Pablo Neira Ayuso says:
nf pull request for net
This series contains netfilter fixes for net, they are:
1) Fix lockdep splat in nft_hash when releasing sets from the
rcu_callback context. We don't the mutex there anymore.
2) Remove unnecessary spinlock_bh in the destroy path of the nf_tables
rbtree set type from rcu_callback context.
3) Fix another lockdep splat in rhashtable. None of the callers hold
a mutex when calling rhashtable_destroy.
4) Fix duplicated error reporting from nfnetlink when aborting and
replaying a batch.
5) Fix a Kconfig issue reported by kbuild robot.
CONFIG_IPV6=m
CONFIG_NETFILTER_XT_TARGET_TPROXY=y
net/built-in.o: In function `nf_tproxy_get_sock_v6.constprop.11':
>> xt_TPROXY.c:(.text+0x583a1): undefined reference to `udp6_lib_lookup'
net/built-in.o: In function `tproxy_tg_init':
>> xt_TPROXY.c:(.init.text+0x1dc3): undefined reference to `nf_defrag_ipv6_enable'
This fix is similar to 1a5bbfc ("netfilter: Fix build errors with
xt_socket.c").
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Paul Bolle reports that 'select NETFILTER_XT_NAT' from the IPV4 and IPV6
NAT tables becomes noop since there is no Kconfig switch for it. Add the
Kconfig switch to resolve this problem.
Fixes: 8993cf8 netfilter: move NAT Kconfig switches out of the iptables scope
Reported-by: Paul Bolle <pebolle@tiscali.nl>
We have to wait until the full batch has been processed to deliver the
netlink error messages to userspace. Otherwise, we may deliver
duplicated errors to userspace in case that we need to abort and replay
the transaction if any of the required modules needs to be autoloaded.
A simple way to reproduce this (assumming nft_meta is not loaded) with
the following test file:
add table filter
add chain filter test
add chain bad test # intentional wrong unexistent table
add rule filter test meta mark 0
Then, when trying to load the batch:
# nft -f test
test:4:1-19: Error: Could not process rule: No such file or directory
add chain bad test
add chain bad test
The error is reported twice, once when the batch is aborted due to
missing nft_meta and another when it is fully processed.
The sets are released from the rcu callback, after the rule is removed
from the chain list, which implies that nfnetlink cannot update the
rbtree and no packets are walking on the set anymore. Thus, we can get
rid of the spinlock in the set destroy path there.
Reviewied-by: Thomas Graf <tgraf@suug.ch>
hashes (thus, no resizing may occur) and no packets are walking on the
set anymore.
This resolves a lockdep splat in the nft_hash_destroy() path since the
nfnl mutex is not held there.
[ INFO: suspicious RCU usage. ]
3.16.0-rc2+ #168 Not tainted
net/netfilter/nft_hash.c:362 suspicious rcu_dereference_protected() usage!
rcu_scheduler_active = 1, debug_locks = 1
1 lock held by ksoftirqd/0/3:
#0: (rcu_callback){......}, at: [<ffffffff81096393>] rcu_process_callbacks+0x27e/0x4c7
stack backtrace:
CPU: 0 PID: 3 Comm: ksoftirqd/0 Not tainted 3.16.0-rc2+ #168
Hardware name: LENOVO 23259H1/23259H1, BIOS G2ET32WW (1.12 ) 05/30/2012
0000000000000001 ffff88011769bb98 ffffffff8142c922 0000000000000006
ffff880117694090 ffff88011769bbc8 ffffffff8107c3ff ffff8800cba52400
ffff8800c476bea8 ffff8800c476bea8 ffff8800cba52400 ffff88011769bc08
Call Trace:
[<ffffffff8142c922>] dump_stack+0x4e/0x68
[<ffffffff8107c3ff>] lockdep_rcu_suspicious+0xfa/0x103
[<ffffffffa079931e>] nft_hash_destroy+0x50/0x137 [nft_hash]
[<ffffffffa078cd57>] nft_set_destroy+0x11/0x2a [nf_tables]
Acked-by: Thomas Graf <tgraf@suug.ch>
CONFIG_NETFILTER_XT_TARGET_LOG is not selected anymore when jumping
from 3.16 to 3.17-rc1 if you don't set on the new NF_LOG_IPV4 and
NF_LOG_IPV6 switches.
