There are some codes which are used to get one random once in netfilter.
We could use net_get_random_once to simplify these codes.
Signed-off-by: Gao Feng <fgao@ikuai8.com>
As gre does not have the srckey in the packet gre_pkt_to_tuple
needs to perform a lookup in it's per network namespace tables.
Pass in the proper network namespace to all pkt_to_tuple
implementations to ensure gre (and any similar protocols) can get this
right.
devices
This patch replaces the zone id which is pushed down into functions
with the actual zone object. It's a bigger one-time change, but
needed for later on extending zones with a direction parameter, and
thus decoupling this additional information from all call-sites.
No functional changes in this patch.
The default zone becomes a global const object, namely nf_ct_zone_dflt
and will be returned directly in various cases, one being, when there's
f.e. no zoning support.
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Currently all the conntrack lookups are done using default zone.
In case the skb has a ct attached (e.g. template) we should use this zone
for lookups instead. This makes connlimit work with connections assigned
to other zones.
Eric points out that the locks can be global.
Moreover, both Jesper and Eric note that using only 32 locks increases
false sharing as only two cache lines are used.
This increases locks to 256 (16 cache lines assuming 64byte cacheline and
4 bytes per spinlock).
Suggested-by: Jesper Dangaard Brouer <brouer@redhat.com>
Suggested-by: Eric Dumazet <eric.dumazet@gmail.com>
cannot use ARRAY_SIZE() if spinlock_t is empty struct.
Fixes: 1442e7507dd597 ("netfilter: connlimit: use keyed locks")
Reported-by: kbuild test robot <fengguang.wu@intel.com>
With current match design every invocation of the connlimit_match
function means we have to perform (number_of_conntracks % 256) lookups
in the conntrack table [ to perform GC/delete stale entries ].
This is also the reason why ____nf_conntrack_find() in perf top has
> 20% cpu time per core.
This patch changes the storage to rbtree which cuts down the number of
ct objects that need testing.
When looking up a new tuple, we only test the connections of the host
objects we visit while searching for the wanted host/network (or
the leaf we need to insert at).
The slot count is reduced to 32. Increasing slot count doesn't
speed up things much because of rbtree nature.
before patch (50kpps rx, 10kpps tx):
+ 20.95% ksoftirqd/0 [nf_conntrack] [k] ____nf_conntrack_find
+ 20.50% ksoftirqd/1 [nf_conntrack] [k] ____nf_conntrack_find
+ 20.27% ksoftirqd/2 [nf_conntrack] [k] ____nf_conntrack_find
+ 5.76% ksoftirqd/1 [nf_conntrack] [k] hash_conntrack_raw
+ 5.39% ksoftirqd/2 [nf_conntrack] [k] hash_conntrack_raw
+ 5.35% ksoftirqd/0 [nf_conntrack] [k] hash_conntrack_raw
after (90kpps, 51kpps tx):
+ 17.24% swapper [nf_conntrack] [k] ____nf_conntrack_find
+ 6.60% ksoftirqd/2 [nf_conntrack] [k] ____nf_conntrack_find
+ 2.73% swapper [nf_conntrack] [k] hash_conntrack_raw
+ 2.36% swapper [xt_connlimit] [k] count_tree
Obvious disadvantages to previous version are the increase in code
complexity and the increased memory cost.
Partially based on Eric Dumazets fq scheduler.
Reviewed-by: Jesper Dangaard Brouer <brouer@redhat.com>
currently returns 1 if they're the same. Make it work like mem/strcmp
so it can be used as rbtree search function.
