[ Upstream commit 7707a4d01a648e4c655101a469c956cb11273655 ]
While existing code is correct, KCSAN is reporting
a data-race in netlink_insert / netlink_sendmsg [1]
It is correct to read nlk->bound without a lock, as netlink_autobind()
will acquire all needed locks.
[1]
BUG: KCSAN: data-race in netlink_insert / netlink_sendmsg
write to 0xffff8881031c8b30 of 1 bytes by task 18752 on cpu 0:
netlink_insert+0x5cc/0x7f0 net/netlink/af_netlink.c:597
netlink_autobind+0xa9/0x150 net/netlink/af_netlink.c:842
netlink_sendmsg+0x479/0x7c0 net/netlink/af_netlink.c:1892
sock_sendmsg_nosec net/socket.c:703 [inline]
sock_sendmsg net/socket.c:723 [inline]
____sys_sendmsg+0x360/0x4d0 net/socket.c:2392
___sys_sendmsg net/socket.c:2446 [inline]
__sys_sendmsg+0x1ed/0x270 net/socket.c:2475
__do_sys_sendmsg net/socket.c:2484 [inline]
__se_sys_sendmsg net/socket.c:2482 [inline]
__x64_sys_sendmsg+0x42/0x50 net/socket.c:2482
do_syscall_x64 arch/x86/entry/common.c:50 [inline]
do_syscall_64+0x3d/0x90 arch/x86/entry/common.c:80
entry_SYSCALL_64_after_hwframe+0x44/0xae
read to 0xffff8881031c8b30 of 1 bytes by task 18751 on cpu 1:
netlink_sendmsg+0x270/0x7c0 net/netlink/af_netlink.c:1891
__sys_sendto+0x2a8/0x370 net/socket.c:2019
__do_sys_sendto net/socket.c:2031 [inline]
__se_sys_sendto net/socket.c:2027 [inline]
__x64_sys_sendto+0x74/0x90 net/socket.c:2027
value changed: 0x00 -> 0x01
Reported by Kernel Concurrency Sanitizer on:
CPU: 1 PID: 18751 Comm: syz-executor.0 Not tainted 5.14.0-rc1-syzkaller #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Fixes: da314c9923fe ("netlink: Replace rhash_portid with bound")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit fef773fc8110d8124c73a5e6610f89e52814637d ]
Yonghong Song report:
The bpf selftest tc_bpf failed with latest bpf-next.
The following is the command to run and the result:
$ ./test_progs -n 132
[ 40.947571] bpf_testmod: loading out-of-tree module taints kernel.
test_tc_bpf:PASS:test_tc_bpf__open_and_load 0 nsec
test_tc_bpf:PASS:bpf_tc_hook_create(BPF_TC_INGRESS) 0 nsec
test_tc_bpf:PASS:bpf_tc_hook_create invalid hook.attach_point 0 nsec
test_tc_bpf_basic:PASS:bpf_obj_get_info_by_fd 0 nsec
test_tc_bpf_basic:PASS:bpf_tc_attach 0 nsec
test_tc_bpf_basic:PASS:handle set 0 nsec
test_tc_bpf_basic:PASS:priority set 0 nsec
test_tc_bpf_basic:PASS:prog_id set 0 nsec
test_tc_bpf_basic:PASS:bpf_tc_attach replace mode 0 nsec
test_tc_bpf_basic:PASS:bpf_tc_query 0 nsec
libbpf: Kernel error message: Failed to send filter delete notification
test_tc_bpf_basic:FAIL:bpf_tc_detach unexpected error: -3 (errno 3)
test_tc_bpf:FAIL:test_tc_internal ingress unexpected error: -3 (errno 3)
The failure seems due to the commit
cfdf0d9ae75b ("rtnetlink: use nlmsg_notify() in rtnetlink_send()")
Deal with ESRCH error in nlmsg_notify() even the report variable is zero.
Reported-by: Yonghong Song <yhs@fb.com>
Signed-off-by: Yajun Deng <yajun.deng@linux.dev>
Link: https://lore.kernel.org/r/20210719051816.11762-1-yajun.deng@linux.dev
Signed-off-by: Jakub Kicinski <kuba@kernel.org>
[ Upstream commit 1d482e666b8e74c7555dbdfbfb77205eeed3ff2d ]
Syzbot reports that in mac80211 we have a potential deadlock
between our "local->stop_queue_reasons_lock" (spinlock) and
netlink's nl_table_lock (rwlock). This is because there's at
least one situation in which we might try to send a netlink
message with this spinlock held while it is also possible to
take the spinlock from a hardirq context, resulting in the
following deadlock scenario reported by lockdep:
CPU0 CPU1
lock(nl_table_lock);
local_irq_disable();
lock(&local->queue_stop_reason_lock);
<Interrupt>
This seems valid, we can take the queue_stop_reason_lock in
any kind of context ("CPU0"), and call ieee80211_report_ack_skb()
with the spinlock held and IRQs disabled ("CPU1") in some
code path (ieee80211_do_stop() via ieee80211_free_txskb()).
Short of disallowing netlink use in scenarios like these
(which would be rather complex in mac80211's case due to
the deep callchain), it seems the only fix for this is to
disable IRQs while nl_table_lock is held to avoid hitting
this scenario, this disallows the "CPU0" portion of the
reported deadlock.
Note that the writer side (netlink_table_grab()) already
disables IRQs for this lock.
Unfortunately though, this seems like a huge hammer, and
maybe the whole netlink table locking should be reworked.
Reported-by: syzbot+69ff9dff50dcfe14ddd4@syzkaller.appspotmail.com
commit 3a20773beeeeadec41477a5ba872175b778ff752 upstream.
Since nl_groups is a u32 we can't bind more groups via ->bind
(netlink_bind) call, but netlink has supported more groups via
setsockopt() for a long time and thus nlk->ngroups could be over 32.
Recently I added support for per-vlan notifications and increased the
groups to 33 for NETLINK_ROUTE which exposed an old bug in the
netlink_bind() code causing out-of-bounds access on archs where unsigned
long is 32 bits via test_bit() on a local variable. Fix this by capping the
maximum groups in netlink_bind() to BITS_PER_TYPE(u32), effectively
capping them at 32 which is the minimum of allocated groups and the
maximum groups which can be bound via netlink_bind().
CC: Christophe Leroy <christophe.leroy@c-s.fr>
CC: Richard Guy Briggs <rgb@redhat.com>
Fixes: 4f520900522f ("netlink: have netlink per-protocol bind function return an error code.")
