path: root/net/netfilter
2013-01-17rtnetlink: Compute and store minimum ifinfo dump sizeGreg Rose
commit c7ac8679bec9397afe8918f788cbcef88c38da54 upstream. The message size allocated for rtnl ifinfo dumps was limited to a single page. This is not enough for additional interface info available with devices that support SR-IOV and caused a bug in which VF info would not be displayed if more than approximately 40 VFs were created per interface. Implement a new function pointer for the rtnl_register service that will calculate the amount of data required for the ifinfo dump and allocate enough data to satisfy the request. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Cc: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26netfilter: Mark SYN/ACK packets as invalid from original directionJozsef Kadlecsik
commit 64f509ce71b08d037998e93dd51180c19b2f464c upstream. Clients should not send such packets. By accepting them, we open up a hole by wich ephemeral ports can be discovered in an off-path attack. See: "Reflection scan: an Off-Path Attack on TCP" by Jan Wrobel, http://arxiv.org/abs/1201.2074 Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26netfilter: Validate the sequence number of dataless ACK packets as wellJozsef Kadlecsik
commit 4a70bbfaef0361d27272629d1a250a937edcafe4 upstream. We spare nothing by not validating the sequence number of dataless ACK packets and enabling it makes harder off-path attacks. See: "Reflection scan: an Off-Path Attack on TCP" by Jan Wrobel, http://arxiv.org/abs/1201.2074 Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21netfilter: xt_limit: have r->cost != 0 case workJan Engelhardt
commit 82e6bfe2fbc4d48852114c4f979137cd5bf1d1a8 upstream. Commit v2.6.19-rc1~1272^2~41 tells us that r->cost != 0 can happen when a running state is saved to userspace and then reinstated from there. Make sure that private xt_limit area is initialized with correct values. Otherwise, random matchings due to use of uninitialized memory. Signed-off-by: Jan Engelhardt <jengelh@inai.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21netfilter: limit, hashlimit: avoid duplicated inlineFlorian Westphal
commit 7a909ac70f6b0823d9f23a43f19598d4b57ac901 upstream. credit_cap can be set to credit, which avoids inlining user2credits twice. Also, remove inline keyword and let compiler decide. old: 684 192 0 876 36c net/netfilter/xt_limit.o 4927 344 32 5303 14b7 net/netfilter/xt_hashlimit.o now: 668 192 0 860 35c net/netfilter/xt_limit.o 4793 344 32 5169 1431 net/netfilter/xt_hashlimit.o Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21netfilter: nf_ct_expect: fix possible access to uninitialized timerPablo Neira Ayuso
commit 2614f86490122bf51eb7c12ec73927f1900f4e7d upstream. In __nf_ct_expect_check, the function refresh_timer returns 1 if a matching expectation is found and its timer is successfully refreshed. This results in nf_ct_expect_related returning 0. Note that at this point: - the passed expectation is not inserted in the expectation table and its timer was not initialized, since we have refreshed one matching/existing expectation. - nf_ct_expect_alloc uses kmem_cache_alloc, so the expectation timer is in some undefined state just after the allocation, until it is appropriately initialized. This can be a problem for the SIP helper during the expectation addition: ... if (nf_ct_expect_related(rtp_exp) == 0) { if (nf_ct_expect_related(rtcp_exp) != 0) nf_ct_unexpect_related(rtp_exp); ... Note that nf_ct_expect_related(rtp_exp) may return 0 for the timer refresh case that is detailed above. Then, if nf_ct_unexpect_related(rtcp_exp) returns != 0, nf_ct_unexpect_related(rtp_exp) is called, which does: spin_lock_bh(&nf_conntrack_lock); if (del_timer(&exp->timeout)) { nf_ct_unlink_expect(exp); nf_ct_expect_put(exp); } spin_unlock_bh(&nf_conntrack_lock); Note that del_timer always returns false if the timer has been initialized. However, the timer was not initialized since setup_timer was not called, therefore, the expectation timer remains in some undefined state. If I'm not missing anything, this may lead to the removal an unexistent expectation. To fix this, the optimization that allows refreshing an expectation is removed. Now nf_conntrack_expect_related looks more consistent to me since it always add the expectation in case that it returns success. Thanks to Patrick McHardy for participating in the discussion of this patch. I think this may be the source of the problem described by: http://marc.info/?l=netfilter-devel&m=134073514719421&w=2 Reported-by: Rafal Fitt <rafalf@aplusc.com.pl> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21netfilter: nf_conntrack: fix racy timer handling with reliable eventsPablo Neira Ayuso
