path: root/net/netlink
2010-07-26genetlink: use genl_register_family_with_ops()Changli Gao
Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-26genetlink: cleanup code according to CodingStyleChangli Gao
If the function is exported, the EXPORT* macro for it should follow immediately after the closing function brace line. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- net/netlink/genetlink.c | 9 ++++----- 1 file changed, 4 insertions(+), 5 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-26netlink: netlink_recvmsg() fixEric Dumazet
commit 1dacc76d0014 (net/compat/wext: send different messages to compat tasks) introduced a race condition on netlink, in case MSG_PEEK is used. An skb given by skb_recv_datagram() might be shared, we must copy it before any modification, or risk fatal corruption. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-07-20drop_monitor: convert some kfree_skb call sites to consume_skbNeil Horman
Convert a few calls from kfree_skb to consume_skb Noticed while I was working on dropwatch that I was detecting lots of internal skb drops in several places. While some are legitimate, several were not, freeing skbs that were at the end of their life, rather than being discarded due to an error. This patch converts those calls sites from using kfree_skb to consume_skb, which quiets the in-kernel drop_monitor code from detecting them as drops. Tested successfully by myself Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-16af_netlink: Add needed scm_destroy after scm_send.Eric W. Biederman
scm_send occasionally allocates state in the scm_cookie, so I have modified netlink_sendmsg to guarantee that when scm_send succeeds scm_destory will be called to free that state. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Reviewed-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-05-21netlink: Implment netlink_broadcast_filteredEric W. Biederman
When netlink sockets are used to convey data that is in a namespace we need a way to select a subset of the listening sockets to deliver the packet to. For the network namespace we have been doing this by only transmitting packets in the correct network namespace. For data belonging to other namespaces netlink_bradcast_filtered provides a mechanism that allows us to examine the destination socket and to decide if we should transmit the specified packet to it. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
2010-04-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/bonding/bond_main.c drivers/net/via-velocity.c drivers/net/wireless/iwlwifi/iwl-agn.c
2010-04-06Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (37 commits) smc91c92_cs: fix the problem of "Unable to find hardware address" r8169: clean up my printk uglyness net: Hook up cxgb4 to Kconfig and Makefile cxgb4: Add main driver file and driver Makefile cxgb4: Add remaining driver headers and L2T management cxgb4: Add packet queues and packet DMA code cxgb4: Add HW and FW support code cxgb4: Add register, message, and FW definitions netlabel: Fix several rcu_dereference() calls used without RCU read locks bonding: fix potential deadlock in bond_uninit() net: check the length of the socket address passed to connect(2) stmmac: add documentation for the driver. stmmac: fix kconfig for crc32 build error be2net: fix bug in vlan rx path for big endian architecture be2net: fix flashing on big endian architectures be2net: fix a bug in flashing the redboot section bonding: bond_xmit_roundrobin() fix drivers/net: Add missing unlock net: gianfar - align BD ring size console messages net: gianfar - initialize per-queue statistics ...
2010-04-03netlink: Export genl_lock() API for use by modulesJames Chapman
This lets kernel modules which use genl netlink APIs serialize netlink processing. Signed-off-by: James Chapman <jchapman@katalix.com> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-01net: check the length of the socket address passed to connect(2)Changli Gao
check the length of the socket address passed to connect(2). Check the length of the socket address passed to connect(2). If the length is invalid, -EINVAL will be returned. Signed-off-by: Changli Gao <xiaosuo@gmail.com> ---- net/bluetooth/l2cap.c | 3 ++- net/bluetooth/rfcomm/sock.c | 3 ++- net/bluetooth/sco.c | 3 ++- net/can/bcm.c | 3 +++ net/ieee802154/af_ieee802154.c | 3 +++ net/ipv4/af_inet.c | 5 +++++ net/netlink/af_netlink.c | 3 +++ 7 files changed, 20 insertions(+), 3 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-26netlink: use the appropriate namespace pidTom Goff
