Updates the MODULE_DESCRIPTION() tags for all Netfilter modules,
actually describing what the module does and not just
"netfilter XYZ target".
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Introduces the xt_CONNMARK target revision 1. It uses fixed types, and
also uses the more expressive XOR logic. Futhermore, it allows to
selectively pick bits from both the ctmark and the nfmark in the SAVE
and RESTORE operations.
Use %u format specifiers as ->family is unsigned.
Give all Netfilter modules consistent and unique symbol names.
Fix forgotten module release in xt_CONNMARK and xt_CONNSECMARK
When xt_CONNMARK is used outside the mangle table and the user specified
"--restore-mark", the connmark_tg_check() function will (correctly)
error out, but (incorrectly) forgets to release the L3 conntrack module.
Same for xt_CONNSECMARK.
Fix is to move the call to acquire the L3 module after the basic
constraint checks.
Fix the various misspellings of "system", controller", "interrupt" and
"[un]necessary".
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
The patch will add MODULE_ALIAS("ip6t_<modulename>") where missing,
otherwise you will get
ip6tables: No chain/target/match by that name
when xt_<modulename> is not already loaded.
Make a number of variables const and/or remove unneeded casts.
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Switch the return type of target checkentry functions to boolean.
Remove the obsolete IPv4 only connection tracking/NAT as scheduled in
feature-removal-schedule.
Remove unnecessary if() constructs before assignment.
CLUSTERIP, CONNMARK, CONNSECMARK, and connbytes need ip_conntrack or
layer 3 protocol module of nf_conntrack.
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
This patch splits out the event cache into its own file
nf_conntrack_ecache.c
Signed-off-by: Martin Josefsson <gandalf@wlug.westbo.se>
nfmark is being used in various subsystems and has become
the defacto mark field for all kinds of packets. Therefore
it makes sense to rename it to `mark' and remove the
dependency on CONFIG_NETFILTER.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
net/netfilter/xt_CONNMARK.c: In function 'target':
net/netfilter/xt_CONNMARK.c:59: warning: implicit declaration of
function 'nf_conntrack_event_cache'
The warning is due to the following .config:
CONFIG_IP_NF_CONNTRACK=m
CONFIG_IP_NF_CONNTRACK_MARK=y
# CONFIG_IP_NF_CONNTRACK_EVENTS is not set
CONFIG_IP_NF_CONNTRACK_NETLINK=m
This change was introduced by:
http://www.kernel.org/git/?p=linux/kernel/git/davem/net-2.6.19.git;a=commit;h=76e4b41009b8a2e9dd246135cf43c7fe39553aa5
Proposed solution (based on the define in
include/net/netfilter/nf_conntrack_compat.h:
Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org>
Acked-by: Pablo Neira Ayuso <pablo@netfilter.org>
The size is verified by x_tables and isn't needed by the modules anymore.
This patch introduces the mark event. ctnetlink can use this to know if
the mark needs to be dumped.
Every netfilter module uses `init' for its module_init() function and
`fini' or `cleanup' for its module_exit() function.
Problem is, this creates uninformative initcall_debug output and makes
ctags rather useless.
So go through and rename them all to $(filename)_init and
$(filename)_fini.
Set the family field in xt_[matches|targets] registered.
This monster-patch tries to do the best job for unifying the data
structures and backend interfaces for the three evil clones ip_tables,
ip6_tables and arp_tables. In an ideal world we would never have
allowed this kind of copy+paste programming... but well, our world
isn't (yet?) ideal.
o introduce a new x_tables module
o {ip,arp,ip6}_tables depend on this x_tables module
o registration functions for tables, matches and targets are only
wrappers around x_tables provided functions
o all matches/targets that are used from ip_tables and ip6_tables
are now implemented as xt_FOOBAR.c files and provide module aliases
to ipt_FOOBAR and ip6t_FOOBAR
o header files for xt_matches are in include/linux/netfilter/,
include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers
around the xt_FOOBAR.h headers
Based on this patchset we're going to further unify the code,
gradually getting rid of all the layer 3 specific assumptions.
Signed-off-by: Harald Welte <laforge@netfilter.org>
