Fix the various misspellings of "system", controller", "interrupt" and
"[un]necessary".
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
remove asm/bitops.h includes
including asm/bitops directly may cause compile errors. don't include it
and include linux/bitops instead. next patch will deny including asm header
directly.
Cc: Adrian Bunk <bunk@kernel.org>
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
* 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (51 commits)
[IPV6]: Fix again the fl6_sock_lookup() fixed locking
[NETFILTER]: nf_conntrack_tcp: fix connection reopening fix
[IPV6]: Fix race in ipv6_flowlabel_opt() when inserting two labels
[IPV6]: Lost locking in fl6_sock_lookup
[IPV6]: Lost locking when inserting a flowlabel in ipv6_fl_list
[NETFILTER]: xt_sctp: fix mistake to pass a pointer where array is required
[NET]: Fix OOPS due to missing check in dev_parse_header().
[TCP]: Remove lost_retrans zero seqno special cases
[NET]: fix carrier-on bug?
[NET]: Fix uninitialised variable in ip_frag_reasm()
[IPSEC]: Rename mode to outer_mode and add inner_mode
[IPSEC]: Disallow combinations of RO and AH/ESP/IPCOMP
[IPSEC]: Use the top IPv4 route's peer instead of the bottom
[IPSEC]: Store afinfo pointer in xfrm_mode
[IPSEC]: Add missing BEET checks
[IPSEC]: Move type and mode map into xfrm_state.c
[IPSEC]: Fix length check in xfrm_parse_spi
[IPSEC]: Move ip_summed zapping out of xfrm6_rcv_spi
[IPSEC]: Get nexthdr from caller in xfrm6_rcv_spi
[IPSEC]: Move tunnel parsing for IPv4 out of xfrm4_input
No one has bothered to set strategy routine for the the netfilter sysctls that
return jiffies to be sysctl_jiffies.
So it appears the sys_sysctl path is unused and untested, so this patch
removes the binary sysctl numbers.
Which fixes the netfilter oops in 2.6.23-rc2-mm2 for me.
Cc: Patrick McHardy <kaber@trash.net>
If one side aborts an established connection, the entry still lingers
for 10s in conntrack for the late packets. Allow to open up the
connection again for the party which sent the RST packet.
Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu>
Tested-by: Krzysztof Piotr Oledzki <ole@ans.pl>
Macros like SCTP_CHUNKMAP_XXX(chukmap) require chukmap to be an array,
but match_packet() passes a pointer to these macros. Also remove the
ELEMCOUNT macro and fix a bug in SCTP_CHUNKMAP_COPY.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
This patch replaces unnecessary uses of skb_copy, pskb_copy and
skb_realloc_headroom by functions such as skb_make_writable and
pskb_expand_head.
This allows us to remove the double pointers later.
Now that all callers of netfilter can guarantee that the skb is not shared,
we no longer have to copy the skb in skb_make_writable.
The patch will add MODULE_ALIAS("ip6t_<modulename>") where missing,
otherwise you will get
ip6tables: No chain/target/match by that name
when xt_<modulename> is not already loaded.
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
With your description I could reproduce the bug and actually you were
completely right: the code above is incorrect. Somehow I was able to
misread RFC1122 and mixed the roles :-(:
When a connection is >>closed actively<<, it MUST linger in
TIME-WAIT state for a time 2xMSL (Maximum Segment Lifetime).
However, it MAY >>accept<< a new SYN from the remote TCP to
reopen the connection directly from TIME-WAIT state, if it:
The fix is as follows: if the receiver initiated an active close, then the
sender may reopen the connection - otherwise try to figure out if we hold
a dead connection.
This patch make processing netlink user -> kernel messages synchronious.
This change was inspired by the talk with Alexey Kuznetsov about current
netlink messages processing. He says that he was badly wrong when introduced
asynchronious user -> kernel communication.
The call netlink_unicast is the only path to send message to the kernel
netlink socket. But, unfortunately, it is also used to send data to the
user.
Before this change the user message has been attached to the socket queue
and sk->sk_data_ready was called. The process has been blocked until all
pending messages were processed. The bad thing is that this processing
may occur in the arbitrary process context.
This patch changes nlk->data_ready callback to get 1 skb and force packet
processing right in the netlink_unicast.
Kernel -> user path in netlink_unicast remains untouched.