Reported-by: Erhard F. <erhard_f@mailbox.org>
Signed-off-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
commit 91874ecf32e41b5d86a4cb9d60e0bee50d828058 upstream.
It's legal to have 64 groups for netlink_sock.
As user-supplied nladdr->nl_groups is __u32, it's possible to subscribe
only to first 32 groups.
The check for correctness of .bind() userspace supplied parameter
is done by applying mask made from ngroups shift. Which broke Android
as they have 64 groups and the shift for mask resulted in an overflow.
Fixes: 61f4b23769f0 ("netlink: Don't shift with UB on nlk->ngroups")
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
Cc: netdev@vger.kernel.org
Cc: stable@vger.kernel.org
Reported-and-Tested-by: Nathan Chancellor <natechancellor@gmail.com>
Signed-off-by: Dmitry Safonov <dima@arista.com>
[ Upstream commit 61f4b23769f0cc72ae62c9a81cf08f0397d40da8 ]
On i386 nlk->ngroups might be 32 or 0. Which leads to UB, resulting in
hang during boot.
Check for 0 ngroups and use (unsigned long long) as a type to shift.
Fixes: 7acf9d4237c4 ("netlink: Do not subscribe to non-existent groups").
Reported-by: kernel test robot <rong.a.chen@intel.com>
[ Upstream commit 7acf9d4237c46894e0fa0492dd96314a41742e84 ]
Make ABI more strict about subscribing to group > ngroups.
Code doesn't check for that and it looks bogus.
(one can subscribe to non-existing group)
Still, it's possible to bind() to all possible groups with (-1)
[ Upstream commit bc5b6c0b62b932626a135f516a41838c510c6eba ]
'protocol' is a user-controlled value, so sanitize it after the bounds
check to avoid using it for speculative out-of-bounds access to arrays
indexed by it.
This addresses the following accesses detected with the help of smatch:
* net/netlink/af_netlink.c:654 __netlink_create() warn: potential
spectre issue 'nlk_cb_mutex_keys' [w]
spectre issue 'nlk_cb_mutex_key_strings' [w]
* net/netlink/af_netlink.c:685 netlink_create() warn: potential spectre
issue 'nl_table' [w] (local cap)
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Signed-off-by: Jeremy Cline <jcline@redhat.com>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
commit 6091f09c2f79730d895149bcfe3d66140288cd0e upstream.
syzbot reported :
BUG: KMSAN: uninit-value in ffs arch/x86/include/asm/bitops.h:432 [inline]
BUG: KMSAN: uninit-value in netlink_sendmsg+0xb26/0x1310 net/netlink/af_netlink.c:1851
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
[ Upstream commit 7880287981b60a6808f39f297bb66936e8bdf57a ]
KMSAN reports use of uninitialized memory in the case when |alen| is
smaller than sizeof(struct sockaddr_nl), and therefore |nladdr| isn't
fully copied from the userspace.
Signed-off-by: Alexander Potapenko <glider@google.com>
Fixes: 1da177e4c3f41524 ("Linux-2.6.12-rc2")
Reviewed-by: Eric Dumazet <edumazet@google.com>
[ Upstream commit 93c647643b48f0131f02e45da3bd367d80443291 ]
Currently, a nlmon link inside a child namespace can observe systemwide
netlink activity. Filter the traffic so that nlmon can only sniff
netlink messages from its own netns.
Test case:
vpnns -- bash -c "ip link add nlmon0 type nlmon; \
ip link set nlmon0 up; \
tcpdump -i nlmon0 -q -w /tmp/nlmon.pcap -U" &
sudo ip xfrm state add src 10.1.1.1 dst 10.1.1.2 proto esp \
spi 0x1 mode transport \
auth sha1 0x6162633132330000000000000000000000000000 \
enc aes 0x00000000000000000000000000000000
grep --binary abc123 /tmp/nlmon.pcap
Signed-off-by: Kevin Cernekee <cernekee@chromium.org>
[ Upstream commit 8a0f5ccfb33b0b8b51de65b7b3bf342ba10b4fb6 ]
On Tue, Mar 14, 2017 at 10:44:10AM +0100, Dmitry Vyukov wrote:
> Yes, please.
> Disregarding some reports is not a good way long term.
Please try this patch.
---8<---
Subject: netlink: Annotate nlk cb_mutex by protocol
Currently all occurences of nlk->cb_mutex are annotated by lockdep
as a single class. This causes a false lcokdep cycle involving
genl and crypto_user.
This patch fixes it by dividing cb_mutex into individual classes
based on the netlink protocol. As genl and crypto_user do not
use the same netlink protocol this breaks the false dependency
loop.
commit fc9e50f5a5a4e1fa9ba2756f745a13e693cf6a06 upstream.
The start callback allows the caller to set up a context for the
dump callbacks. Presumably, the context can then be destroyed in
the done callback.
Signed-off-by: Tom Herbert <tom@herbertland.com>
[ Upstream commit 0642840b8bb008528dbdf929cec9f65ac4231ad0 ]
The way people generally use netlink_dump is that they fill in the skb
as much as possible, breaking when nla_put returns an error. Then, they
get called again and start filling out the next skb, and again, and so
forth. The mechanism at work here is the ability for the iterative
dumping function to detect when the skb is filled up and not fill it
past the brim, waiting for a fresh skb for the rest of the data.
However, if the attributes are small and nicely packed, it is possible
that a dump callback function successfully fills in attributes until the
skb is of size 4080 (libmnl's default page-sized receive buffer size).
The dump function completes, satisfied, and then, if it happens to be
that this is actually the last skb, and no further ones are to be sent,
then netlink_dump will add on the NLMSG_DONE part:
nlh = nlmsg_put_answer(skb, cb, NLMSG_DONE, sizeof(len), NLM_F_MULTI);
It is very important that netlink_dump does this, of course. However, in
this example, that call to nlmsg_put_answer will fail, because the
previous filling by the dump function did not leave it enough room. And
how could it possibly have done so? All of the nla_put variety of
functions simply check to see if the skb has enough tailroom,
independent of the context it is in.
In order to keep the important assumptions of all netlink dump users, it
is therefore important to give them an skb that has this end part of the
tail already reserved, so that the call to nlmsg_put_answer does not
fail. Otherwise, library authors are forced to find some bizarre sized
receive buffer that has a large modulo relative to the common sizes of
messages received, which is ugly and buggy.