This was included in OpenVZ kernels but wasn't integrated upstream. >From git://git.openvz.org/pub/linux-2.6.24-openvz: commit 5c69402f18adf7276352e051ece2cf31feefab02 Author: Alexey Dobriyan <adobriyan@openvz.org> Date: Mon Dec 24 14:37:45 2007 +0300 netlink: fixup ->tgid to work in multiple PID namespaces Signed-off-by: Tom Goff <thomas.goff@boeing.com> Acked-by: Alexey Dobriyan <adobriyan@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-20netlink: fix NETLINK_RECV_NO_ENOBUFS in netlink_set_err()Pablo Neira Ayuso
Currently, ENOBUFS errors are reported to the socket via netlink_set_err() even if NETLINK_RECV_NO_ENOBUFS is set. However, that should not happen. This fixes this problem and it changes the prototype of netlink_set_err() to return the number of sockets that have set the NETLINK_RECV_NO_ENOBUFS socket option. This return value is used in the next patch in these bugfix series. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-28netlink: Adding inode field to /proc/net/netlinkMasatake YAMATO
The Inode field in /proc/net/{tcp,udp,packet,raw,...} is useful to know the types of file descriptors associated to a process. Actually lsof utility uses the field. Unfortunately, unlike /proc/net/{tcp,udp,packet,raw,...}, /proc/net/netlink doesn't have the field. This patch adds the field to /proc/net/netlink. Signed-off-by: Masatake YAMATO <yamato@redhat.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-03Merge branch 'master' of ↵David S. Miller
2010-02-03netlink: fix for too early rmmodAlexey Dobriyan
Netlink code does module autoload if protocol userspace is asking for is not ready. However, module can dissapear right after it was autoloaded. Example: modprobe/rmmod stress-testing and xfrm_user.ko providing NETLINK_XFRM. netlink_create() in such situation _will_ create userspace socket and _will_not_ pin module. Now if module was removed and we're going to call ->netlink_rcv into nothing: BUG: unable to handle kernel paging request at ffffffffa02f842a ^^^^^^^^^^^^^^^^ modules are loaded near these addresses here IP: [<ffffffffa02f842a>] 0xffffffffa02f842a PGD 161f067 PUD 1623063 PMD baa12067 PTE 0 Oops: 0010 [#1] PREEMPT SMP DEBUG_PAGEALLOC last sysfs file: /sys/devices/pci0000:00/0000:00:1f.2/host0/target0:0:0/0:0:0:0/block/sda/uevent CPU 1 Pid: 11515, comm: ip Not tainted 2.6.33-rc5-netns-00594-gaaa5728-dirty #6 P5E/P5E RIP: 0010:[<ffffffffa02f842a>] [<ffffffffa02f842a>] 0xffffffffa02f842a RSP: 0018:ffff8800baa3db48 EFLAGS: 00010292 RAX: ffff8800baa3dfd8 RBX: ffff8800be353640 RCX: 0000000000000000 RDX: ffffffff81959380 RSI: ffff8800bab7f130 RDI: 0000000000000001 RBP: ffff8800baa3db58 R08: 0000000000000001 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000001 R12: 0000000000000011 R13: ffff8800be353640 R14: ffff8800bcdec240 R15: ffff8800bd488010 FS: 00007f93749656f0(0000) GS:ffff880002300000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffffffffa02f842a CR3: 00000000ba82b000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process ip (pid: 11515, threadinfo ffff8800baa3c000, task ffff8800bab7eb30) Stack: ffffffff813637c0 ffff8800bd488000 ffff8800baa3dba8 ffffffff8136397d <0> 0000000000000000 ffffffff81344adc 7fffffffffffffff 0000000000000000 <0> ffff8800baa3ded8 ffff8800be353640 ffff8800bcdec240 0000000000000000 Call Trace: [<ffffffff813637c0>] ? netlink_unicast+0x100/0x2d0 [<ffffffff8136397d>] netlink_unicast+0x2bd/0x2d0 netlink_unicast_kernel: nlk->netlink_rcv(skb); [<ffffffff81344adc>] ? memcpy_fromiovec+0x6c/0x90 [<ffffffff81364263>] netlink_sendmsg+0x1d3/0x2d0 [<ffffffff8133975b>] sock_sendmsg+0xbb/0xf0 [<ffffffff8106cdeb>] ? __lock_acquire+0x27b/0xa60 [<ffffffff810a18c3>] ? might_fault+0x73/0xd0 [<ffffffff810a18c3>] ? might_fault+0x73/0xd0 [<ffffffff8106db22>] ? __lock_release+0x82/0x170 [<ffffffff810a190e>] ? might_fault+0xbe/0xd0 [<ffffffff810a18c3>] ? might_fault+0x73/0xd0 [<ffffffff81344c77>] ? verify_iovec+0x47/0xd0 [<ffffffff8133a509>] sys_sendmsg+0x1a9/0x360 [<ffffffff813c2be5>] ? _raw_spin_unlock_irqrestore+0x65/0x70 [<ffffffff8106aced>] ? trace_hardirqs_on+0xd/0x10 [<ffffffff813c2bc2>] ? _raw_spin_unlock_irqrestore+0x42/0x70 [<ffffffff81197004>] ? __up_read+0x84/0xb0 [<ffffffff8106ac95>] ? trace_hardirqs_on_caller+0x145/0x190 [<ffffffff813c207f>] ? trace_hardirqs_on_thunk+0x3a/0x3f [<ffffffff8100262b>] system_call_fastpath+0x16/0x1b Code: Bad RIP value. RIP [<ffffffffa02f842a>] 0xffffffffa02f842a RSP <ffff8800baa3db48> CR2: ffffffffa02f842a If module was quickly removed after autoloading, return -E. Return -EPROTONOSUPPORT if module was quickly removed after autoloading. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-13genetlink: optimize ctrl_dumpfamily()Samir Bellabes