EINTR processing for in netlink_run_queue was changed. It forces rtnl_lock
drop, but the process remains in the cycle until the message will be fully
processed. So, there is no need to use this kludges now.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Acked-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru>
The code in netfilter/nfnetlink.c and in ./net/netlink/genetlink.c looks
like outdated copy/paste from rtnetlink.c. Push them into sync with the
original.
Changes from v1:
- deleted comment in nfnetlink_rcv_msg by request of Patrick McHardy
Acked-by: Patrick McHardy <kaber@trash.net>
Just switch to the consolidated calls.
ipt_recent() has to initialize the private, so use
the __seq_open_private() helper.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
This is ipt_time from POM-ng enhanced by the following:
* xtables/ipv6 support
* second granularity for daytime
* day-of-month support (for example "match on the 15th of each month")
* match against UTC or local timezone
Fix timeout (one second is 1 * HZ) and convert max packet copy length
to #defined constant.
Signed-off-by: Michal Miroslaw <mirq-linux@rere.qmqm.pl>
Fix memory leak on instance_create() while module is being unloaded.
Fix function definition style to match other functions in nfnetlink_log.c.
If queue is filled to its threshold, then flush it right away instead
of waiting for timer or next packet.
Kill some cut'n'paste effect.
Just after __nfulnl_send() returning, inst->skb is always NULL.
This patch adds support to relate a connection to an existing master
connection. This patch is used by conntrackd to correctly replicate
related connections.
Similar to the conntrack ID, the per-expectation ID is not needed
anymore, kill it.
Remove the per-conntrack ID, its not necessary anymore for dumping.
For compatiblity reasons we send the address of the conntrack to
userspace as ID.
Also remove unused nfula_min array.
Add support for automatic checking of per-callback attribute policies.
There is no struct nfattr anymore, rename functions to 'nlattr'.
Get rid of the duplicated rtnetlink macros and use the generic netlink
attribute functions. The old duplicated stuff is moved to a new header
file that exists just for userspace.
Wrap the hard_header_parse function to simplify next step of
header_ops conversion.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
I was looking at Patrick's fix to inet_diag and it occured
to me that we're using a pointer argument to return values
unnecessarily in netlink_run_queue. Changing it to return
the value will allow the compiler to generate better code
since the value won't have to be memory-backed.
Until we support multiple network namespaces with netfilter only allow
netfilter configuration in the initial network namespace.
Each netlink socket will live in exactly one network namespace,
this includes the controlling kernel sockets.
This patch updates all of the existing netlink protocols
to only support the initial network namespace. Request
by clients in other namespaces will get -ECONREFUSED.
As they would if the kernel did not have the support for
that netlink protocol compiled in.
As each netlink protocol is updated to be multiple network
namespace safe it can register multiple kernel sockets
to acquire a presence in the rest of the network namespaces.
The implementation in af_netlink is a simple filter implementation
at hash table insertion and hash table look up time.
Every user of the network device notifiers is either a protocol
stack or a pseudo device. If a protocol stack that does not have
support for multiple network namespaces receives an event for a
device that is not in the initial network namespace it quite possibly
can get confused and do the wrong thing.
To avoid problems until all of the protocol stacks are converted
this patch modifies all netdev event handlers to ignore events on
devices that are not in the initial network namespace.
As the rest of the code is made network namespace aware these
checks can be removed.
This patch makes /proc/net per network namespace. It modifies the global
variables proc_net and proc_net_stat to be per network namespace.
The proc_net file helpers are modified to take a network namespace argument,
and all of their callers are fixed to pass &init_net for that argument.
This ensures that all of the /proc/net files are only visible and
usable in the initial network namespace until the code behind them
has been updated to be handle multiple network namespaces.
Making /proc/net per namespace is necessary as at least some files
in /proc/net depend upon the set of network devices which is per
network namespace, and even more files in /proc/net have contents
that are relevant to a single network namespace.
The following patch fixes the handling of netlink packets containing
multiple messages.
As exposed during netfilter workshop, nfnetlink_log was overwritten the
message type of the last message (setting it to MSG_DONE) in a multipart
packet. The consequence was libnfnetlink to ignore the last message in the
packet.
The following patch adds a supplementary message (with type MSG_DONE) af
the end of the netlink skb.
