path: root/net/netfilter/xt_dscp.c
2010-05-11netfilter: xtables: deconstify struct xt_action_param for matchesJan Engelhardt
In future, layer-3 matches will be an xt module of their own, and need to set the fragoff and thoff fields. Adding more pointers would needlessy increase memory requirements (esp. so for 64-bit, where pointers are wider). Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-05-11netfilter: xtables: substitute temporary defines by final nameJan Engelhardt
2010-03-25netfilter: xtables: slightly better error reportingJan Engelhardt
When extended status codes are available, such as ENOMEM on failed allocations, or subsequent functions (e.g. nf_ct_get_l3proto), passing them up to userspace seems like a good idea compared to just always EINVAL. Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-03-25netfilter: xtables: change matches to return error codeJan Engelhardt
The following semantic patch does part of the transformation: // <smpl> @ rule1 @ struct xt_match ops; identifier check; @@ ops.checkentry = check; @@ identifier rule1.check; @@ check(...) { <... -return true; +return 0; ...> } @@ identifier rule1.check; @@ check(...) { <... -return false; +return -EINVAL; ...> } // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-03-25netfilter: xtables: change xt_match.checkentry return typeJan Engelhardt
Restore function signatures from bool to int so that we can report memory allocation failures or similar using -ENOMEM rather than always having to pass -EINVAL back. This semantic patch may not be too precise (checking for functions that use xt_mtchk_param rather than functions referenced by xt_match.checkentry), but reviewed, it produced the intended result. // <smpl> @@ type bool; identifier check, par; @@ -bool check +int check (struct xt_mtchk_param *par) { ... } // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-03-18netfilter: xt extensions: use pr_<level>Jan Engelhardt
2010-03-18netfilter: xtables: make use of caller family rather than match familyJan Engelhardt
The matches can have .family = NFPROTO_UNSPEC, and though that is not the case for the touched modules, it seems better to just use the nfproto from the caller. Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2009-08-10netfilter: xtables: remove xt_TOS v0Jan Engelhardt
Superseded by xt_TOS v1 (v2.6.24-2396-g5c350e5). Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2008-10-08netfilter: xtables: move extension arguments into compound structure (2/6)Jan Engelhardt
This patch does this for match extensions' checkentry functions. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (1/6)Jan Engelhardt
The function signatures for Xtables extensions have grown over time. It involves a lot of typing/replication, and also a bit of stack space even if they are not used. Realize an NFWS2008 idea and pack them into structs. The skb remains outside of the struct so gcc can continue to apply its optimizations. This patch does this for match extensions' match functions. A few ambiguities have also been addressed. The "offset" parameter for example has been renamed to "fragoff" (there are so many different offsets already) and "protoff" to "thoff" (there is more than just one protocol here, so clarify). Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: x_tables: use NFPROTO_* in extensionsJan Engelhardt
2008-01-28[NETFILTER]: Update modules' descriptionsJan Engelhardt
Updates the MODULE_DESCRIPTION() tags for all Netfilter modules, actually describing what the module does and not just "netfilter XYZ target". Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: IPv6 capable xt_tos v1 matchJan Engelhardt
Extends the xt_dscp match by xt_tos v1 to add support for selectively matching any bit in the IPv4 TOS and IPv6 Priority fields. (ipt_tos and xt_dscp only accepted a limited range of possible values.) Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Merge ipt_tos into xt_dscpJan Engelhardt
Merge ipt_tos into xt_dscp. Merge ipt_tos (tos v0 match) into xt_dscp. They both match on the same field in the IPv4 header, so it seems reasonable to keep them in one piece. This is part one of the implicit 4-patch series to move tos to xtables and extend it by IPv6. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: x_tables: consistent and unique symbol namesJan Engelhardt
Give all Netfilter modules consistent and unique symbol names. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: x_tables: mark matches and targets __read_mostlyPatrick McHardy
2007-07-10[NETFILTER]: x_tables: switch xt_match->checkentry to boolJan Engelhardt
Switch the return type of match functions to boolean Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: x_tables: switch xt_match->match to boolJan Engelhardt
2007-07-10[NETFILTER]: x_tables: switch hotdrop to boolJan Engelhardt
Switch the "hotdrop" variables to boolean Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NETFILTER]: Remove changelogs and CVS IDsPatrick McHardy
2007-04-25[SK_BUFF]: Introduce ipv6_hdr(), remove skb->nh.ipv6hArnaldo Carvalho de Melo
Now the skb->nh union has just one member, .raw, i.e. it is just like the skb->mac union, strange, no? I'm just leaving it like that till the transport layer is done with, when we'll rename skb->mac.raw to skb->mac_header (or ->mac_header_offset?), ditto for ->{h,nh}. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce ip_hdr(), remove skb->nh.iphArnaldo Carvalho de Melo
2006-09-22[NETFILTER]: x_tables: remove unused size argument to check/destroy functionsPatrick McHardy
The size is verified by x_tables and isn't needed by the modules anymore. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETFILTER]: x_tables: make use of mass registation helpersPatrick McHardy
2006-09-22[NETFILTER]: x_tables: replace IPv4 dscp match by address family independent ↵Yasuyuki Kozakai
version This replaces IPv4 dscp match by address family independent version. This also - utilizes dsfield.h to get the DS field in IPv4/IPv6 header, and - checks for the DSCP value from user space. - fixes Kconfig help text. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