Change this to select the three new symbols NF_LOG_COMMON, NF_LOG_IPV4
and NF_LOG_IPV6 instead, so NETFILTER_XT_TARGET_LOG remains enabled
when moving from old to new kernels.
Reported-by: Rafał Miłecki <zajec5@gmail.com>
commit fc604767613b6d2036cdc35b660bc39451040a47
("ipvs: changes for local real server") from 2.6.37
introduced DNAT support to local real server but the
IPv6 LOCAL_OUT handler ip_vs_local_reply6() is
registered incorrectly as IPv4 hook causing any outgoing
IPv4 traffic to be dropped depending on the IP header values.
Chris tracked down the problem to CONFIG_IP_VS_IPV6=y
Bug report: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1349768
Reported-by: Chris J Arges <chris.j.arges@canonical.com>
Tested-by: Chris J Arges <chris.j.arges@canonical.com>
Signed-off-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Simon Horman <horms@verge.net.au>
The tunneling method should properly use tunnel encapsulation.
Fixes problem with CHECKSUM_PARTIAL packets when TCP/UDP csum
offload is supported.
Thanks to Alex Gartrell for reporting the problem, providing
solution and for all suggestions.
Reported-by: Alex Gartrell <agartrell@fb.com>
Signed-off-by: Alex Gartrell <agartrell@fb.com>
Use HAVE_JUMP_LABEL as elsewhere in the kernel to ensure
that the toolchain has the required support in addition to
CONFIG_JUMP_LABEL being set.
Signed-off-by: Zhouyi Zhou <yizhouzhou@ict.ac.cn>
Reviewed-by: Florian Westphal <fw@strlen.de>
This enables the netfilter NAT engine in first place, otherwise
you cannot ever select the nf_tables nat expression if iptables
is not selected.
Reported-by: Matteo Croce <technoboy85@gmail.com>
There's actually no good reason why we cannot use cgroup id 0,
so lets just remove this artificial barrier.
Reported-by: Alexey Perevalov <a.perevalov@samsung.com>
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Tested-by: Alexey Perevalov <a.perevalov@samsung.com>
Currently, the NAT configs depend on iptables and ip6tables. However,
users should be capable of enabling NAT for nft without having to
switch on iptables.
Fix this by adding new specific IP_NF_NAT and IP6_NF_NAT config
switches for iptables and ip6tables NAT support. I have also moved
the original NF_NAT_IPV4 and NF_NAT_IPV6 configs out of the scope
of iptables to make them independent of it.
This patch also adds NETFILTER_XT_NAT which selects the xt_nat
combo that provides snat/dnat for iptables. We cannot use NF_NAT
anymore since nf_tables can select this.
Convert a zero return value on error to a negative one, as returned
elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
identifier ret; expression e1,e2;
if (\(ret < 0\|ret != 0\))
{ ... return ret; }
ret = 0
... when != ret = e1
when != &ret
*if(...)
... when != ret = e2
when forall
return ret;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
Eric Dumazet reports that getsockopt() or setsockopt() sometimes
returns -EINTR instead of -ENOPROTOOPT, causing headaches to
application developers.
This patch replaces all the mutex_lock_interruptible() by mutex_lock()
in the netfilter tree, as there is no reason we should sleep for a
long time there.
Reported-by: Eric Dumazet <edumazet@google.com>
Suggested-by: Patrick McHardy <kaber@trash.net>
Acked-by: Julian Anastasov <ja@ssi.bg>
Fix possible replacement of the per-cpu chain counters by null
pointer when updating an existing chain in the commit path.
This should happen once the element has been effectively released in
the commit path, not before. This fixes a possible chain refcount leak
if the transaction is aborted.