there is a unnecessary test which can be replaced by a good initialization in the 'for' statement Noticed by Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Samir Bellabes <sam@synack.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17netlink: remove subscriptions check on notifierJohannes Berg
The netlink URELEASE notifier doesn't notify for sockets that have been used to receive multicast but it should be called for such sockets as well since they might _also_ be used for sending and not solely for receiving multicast. We will need that for nl80211 (generic netlink sockets) in the future. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-10net: netlink_getname, packet_getname -- use DECLARE_SOCKADDR guardCyrill Gorcunov
Use guard DECLARE_SOCKADDR in a few more places which allow us to catch if the structure copied back is too big. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-17genetlink: Optimize and one bug fix in genl_generate_id()Krishna Kumar
1. GENL_MIN_ID is a valid id -> no need to start at GENL_MIN_ID + 1. 2. Avoid going through the ids two times: If we start at GENL_MIN_ID+1 (*or bigger*) and all ids are over!, the code iterates through the list twice (*or lesser*). 3. Simplify code - no need to start at idx=0 which gets reset to GENL_MIN_ID. Patch on net-next-2.6. Reboot test shows that first id passed to genl_register_family was 16, next two were GENL_ID_GENERATE and genl_generate_id returned 17 & 18 (user level testing of same code shows expected values across entire range of MIN/MAX). Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-17genetlink: Optimize genl_register_family()Krishna Kumar
genl_register_family() doesn't need to call genl_family_find_byid when GENL_ID_GENERATE is passed during register. Patch on net-next-2.6, compile and reboot testing only. Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: mark net_proto_ops as constStephen Hemminger
All usages of structure net_proto_ops should be declared const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-26net: fix nlmsg len size for skb when error bit is set.John Fastabend
Currently, the nlmsg->len field is not set correctly in netlink_ack() for ack messages that include the nlmsg of the error frame. This corrects the length field passed to __nlmsg_put to use the correct payload size. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24genetlink: fix netns vs. netlink table locking (2)Johannes Berg
Similar to commit d136f1bd366fdb7e747ca7e0218171e7a00a98a5, there's a bug when unregistering a generic netlink family, which is caught by the might_sleep() added in that commit: BUG: sleeping function called from invalid context at net/netlink/af_netlink.c:183 in_atomic(): 1, irqs_disabled(): 0, pid: 1510, name: rmmod 2 locks held by rmmod/1510: #0: (genl_mutex){+.+.+.}, at: [<ffffffff8138283b>] genl_unregister_family+0x2b/0x130 #1: (rcu_read_lock){.+.+..}, at: [<ffffffff8138270c>] __genl_unregister_mc_group+0x1c/0x120 Pid: 1510, comm: rmmod Not tainted 2.6.31-wl #444 Call Trace: [<ffffffff81044ff9>] __might_sleep+0x119/0x150 [<ffffffff81380501>] netlink_table_grab+0x21/0x100 [<ffffffff813813a3>] netlink_clear_multicast_users+0x23/0x60 [<ffffffff81382761>] __genl_unregister_mc_group+0x71/0x120 [<ffffffff81382866>] genl_unregister_family+0x56/0x130 [<ffffffffa0007d85>] nl80211_exit+0x15/0x20 [cfg80211] [<ffffffffa000005a>] cfg80211_exit+0x1a/0x40 [cfg80211] Fix in the same way by grabbing the netlink table lock before doing rcu_read_lock(). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-22mm: replace various uses of num_physpages by totalram_pagesJan Beulich
