commit aea9d711f3d68c656ad31ab578ecfb0bb5cd7f97 upstream.
The code that hashes and unhashes connections from the connection table
is missing locking of the connection being modified, which opens up a
race condition and results in memory corruption when this race condition
is hit.
Here is what happens in pretty verbose form:
CPU 0 CPU 1
An active connection is terminated and
we schedule ip_vs_conn_expire() on this
CPU to expire this connection.
IRQ assignment is changed to this CPU,
but the expire timer stays scheduled on
the other CPU.
New connection from same ip:port comes
in right before the timer expires, we
find the inactive connection in our
connection table and get a reference to
it. We proper lock the connection in
tcp_state_transition() and read the
connection flags in set_tcp_state().
ip_vs_conn_expire() gets called, we
unhash the connection from our
connection table and remove the hashed
flag in ip_vs_conn_unhash(), without
proper locking!
While still holding proper locks we
write the connection flags in
set_tcp_state() and this sets the hashed
flag again.
ip_vs_conn_expire() fails to expire the
connection, because the other CPU has
incremented the reference count. We try
to re-insert the connection into our
connection table, but this fails in
ip_vs_conn_hash(), because the hashed
flag has been set by the other CPU. We
re-schedule execution of
ip_vs_conn_expire(). Now this connection
has the hashed flag set, but isn't
actually hashed in our connection table
and has a dangling list_head.
We drop the reference we held on the
connection and schedule the expire timer
for timeouting the connection on this
CPU. Further packets won't be able to
find this connection in our connection
table.
ip_vs_conn_expire() gets called again,
we think it's already hashed, but the
list_head is dangling and while removing
the connection from our connection table
we write to the memory location where
this list_head points to.
The result will probably be a kernel oops at some other point in time.
This race condition is pretty subtle, but it can be triggered remotely.
It needs the IRQ assignment change or another circumstance where packets
coming from the same ip:port for the same service are being processed on
different CPUs. And it involves hitting the exact time at which
ip_vs_conn_expire() gets called. It can be avoided by making sure that
all packets from one connection are always processed on the same CPU and
can be made harder to exploit by changing the connection timeouts to
some custom values.
Signed-off-by: Sven Wegener <sven.wegener@stealer.net>
Acked-by: Simon Horman <horms@verge.net.au>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
A missing break statement in hashlimit_ipv6_mask(), and masks
between /64 and /95 are not working at all...
If dl_seq_start() memory allocation fails, we crash later in
dl_seq_stop(), trying to kfree(ERR_PTR(-ENOMEM))
Commit 8ccb92ad (netfilter: xt_recent: fix false match) fixed supposedly
false matches in rules using a zero hit_count. As it turns out there is
nothing false about these matches and people are actually using entries
with a hit_count of zero to make rules dependant on addresses inserted
manually through /proc.
Since this slipped past the eyes of three reviewers, instead of
reverting the commit in question, this patch explicitly checks
for a hit_count of zero to make the intentions more clear.
Reported-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
Tested-by: Thomas Jarosch <thomas.jarosch@intra2net.com>
Cc: stable@kernel.org
This patch fixes a bug that allows to lose events when reliable
event delivery mode is used, ie. if NETLINK_BROADCAST_SEND_ERROR
and NETLINK_RECV_NO_ENOBUFS socket options are set.
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
Quick fix for memory/module refcount leak.
Reference count of listener instance never reaches 0.
Start/stop of ulogd2 is enough to trigger this bug!
Now, refcounting there looks very fishy in particular this code:
if (!try_module_get(THIS_MODULE)) {
and creation of listener instance with refcount 2,
so it may very well be ripped and redone. :-)
Use list_head rather than a custom list implementation.
Signed-off-by: Simon Horman <horms@verge.net.au>
The macro is replaced by a list.h-like foreach loop. This makes
the code more inspectable.
Signed-off-by: Jan Engelhardt <jengelh@medozas.de>
A rule with a zero hit_count will always match.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
e->index overflows e->stamps[] every ip_pkt_list_tot packets.
Consider the case when ip_pkt_list_tot==1; the first packet received is stored
in e->stamps[0] and e->index is initialized to 1. The next received packet
timestamp is then stored at e->stamps[1] in recent_entry_update(),
a buffer overflow because the maximum e->stamps[] index is 0.
commit 3bc38712e3a6e059 (handle NF_STOP and unknown verdicts in
nf_reinject) was a partial fix to packet leaks.
If user asks NF_STOLEN status, we must free the skb as well.
Reported-by: Afi Gjermund <afigjermund@gmail.com>
Signed-off-by: Eric DUmazet <eric.dumazet@gmail.com>
This patch fixes a bug that triggers an assertion if you create
a conntrack entry with a helper and netfilter debugging is enabled.
Basically, we hit the assertion because the confirmation flag is
set before the conntrack extensions are added. To fix this, we
move the extension addition before the aforementioned flag is
set.
This patch also removes the possibility of setting a helper for
existing conntracks. This operation would also trigger the
assertion since we are not allowed to add new extensions for
existing conntracks. We know noone that could benefit from
this operation sanely.
Thanks to Eric Dumazet for initial posting a preliminary patch
to address this issue.
Reported-by: David Ramblewski <David.Ramblewski@atosorigin.com>
Dunno, what was the idea, it wasn't used for a long time.
Enhance IPVS to load balance SCTP transport protocol packets. This is done
based on the SCTP rfc 4960. All possible control chunks have been taken
care. The state machine used in this code looks some what lengthy. I tried
to make the state machine easy to understand.