connlimit currently suffers from spinlock contention, example for
4-core system with rps enabled:
+ 20.84% ksoftirqd/2 [kernel.kallsyms] [k] _raw_spin_lock_bh
+ 20.76% ksoftirqd/1 [kernel.kallsyms] [k] _raw_spin_lock_bh
+ 20.42% ksoftirqd/0 [kernel.kallsyms] [k] _raw_spin_lock_bh
+ 6.07% ksoftirqd/2 [nf_conntrack] [k] ____nf_conntrack_find
+ 6.07% ksoftirqd/1 [nf_conntrack] [k] ____nf_conntrack_find
+ 5.97% ksoftirqd/0 [nf_conntrack] [k] ____nf_conntrack_find
+ 2.47% ksoftirqd/2 [nf_conntrack] [k] hash_conntrack_raw
+ 2.45% ksoftirqd/0 [nf_conntrack] [k] hash_conntrack_raw
+ 2.44% ksoftirqd/1 [nf_conntrack] [k] hash_conntrack_raw
May allow parallel lookup/insert/delete if the entry is hashed to
another slot. With patch:
+ 2.00% ksoftirqd/1 [kernel.kallsyms] [k] __rcu_read_unlock
Improved rx processing rate from ~35kpps to ~50 kpps.
We might allocate thousands of these (one object per connection).
Use distinct kmem cache to permit simplte tracking on how many
objects are currently used by the connlimit match via the sysfs.
Allows easier code-reuse in followup patches.
Instead of freeing the entry from our list and then adding
it back again in the 'packet to closing connection' case just keep the
matching entry around. Also drop the found_ct != NULL test as
nf_ct_tuplehash_to_ctrack is just container_of().
Simplifies followup patch that introduces separate locks for each of
the hash slots.
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
It was scheduled to be removed.
Cc: Jan Engelhardt <jengelh@medozas.de>
A potential race condition when generating connlimit_rnd is also fixed.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
The header of hlist is smaller than list.
All the members are initialized after kzalloc().
We use the reply tuples when limiting the connections by the destination
addresses, however, in SNAT scenario, the final reply tuples won't be
ready until SNAT is done in POSTROUING or INPUT chain, and the following
nf_conntrack_find_get() in count_tem() will get nothing, so connlimit
can't work as expected.
In this patch, the original tuples are always used, and an additional
member addr is appended to save the address in either end.
This reverts commit 44bd4de9c2270b22c3c898310102bc6be9ed2978.
I have to revert the early loop termination in connlimit since it generates
problems when an iptables statement does not use -m state --state NEW before
the connlimit match extension.
Signed-off-by: Stefan Berger <stefanb@linux.vnet.ibm.com>
The patch below introduces an early termination of the loop that is
counting matches. It terminates once the counter has exceeded the
threshold provided by the user. There's no point in continuing the loop
afterwards and looking at other entries.
It plays together with the following code further below:
return (connections > info->limit) ^ info->inverse;
where connections is the result of the counted connection, which in turn
is the matches variable in the loop. So once
-> matches = info->limit + 1
alias -> matches > info->limit
alias -> matches > threshold
we can terminate the loop.
xt_connlimit normally records the "original" tuples in a hashlist
(such as "1.2.3.4 -> 5.6.7.8"), and looks in this list for iph->daddr
when counting.
When the user however uses DNAT in PREROUTING, looking for
iph->daddr -- which is now 192.168.9.10 -- will not match. Thus in
daddr mode, we need to record the reverse direction tuple
("192.168.9.10 -> 1.2.3.4") instead. In the reverse tuple, the dst
addr is on the src side, which is convenient, as count_them still uses
&conn->tuple.src.u3.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
This adds destination address-based selection. The old "inverse"
member is overloaded (memory-wise) with a new "flags" variable,
similar to how J.Park did it with xt_string rev 1. Since revision 0
userspace only sets flag 0x1, no great changes are made to explicitly
test for different revisions.
Signed-off-by: Richard Weinberger <richard@nod.at>
Since xt_action_param is writable, let's use it. The pointer to
'bool hotdrop' always worried (8 bytes (64-bit) to write 1 byte!).
Surprisingly results in a reduction in size:
text data bss filename
5457066 692730 357892 vmlinux.o-prev
5456554 692730 357892 vmlinux.o
In future, layer-3 matches will be an xt module of their own, and
need to set the fragoff and thoff fields. Adding more pointers would
needlessy increase memory requirements (esp. so for 64-bit, where
pointers are wider).
