path: root/net/netfilter/xt_iprange.c
2011-02-04Merge branch 'master' of ↵David S. Miller
2011-01-28netfilter: xt_iprange: add IPv6 match debug print codeThomas Jacob
Signed-off-by: Thomas Jacob <jacob@internet24.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-01-27netfilter: xt_iprange: typo in IPv4 match debug print codeThomas Jacob
2011-01-24netfilter: xt_iprange: Incorrect xt_iprange boundary check for IPv6Thomas Jacob
iprange_ipv6_sub was substracting 2 unsigned ints and then casting the result to int to find out whether they are lt, eq or gt each other, this doesn't work if the full 32 bits of each part can be used in IPv6 addresses. Patch should remedy that without significant performance penalties. Also number of ntohl calls can be reduced this way (Jozsef Kadlecsik). Signed-off-by: Thomas Jacob <jacob@internet24.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-05-11netfilter: xtables: deconstify struct xt_action_param for matchesJan Engelhardt
In future, layer-3 matches will be an xt module of their own, and need to set the fragoff and thoff fields. Adding more pointers would needlessy increase memory requirements (esp. so for 64-bit, where pointers are wider). Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-05-11netfilter: xtables: substitute temporary defines by final nameJan Engelhardt
2010-03-25netfilter: xt extensions: use pr_<level> (2)Jan Engelhardt
Supplement to 1159683ef48469de71dc26f0ee1a9c30d131cf89. Downgrade the log level to INFO for most checkentry messages as they are, IMO, just an extra information to the -EINVAL code that is returned as part of a parameter "constraint violation". Leave errors to real errors, such as being unable to create a LED trigger. Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2009-08-10netfilter: xtables: remove xt_iprange v0Jan Engelhardt
Superseded by xt_iprange v1 (v2.6.24-2928-g1a50c5a1). Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2008-10-31net: replace NIPQUAD() in net/netfilter/Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-20netfilter: xt_iprange: fix range inversion matchAlexey Dobriyan
Inverted IPv4 v1 and IPv6 v0 matches don't match anything since 2.6.25-rc1! Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (1/6)Jan Engelhardt
The function signatures for Xtables extensions have grown over time. It involves a lot of typing/replication, and also a bit of stack space even if they are not used. Realize an NFWS2008 idea and pack them into structs. The skb remains outside of the struct so gcc can continue to apply its optimizations. This patch does this for match extensions' match functions. A few ambiguities have also been addressed. The "offset" parameter for example has been renamed to "fragoff" (there are so many different offsets already) and "protoff" to "thoff" (there is more than just one protocol here, so clarify). Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: x_tables: use NFPROTO_* in extensionsJan Engelhardt
2008-05-13netfilter: xt_iprange: module aliases for xt_iprangePhil Oester
Using iptables 1.3.8 with kernel 2.6.25, rules which include '-m iprange' don't automatically pull in xt_iprange module. Below patch adds module aliases to fix that. Patch against latest -git, but seems like a good candidate for -stable also. Signed-off-by: Phil Oester <kernel@linuxace.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-19[NETFILTER]: xt_iprange: fix subtraction-based comparisonJan Engelhardt
The host address parts need to be converted to host-endian first before arithmetic makes any sense on them. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-07[NETFILTER]: xt_iprange: add missing #includeJan Engelhardt
2008-02-07[NETFILTER]: xt_iprange: fix typo in address familyPatrick McHardy
The family for iprange_mt4 should be AF_INET, not AF_INET6. Noticed by Jiri Moravec <jim.lkml@gmail.com>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: xt_iprange: fix sparse warningsPatrick McHardy
CHECK net/netfilter/xt_iprange.c net/netfilter/xt_iprange.c:104:19: warning: restricted degrades to integer net/netfilter/xt_iprange.c:104:37: warning: restricted degrades to integer net/netfilter/xt_iprange.c:104:19: warning: restricted degrades to integer net/netfilter/xt_iprange.c:104:37: warning: restricted degrades to integer net/netfilter/xt_iprange.c:104:19: warning: restricted degrades to integer net/netfilter/xt_iprange.c:104:37: warning: restricted degrades to integer net/netfilter/xt_iprange.c:104:19: warning: restricted degrades to integer net/netfilter/xt_iprange.c:104:37: warning: restricted degrades to integer Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: xt_iprange match, revision 1Jan Engelhardt
Adds IPv6 support to xt_iprange, making it possible to match on IPv6 address ranges with ip6tables. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Rename ipt_iprange to xt_iprangeJan Engelhardt
This patch moves ipt_iprange to xt_iprange, in preparation for adding IPv6 support to xt_iprange. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