This patch thus saves the NLMSG_DONE for an additional message, for the
case that things are dangerously close to the brim. This requires
keeping track of the errno from ->dump() across calls.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
The backport of d35c99ff77ec ("netlink: do not enter direct reclaim from
netlink_dump()") to the 4.4 branch (first in 4.4.32) mistakenly removed
direct claim from the initial large allocation _and_ the fallback
allocation which means that allocations can spuriously fail.
Fix the issue by adding back the direct reclaim flag to the fallback
allocation.
Fixes: 6d123f1d396b ("netlink: do not enter direct reclaim from netlink_dump()")
Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com>
commit d1b4c689d4130bcfd3532680b64db562300716b6 upstream.
mmapped netlink has a number of unresolved issues:
- TX zerocopy support had to be disabled more than a year ago via
commit 4682a0358639b29cf ("netlink: Always copy on mmap TX.")
because the content of the mmapped area can change after netlink
attribute validation but before message processing.
- RX support was implemented mainly to speed up nfqueue dumping packet
payload to userspace. However, since commit ae08ce0021087a5d812d2
("netfilter: nfnetlink_queue: zero copy support") we avoid one copy
with the socket-based interface too (via the skb_zerocopy helper).
The other problem is that skbs attached to mmaped netlink socket
behave different from normal skbs:
- they don't have a shinfo area, so all functions that use skb_shinfo()
(e.g. skb_clone) cannot be used.
- reserving headroom prevents userspace from seeing the content as
it expects message to start at skb->head.
See for instance
commit aa3a022094fa ("netlink: not trim skb for mmaped socket when dump").
- skbs handed e.g. to netlink_ack must have non-NULL skb->sk, else we
crash because it needs the sk to check if a tx ring is attached.
Also not obvious, leads to non-intuitive bug fixes such as 7c7bdf359
("netfilter: nfnetlink: use original skbuff when acking batches").
mmaped netlink also didn't play nicely with the skb_zerocopy helper
used by nfqueue and openvswitch. Daniel Borkmann fixed this via
commit 6bb0fef489f6 ("netlink, mmap: fix edge-case leakages in nf queue
zero-copy")' but at the cost of also needing to provide remaining
length to the allocation function.
nfqueue also has problems when used with mmaped rx netlink:
- mmaped netlink doesn't allow use of nfqueue batch verdict messages.
Problem is that in the mmap case, the allocation time also determines
the ordering in which the frame will be seen by userspace (A
allocating before B means that A is located in earlier ring slot,
but this also means that B might get a lower sequence number then A
since seqno is decided later. To fix this we would need to extend the
spinlocked region to also cover the allocation and message setup which
isn't desirable.
- nfqueue can now be configured to queue large (GSO) skbs to userspace.
Queing GSO packets is faster than having to force a software segmentation
in the kernel, so this is a desirable option. However, with a mmap based
ring one has to use 64kb per ring slot element, else mmap has to fall back
to the socket path (NL_MMAP_STATUS_COPY) for all large packets.
To use the mmap interface, userspace not only has to probe for mmap netlink
support, it also has to implement a recv/socket receive path in order to
handle messages that exceed the size of an rx ring element.
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Ken-ichirou MATSUZAWA <chamaken@gmail.com>
Cc: Pablo Neira Ayuso <pablo@netfilter.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Thomas Graf <tgraf@suug.ch>
Cc: Shi Yuejie <shiyuejie@outlook.com>
[ Upstream commit ed5d7788a934a4b6d6d025e948ed4da496b4f12e ]
It is wrong to schedule a work from sk_destruct using the socket
as the memory reserve because the socket will be freed immediately
after the return from sk_destruct.
Instead we should do the deferral prior to sk_free.
This patch does just that.
Fixes: 707693c8a498 ("netlink: Call cb->done from a worker thread")
Tested-by: Andrey Konovalov <andreyknvl@google.com>
[ Upstream commit 707693c8a498697aa8db240b93eb76ec62e30892 ]
The cb->done interface expects to be called in process context.
This was broken by the netlink RCU conversion. This patch fixes
it by adding a worker struct to make the cb->done call where
necessary.
Fixes: 21e4902aea80 ("netlink: Lockless lookup with RCU grace...")
Reported-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
[ Upstream commit d35c99ff77ecb2eb239731b799386f3b3637a31e ]
Since linux-3.15, netlink_dump() can use up to 16384 bytes skb
allocations.
Due to struct skb_shared_info ~320 bytes overhead, we end up using
order-3 (on x86) page allocations, that might trigger direct reclaim and
add stress.
The intent was really to attempt a large allocation but immediately
fallback to a smaller one (order-1 on x86) in case of memory stress.
On recent kernels (linux-4.4), we can remove __GFP_DIRECT_RECLAIM to
meet the goal. Old kernels would need to remove __GFP_WAIT
While we are at it, since we do an order-3 allocation, allow to use
all the allocated bytes instead of 16384 to reduce syscalls during
large dumps.
iproute2 already uses 32KB recvmsg() buffer sizes.
Alexei provided an initial patch downsizing to SKB_WITH_OVERHEAD(16384)
Fixes: 9063e21fb026 ("netlink: autosize skb lengthes")
Reported-by: Alexei Starovoitov <ast@kernel.org>
Reviewed-by: Greg Rose <grose@lightfleet.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit 92964c79b357efd980812c4de5c1fd2ec8bb5520 ]
When we free cb->skb after a dump, we do it after releasing the
lock. This means that a new dump could have started in the time
being and we'll end up freeing their skb instead of ours.
This patch saves the skb and module before we unlock so we free
the right memory.
Fixes: 16b304f3404f ("netlink: Eliminate kmalloc in netlink dump operation.")
Reported-by: Baozeng Ding <sploving1@gmail.com>
commit e27260203912b40751fa353d009eaa5a642c739f upstream.
All existing users of NETLINK_URELEASE use it to clean up resources that
were previously allocated to a socket via some command. As a result, no
users require getting this notification for unbound sockets.
Sending it for unbound sockets, however, is a problem because any user
(including unprivileged users) can create a socket that uses the same ID
as an existing socket. Binding this new socket will fail, but if the
NETLINK_URELEASE notification is generated for such sockets, the users
thereof will be tricked into thinking the socket that they allocated the
resources for is closed.