Documentation/feature-removal-schedule.txt
net/ipv6/netfilter/ip6t_REJECT.c
net/netfilter/xt_limit.c
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
When extended status codes are available, such as ENOMEM on failed
allocations, or subsequent functions (e.g. nf_ct_get_l3proto), passing
them up to userspace seems like a good idea compared to just always
EINVAL.
The following semantic patch does part of the transformation:
// <smpl>
@ rule1 @
struct xt_match ops;
identifier check;
ops.checkentry = check;
identifier rule1.check;
check(...) { <...
-return true;
+return 0;
check(...) { <...
-return false;
+return -EINVAL;
// </smpl>
Restore function signatures from bool to int so that we can report
memory allocation failures or similar using -ENOMEM rather than
always having to pass -EINVAL back.
This semantic patch may not be too precise (checking for functions
that use xt_mtchk_param rather than functions referenced by
xt_match.checkentry), but reviewed, it produced the intended result.
// <smpl>
type bool;
identifier check, par;
-bool check
+int check
(struct xt_mtchk_param *par) { ... }
// </smpl>
Normally, each connection needs a unique identity. Conntrack zones allow
to specify a numerical zone using the CT target, connections in different
zones can use the same identity.
Example:
iptables -t raw -A PREROUTING -i veth0 -j CT --zone 1
iptables -t raw -A OUTPUT -o veth1 -j CT --zone 1
We can initialize the random hash bytes on checkentry. This is
preferable since it is outside the hot path.
Reference: http://bugzilla.netfilter.org/show_bug.cgi?id=621
Commit v2.6.28-rc1~717^2~109^2~2 was slightly incomplete; not all
instances of par->match->family were changed to par->family.
References: http://bugzilla.netfilter.org/show_bug.cgi?id=610
Use "hlist_nulls" infrastructure we added in 2.6.29 for RCUification of UDP & TCP.
This permits an easy conversion from call_rcu() based hash lists to a
SLAB_DESTROY_BY_RCU one.
Avoiding call_rcu() delay at nf_conn freeing time has numerous gains.
First, it doesnt fill RCU queues (up to 10000 elements per cpu).
This reduces OOM possibility, if queued elements are not taken into account
This reduces latency problems when RCU queue size hits hilimit and triggers
emergency mode.
- It allows fast reuse of just freed elements, permitting better use of
CPU cache.
- We delete rcu_head from "struct nf_conn", shrinking size of this structure
by 8 or 16 bytes.
This patch only takes care of "struct nf_conn".
call_rcu() is still used for less critical conntrack parts, that may
be converted later if necessary.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
Using ->family in struct xt_*_param, multiple struct xt_{match,target}
can be squashed together.
This patch does this for match extensions' destroy functions.
This patch does this for match extensions' checkentry functions.
The function signatures for Xtables extensions have grown over time.
It involves a lot of typing/replication, and also a bit of stack space
even if they are not used. Realize an NFWS2008 idea and pack them into
structs. The skb remains outside of the struct so gcc can continue to
apply its optimizations.
This patch does this for match extensions' match functions.
A few ambiguities have also been addressed. The "offset" parameter for
example has been renamed to "fragoff" (there are so many different
offsets already) and "protoff" to "thoff" (there is more than just one
protocol here, so clarify).
* make per-netns conntrack hash
Other solution is to add ->ct_net pointer to tuplehashes and still has one
hash, I tried that it's ugly and requires more code deep down in protocol
modules et al.
* propagate netns pointer to where needed, e. g. to conntrack iterators.
and (try to) consistently use u_int8_t for the L3 family.
ESTABLISHED state
In xt_connlimit match module, the counter of an IP is decreased when
the TCP packet is go through the chain with ip_conntrack state TW.
Well, it's very natural that the server and client close the socket
with FIN packet. But when the client/server close the socket with RST
packet(using so_linger), the counter for this connection still exsit.
The following patch can fix it which is based on linux-2.6.25.4
Signed-off-by: Dong Wei <dwei.zh@gmail.com>
Acked-by: Jan Engelhardt <jengelh@medozas.de>
Add accessors for l3num and protonum and get rid of some overly long
expressions.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
