path: root/net/netfilter/xt_RATEEST.c
2008-04-14[NETFILTER]: annotate xtables targets with const and remove castsJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-01-28[NET_SCHED]: Convert packet schedulers from rtnetlink to new netlink APIPatrick McHardy
Convert packet schedulers to use the netlink API. Unfortunately a gradual conversion is not possible without breaking compilation in the middle or adding lots of casts, so this patch converts them all in one step. The patch has been mostly generated automatically with some minor edits to at least allow seperate conversion of classifiers and actions. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Update modules' descriptionsJan Engelhardt
Updates the MODULE_DESCRIPTION() tags for all Netfilter modules, actually describing what the module does and not just "netfilter XYZ target". Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: x_tables: add RATEEST targetPatrick McHardy
Add new rate estimator target (using gen_estimator). In combination with the rateest match (next patch) this can be used for load-based multipath routing. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