Reported-by: Thomas Graf <tgraf@suug.ch>
drivers/net/Makefile
net/ipv6/sysctl_net_ipv6.c
Two ipv6_table_template[] additions overlap, so the index
of the ipv6_table[x] assignments needed to be adjusted.
In the drivers/net/Makefile case, we've gotten rid of the
garbage whereby we had to list every single USB networking
driver in the top-level Makefile, there is just one
"USB_NETWORKING" that guards everything.
The sizing of the hash table and the practice of requiring a lookup
to retrieve the pprev to be stored in the element cookie before the
deletion of an entry is left intact.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Acked-by: Patrick McHardy <kaber@trash.net>
Reviewed-by: Nikolay Aleksandrov <nikolay@redhat.com>
clean up names related to socket filtering and bpf in the following way:
- everything that deals with sockets keeps 'sk_*' prefix
- everything that is pure BPF is changed to 'bpf_*' prefix
split 'struct sk_filter' into
struct sk_filter {
atomic_t refcnt;
struct rcu_head rcu;
struct bpf_prog *prog;
and
struct bpf_prog {
u32 jited:1,
len:31;
struct sock_fprog_kern *orig_prog;
unsigned int (*bpf_func)(const struct sk_buff *skb,
const struct bpf_insn *filter);
union {
struct sock_filter insns[0];
struct bpf_insn insnsi[0];
struct work_struct work;
so that 'struct bpf_prog' can be used independent of sockets and cleans up
'unattached' bpf use cases
split SK_RUN_FILTER macro into:
SK_RUN_FILTER to be used with 'struct sk_filter *' and
BPF_PROG_RUN to be used with 'struct bpf_prog *'
__sk_filter_release(struct sk_filter *) gains
__bpf_prog_release(struct bpf_prog *) helper function
also perform related renames for the functions that work
with 'struct bpf_prog *', since they're on the same lines:
sk_filter_size -> bpf_prog_size
sk_filter_select_runtime -> bpf_prog_select_runtime
sk_filter_free -> bpf_prog_free
sk_unattached_filter_create -> bpf_prog_create
sk_unattached_filter_destroy -> bpf_prog_destroy
sk_store_orig_filter -> bpf_prog_store_orig_filter
sk_release_orig_filter -> bpf_release_orig_filter
__sk_migrate_filter -> bpf_migrate_filter
__sk_prepare_filter -> bpf_prepare_filter
API for attaching classic BPF to a socket stays the same:
sk_attach_filter(prog, struct sock *)/sk_detach_filter(struct sock *)
and SK_RUN_FILTER(struct sk_filter *, ctx) to execute a program
which is used by sockets, tun, af_packet
API for 'unattached' BPF programs becomes:
bpf_prog_create(struct bpf_prog **)/bpf_prog_destroy(struct bpf_prog *)
and BPF_PROG_RUN(struct bpf_prog *, ctx) to execute a program
which is used by isdn, ppp, team, seccomp, ptp, xt_bpf, cls_bpf, test_bpf
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
nft_del_setelem() currently calls nft_data_uninit() twice on the same
key. Once to release the key which is guaranteed to be NFT_DATA_VALUE
and a second time in the error path to which it falls through.
The second call has been harmless so far though because the type
passed is always NFT_DATA_VALUE which is currently a no-op.
Netfilter updates for net-next
The following patchset contains netfilter updates for net-next, they are:
1) Add the reject expression for the nf_tables bridge family, this
allows us to send explicit reject (TCP RST / ICMP dest unrech) to
the packets matching a rule.
2) Simplify and consolidate the nf_tables set dumping logic. This uses
netlink control->data to filter out depending on the request.
3) Perform garbage collection in xt_hashlimit using a workqueue instead
of a timer, which is problematic when many entries are in place in
the tables, from Eric Dumazet.
4) Remove leftover code from the removed ulog target support, from
Paul Bolle.
5) Dump unmodified flags in the netfilter packet accounting when resetting
counters, so userspace knows that a counter was in overquota situation,
from Alexey Perevalov.
6) Fix wrong usage of the bitwise functions in nfnetlink_acct, also from
Alexey.
