Updates the MODULE_DESCRIPTION() tags for all Netfilter modules,
actually describing what the module does and not just
"netfilter XYZ target".
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Fix incorrect mask value passed to ipv4_change_dsfield/ipv6_change_dsfield.
This patch changes the behavior of xt_TOS v1 so that the mask value
the user supplies means "zero out these bits" rather than "keep these
bits". This is more easy on the user, as (I would assume) people keep
more bits than zeroing, so, an example:
Action: Set bit 0x01.
before (&): iptables -j TOS --set-tos 0x01/0xFE
after (&~): iptables -j TOS --set-tos 0x01/0x01
This is not too "tragic" with xt_TOS, but where larger fields are used
(e.g. proposed xt_MARK v2), `--set-xmar 0x01/0x01` vs. `--set-xmark
0x01/0xFFFFFFFE` really makes a difference. Other target(!) modules,
such as xt_TPROXY also use &~ rather than &, so let's get to a common
ground.
(Since xt_TOS has not yet left the development tree en direction to
mainline, the semantic can be changed as proposed without breaking
iptables.)
Extends the xt_DSCP target by xt_TOS v1 to add support for selectively
setting and flipping any bit in the IPv4 TOS and IPv6 Priority fields.
(ipt_TOS and xt_DSCP only accepted a limited range of possible
values.)
Merge ipt_TOS into xt_DSCP.
Merge ipt_TOS (tos v0 target) into xt_DSCP. They both modify the same
field in the IPv4 header, so it seems reasonable to keep them in one
piece. This is part two of the implicit 4-patch series to move tos to
xtables and extend it by IPv6.
Give all Netfilter modules consistent and unique symbol names.
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
Now that all callers of netfilter can guarantee that the skb is not shared,
we no longer have to copy the skb in skb_make_writable.
Removes redundant parentheses and braces (And add one pair in a
xt_tcpudp.c macro).
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Switch the return type of target checkentry functions to boolean.
Now the skb->nh union has just one member, .raw, i.e. it is just like the
skb->mac union, strange, no? I'm just leaving it like that till the transport
layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or
->mac_header_offset?), ditto for ->{h,nh}.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
The size is verified by x_tables and isn't needed by the modules anymore.
independent version
This replaces IPv4 DSCP target by address family independent version.
This also
- utilizes dsfield.h to get/mangle DS field in IPv4/IPv6 header
- fixes Kconfig help text.
Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp>