Signed-off-by: Venkata Mohan Reddy Koppula <mohanreddykv@gmail.com>
Commit 2eff25c18c3d332d3c4dd98f2ac9b7114e9771b0
(netfilter: xt_hashlimit: fix race condition and simplify locking)
added a mutex deadlock :
htable_create() is called with hashlimit_mutex already locked
with 32 bit userland and 64 bit kernels, it is unlikely but possible
that insertion of new rules fails even tough there are only about 2000
iptables rules.
This happens because the compat delta is using a short int.
Easily reproducible via "iptables -m limit" ; after about 2050
rules inserting new ones fails with -ELOOP.
Note that compat_delta included 2 bytes of padding on x86_64, so
structure size remains the same.
Parse and dump the conntrack zone in ctnetlink.
Normally, each connection needs a unique identity. Conntrack zones allow
to specify a numerical zone using the CT target, connections in different
zones can use the same identity.
Example:
iptables -t raw -A PREROUTING -i veth0 -j CT --zone 1
iptables -t raw -A OUTPUT -o veth1 -j CT --zone 1
The error handlers might need the template to get the conntrack zone
introduced in the next patches to perform a conntrack lookup.
Print which revision has been used and which size are which
(kernel/user) for easier debugging.
It is one of these things that iptables cannot catch and which can
cause "Invalid argument" to be printed. Without a hint in dmesg, it is
not going to be helpful.
call_rcu() will unconditionally reinitialize RCU head anyway.
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Add support for mangling TCP SIP packets.
Add TCP support, which is mandated by RFC3261 for all SIP elements.
SIP over TCP is similar to UDP, except that messages are delimited
by Content-Length: headers and multiple messages may appear in one
packet.
When using TCP multiple SIP messages might be present in a single packet.
A following patch will parse them by setting the dptr to the beginning of
each message. The NAT helper needs to reload the dptr value after mangling
the packet however, so it needs to know the offset of the message to the
beginning of the packet.
When requests are parsed, the "sip:" part of the SIP URI should be skipped.
Usually this doesn't matter because address parsing skips forward until after
the username part, but in case REGISTER requests it doesn't contain a username
and the address can not be parsed.
Make the output a bit more informative by showing the helper an expectation
belongs to and the expectation class.
The static initial tables are pretty large, and after the net
namespace has been instantiated, they just hang around for nothing.
This commit removes them and creates tables on-demand at runtime when
needed.
Size shrinks by 7735 bytes (x86_64).
The respective xt_table structures already have most of the metadata
needed for hook setup. Add a 'priority' field to struct xt_table so
that xt_hook_link() can be called with a reduced number of arguments.
So should we be having more tables in the future, it comes at no
static cost (only runtime, as before) - space saved:
6807373->6806555.
Rewrite COMPAT_XT_ALIGN in terms of dummy structure hack.
Compat counters logically have nothing to do with it.
Use ALIGN() macro while I'm at it for same types.
In particular, several occurances of funny versions of 'success',
'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address',
'beginning', 'desirable', 'separate' and 'necessary' are fixed.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Joe Perches <joe@perches.com>
Cc: Junio C Hamano <gitster@pobox.com>
As noticed by Jon Masters <jonathan@jonmasters.org>, the conntrack hash
size is global and not per namespace, but modifiable at runtime through
/sys/module/nf_conntrack/hashsize. Changing the hash size will only
resize the hash in the current namespace however, so other namespaces
will use an invalid hash size. This can cause crashes when enlarging
the hashsize, or false negative lookups when shrinking it.
Move the hash size into the per-namespace data and only use the global
hash size to initialize the per-namespace value when instanciating a
new namespace. Additionally restrict hash resizing to init_net for
now as other namespaces are not handled currently.
Expectation hashtable size was simply glued to a variable with no code
to rehash expectations, so it was a bug to allow writing to it.
Make "expect_hashsize" readonly.
nf_conntrack_cachep is currently shared by all netns instances, but
because of SLAB_DESTROY_BY_RCU special semantics, this is wrong.
If we use a shared slab cache, one object can instantly flight between
one hash table (netns ONE) to another one (netns TWO), and concurrent
reader (doing a lookup in netns ONE, 'finding' an object of netns TWO)
can be fooled without notice, because no RCU grace period has to be
observed between object freeing and its reuse.
We dont have this problem with UDP/TCP slab caches because TCP/UDP
hashtables are global to the machine (and each object has a pointer to
its netns).
If we use per netns conntrack hash tables, we also *must* use per netns
conntrack slab caches, to guarantee an object can not escape from one
namespace to another one.
[Patrick: added unique slab name allocation]
As discovered by Jon Masters <jonathan@jonmasters.org>, the "untracked"
conntrack, which is located in the data section, might be accidentally
freed when a new namespace is instantiated while the untracked conntrack
is attached to a skb because the reference count it re-initialized.
The best fix would be to use a seperate untracked conntrack per
namespace since it includes a namespace pointer. Unfortunately this is
not possible without larger changes since the namespace is not easily
available everywhere we need it. For now move the untracked conntrack
initialization to the init_net setup function to make sure the reference
count is not re-initialized and handle cleanup in the init_net cleanup
function to make sure namespaces can exit properly while the untracked
conntrack is in use in other namespaces.
Add a new target for the raw table, which can be used to specify conntrack
parameters for specific connections, f.i. the conntrack helper.
The target attaches a "template" connection tracking entry to the skb, which
is used by the conntrack core when initializing a new conntrack.
Support initializing selected parameters of new conntrack entries from a
"conntrack template", which is a specially marked conntrack entry attached
to the skb.
Currently the helper and the event delivery masks can be initialized this
way.
Add two masks for conntrack end expectation events to struct nf_conntrack_ecache
and use them to filter events. Their default value is "all events" when the
event sysctl is on and "no events" when it is off. A following patch will add
specific initializations. Expectation events depend on the ecache struct of
their master conntrack.