Sizing of memory allocations shouldn't depend on the number of physical pages found in a system, as that generally includes (perhaps a huge amount of) non-RAM pages. The amount of what actually is usable as storage should instead be used as a basis here. Some of the calculations (i.e. those not intending to use high memory) should likely even use (totalram_pages - totalhigh_pages). Signed-off-by: Jan Beulich <jbeulich@novell.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Dave Airlie <airlied@linux.ie> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Hugh Dickins <hugh.dickins@tiscali.co.uk> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-14genetlink: fix netns vs. netlink table lockingJohannes Berg
Since my commits introducing netns awareness into genetlink we can get this problem: BUG: scheduling while atomic: modprobe/1178/0x00000002 2 locks held by modprobe/1178: #0: (genl_mutex){+.+.+.}, at: [<ffffffff8135ee1a>] genl_register_mc_grou #1: (rcu_read_lock){.+.+..}, at: [<ffffffff8135eeb5>] genl_register_mc_g Pid: 1178, comm: modprobe Not tainted 2.6.31-rc8-wl-34789-g95cb731-dirty # Call Trace: [<ffffffff8103e285>] __schedule_bug+0x85/0x90 [<ffffffff81403138>] schedule+0x108/0x588 [<ffffffff8135b131>] netlink_table_grab+0xa1/0xf0 [<ffffffff8135c3a7>] netlink_change_ngroups+0x47/0x100 [<ffffffff8135ef0f>] genl_register_mc_group+0x12f/0x290 because I overlooked that netlink_table_grab() will schedule, thinking it was just the rwlock. However, in the contention case, that isn't actually true. Fix this by letting the code grab the netlink table lock first and then the RCU for netns protection. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-10Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/nf-next-2.6
2009-09-04netlink: silence compiler warningBrian Haley
CC net/netlink/genetlink.o net/netlink/genetlink.c: In function ‘genl_register_mc_group’: net/netlink/genetlink.c:139: warning: ‘err’ may be used uninitialized in this function From following the code 'err' is initialized, but set it to zero to silence the warning. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-25netlink: constify nlmsghdr argumentsPatrick McHardy
Consitfy nlmsghdr arguments to a couple of functions as preparation for the next patch, which will constify the netlink message data in all nfnetlink users. Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-07-15net/compat/wext: send different messages to compat tasksJohannes Berg
Wireless extensions have the unfortunate problem that events are multicast netlink messages, and are not independent of pointer size. Thus, currently 32-bit tasks on 64-bit platforms cannot properly receive events and fail with all kinds of strange problems, for instance wpa_supplicant never notices disassociations, due to the way the 64-bit event looks (to a 32-bit process), the fact that the address is all zeroes is lost, it thinks instead it is 00:00:00:00:01:00. The same problem existed with the ioctls, until David Miller fixed those some time ago in an heroic effort. A different problem caused by this is that we cannot send the ASSOCREQIE/ASSOCRESPIE events because sending them causes a 32-bit wpa_supplicant on a 64-bit system to overwrite its internal information, which is worse than it not getting the information at all -- so we currently resort to sending a custom string event that it then parses. This, however, has a severe size limitation we are frequently hitting with modern access points; this limitation would can be lifted after this patch by sending the correct binary, not custom, event. A similar problem apparently happens for some other netlink users on x86_64 with 32-bit tasks due to the alignment for 64-bit quantities. In order to fix these problems, I have implemented a way to send compat messages to tasks. When sending an event, we send the non-compat event data together with a compat event data in skb_shinfo(main_skb)->frag_list. Then, when the event is read from the socket, the netlink code makes sure to pass out only the skb that is compatible with the task. This approach was suggested by David Miller, my original approach required always sending two skbs but that had various small problems. To determine whether compat is needed or not, I have used the MSG_CMSG_COMPAT flag, and adjusted the call path for recv and recvfrom to include it, even if those calls do not have a cmsg parameter. I have not solved one small part of the problem, and I don't think it is necessary to: if a 32-bit application uses read() rather than any form of recvmsg() it will still get the wrong (64-bit) event. However, neither do applications actually do this, nor would it be a regression. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-12genetlink: make netns awareJohannes Berg