commit 5b423f6a40a0327f9d40bc8b97ce9be266f74368 upstream. Existing code assumes that del_timer returns true for alive conntrack entries. However, this is not true if reliable events are enabled. In that case, del_timer may return true for entries that were just inserted in the dying list. Note that packets / ctnetlink may hold references to conntrack entries that were just inserted to such list. This patch fixes the issue by adding an independent timer for event delivery. This increases the size of the ecache extension. Still we can revisit this later and use variable size extensions to allocate this area on demand. Tested-by: Oliver Smith <olipro@8.c.9.b.0.7.4.0.1.0.0.2.ip6.arpa> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-21ipvs: fix oops in ip_vs_dst_event on rmmodJulian Anastasov
commit 283283c4da91adc44b03519f434ee1e7e91d6fdb upstream. After commit 39f618b4fd95ae243d940ec64c961009c74e3333 (3.4) "ipvs: reset ipvs pointer in netns" we can oops in ip_vs_dst_event on rmmod ip_vs because ip_vs_control_cleanup is called after the ipvs_core_ops subsys is unregistered and net->ipvs is NULL. Fix it by exiting early from ip_vs_dst_event if ipvs is NULL. It is safe because all services and dests for the net are already freed. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02ipvs: fix info leak in getsockopt(IP_VS_SO_GET_TIMEOUT)Mathias Krause
[ Upstream commit 2d8a041b7bfe1097af21441cb77d6af95f4f4680 ] If at least one of CONFIG_IP_VS_PROTO_TCP or CONFIG_IP_VS_PROTO_UDP is not set, __ip_vs_get_timeouts() does not fully initialize the structure that gets copied to userland and that for leaks up to 12 bytes of kernel stack. Add an explicit memset(0) before passing the structure to __ip_vs_get_timeouts() to avoid the info leak. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Wensong Zhang <wensong@linux-vs.org> Cc: Simon Horman <horms@verge.net.au> Cc: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-29ipvs: fix matching of fwmark templates during schedulingSimon Horman
commit e0aac52e17a3db68fe2ceae281780a70fc69957f upstream. Commit f11017ec2d1859c661f4e2b12c4a8d250e1f47cf (2.6.37) moved the fwmark variable in subcontext that is invalidated before reaching the ip_vs_ct_in_get call. As vaddr is provided as pointer in the param structure make sure the fwmark variable is in same context. As the fwmark templates can not be matched, more and more template connections are created and the controlled connections can not go to single real server. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-08-15IPVS: Free resources on module removalSimon Horman
[ Upstream commit 7676e345824f162191b1fe2058ad948a6cf91c20 ] This resolves a panic on module removal. Reported-by: Dave Jones <davej@redhat.com> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Hans Schillstrom <hans.schillstrom@ericsson.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-16netfilter: fix looped (broad|multi)cast's MAC handlingNicolas Cavallari
By default, when broadcast or multicast packet are sent from a local application, they are sent to the interface then looped by the kernel to other local applications, going throught netfilter hooks in the process. These looped packet have their MAC header removed from the skb by the kernel looping code. This confuse various netfilter's netlink queue, netlink log and the legacy ip_queue, because they try to extract a hardware address from these packets, but extracts a part of the IP header instead. This patch prevent NFQUEUE, NFLOG and ip_QUEUE to include a MAC header if there is none in the packet. Signed-off-by: Nicolas Cavallari <cavallar@lri.fr> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-06-13IPVS netns exit causes crash in conntrackHans Schillstrom
Quote from Patric Mc Hardy "This looks like nfnetlink.c excited and destroyed the nfnl socket, but ip_vs was still holding a reference to a conntrack. When the conntrack got destroyed it created a ctnetlink event, causing an oops in netlink_has_listeners when trying to use the destroyed nfnetlink socket." If nf_conntrack_netlink is loaded before ip_vs this is not a problem. This patch simply avoids calling ip_vs_conn_drop_conntrack() when netns is dying as suggested by Julian. Signed-off-by: Hans Schillstrom <hans.schillstrom@ericsson.com> Signed-off-by: Simon Horman <horms@verge.net.au>
2011-06-06netfilter: nf_conntrack: fix ct refcount leak in l4proto->error()Pablo Neira Ayuso