In the nl80211 case, this will cause destruction of virtual interfaces
that still belong to an existing hostapd process; this is the case that
Dmitry noticed. In the NFC case, it will cause a poll abort. In the case
of netlink log/queue it will cause them to stop reporting events, as if
NFULNL_CFG_CMD_UNBIND/NFQNL_CFG_CMD_UNBIND had been called.
Fix this problem by checking that the socket is bound before generating
the NETLINK_URELEASE notification.
Signed-off-by: Dmitry Ivanov <dima@ubnt.com>
sleep and avoiding waking kswapd
__GFP_WAIT has been used to identify atomic context in callers that hold
spinlocks or are in interrupts. They are expected to be high priority and
have access one of two watermarks lower than "min" which can be referred
to as the "atomic reserve". __GFP_HIGH users get access to the first
lower watermark and can be called the "high priority reserve".
Over time, callers had a requirement to not block when fallback options
were available. Some have abused __GFP_WAIT leading to a situation where
an optimisitic allocation with a fallback option can access atomic
reserves.
This patch uses __GFP_ATOMIC to identify callers that are truely atomic,
cannot sleep and have no alternative. High priority users continue to use
__GFP_HIGH. __GFP_DIRECT_RECLAIM identifies callers that can sleep and
are willing to enter direct reclaim. __GFP_KSWAPD_RECLAIM to identify
callers that want to wake kswapd for background reclaim. __GFP_WAIT is
redefined as a caller that is willing to enter direct reclaim and wake
This patch then converts a number of sites
o __GFP_ATOMIC is used by callers that are high priority and have memory
pools for those requests. GFP_ATOMIC uses this flag.
o Callers that have a limited mempool to guarantee forward progress clear
__GFP_DIRECT_RECLAIM but keep __GFP_KSWAPD_RECLAIM. bio allocations fall
into this category where kswapd will still be woken but atomic reserves
are not used as there is a one-entry mempool to guarantee progress.
o Callers that are checking if they are non-blocking should use the
helper gfpflags_allow_blocking() where possible. This is because
checking for __GFP_WAIT as was done historically now can trigger false
positives. Some exceptions like dm-crypt.c exist where the code intent
is clearer if __GFP_DIRECT_RECLAIM is used instead of the helper due to
flag manipulations.
o Callers that built their own GFP flags instead of starting with GFP_KERNEL
and friends now also need to specify __GFP_KSWAPD_RECLAIM.
The first key hazard to watch out for is callers that removed __GFP_WAIT
and was depending on access to atomic reserves for inconspicuous reasons.
In some cases it may be appropriate for them to use __GFP_HIGH.
The second key hazard is callers that assembled their own combination of
GFP flags instead of starting with something like GFP_KERNEL. They may
now wish to specify __GFP_KSWAPD_RECLAIM. It's almost certainly harmless
if it's missed in most cases as other activity will wake kswapd.
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Christoph Lameter <cl@linux.com>
Cc: Vitaly Wool <vitalywool@gmail.com>
Currently, NETLINK_LIST_MEMBERSHIPS grabs the netlink table while copying
the membership state to user-space. However, grabing the netlink table is
effectively a write_lock_irq(), and as such we should not be triggering
page-faults in the critical section.
This can be easily reproduced by the following snippet:
int s = socket(AF_NETLINK, SOCK_RAW, NETLINK_ROUTE);
void *p = mmap(0, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANON, -1, 0);
int r = getsockopt(s, 0x10e, 9, p, (void*)((char*)p + 4092));
This should work just fine, but currently triggers EFAULT and a possible
WARN_ON below handle_mm_fault().
Fix this by reducing locking of NETLINK_LIST_MEMBERSHIPS to a read-side
lock. The write-lock was overkill in the first place, and the read-lock
allows page-faults just fine.
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
netlink_dump() allocates skb based on the calculated min_dump_alloc or
a per socket max_recvmsg_len.
min_alloc_size is maximum space required for any single netdev
attributes as calculated by rtnl_calcit().
max_recvmsg_len tracks the user provided buffer to netlink_recvmsg.
It is capped at 16KiB.
The intention is to avoid small allocations and to minimize the number
of calls required to obtain dump information for all net devices.
netlink_dump packs as many small messages as could fit within an skb
that was sized for the largest single netdev information. The actual
space available within an skb is larger than what is requested. It could
be much larger and up to near 2x with align to next power of 2 approach.
Allowing netlink_dump to use all the space available within the
allocated skb increases the buffer size a user has to provide to avoid
truncaion (i.e. MSG_TRUNG flag set).
It was observed that with many VLANs configured on at least one netdev,
a larger buffer of near 64KiB was necessary to avoid "Message truncated"
error in "ip link" or "bridge [-c[ompressvlans]] vlan show" when
min_alloc_size was only little over 32KiB.
This patch trims skb to allocated size in order to allow the user to
avoid truncation with more reasonable buffer size.
Signed-off-by: Ronen Arad <ronen.arad@intel.com>
On Mon, Sep 21, 2015 at 02:20:22PM -0400, Tejun Heo wrote:
> store_release and load_acquire are different from the usual memory
> barriers and can't be paired this way. You have to pair store_release
> and load_acquire. Besides, it isn't a particularly good idea to
OK I've decided to drop the acquire/release helpers as they don't
help us at all and simply pessimises the code by using full memory
barriers (on some architectures) where only a write or read barrier
is needed.
> depend on memory barriers embedded in other data structures like the
> above. Here, especially, rhashtable_insert() would have write barrier
> *before* the entry is hashed not necessarily *after*, which means that
> in the above case, a socket which appears to have set bound to a
> reader might not visible when the reader tries to look up the socket
> on the hashtable.
But you are right we do need an explicit write barrier here to
ensure that the hashing is visible.
> There's no reason to be overly smart here. This isn't a crazy hot
> path, write barriers tend to be very cheap, store_release more so.
> Please just do smp_store_release() and note what it's paired with.
It's not about being overly smart. It's about actually understanding
what's going on with the code. I've seen too many instances of
people simply sprinkling synchronisation primitives around without
any knowledge of what is happening underneath, which is just a recipe
for creating hard-to-debug races.
> > @@ -1539,7 +1546,7 @@ static int netlink_bind(struct socket *sock, struct sockaddr *addr,
> > - if (!nlk->portid) {
> > + if (!nlk->bound) {
> I don't think you can skip load_acquire here just because this is the
> second deref of the variable. That doesn't change anything. Race
> condition could still happen between the first and second tests and
> skipping the second would lead to the same kind of bug.