This makes generic netlink network namespace aware. No generic netlink families except for the controller family are made namespace aware, they need to be checked one by one and then set the family->netnsok member to true. A new function genlmsg_multicast_netns() is introduced to allow sending a multicast message in a given namespace, for example when it applies to an object that lives in that namespace, a new function genlmsg_multicast_allns() to send a message to all network namespaces (for objects that do not have an associated netns). The function genlmsg_multicast() is changed to multicast the message in just init_net, which is currently correct for all generic netlink families since they only work in init_net right now. Some will later want to work in all net namespaces because they do not care about the netns at all -- those will have to be converted to use one of the new functions genlmsg_multicast_allns() or genlmsg_multicast_netns() whenever they are made netns aware in some way. After this patch families can easily decide whether or not they should be available in all net namespaces. Many genl families us it for objects not related to networking and should therefore be available in all namespaces, but that will have to be done on a per family basis. Note that this doesn't touch on the checkpoint/restart problem where network namespaces could be used, genl families and multicast groups are numbered globally and I see no easy way of changing that, especially since it must be possible to multicast to all network namespaces for those families that do not care about netns. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-12netlink: use call_rcu for netlink_change_ngroupsJohannes Berg
For the network namespace work in generic netlink I need to be able to call this function under rcu_read_lock(), otherwise the locking becomes a nightmare and more locks would be needed. Instead, just embed a struct rcu_head (actually a struct listeners_rcu_head that also carries the pointer to the memory block) into the listeners memory so we can use call_rcu() instead of synchronising and then freeing. No rcu_barrier() is needed since this code cannot be modular. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-12netlink: remove unused exportsJohannes Berg
I added those myself in commits b4ff4f04 and 84659eb5, but I see no reason now why they should be exported, only generic netlink uses them which cannot be modular. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-21genetlink: Introduce genl_register_family_with_ops()Michał Mirosław
This introduces genl_register_family_with_ops() that registers a genetlink family along with operations from a table. This is used to kill copy'n'paste occurrences in following patches. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-26Merge branch 'master' of /home/davem/src/GIT/linux-2.6/David S. Miller
Conflicts: drivers/net/wimax/i2400m/usb-notif.c
2009-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (29 commits) crypto: sha512-s390 - Add missing block size hwrng: timeriomem - Breaks an allyesconfig build on s390: nlattr: Fix build error with NET off crypto: testmgr - add zlib test crypto: zlib - New zlib crypto module, using pcomp crypto: testmgr - Add support for the pcomp interface crypto: compress - Add pcomp interface netlink: Move netlink attribute parsing support to lib crypto: Fix dead links hwrng: timeriomem - New driver crypto: chainiv - Use kcrypto_wq instead of keventd_wq crypto: cryptd - Per-CPU thread implementation based on kcrypto_wq crypto: api - Use dedicated workqueue for crypto subsystem crypto: testmgr - Test skciphers with no IVs crypto: aead - Avoid infinite loop when nivaead fails selftest crypto: skcipher - Avoid infinite loop when cipher fails selftest crypto: api - Fix crypto_alloc_tfm/create_create_tfm return convention crypto: api - crypto_alg_mod_lookup either tested or untested crypto: amcc - Add crypt4xx driver crypto: ansi_cprng - Add maintainer ...