This patch fixes a refcount leak of ct objects that may occur if l4proto->error() assigns one conntrack object to one skbuff. In that case, we have to skip further processing in nf_conntrack_in(). With this patch, we can also fix wrong return values (-NF_ACCEPT) for special cases in ICMP[v6] that should not bump the invalid/error statistic counters. Reported-by: Zoltan Menyhart <Zoltan.Menyhart@bull.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-06-06netfilter: ipset: Use the stored first cidr value instead of '1'Jozsef Kadlecsik
The stored cidr values are tried one after anoter. The boolean condition evaluated to '1' instead of the first stored cidr or the default host cidr. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-06-06netfilter: ipset: Fix return code for destroy when sets are in useJozsef Kadlecsik
2011-06-06ipvs: restore support for iptables SNATJulian Anastasov
Fix the IPVS priority in LOCAL_IN hook, so that SNAT target in POSTROUTING is supported for IPVS traffic as in 2.6.36 where it worked depending on module load order. Before 2.6.37 we used priority 100 in LOCAL_IN to process remote requests. We used the same priority as iptables SNAT and if IPVS handlers are installed before SNAT handlers we supported SNAT in POSTROUTING for the IPVS traffic. If SNAT is installed before IPVS, the netfilter handlers are before IPVS and netfilter checks the NAT table twice for the IPVS requests: once in LOCAL_IN where IPS_SRC_NAT_DONE is set and second time in POSTROUTING where the SNAT rules are ignored because IPS_SRC_NAT_DONE was already set in LOCAL_IN. But in 2.6.37 we changed the IPVS priority for LOCAL_IN with the goal to be unique (101) forgetting the fact that for IPVS traffic we should not walk both LOCAL_IN and POSTROUTING nat tables. So, change the priority for processing remote IPVS requests from 101 to 99, i.e. before NAT_SRC (100) because we prefer to support SNAT in POSTROUTING instead of LOCAL_IN. It also moves the priority for IPVS replies from 99 to 98. Use constants instead of magic numbers at these places. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-06-06netfilter: add more values to enum ip_conntrack_infoEric Dumazet
Following error is raised (and other similar ones) : net/ipv4/netfilter/nf_nat_standalone.c: In function ‘nf_nat_fn’: net/ipv4/netfilter/nf_nat_standalone.c:119:2: warning: case value ‘4’ not in enumerated type ‘enum ip_conntrack_info’ gcc barfs on adding two enum values and getting a not enumerated result : case IP_CT_RELATED+IP_CT_IS_REPLY: Add missing enum values Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: David Miller <davem@davemloft.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-05-27IPVS: bug in ip_vs_ftp, same list heaad used in all netns.Hans Schillstrom
When ip_vs was adapted to netns the ftp application was not adapted in a correct way. However this is a fix to avoid kernel errors. In the long term another solution might be chosen. I.e the ports that the ftp appl, uses should be per netns. Signed-off-by: Hans Schillstrom <hans.schillstrom@ericsson.com> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-05-26netfilter: ipset: fix ip_set_flush return codeJozsef Kadlecsik
ip_set_flush returned -EPROTO instead of -IPSET_ERR_PROTOCOL, fixed Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-19Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (78 commits) Revert "rcu: Decrease memory-barrier usage based on semi-formal proof" net,rcu: convert call_rcu(prl_entry_destroy_rcu) to kfree batman,rcu: convert call_rcu(softif_neigh_free_rcu) to kfree_rcu batman,rcu: convert call_rcu(neigh_node_free_rcu) to kfree() batman,rcu: convert call_rcu(gw_node_free_rcu) to kfree_rcu net,rcu: convert call_rcu(kfree_tid_tx) to kfree_rcu() net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu() net/mac80211,rcu: convert call_rcu(work_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu() perf,rcu: convert call_rcu(swevent_hlist_release_rcu) to kfree_rcu() perf,rcu: convert call_rcu(free_ctx) to kfree_rcu() net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu() net,rcu: convert call_rcu(net_generic_release) to kfree_rcu() net,rcu: convert call_rcu(netlbl_unlhsh_free_addr6) to kfree_rcu() net,rcu: convert call_rcu(netlbl_unlhsh_free_addr4) to kfree_rcu() security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu() net,rcu: convert call_rcu(xps_dev_maps_release) to kfree_rcu() net,rcu: convert call_rcu(xps_map_release) to kfree_rcu() net,rcu: convert call_rcu(rps_map_release) to kfree_rcu() ...
