path: root/net/netfilter/xt_iprange.c
2008-05-13netfilter: xt_iprange: module aliases for xt_iprangePhil Oester
Using iptables 1.3.8 with kernel 2.6.25, rules which include '-m iprange' don't automatically pull in xt_iprange module. Below patch adds module aliases to fix that. Patch against latest -git, but seems like a good candidate for -stable also. Signed-off-by: Phil Oester <kernel@linuxace.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-19[NETFILTER]: xt_iprange: fix subtraction-based comparisonJan Engelhardt
The host address parts need to be converted to host-endian first before arithmetic makes any sense on them. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-07[NETFILTER]: xt_iprange: add missing #includeJan Engelhardt
2008-02-07[NETFILTER]: xt_iprange: fix typo in address familyPatrick McHardy
The family for iprange_mt4 should be AF_INET, not AF_INET6. Noticed by Jiri Moravec <jim.lkml@gmail.com>. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-31[NETFILTER]: xt_iprange: fix sparse warningsPatrick McHardy
CHECK net/netfilter/xt_iprange.c net/netfilter/xt_iprange.c:104:19: warning: restricted degrades to integer net/netfilter/xt_iprange.c:104:37: warning: restricted degrades to integer net/netfilter/xt_iprange.c:104:19: warning: restricted degrades to integer net/netfilter/xt_iprange.c:104:37: warning: restricted degrades to integer net/netfilter/xt_iprange.c:104:19: warning: restricted degrades to integer net/netfilter/xt_iprange.c:104:37: warning: restricted degrades to integer net/netfilter/xt_iprange.c:104:19: warning: restricted degrades to integer net/netfilter/xt_iprange.c:104:37: warning: restricted degrades to integer Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: xt_iprange match, revision 1Jan Engelhardt
Adds IPv6 support to xt_iprange, making it possible to match on IPv6 address ranges with ip6tables. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Rename ipt_iprange to xt_iprangeJan Engelhardt
This patch moves ipt_iprange to xt_iprange, in preparation for adding IPv6 support to xt_iprange. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