2009-03-24netlink: add NETLINK_NO_ENOBUFS socket flagPablo Neira Ayuso
This patch adds the NETLINK_NO_ENOBUFS socket flag. This flag can be used by unicast and broadcast listeners to avoid receiving ENOBUFS errors. Generally speaking, ENOBUFS errors are useful to notify two things to the listener: a) You may increase the receiver buffer size via setsockopt(). b) You have lost messages, you may be out of sync. In some cases, ignoring ENOBUFS errors can be useful. For example: a) nfnetlink_queue: this subsystem does not have any sort of resync method and you can decide to ignore ENOBUFS once you have set a given buffer size. b) ctnetlink: you can use this together with the socket flag NETLINK_BROADCAST_SEND_ERROR to stop getting ENOBUFS errors as you do not need to resync (packets whose event are not delivered are drop to provide reliable logging and state-synchronization). Moreover, the use of NETLINK_NO_ENOBUFS also reduces a "go up, go down" effect in terms of performance which is due to the netlink congestion control when the listener cannot back off. The effect is the following: 1) throughput rate goes up and netlink messages are inserted in the receiver buffer. 2) Then, netlink buffer fills and overruns (set on nlk->state bit 0). 3) While the listener empties the receiver buffer, netlink keeps dropping messages. Thus, throughput goes dramatically down. 4) Then, once the listener has emptied the buffer (nlk->state bit 0 is set off), goto step 1. This effect is easy to trigger with netlink broadcast under heavy load, and it is more noticeable when using a big receiver buffer. You can find some results in [1] that show this problem. [1] http://1984.lsi.us.es/linux/netlink/ This patch also includes the use of sk_drop to account the number of netlink messages drop due to overrun. This value is shown in /proc/net/netlink. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-24Merge branch 'master' of ↵David S. Miller
2009-03-23nefilter: nfnetlink: add nfnetlink_set_err and use it in ctnetlinkPablo Neira Ayuso
This patch adds nfnetlink_set_err() to propagate the error to netlink broadcast listener in case of memory allocation errors in the message building. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-03-05Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/tokenring/tmspci.c drivers/net/ucc_geth_mii.c
2009-03-03netlink: invert error code in netlink_set_err()Pablo Neira Ayuso
The callers of netlink_set_err() currently pass a negative value as parameter for the error code. However, sk->sk_err wants a positive error value. Without this patch, skb_recv_datagram() called by netlink_recvmsg() may return a positive value to report an error. Another choice to fix this is to change callers to pass a positive error value, but this seems a bit inconsistent and error prone to me. Indeed, the callers of netlink_set_err() assumed that the (usual) negative value for error codes was fine before this patch :). This patch also includes some documentation in docbook format for netlink_set_err() to avoid this sort of confusion. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-04netlink: Move netlink attribute parsing support to libGeert Uytterhoeven
Netlink attribute parsing may be used even if CONFIG_NET is not set. Move it from net/netlink to lib and control its inclusion based on the new config symbol CONFIG_NLATTR, which is selected by CONFIG_NET. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2009-02-26netlink: remove some pointless conditionals before kfree_skb()Wei Yongjun
Remove some pointless conditionals before kfree_skb(). Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-24netlink: change nlmsg_notify() return value logicPablo Neira Ayuso
This patch changes the return value of nlmsg_notify() as follows: If NETLINK_BROADCAST_ERROR is set by any of the listeners and an error in the delivery happened, return the broadcast error; else if there are no listeners apart from the socket that requested a change with the echo flag, return the result of the unicast notification. Thus, with this patch, the unicast notification is handled in the same way of a broadcast listener that has set the NETLINK_BROADCAST_ERROR socket flag. This patch is useful in case that the caller of nlmsg_notify() wants to know the result of the delivery of a netlink notification (including the broadcast delivery) and take any action in case that the delivery failed. For example, ctnetlink can drop packets if the event delivery failed to provide reliable logging and state-synchronization at the cost of dropping packets. This patch also modifies the rtnetlink code to ignore the return value of rtnl_notify() in all callers. The function rtnl_notify() (before this patch) returned the error of the unicast notification which makes rtnl_set_sk_err() reports errors to all listeners. This is not of any help since the origin of the change (the socket that requested the echoing) notices the ENOBUFS error if the notification fails and should resync itself. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-20netlink: add NETLINK_BROADCAST_ERROR socket optionPablo Neira Ayuso
This patch adds NETLINK_BROADCAST_ERROR which is a netlink socket option that the listener can set to make netlink_broadcast() return errors in the delivery to the caller. This option is useful if the caller of netlink_broadcast() do something with the result of the message delivery, like in ctnetlink where it drops a network packet if the event delivery failed, this is used to enable reliable logging and state-synchronization. If this socket option is not set, netlink_broadcast() only reports ESRCH errors and silently ignore ENOBUFS errors, which is what most netlink_broadcast() callers should do. This socket option is based on a suggestion from Patrick McHardy. Patrick McHardy can exchange this patch for a beer from me ;). Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