The reason this one is OK is because we do not use nlk->portid or
try to get nlk from the hash table before we return to user-space.
However, there is a real bug here that none of these acquire/release
helpers discovered. The two bound tests here used to be a single
one. Now that they are separate it is entirely possible for another
thread to come in the middle and bind the socket. So we need to
repeat the portid check in order to maintain consistency.
> > @@ -1587,7 +1594,7 @@ static int netlink_connect(struct socket *sock, struct sockaddr *addr,
> > !netlink_allowed(sock, NL_CFG_F_NONROOT_SEND))
> > return -EPERM;
> > - if (!nlk->portid)
> > + if (!nlk->bound)
> Don't we need load_acquire here too? Is this path holding a lock
> which makes that unnecessary?
Ditto.
---8<---
The commit 1f770c0a09da855a2b51af6d19de97fb955eca85 ("netlink:
Fix autobind race condition that leads to zero port ID") created
some new races that can occur due to inconcsistencies between the
two port IDs.
Tejun is right that a barrier is unavoidable. Therefore I am
reverting to the original patch that used a boolean to indicate
that a user netlink socket has been bound.
Barriers have been added where necessary to ensure that a valid
portid and the hashed socket is visible.
I have also changed netlink_insert to only return EBUSY if the
socket is bound to a portid different to the requested one. This
combined with only reading nlk->bound once in netlink_bind fixes
a race where two threads that bind the socket at the same time
with different port IDs may both succeed.
Fixes: 1f770c0a09da ("netlink: Fix autobind race condition that leads to zero port ID")
Reported-by: Tejun Heo <tj@kernel.org>
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Nacked-by: Tejun Heo <tj@kernel.org>
The commit c0bb07df7d981e4091432754e30c9c720e2c0c78 ("netlink:
Reset portid after netlink_insert failure") introduced a race
condition where if two threads try to autobind the same socket
one of them may end up with a zero port ID. This led to kernel
deadlocks that were observed by multiple people.
This patch reverts that commit and instead fixes it by introducing
a separte rhash_portid variable so that the real portid is only set
after the socket has been successfully hashed.
Fixes: c0bb07df7d98 ("netlink: Reset portid after netlink_insert failure")
Ken-ichirou reported that running netlink in mmap mode for receive in
combination with nlmon will throw a NULL pointer dereference in
__kfree_skb() on nlmon_xmit(), in my case I can also trigger an "unable
to handle kernel paging request". The problem is the skb_clone() in
__netlink_deliver_tap_skb() for skbs that are mmaped.
I.e. the cloned skb doesn't have a destructor, whereas the mmap netlink
skb has it pointed to netlink_skb_destructor(), set in the handler
netlink_ring_setup_skb(). There, skb->head is being set to NULL, so
that in such cases, __kfree_skb() doesn't perform a skb_release_data()
via skb_release_all(), where skb->head is possibly being freed through
kfree(head) into slab allocator, although netlink mmap skb->head points
to the mmap buffer. Similarly, the same has to be done also for large
netlink skbs where the data area is vmalloced. Therefore, as discussed,
make a copy for these rather rare cases for now. This fixes the issue
on my and Ken-ichirou's test-cases.
Reference: http://thread.gmane.org/gmane.linux.network/371129
Fixes: bcbde0d449ed ("net: netlink: virtual tap device management")
Reported-by: Ken-ichirou MATSUZAWA <chamaken@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Tested-by: Ken-ichirou MATSUZAWA <chamaken@gmail.com>
When netlink mmap on receive side is the consumer of nf queue data,
it can happen that in some edge cases, we write skb shared info into
the user space mmap buffer:
Assume a possible rx ring frame size of only 4096, and the network skb,
which is being zero-copied into the netlink skb, contains page frags
with an overall skb->len larger than the linear part of the netlink
skb.
skb_zerocopy(), which is generic and thus not aware of the fact that
shared info cannot be accessed for such skbs then tries to write and
fill frags, thus leaking kernel data/pointers and in some corner cases
possibly writing out of bounds of the mmap area (when filling the
last slot in the ring buffer this way).
I.e. the ring buffer slot is then of status NL_MMAP_STATUS_VALID, has
an advertised length larger than 4096, where the linear part is visible
at the slot beginning, and the leaked sizeof(struct skb_shared_info)
has been written to the beginning of the next slot (also corrupting
the struct nl_mmap_hdr slot header incl. status etc), since skb->end
points to skb->data + ring->frame_size - NL_MMAP_HDRLEN.
The fix adds and lets __netlink_alloc_skb() take the actual needed
linear room for the network skb + meta data into account. It's completely
irrelevant for non-mmaped netlink sockets, but in case mmap sockets
are used, it can be decided whether the available skb_tailroom() is
really large enough for the buffer, or whether it needs to internally
fallback to a normal alloc_skb().
>From nf queue side, the information whether the destination port is
an mmap RX ring is not really available without extra port-to-socket
lookup, thus it can only be determined in lower layers i.e. when
__netlink_alloc_skb() is called that checks internally for this. I
chose to add the extra ldiff parameter as mmap will then still work:
We have data_len and hlen in nfqnl_build_packet_message(), data_len
is the full length (capped at queue->copy_range) for skb_zerocopy()
and hlen some possible part of data_len that needs to be copied; the
rem_len variable indicates the needed remaining linear mmap space.
The only other workaround in nf queue internally would be after
allocation time by f.e. cap'ing the data_len to the skb_tailroom()
iff we deal with an mmap skb, but that would 1) expose the fact that
we use a mmap skb to upper layers, and 2) trim the skb where we
otherwise could just have moved the full skb into the normal receive
queue.
After the patch, in my test case the ring slot doesn't fit and therefore
shows NL_MMAP_STATUS_COPY, where a full skb carries all the data and
thus needs to be picked up via recv().
Fixes: 3ab1f683bf8b ("nfnetlink: add support for memory mapped netlink")
In case of netlink mmap, there can be situations where received frames
have to be placed into the normal receive queue. The ring buffer indicates
this through NL_MMAP_STATUS_COPY, so the user is asked to pick them up
via recvmsg(2) syscall, and to put the slot back to NL_MMAP_STATUS_UNUSED.
Commit 0ef707700f1c ("netlink: rx mmap: fix POLLIN condition") changed
polling, so that we walk in the worst case the whole ring through the
new netlink_has_valid_frame(), for example, when the ring would have no
NL_MMAP_STATUS_VALID, but at least one NL_MMAP_STATUS_COPY frame.