7) Fix a crash when adding new set element with an empty NFTA_SET_ELEM_LIST
attribute.
This patchset also includes a couple of cleanups for xt_LED from
Duan Jiong and for nf_conntrack_ipv4 (using coccinelle) from
Himangi Saraogi.
Otherwise, the kernel oopses in nla_for_each_nested when iterating over
the unset attribute NFTA_SET_ELEM_LIST_ELEMENTS in the
nf_tables_{new,del}setelem() path.
netlink: 65524 bytes leftover after parsing attributes in process `nft'.
Oops: 0000 [#1] SMP
CPU: 2 PID: 6287 Comm: nft Not tainted 3.16.0-rc2+ #169
RIP: 0010:[<ffffffffa0526e61>] [<ffffffffa0526e61>] nf_tables_newsetelem+0x82/0xec [nf_tables]
Call Trace:
[<ffffffffa05178c4>] nfnetlink_rcv+0x2e7/0x3d7 [nfnetlink]
[<ffffffffa0517939>] ? nfnetlink_rcv+0x35c/0x3d7 [nfnetlink]
[<ffffffff8137d300>] netlink_unicast+0xf8/0x17a
[<ffffffff8137d6a5>] netlink_sendmsg+0x323/0x351
Fix this by returning -EINVAL if this attribute is not set, which
doesn't make sense at all since those commands are there to add and to
delete elements from the set.
functions
Bit helper functions were used for manipulation with NFACCT_F_OVERQUOTA,
but they are accepting pit position, but not a bit mask. As a result
not a third bit for NFACCT_F_OVERQUOTA was set, but forth. Such
behaviour was dangarous and could lead to unexpected overquota report
result.
Signed-off-by: Alexey Perevalov <a.perevalov@samsung.com>
NFNL_MSG_ACCT_GET_CTRZERO modifies dumped flags, in this case
client see unmodified (uncleared) counter value and cleared
overquota state - end user doesn't know anything about overquota state,
unless end user subscribed on overquota report.
If led-always-blink is set, then between switch led OFF and ON
is almost zero time. So blink is invisible. This use oneshot led trigger
with fixed time 50ms witch is enough to see blink.
Signed-off-by: Jiri Prchal <jiri.prchal@aksignal.cz>
The function led_trigger_register() will only return -EEXIST when
error arises.
Signed-off-by: Duan Jiong <duanj.fnst@cn.fujitsu.com>
xt_hashlimit cannot be used with large hash tables, because garbage
collector is run from a timer. If table is really big, its possible
to hold cpu for more than 500 msec, which is unacceptable.
Switch to a work queue, and use proper scheduling points to remove
latencies spikes.
Later, we also could switch to a smoother garbage collection done
at lookup time, one bucket at a time...
Cc: Florian Westphal <fw@strlen.de>
Cc: Patrick McHardy <kaber@trash.net>
This patch uses the cb->data pointer that allows us to store the
context when dumping the set list. Thus, we don't need to parse the
original netlink message containing the dump request for each recvmsg()
call when dumping the set list. The different function flavours
depending on the dump criteria has been also merged into one single
generic function. This saves us ~100 lines of code.
drivers/infiniband/hw/cxgb4/device.c
The cxgb4 conflict was simply overlapping changes.
The following patchset contains updates for your net-next tree,
they are:
1) Use kvfree() helper function from x_tables, from Eric Dumazet.
2) Remove extra timer from the conntrack ecache extension, use a
workqueue instead to redeliver lost events to userspace instead,
from Florian Westphal.
3) Removal of the ulog targets for ebtables and iptables. The nflog
infrastructure superseded this almost 9 years ago, time to get rid
of this code.
4) Replace the list of loggers by an array now that we can only have
two possible non-overlapping logger flavours, ie. kernel ring buffer
and netlink logging.
5) Move Eric Dumazet's log buffer code to nf_log to reuse it from
all of the supported per-family loggers.
6) Consolidate nf_log_packet() as an unified interface for packet logging.
