path: root/net/netfilter/xt_string.c
2010-05-11netfilter: xtables: deconstify struct xt_action_param for matchesJan Engelhardt
In future, layer-3 matches will be an xt module of their own, and need to set the fragoff and thoff fields. Adding more pointers would needlessy increase memory requirements (esp. so for 64-bit, where pointers are wider). Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-05-11netfilter: xtables: substitute temporary defines by final nameJan Engelhardt
2010-04-20Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: Documentation/feature-removal-schedule.txt net/ipv6/netfilter/ip6t_REJECT.c net/netfilter/xt_limit.c Signed-off-by: Patrick McHardy <kaber@trash.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-25netfilter: xtables: remove xt_string revision 0Jan Engelhardt
Superseded by xt_string revision 1 (linux v2.6.26-rc8-1127-g4ad3f26, iptables 1.4.2-rc1). Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-03-25netfilter: xtables: slightly better error reportingJan Engelhardt
When extended status codes are available, such as ENOMEM on failed allocations, or subsequent functions (e.g. nf_ct_get_l3proto), passing them up to userspace seems like a good idea compared to just always EINVAL. Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-03-25netfilter: xtables: change matches to return error codeJan Engelhardt
The following semantic patch does part of the transformation: // <smpl> @ rule1 @ struct xt_match ops; identifier check; @@ ops.checkentry = check; @@ identifier rule1.check; @@ check(...) { <... -return true; +return 0; ...> } @@ identifier rule1.check; @@ check(...) { <... -return false; +return -EINVAL; ...> } // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2010-03-25netfilter: xtables: change xt_match.checkentry return typeJan Engelhardt
Restore function signatures from bool to int so that we can report memory allocation failures or similar using -ENOMEM rather than always having to pass -EINVAL back. This semantic patch may not be too precise (checking for functions that use xt_mtchk_param rather than functions referenced by xt_match.checkentry), but reviewed, it produced the intended result. // <smpl> @@ type bool; identifier check, par; @@ -bool check +int check (struct xt_mtchk_param *par) { ... } // </smpl> Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
2008-10-08netfilter: xtables: move extension arguments into compound structure (3/6)Jan Engelhardt
This patch does this for match extensions' destroy functions. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (2/6)Jan Engelhardt
This patch does this for match extensions' checkentry functions. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: xtables: move extension arguments into compound structure (1/6)Jan Engelhardt
The function signatures for Xtables extensions have grown over time. It involves a lot of typing/replication, and also a bit of stack space even if they are not used. Realize an NFWS2008 idea and pack them into structs. The skb remains outside of the struct so gcc can continue to apply its optimizations. This patch does this for match extensions' match functions. A few ambiguities have also been addressed. The "offset" parameter for example has been renamed to "fragoff" (there are so many different offsets already) and "protoff" to "thoff" (there is more than just one protocol here, so clarify). Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: implement NFPROTO_UNSPEC as a wildcard for extensionsJan Engelhardt
When a match or target is looked up using xt_find_{match,target}, Xtables will also search the NFPROTO_UNSPEC module list. This allows for protocol-independent extensions (like xt_time) to be reused from other components (e.g. arptables, ebtables). Extensions that take different codepaths depending on match->family or target->family of course cannot use NFPROTO_UNSPEC within the registration structure (e.g. xt_pkttype). Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2008-10-08netfilter: x_tables: use NFPROTO_* in extensionsJan Engelhardt
2008-07-08netfilter: fix string extension for case insensitive pattern matchingJoonwoo Park
The flag XT_STRING_FLAG_IGNORECASE indicates case insensitive string matching. netfilter can find cmd.exe, Cmd.exe, cMd.exe and etc easily. A new revision 1 was added, in the meantime invert of xt_string_info was moved into flags as a flag. If revision is 1, The flag XT_STRING_FLAG_INVERT indicates invert matching. Signed-off-by: Joonwoo Park <joonwpark81@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Update modules' descriptionsJan Engelhardt
Updates the MODULE_DESCRIPTION() tags for all Netfilter modules, actually describing what the module does and not just "netfilter XYZ target". Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Parenthesize macro parametersJan Engelhardt
Parenthesize macro parameters. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: x_tables: consistent and unique symbol namesJan Engelhardt
Give all Netfilter modules consistent and unique symbol names. Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: x_tables: mark matches and targets __read_mostlyPatrick McHardy
2007-07-10[NETFILTER]: x_tables: switch xt_match->checkentry to boolJan Engelhardt
Switch the return type of match functions to boolean Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NETFILTER]: x_tables: switch xt_match->match to boolJan Engelhardt
2007-07-10[NETFILTER]: x_tables: switch hotdrop to boolJan Engelhardt
Switch the "hotdrop" variables to boolean Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[NETFILTER]: Fix whitespace errorsYOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETFILTER]: x_tables: remove unused size argument to check/destroy functionsPatrick McHardy
The size is verified by x_tables and isn't needed by the modules anymore. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NETFILTER]: x_tables: make use of mass registation helpersPatrick McHardy
2006-08-13[NETFILTER]: xt_string: fix negationPhil Oester
The xt_string match is broken with ! negation. This resolves a portion of netfilter bugzilla #497. Signed-off-by: Phil Oester <kernel@linuxace.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-08-02[NETFILTER]: xt_hashlimit/xt_string: missing string validationPatrick McHardy
The hashlimit table name and the textsearch algorithm need to be terminated, the textsearch pattern length must not exceed the maximum size. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-17[NETFILTER]: x_tables: remove some unnecessary castsPatrick McHardy
2006-03-28[NETFILTER]: Rename init functions.Andrew Morton
Every netfilter module uses `init' for its module_init() function and `fini' or `cleanup' for its module_exit() function. Problem is, this creates uninformative initcall_debug output and makes ctags rather useless. So go through and rename them all to $(filename)_init and $(filename)_fini. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-22[NETFILTER]: x_tables: set the protocol family in x_tables targets/matchesPablo Neira Ayuso
Set the family field in xt_[matches|targets] registered. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-20[NETFILTER]: x_tables: add xt_{match,target} arguments to match/target functionsPatrick McHardy
2006-03-20[NETFILTER]: Convert x_tables matches/targets to centralized error checkingPatrick McHardy
2006-01-12[NETFILTER] x_tables: Abstraction layer for {ip,ip6,arp}_tablesHarald Welte
This monster-patch tries to do the best job for unifying the data structures and backend interfaces for the three evil clones ip_tables, ip6_tables and arp_tables. In an ideal world we would never have allowed this kind of copy+paste programming... but well, our world isn't (yet?) ideal. o introduce a new x_tables module o {ip,arp,ip6}_tables depend on this x_tables module o registration functions for tables, matches and targets are only wrappers around x_tables provided functions o all matches/targets that are used from ip_tables and ip6_tables are now implemented as xt_FOOBAR.c files and provide module aliases to ipt_FOOBAR and ip6t_FOOBAR o header files for xt_matches are in include/linux/netfilter/, include/linux/netfilter_{ipv4,ipv6} contains compatibility wrappers around the xt_FOOBAR.h headers Based on this patchset we're going to further unify the code, gradually getting rid of all the layer 3 specific assumptions. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