Signed-off-by: Eric Leblond <eric@inl.fr>
So I've had a deadlock reported to me. I've found that the sequence of
events goes like this:
1) process A (modprobe) runs to remove ip_tables.ko
2) process B (iptables-restore) runs and calls setsockopt on a netfilter socket,
increasing the ip_tables socket_ops use count
3) process A acquires a file lock on the file ip_tables.ko, calls remove_module
in the kernel, which in turn executes the ip_tables module cleanup routine,
which calls nf_unregister_sockopt
4) nf_unregister_sockopt, seeing that the use count is non-zero, puts the
calling process into uninterruptible sleep, expecting the process using the
socket option code to wake it up when it exits the kernel
4) the user of the socket option code (process B) in do_ipt_get_ctl, calls
ipt_find_table_lock, which in this case calls request_module to load
ip_tables_nat.ko
5) request_module forks a copy of modprobe (process C) to load the module and
blocks until modprobe exits.
6) Process C. forked by request_module process the dependencies of
ip_tables_nat.ko, of which ip_tables.ko is one.
7) Process C attempts to lock the request module and all its dependencies, it
blocks when it attempts to lock ip_tables.ko (which was previously locked in
step 3)
Theres not really any great permanent solution to this that I can see, but I've
developed a two part solution that corrects the problem
Part 1) Modifies the nf_sockopt registration code so that, instead of using a
use counter internal to the nf_sockopt_ops structure, we instead use a pointer
to the registering modules owner to do module reference counting when nf_sockopt
calls a modules set/get routine. This prevents the deadlock by preventing set 4
from happening.
Part 2) Enhances the modprobe utilty so that by default it preforms non-blocking
remove operations (the same way rmmod does), and add an option to explicity
request blocking operation. So if you select blocking operation in modprobe you
can still cause the above deadlock, but only if you explicity try (and since
root can do any old stupid thing it would like.... :) ).
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
It doesn't seem to have any effect on the x86 architecture but it does
have effect on the Axis CRIS architecture.
Signed-off-by: Jesper Bengtsson <jesper.bengtsson@axis.com>
The userinfo component of a SIP-URI is optional, continue parsing at the
beginning of the SIP-URI in case its not found.
The check got lost during the conversion to nf_conntrack.
An extraneous ";" makes xt_u32 match useless
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
conntracks
ctnetlink must return EEXIST for existing nat'ed conntracks instead of
EINVAL. Only return EINVAL if we try to update a conntrack with NAT
handlings (that is not allowed).
Decadence:libnetfilter_conntrack/utils# ./conntrack_create_nat
TEST: create conntrack (0)(Success)
TEST: create conntrack (-1)(Invalid argument)
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
no real bugs, just misannotations cropping up
This patch cleans up duplicate includes in
net/netfilter/
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
It's C, not C++...
Slab destructors were no longer supported after Christoph's
c59def9f222d44bb7e2f0a559f2906191a0862d7 change. They've been
BUGs for both slab and slub, and slob never supported them
either.
This rips out support for the dtor pointer from kmem_cache_create()
completely and fixes up every single callsite in the kernel (there were
about 224, not including the slab allocator definitions themselves,
or the documentation references).
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
* 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (25 commits)
[TG3]: Fix msi issue with kexec/kdump.
[NET] XFRM: Fix whitespace errors.
[NET] TIPC: Fix whitespace errors.
[NET] SUNRPC: Fix whitespace errors.
[NET] SCTP: Fix whitespace errors.
[NET] RXRPC: Fix whitespace errors.
[NET] ROSE: Fix whitespace errors.
[NET] RFKILL: Fix whitespace errors.
[NET] PACKET: Fix whitespace errors.
[NET] NETROM: Fix whitespace errors.
[NET] NETFILTER: Fix whitespace errors.
[NET] IPV4: Fix whitespace errors.
[NET] DCCP: Fix whitespace errors.
[NET] CORE: Fix whitespace errors.
[NET] BLUETOOTH: Fix whitespace errors.
[NET] AX25: Fix whitespace errors.
[PATCH] mac80211: remove rtnl locking in ieee80211_sta.c
[PATCH] mac80211: fix GCC warning on 64bit platforms
[GENETLINK]: Dynamic multicast groups.
[NETLIKN]: Allow removing multicast groups.