2011-05-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/vmxnet3/vmxnet3_ethtool.c net/core/dev.c
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-2.6
2011-05-16netfilter: nf_ct_sip: fix SDP parsing in TCP SIP messages for some Cisco phonesPatrick McHardy
Some Cisco phones do not place the Content-Length field at the end of the SIP message. This is valid, due to a misunderstanding of the specification the parser expects the SDP body to start directly after the Content-Length field. Fix the parser to scan for \r\n\r\n to locate the beginning of the SDP body. Reported-by: Teresa Kang <teresa_kang@gemtek.com.tw> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-05-16netfilter: nf_ct_sip: validate Content-Length in TCP SIP messagesPatrick McHardy
Verify that the message length of a single SIP message, which is calculated based on the Content-Length field contained in the SIP message, does not exceed the packet boundaries. Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-05-15IPVS: fix netns if reading ip_vs_* procfs entriesHans Schillstrom
Without this patch every access to ip_vs in procfs will increase the netns count i.e. an unbalanced get_net()/put_net(). (ipvsadm commands also use procfs.) The result is you can't exit a netns if reading ip_vs_* procfs entries. Signed-off-by: Hans Schillstrom <hans.schillstrom@ericsson.com> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-05-12ipvs: Remove all remaining references to rt->rt_{src,dst}Julian Anastasov
Remove all remaining references to rt->rt_{src,dst} by using dest->dst_saddr to cache saddr (used for TUN mode). For ICMP in FORWARD hook just restrict the rt_mode for NAT to disable LOCALNODE. All other modes do not allow IP_VS_RT_MODE_RDR, so we should be safe with the ICMP forwarding. Using cp->daddr as replacement for rt_dst is safe for all modes except BYPASS, even when cp->dest is NULL because it is cp->daddr that is used to assign cp->dest for sync-ed connections. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12ipvs: Eliminate rt->rt_dst usage in __ip_vs_get_out_rt().David S. Miller
We can simply track what destination address is used based upon which code block is taken at the top of the function. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-12ipvs: Use IP_VS_RT_MODE_* instead of magic constants.David S. Miller
[ Add some cases I missed, from Julian Anastasov ] Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-3.6 Conflicts: drivers/net/benet/be_main.c
2011-05-10netfilter: revert a2361c8735e07322023aedc36e4938b35af31eb0Pablo Neira Ayuso
This patch reverts a2361c8735e07322023aedc36e4938b35af31eb0: "[PATCH] netfilter: xt_conntrack: warn about use in raw table" Florian Wesphal says: "... when the packet was sent from the local machine the skb already has ->nfct attached, and -m conntrack seems to do the right thing." Acked-by: Jan Engelhardt <jengelh@medozas.de> Reported-by: Florian Wesphal <fw@strlen.de> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-05-10netfilter: IPv6: fix DSCP mangle codeFernando Luis Vazquez Cao
The mask indicates the bits one wants to zero out, so it needs to be inverted before applying to the original TOS field. Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-05-10IPVS: init and cleanup restructuringHans Schillstrom
DESCRIPTION This patch tries to restore the initial init and cleanup sequences that was before namspace patch. Netns also requires action when net devices unregister which has never been implemented. I.e this patch also covers when a device moves into a network namespace, and has to be released. IMPLEMENTATION The number of calls to register_pernet_device have been reduced to one for the ip_vs.ko Schedulers still have their own calls. This patch adds a function __ip_vs_service_cleanup() and an enable flag for the netfilter hooks. The nf hooks will be enabled when the first service is loaded and never disabled again, except when a namespace exit starts. Signed-off-by: Hans Schillstrom <hans@schillstrom.com> Acked-by: Julian Anastasov <ja@ssi.bg> [horms@verge.net.au: minor edit to changelog] Signed-off-by: Simon Horman <horms@verge.net.au>
