After I add the nft rule "nft add rule filter prerouting reject
with tcp reset", kernel panic happened on my system:
NULL pointer dereference at ...
IP: [<ffffffff81b9db2f>] nf_send_reset+0xaf/0x400
Call Trace:
[<ffffffff81b9da80>] ? nf_reject_ip_tcphdr_get+0x160/0x160
[<ffffffffa0928061>] nft_reject_ipv4_eval+0x61/0xb0 [nft_reject_ipv4]
[<ffffffffa08e836a>] nft_do_chain+0x1fa/0x890 [nf_tables]
[<ffffffffa08e8170>] ? __nft_trace_packet+0x170/0x170 [nf_tables]
[<ffffffffa06e0900>] ? nf_ct_invert_tuple+0xb0/0xc0 [nf_conntrack]
[<ffffffffa07224d4>] ? nf_nat_setup_info+0x5d4/0x650 [nf_nat]
Because in the PREROUTING chain, routing information is not exist,
then we will dereference the NULL pointer and oops happen.
So we restrict reject expression to INPUT, FORWARD and OUTPUT chain.
This is consistent with iptables REJECT target.
Signed-off-by: Liping Zhang <liping.zhang@spreadtrum.com>
This is needed so struct net can be pushed down into
ip_route_me_harder.
net_devices
- Add nft_pktinfo.pf to replace ops->pf
- Add nft_pktinfo.hook to replace ops->hooknum
This simplifies the code, makes it more readable, and likely reduces
cache line misses. Maintainability is enhanced as the details of
nft_hook_ops are of no concern to the recpients of nft_pktinfo.
This fixes:
net/netfilter/nft_reject.c: In function ‘nft_reject_dump’:
net/netfilter/nft_reject.c:61:2: warning: enumeration value ‘NFT_REJECT_TCP_RST’ not handled in switch [-Wswitch]
switch (priv->type) {
net/netfilter/nft_reject.c:61:2: warning: enumeration value ‘NFT_REJECT_ICMPX_UNREACH’ not handled in switch [-Wswi\
tch]
net/netfilter/nft_reject_inet.c: In function ‘nft_reject_inet_dump’:
net/netfilter/nft_reject_inet.c:105:2: warning: enumeration value ‘NFT_REJECT_TCP_RST’ not handled in switch [-Wswi\
tch]
Replace the array of registers passed to expressions by a struct nft_regs,
containing the verdict as a seperate member, which aliases to the
NFT_REG_VERDICT register.
This is needed to seperate the verdict from the data registers completely,
so their size can be changed.
tcp resets are never emitted if the packet that triggers the
reject/reset has an invalid checksum.
For icmp error responses there was no such check.
It allows to distinguish icmp response generated via
iptables -I INPUT -p udp --dport 42 -j REJECT
and those emitted by network stack (won't respond if csum is invalid,
REJECT does).
Arguably its possible to avoid this by using conntrack and only
using REJECT with -m conntrack NEW/RELATED.
However, this doesn't work when connection tracking is not in use
or when using nf_conntrack_checksum=0.
Furthermore, sending errors in response to invalid csums doesn't make
much sense so just add similar test as in nf_send_reset.
Validate csum if needed and only send the response if it is ok.
Reference: http://bugzilla.redhat.com/show_bug.cgi?id=1169829
This patch introduces the NFT_REJECT_ICMPX_UNREACH type which provides
an abstraction to the ICMP and ICMPv6 codes that you can use from the
inet and bridge tables, they are:
* NFT_REJECT_ICMPX_NO_ROUTE: no route to host - network unreachable
* NFT_REJECT_ICMPX_PORT_UNREACH: port unreachable
* NFT_REJECT_ICMPX_HOST_UNREACH: host unreachable
* NFT_REJECT_ICMPX_ADMIN_PROHIBITED: administratevely prohibited
You can still use the specific codes when restricting the rule to match
the corresponding layer 3 protocol.
I decided to not overload the existing NFT_REJECT_ICMP_UNREACH to have
different semantics depending on the table family and to allow the user
to specify ICMP family specific codes if they restrict it to the
corresponding family.
For IPv4 packets, we call both IPv4 and IPv6 reject.
Reported-by: Dave Jones <davej@redhat.com>
Add a reject module for NFPROTO_INET. It does nothing but dispatch
to the AF-specific modules based on the hook family.