Since we do a datagram_poll() already earlier to pick up a mask that could
possibly contain POLLIN | POLLRDNORM already (due to NL_MMAP_STATUS_COPY),
we can skip checking the rx ring entirely.
In case the kernel is compiled with !CONFIG_NETLINK_MMAP, then all this is
irrelevant anyway as netlink_poll() is just defined as datagram_poll().
Poll() returns immediately after setting the kernel current frame
(ring->head) to SKIP from user space even though there is no new
frame. And in a case of all frames is VALID, user space program
unintensionally sets (only) kernel current frame to UNUSED, then
calls poll(), it will not return immediately even though there are
VALID frames.
To avoid situations like above, I think we need to scan all frames
to find VALID frames at poll() like netlink_alloc_skb(),
netlink_forward_ring() finding an UNUSED frame at skb allocation.
Signed-off-by: Ken-ichirou MATSUZAWA <chamas@h4.dion.ne.jp>
__netlink_lookup_frame() was always called with the same "pos"
value in netlink_forward_ring(). It will look at the same ring entry
header over and over again, every time through this loop. Then cycle
through the whole ring, advancing ring->head, not "pos" until it
equals the "ring->head != head" loop test fails.
Since commit c05cdb1b864f ("netlink: allow large data transfers from
user-space"), the kernel may fail to allocate the necessary room for the
acknowledgment message back to userspace. This patch introduces a new
socket option that trims off the payload of the original netlink message.
The netlink message header is still included, so the user can guess from
the sequence number what is the message that has triggered the
acknowledgment.
Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com>
I can't send netlink message via mmaped netlink socket since
commit: a8866ff6a5bce7d0ec465a63bc482a85c09b0d39
netlink: make the check for "send from tx_ring" deterministic
msg->msg_iter.type is set to WRITE (1) at
SYSCALL_DEFINE6(sendto, ...
import_single_range(WRITE, ...
iov_iter_init(1, WRITE, ...
call path, so that we need to check the type by iter_is_iovec()
to accept the WRITE.
Linus reports the following deadlock on rtnl_mutex; triggered only
once so far (extract):
[12236.694209] NetworkManager D 0000000000013b80 0 1047 1 0x00000000
[12236.694218] ffff88003f902640 0000000000000000 ffffffff815d15a9 0000000000000018
[12236.694224] ffff880119538000 ffff88003f902640 ffffffff81a8ff84 00000000ffffffff
[12236.694230] ffffffff81a8ff88 ffff880119c47f00 ffffffff815d133a ffffffff81a8ff80
[12236.694235] Call Trace:
[12236.694250] [<ffffffff815d15a9>] ? schedule_preempt_disabled+0x9/0x10
[12236.694257] [<ffffffff815d133a>] ? schedule+0x2a/0x70
[12236.694263] [<ffffffff815d15a9>] ? schedule_preempt_disabled+0x9/0x10
[12236.694271] [<ffffffff815d2c3f>] ? __mutex_lock_slowpath+0x7f/0xf0
[12236.694280] [<ffffffff815d2cc6>] ? mutex_lock+0x16/0x30
[12236.694291] [<ffffffff814f1f90>] ? rtnetlink_rcv+0x10/0x30
[12236.694299] [<ffffffff8150ce3b>] ? netlink_unicast+0xfb/0x180
[12236.694309] [<ffffffff814f5ad3>] ? rtnl_getlink+0x113/0x190
[12236.694319] [<ffffffff814f202a>] ? rtnetlink_rcv_msg+0x7a/0x210
[12236.694331] [<ffffffff8124565c>] ? sock_has_perm+0x5c/0x70
[12236.694339] [<ffffffff814f1fb0>] ? rtnetlink_rcv+0x30/0x30
[12236.694346] [<ffffffff8150d62c>] ? netlink_rcv_skb+0x9c/0xc0
[12236.694354] [<ffffffff814f1f9f>] ? rtnetlink_rcv+0x1f/0x30
[12236.694360] [<ffffffff8150ce3b>] ? netlink_unicast+0xfb/0x180
[12236.694367] [<ffffffff8150d344>] ? netlink_sendmsg+0x484/0x5d0
[12236.694376] [<ffffffff810a236f>] ? __wake_up+0x2f/0x50
[12236.694387] [<ffffffff814cad23>] ? sock_sendmsg+0x33/0x40
[12236.694396] [<ffffffff814cb05e>] ? ___sys_sendmsg+0x22e/0x240
[12236.694405] [<ffffffff814cab75>] ? ___sys_recvmsg+0x135/0x1a0
[12236.694415] [<ffffffff811a9d12>] ? eventfd_write+0x82/0x210
[12236.694423] [<ffffffff811a0f9e>] ? fsnotify+0x32e/0x4c0
[12236.694429] [<ffffffff8108cb70>] ? wake_up_q+0x60/0x60
[12236.694434] [<ffffffff814cba09>] ? __sys_sendmsg+0x39/0x70
[12236.694440] [<ffffffff815d4797>] ? entry_SYSCALL_64_fastpath+0x12/0x6a
It seems so far plausible that the recursive call into rtnetlink_rcv()
looks suspicious. One way, where this could trigger is that the senders
NETLINK_CB(skb).portid was wrongly 0 (which is rtnetlink socket), so
the rtnl_getlink() request's answer would be sent to the kernel instead
to the actual user process, thus grabbing rtnl_mutex() twice.
One theory would be that netlink_autobind() triggered via netlink_sendmsg()
internally overwrites the -EBUSY error to 0, but where it is wrongly
originating from __netlink_insert() instead. That would reset the
socket's portid to 0, which is then filled into NETLINK_CB(skb).portid
later on. As commit d470e3b483dc ("[NETLINK]: Fix two socket hashing bugs.")
also puts it, -EBUSY should not be propagated from netlink_insert().
It looks like it's very unlikely to reproduce. We need to trigger the
rhashtable_insert_rehash() handler under a situation where rehashing
currently occurs (one /rare/ way would be to hit ht->elasticity limits
while not filled enough to expand the hashtable, but that would rather
require a specifically crafted bind() sequence with knowledge about
destination slots, seems unlikely). It probably makes sense to guard
__netlink_insert() in any case and remap that error. It was suggested
that EOVERFLOW might be better than an already overloaded ENOMEM.