After this patch, if the struct nf_loginfo is available, it explicitly
selects the logger that is used.
7) Move ip and ip6 logging code from xt_LOG to the corresponding
per-family loggers. Thus, x_tables and nf_tables share the same code
for packet logging.
8) Add generic ARP packet logger, which is used by nf_tables. The
format aims to be consistent with the output of xt_LOG.
9) Add generic bridge packet logger. Again, this is used by nf_tables
and it routes the packets to the real family loggers. As a result,
we get consistent logging format for the bridge family. The ebt_log
logging code has been intentionally left in place not to break
backward compatibility since the logging output differs from xt_LOG.
10) Update nft_log to explicitly request the required family logger when
needed.
11) Finish nft_log so it supports arp, ip, ip6, bridge and inet families.
Allowing selection between netlink and kernel buffer ring logging.
12) Several fixes coming after the netfilter core logging changes spotted
by robots.
13) Use IS_ENABLED() macros whenever possible in the netfilter tree,
from Duan Jiong.
14) Removal of a couple of unnecessary branch before kfree, from Fabian
Frederick.
Previously, only the four high bits of the tclass were maintained in the
ipv6 case. This matches the behavior of ipv4, though whether or not we
should reflect ECN bits may be up for debate.
This code section cannot compile as it refer to non existing variable
It also pre-date git history.
Signed-off-by: Yannick Brosseau <scientist@fb.com>
Fix checkpatch warning:
WARNING: kfree(NULL) is safe this check is probably not required
Signed-off-by: Fabian Frederick <fabf@skynet.be>
commit 8f4e0a18682d91 ("IPVS netns exit causes crash in conntrack")
added second ip_vs_conn_drop_conntrack call instead of just adding
the needed check. As result, the first call still can cause
crash on netns exit. Remove it.
Signed-off-by: Hans Schillstrom <hans@schillstrom.com>
Use generic u64_stats_sync infrastructure to get proper 64bit stats,
even on 32bit arches, at no extra cost for 64bit arches.
Without this fix, 32bit arches can have some wrong counters at the time
the carry is propagated into upper word.
An updater may interfer with the dumping of any of the object lists.
Fix this by using a per-net generation counter and use the
nl_dump_check_consistent() interface so the NLM_F_DUMP_INTR flag is set
to notify userspace that it has to restart the dump since an updater
has interfered.
This patch also replaces the existing consistency checking code in the
rule dumping path since it is broken. Basically, the value that the
dump callback returns is not propagated to userspace via
netlink_dump_start().
The dump operation through netlink is not protected by the nfnl_lock.
Thus, a reader process can be dumping any of the existing object
lists while another process can be updating the list content.
This patch resolves this situation by protecting all the object
lists with RCU in the netlink dump path which is the reader side.
The updater path is already protected via nfnl_lock, so use list
manipulation RCU-safe operations.
Skip transaction handling for table updates with no changes in
the flags. This fixes a crash when passing the table flag with all
bits unset.
Reported-by: Ana Rey <anarey@gmail.com>
replace:
#if defined(CONFIG_NF_CT_NETLINK) || defined(CONFIG_NF_CT_NETLINK_MODULE)
with
#if IS_ENABLED(CONFIG_NF_CT_NETLINK)
replace:
#if !defined(CONFIG_NF_NAT) && !defined(CONFIG_NF_NAT_MODULE)
with
#if !IS_ENABLED(CONFIG_NF_NAT)
replace:
#if !defined(CONFIG_NF_CONNTRACK) && !defined(CONFIG_NF_CONNTRACK_MODULE)
with
#if !IS_ENABLED(CONFIG_NF_CONNTRACK)
And add missing:
in net/ipv{4,6}/netfilter/nf_nat_l3proto_ipv{4,6}.c
net/netfilter/nft_log.c:79:44-45: Unneeded semicolon
Removes unneeded semicolon.
