consumer in non monotonic way (packet N+1 being delivered after packet
N)
This patch moves the packet id setup from nfqnl_build_packet_message()
to nfqnl_enqueue_packet() to guarantee correct delivery order.
This also removes one atomic operation.
CC: Florian Westphal <fw@strlen.de>
CC: Pablo Neira Ayuso <pablo@netfilter.org>
CC: Eric Leblond <eric@regit.org>