Reference: http://thread.gmane.org/gmane.linux.network/372676
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Acked-by: Thomas Graf <tgraf@suug.ch>
Kirill A. Shutemov says:
This simple test-case trigers few locking asserts in kernel:
int main(int argc, char **argv)
unsigned int block_size = 16 * 4096;
struct nl_mmap_req req = {
.nm_block_size = block_size,
.nm_block_nr = 64,
.nm_frame_size = 16384,
.nm_frame_nr = 64 * block_size / 16384,
unsigned int ring_size;
int fd;
fd = socket(AF_NETLINK, SOCK_RAW, NETLINK_GENERIC);
if (setsockopt(fd, SOL_NETLINK, NETLINK_RX_RING, &req, sizeof(req)) < 0)
exit(1);
if (setsockopt(fd, SOL_NETLINK, NETLINK_TX_RING, &req, sizeof(req)) < 0)
exit(1);
ring_size = req.nm_block_nr * req.nm_block_size;
mmap(NULL, 2 * ring_size, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0);
return 0;
+++ exited with 0 +++
BUG: sleeping function called from invalid context at /home/kas/git/public/linux-mm/kernel/locking/mutex.c:616
in_atomic(): 1, irqs_disabled(): 0, pid: 1, name: init
3 locks held by init/1:
#0: (reboot_mutex){+.+...}, at: [<ffffffff81080959>] SyS_reboot+0xa9/0x220
#1: ((reboot_notifier_list).rwsem){.+.+..}, at: [<ffffffff8107f379>] __blocking_notifier_call_chain+0x39/0x70
#2: (rcu_callback){......}, at: [<ffffffff810d32e0>] rcu_do_batch.isra.49+0x160/0x10c0
Preemption disabled at:[<ffffffff8145365f>] __delay+0xf/0x20
CPU: 1 PID: 1 Comm: init Not tainted 4.1.0-00009-gbddf4c4818e0 #253
Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS Debian-1.8.2-1 04/01/2014
ffff88017b3d8000 ffff88027bc03c38 ffffffff81929ceb 0000000000000102
0000000000000000 ffff88027bc03c68 ffffffff81085a9d 0000000000000002
ffffffff81ca2a20 0000000000000268 0000000000000000 ffff88027bc03c98
Call Trace:
<IRQ> [<ffffffff81929ceb>] dump_stack+0x4f/0x7b
[<ffffffff81085a9d>] ___might_sleep+0x16d/0x270
[<ffffffff81085bed>] __might_sleep+0x4d/0x90
[<ffffffff8192e96f>] mutex_lock_nested+0x2f/0x430
[<ffffffff81932fed>] ? _raw_spin_unlock_irqrestore+0x5d/0x80
[<ffffffff81464143>] ? __this_cpu_preempt_check+0x13/0x20
[<ffffffff8182fc3d>] netlink_set_ring+0x1ed/0x350
[<ffffffff8182e000>] ? netlink_undo_bind+0x70/0x70
[<ffffffff8182fe20>] netlink_sock_destruct+0x80/0x150
[<ffffffff817e484d>] __sk_free+0x1d/0x160
[<ffffffff817e49a9>] sk_free+0x19/0x20
Cong Wang says:
We can't hold mutex lock in a rcu callback, [..]
Thomas Graf says:
The socket should be dead at this point. It might be simpler to
add a netlink_release_ring() function which doesn't require
locking at all.
Reported-by: "Kirill A. Shutemov" <kirill@shutemov.name>
Diagnosed-by: Cong Wang <cwang@twopensource.com>
Suggested-by: Thomas Graf <tgraf@suug.ch>
The module_put() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
This patch adds getsockopt(SOL_NETLINK, NETLINK_LIST_MEMBERSHIPS) to
retrieve all groups a socket is a member of. Currently, we have to use
getsockname() and look at the nl.nl_groups bitmask. However, this mask is
limited to 32 groups. Hence, similar to NETLINK_ADD_MEMBERSHIP and
NETLINK_DROP_MEMBERSHIP, this adds a separate sockopt to manager higher
groups IDs than 32.
This new NETLINK_LIST_MEMBERSHIPS option takes a pointer to __u32 and the
size of the array. The array is filled with the full membership-set of the
socket, and the required array size is returned in optlen. Hence,
user-space can retry with a properly sized array in case it was too small.
drivers/net/ethernet/cadence/macb.c
drivers/net/phy/phy.c
include/linux/skbuff.h
net/ipv4/tcp.c
net/switchdev/switchdev.c
Switchdev was a case of RTNH_H_{EXTERNAL --> OFFLOAD}
renaming overlapping with net-next changes of various
sorts.
phy.c was a case of two changes, one adding a local
variable to a function whilst the second was removing
one.
tcp.c overlapped a deadlock fix with the addition of new tcp_info
statistic values.
macb.c involved the addition of two zyncq device entries.
skbuff.h involved adding back ipv4_daddr to nf_bridge_info
whilst net-next changes put two other existing members of
that struct into a union.
Currently we use a global rover to select a port ID that is unique.
This used to work consistently when it was protected with a global
lock. However as we're now lockless, the global rover can exhibit
pathological behaviour should multiple threads all stomp on it at
the same time.
Granted this will eventually resolve itself but the process is
suboptimal.
This patch replaces the global rover with a pseudorandom starting
point to avoid this issue.
The commit c5adde9468b0714a051eac7f9666f23eb10b61f7 ("netlink:
eliminate nl_sk_hash_lock") breaks the autobind retry mechanism
because it doesn't reset portid after a failed netlink_insert.
This means that should autobind fail the first time around, then
the socket will be stuck in limbo as it can never be bound again
since it already has a non-zero portid.
Fixes: c5adde9468b0 ("netlink: eliminate nl_sk_hash_lock")
netlink sockets creation and deletion heavily modify nl_table_users
and nl_table_lock.
If nl_table is sharing one cache line with one of them, netlink
performance is really bad on SMP.
ffffffff81ff5f00 B nl_table
ffffffff81ff5f0c b nl_table_users
Putting nl_table in read_mostly section increased performance
of my open/delete netlink sockets test by about 80 %
This came up while diagnosing a getaddrinfo() problem.
Four minor merge conflicts:
1) qca_spi.c renamed the local variable used for the SPI device
from spi_device to spi, meanwhile the spi_set_drvdata() call
got moved further up in the probe function.
2) Two changes were both adding new members to codel params
structure, and thus we had overlapping changes to the
initializer function.
3) 'net' was making a fix to sk_release_kernel() which is
completely removed in 'net-next'.