2011-05-10IPVS: Change of socket usage to enable name space exit.Hans Schillstrom
If the sync daemons run in a name space while it crashes or get killed, there is no way to stop them except for a reboot. When all patches are there, ip_vs_core will handle register_pernet_(), i.e. ip_vs_sync_init() and ip_vs_sync_cleanup() will be removed. Kernel threads should not increment the use count of a socket. By calling sk_change_net() after creating a socket this is avoided. sock_release cant be used intead sk_release_kernel() should be used. Thanks Eric W Biederman for your advices. Signed-off-by: Hans Schillstrom <hans@schillstrom.com> [horms@verge.net.au: minor edit to changelog] Signed-off-by: Simon Horman <horms@verge.net.au>
2011-05-10netfilter: fix ebtables compat supportEric Dumazet
commit 255d0dc34068a976 (netfilter: x_table: speedup compat operations) made ebtables not working anymore. 1) xt_compat_calc_jump() is not an exact match lookup 2) compat_table_info() has a typo in xt_compat_init_offsets() call 3) compat_do_replace() misses a xt_compat_init_offsets() call Reported-by: dann frazier <dannf@dannf.org> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-05-10netfilter: ctnetlink: fix timestamp support for new conntracksPablo Neira Ayuso
This patch fixes the missing initialization of the start time if the timestamp support is enabled. libnetfilter_conntrack/utils# conntrack -E & libnetfilter_conntrack/utils# ./conntrack_create tcp 6 109 ESTABLISHED src=1.1.1.1 dst=2.2.2.2 sport=1025 dport=21 packets=0 bytes=0 [UNREPLIED] src=2.2.2.2 dst=1.1.1.1 sport=21 dport=1025 packets=0 bytes=0 mark=0 delta-time=1303296401 use=2 Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-05-09IPVS: init and cleanup restructuringHans Schillstrom
2011-05-09IPVS: Change of socket usage to enable name space exit.Hans Schillstrom
2011-05-07net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu()Lai Jiangshan
The rcu callback xt_osf_finger_free_rcu() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(xt_osf_finger_free_rcu). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-07net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu()Lai Jiangshan
The rcu callback __nf_ct_ext_free_rcu() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(__nf_ct_ext_free_rcu). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-04-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Resolved logic conflicts causing a build failure due to drivers/net/r8169.c changes using a patch from Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-26Merge branch 'master' into for-nextJiri Kosina
Fast-forwarded to current state of Linus' tree as there are patches to be applied for files that didn't exist on the old branch.
2011-04-21netfilter: fix ebtables compat supportEric Dumazet
2011-04-21netfilter: ctnetlink: fix timestamp support for new conntracksPablo Neira Ayuso
2011-04-19Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
2011-04-19netfilter: ipset: Fix the order of listing of setsJozsef Kadlecsik
A restoreable saving of sets requires that list:set type of sets come last and the code part which should have taken into account the ordering was broken. The patch fixes the listing order. Signed-off-by: Jozsef Kadlecsik <kadlec@blackhole.kfki.hu> Signed-off-by: Patrick McHardy <kaber@trash.net>
2011-04-17netfilter: nf_conntrack_standalone: Fix set-but-unused variables.David S. Miller
The variable 'ret' is set but unused in ct_seq_show(). This was obviously meant to be used to propagate error codes to the caller, so make it so. Signed-off-by: David S. Miller <davem@davemloft.net>