Generated by: scripts/coccinelle/misc/semicolon.cocci
CC: Pablo Neira Ayuso <pablo@netfilter.org>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
net/netfilter/xt_LOG.c: In function 'log_tg':
>> net/netfilter/xt_LOG.c:43: error: format not a string literal and no format arguments
Fixes: fab4085 ("netfilter: log: nf_log_packet() as real unified interface")
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
warning: (NETFILTER_XT_TARGET_LOG) selects NF_LOG_IPV6 which has unmet direct dependencies (NET && INET && IPV6 && NETFILTER && IP6_NF_IPTABLES && NETFILTER_ADVANCED)
warning: (NF_LOG_IPV4 && NF_LOG_IPV6) selects NF_LOG_COMMON which has unmet direct dependencies (NET && INET && NETFILTER && NF_CONNTRACK)
Fixes: 83e96d4 ("netfilter: log: split family specific code to nf_log_{ip,ip6,common}.c files")
Use the unified nf_log_packet() interface that allows us explicit
logger selection through the nf_loginfo structure.
If you specify the group attribute, this means you want to receive
logging messages through nfnetlink_log. In that case, the snaplen
and qthreshold attributes allows you to tune internal aspects of
the netlink logging infrastructure.
On the other hand, if the level is specified, then the plain text
format through the kernel logging ring is used instead, which is
also used by default if neither group nor level are indicated.
This includes the special handling for NFPROTO_INET. There is
no real inet logger since we don't see packets of this family.
However, rules are loaded using this special family type. So
let's just request both IPV4 and IPV6 loggers.
This adds the generic plain text packet loggger for bridged packets.
It routes the logging message to the real protocol packet logger.
I decided not to refactor the ebt_log code for two reasons:
1) The ebt_log output is not consistent with the IPv4 and IPv6
Netfilter packet loggers. The output is different for no good
reason and it adds redundant code to handle packet logging.
2) To avoid breaking backward compatibility for applications
outthere that are parsing the specific ebt_log output, the ebt_log
output has been left as is. So only nftables will use the new
consistent logging format for logged bridged packets.
More decisions coming in this patch:
1) This also removes ebt_log as default logger for bridged packets.
Thus, nf_log_packet() routes packet to this new packet logger
instead. This doesn't break backward compatibility since
nf_log_packet() is not used to log packets in plain text format
from anywhere in the ebtables/netfilter bridge code.
2) The new bridge packet logger also performs a lazy request to
register the real IPv4, ARP and IPv6 netfilter packet loggers.
If the real protocol logger is no available (not compiled or the
module is not available in the system, not packet logging happens.
Before this patch, the nf_loginfo parameter specified the logging
configuration in case the specified default logger was loaded. This
patch updates the semantics of the nf_loginfo parameter in
nf_log_packet() which now indicates the logger that you explicitly
want to use.
Thus, nf_log_packet() is exposed as an unified interface which
internally routes the log message to the corresponding logger type
by family.
The module dependencies are expressed by the new nf_logger_find_get()
and nf_logger_put() functions which bump the logger module refcount.
Thus, you can not remove logger modules that are used by rules anymore.
Another important effect of this change is that the family specific
module is only loaded when required. Therefore, xt_LOG and nft_log
will just trigger the autoload of the nf_log_{ip,ip6} modules
according to the family.
The plain text logging is currently embedded into the xt_LOG target.
In order to be able to use the plain text logging from nft_log, as a
first step, this patch moves the family specific code to the following
files and Kconfig symbols:
1) net/ipv4/netfilter/nf_log_ip.c: CONFIG_NF_LOG_IPV4
2) net/ipv6/netfilter/nf_log_ip6.c: CONFIG_NF_LOG_IPV6
3) net/netfilter/nf_log_common.c: CONFIG_NF_LOG_COMMON
These new modules will be required by xt_LOG and nft_log. This patch
is based on original patch from Arturo Borrero Gonzalez.
This patch moves Eric Dumazet's log buffer implementation from the
xt_log.h header file to the core net/netfilter/nf_log.c. This also
includes the renaming of the structure and functions to avoid possible
undesired namespace clashes.
This change allows us to use it from the arp and bridge packet logging
implementation in follow up patches.