4) In net_namespace.c, the rtnl_net_fill() call for GET operations
had the command value fixed, meanwhile 'net-next' adjusted the
argument signature a bit.
This also matches example merge resolutions posted by Stephen
Rothwell over the past two days.
Utilize the new functionality of sk_alloc so that nothing needs to be
done to suprress the reference counting on kernel sockets.
In preparation for changing how struct net is refcounted
on kernel sockets pass the knowledge that we are creating
a kernel socket from sock_create_kern through to sk_alloc.
More accurately, listen all netns that have a nsid assigned into the netns
where the netlink socket is opened.
For this purpose, a netlink socket option is added:
NETLINK_LISTEN_ALL_NSID. When this option is set on a netlink socket, this
socket will receive netlink notifications from all netns that have a nsid
assigned into the netns where the socket has been opened. The nsid is sent
to userland via an anscillary data.
With this patch, a daemon needs only one socket to listen many netns. This
is useful when the number of netns is high.
Because 0 is a valid value for a nsid, the field nsid_is_set indicates if
the field nsid is valid or not. skb->cb is initialized to 0 on skb
allocation, thus we are sure that we will never send a nsid 0 by error to
the userland.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
These flags and states have the same prefix (NETLINK_) that netlink socket
options. To avoid confusion and to be able to name a flag like a socket
option, let's use an other prefix: NETLINK_[S|F]_.
Note: a comment has been fixed, it was talking about
NETLINK_RECV_NO_ENOBUFS socket option instead of NETLINK_NO_ENOBUFS.
We currently limit the hash table size to 64K which is very bad
as even 10 years ago it was relatively easy to generate millions
of sockets.
Since the hash table is naturally limited by memory allocation
failure, we don't really need an explicit limit so this patch
removes it.
Acked-by: Thomas Graf <tgraf@noironetworks.com>
When I added pfmemalloc support in build_skb(), I forgot netlink
was using build_skb() with a vmalloc() area.
In this patch I introduce __build_skb() for netlink use,
and build_skb() is a wrapper handling both skb->head_frag and
skb->pfmemalloc
This means netlink no longer has to hack skb->head_frag
[ 1567.700067] kernel BUG at arch/x86/mm/physaddr.c:26!
[ 1567.700067] invalid opcode: 0000 [#1] PREEMPT SMP KASAN
[ 1567.700067] Dumping ftrace buffer:
[ 1567.700067] (ftrace buffer empty)
[ 1567.700067] Modules linked in:
[ 1567.700067] CPU: 9 PID: 16186 Comm: trinity-c182 Not tainted 4.0.0-next-20150424-sasha-00037-g4796e21 #2167
[ 1567.700067] task: ffff880127efb000 ti: ffff880246770000 task.ti: ffff880246770000
[ 1567.700067] RIP: __phys_addr (arch/x86/mm/physaddr.c:26 (discriminator 3))
[ 1567.700067] RSP: 0018:ffff8802467779d8 EFLAGS: 00010202
[ 1567.700067] RAX: 000041000ed8e000 RBX: ffffc9008ed8e000 RCX: 000000000000002c
[ 1567.700067] RDX: 0000000000000004 RSI: 0000000000000000 RDI: ffffffffb3fd6049
[ 1567.700067] RBP: ffff8802467779f8 R08: 0000000000000019 R09: ffff8801d0168000
[ 1567.700067] R10: ffff8801d01680c7 R11: ffffed003a02d019 R12: ffffc9000ed8e000
[ 1567.700067] R13: 0000000000000f40 R14: 0000000000001180 R15: ffffc9000ed8e000
[ 1567.700067] FS: 00007f2a7da3f700(0000) GS:ffff8801d1000000(0000) knlGS:0000000000000000
[ 1567.700067] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1567.700067] CR2: 0000000000738308 CR3: 000000022e329000 CR4: 00000000000007e0
[ 1567.700067] Stack:
[ 1567.700067] ffffc9000ed8e000 ffff8801d0168000 ffffc9000ed8e000 ffff8801d0168000
[ 1567.700067] ffff880246777a28 ffffffffad7c0a21 0000000000001080 ffff880246777c08
[ 1567.700067] ffff88060d302e68 ffff880246777b58 ffff880246777b88 ffffffffad9a6821
[ 1567.700067] Call Trace:
[ 1567.700067] build_skb (include/linux/mm.h:508 net/core/skbuff.c:316)
[ 1567.700067] netlink_sendmsg (net/netlink/af_netlink.c:1633 net/netlink/af_netlink.c:2329)
[ 1567.774369] ? sched_clock_cpu (kernel/sched/clock.c:311)
[ 1567.774369] ? netlink_unicast (net/netlink/af_netlink.c:2273)
[ 1567.774369] sock_sendmsg (net/socket.c:614 net/socket.c:623)
[ 1567.774369] sock_write_iter (net/socket.c:823)
[ 1567.774369] ? sock_sendmsg (net/socket.c:806)
[ 1567.774369] __vfs_write (fs/read_write.c:479 fs/read_write.c:491)
[ 1567.774369] ? get_lock_stats (kernel/locking/lockdep.c:249)
[ 1567.774369] ? default_llseek (fs/read_write.c:487)
[ 1567.774369] ? vtime_account_user (kernel/sched/cputime.c:701)
[ 1567.774369] ? rw_verify_area (fs/read_write.c:406 (discriminator 4))
[ 1567.774369] vfs_write (fs/read_write.c:539)
[ 1567.774369] SyS_write (fs/read_write.c:586 fs/read_write.c:577)
[ 1567.774369] ? SyS_read (fs/read_write.c:577)
[ 1567.774369] ? __this_cpu_preempt_check (lib/smp_processor_id.c:63)
[ 1567.774369] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2594 kernel/locking/lockdep.c:2636)
[ 1567.774369] ? trace_hardirqs_on_thunk (arch/x86/lib/thunk_64.S:42)
[ 1567.774369] system_call_fastpath (arch/x86/kernel/entry_64.S:261)
Fixes: 79930f5892e ("net: do not deplete pfmemalloc reserve")
Reported-by: Sasha Levin <sasha.levin@oracle.com>
nftables sets will be converted to use so called setextensions, moving
the key to a non-fixed position. To hash it, the obj_hashfn must be used,
however it so far doesn't receive the length parameter.
Pass the key length to obj_hashfn() and convert existing users.
Introduce a new bool automatic_shrinking to require the
user to explicitly opt-in to automatic shrinking of tables.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
