path: root/net/netlink
2006-03-12[NETLINK]: Fix use-after-free in netlink_recvmsgPatrick McHardy
The skb given to netlink_cmsg_recv_pktinfo is already freed, move it up a few lines. Coverity #948 Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-13[NETLINK] genetlink: Fix bugs spotted by Andrew Morton.Jamal Hadi Salim
- panic() doesn't return. - Don't forget to unlock on genl_register_family() error path - genl_rcv_msg() is called via pointer so there's no point in declaring it `inline'. Notes: genl_ctrl_event() ignores the genlmsg_multicast() return value. lots of things ignore the genl_ctrl_event() return value. Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-09[NETLINK]: Fix a severe bugAlexey Kuznetsov
netlink overrun was broken while improvement of netlink. Destination socket is used in the place where it was meant to be source socket, so that now overrun is never sent to user netlink sockets, when it should be, and it even can be set on kernel socket, which results in complete deadlock of rtnetlink. Suggested fix is to restore status quo passing source socket as additional argument to netlink_attachskb(). A little explanation: overrun is set on a socket, when it failed to receive some message and sender of this messages does not or even have no way to handle this error. This happens in two cases: 1. when kernel sends something. Kernel never retransmits and cannot wait for buffer space. 2. when user sends a broadcast and the message was not delivered to some recipients. Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-13[PATCH] genetlink: don't touch module ref countPer Liden
Increasing the module ref count at registration will block the module from ever being unloaded. In fact, genetlink should not care about the owner at all. This patch removes the owner field from the struct registered with genetlink. Signed-off-by: Per Liden <per.liden@ericsson.com> Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[AF_NETLINK]: Fix DoS in netlink_rcv_skb()Martin Murray
From: Martin Murray <murrayma@citi.umich.edu> Sanity check nlmsg_len during netlink_rcv_skb. An nlmsg_len == 0 can cause infinite loop in kernel, effectively DoSing machine. Noted by Matin Murray. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-09[PATCH] netlink oops fix due to incorrect error codeKirill Korotaev
Fixed oops after failed netlink socket creation. Wrong parathenses in if() statement caused err to be 1, instead of negative value. Trivial fix, not trivial to find though. Signed-Off-By: Dmitry Mishin <dim@sw.ru> Signed-Off-By: Kirill Korotaev <dev@openvz.org> Signed-Off-By: Linus Torvalds <torvalds@osdl.org>
2006-01-03[NETLINK] genetlink: fix cmd type in genl_ops to be consistent to u8Per Liden
Signed-off-by: Per Liden <per.liden@ericsson.com> ACKed-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-22[NETLINK]: Use tgid instead of pid for nlmsg_pidHerbert Xu
Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NETLINK]: Generic netlink familyThomas Graf
The generic netlink family builds on top of netlink and provides simplifies access for the less demanding netlink users. It solves the problem of protocol numbers running out by introducing a so called controller taking care of id management and name resolving. Generic netlink modules register themself after filling out their id card (struct genl_family), after successful registration the modules are able to register callbacks to command numbers by filling out a struct genl_ops and calling genl_register_op(). The registered callbacks are invoked with attributes parsed making life of simple modules a lot easier. Although generic netlink modules can request static identifiers, it is recommended to use GENL_ID_GENERATE and to let the controller assign a unique identifier to the module. Userspace applications will then ask the controller and lookup the idenfier by the module name. Due to the current multicast implementation of netlink, the number of generic netlink modules is restricted to 1024 to avoid wasting memory for the per socket multiacst subscription bitmask. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NETLINK]: Generic netlink receive queue processorThomas Graf
Introduces netlink_run_queue() to handle the receive queue of a netlink socket in a generic way. Processes as much as there was in the queue upon entry and invokes a callback function for each netlink message found. The callback function may refuse a message by returning a negative error code but setting the error pointer to 0 in which case netlink_run_queue() will return with a qlen != 0. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NETLINK]: Make netlink_callback->done() optionalThomas Graf
Most netlink families make no use of the done() callback, making it optional gets rid of all unnecessary dummy implementations. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NETLINK]: Type-safe netlink messages/attributes interfaceThomas Graf
Introduces a new type-safe interface for netlink message and attributes handling. The interface is fully binary compatible with the old interface towards userspace. Besides type safety, this interface features attribute validation capabilities, simplified message contstruction, and documentation. The resulting netlink code should be smaller, less error prone and easier to understand. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-28Merge master.kernel.org:/pub/scm/linux/kernel/git/acme/net-2.6.15Linus Torvalds
2005-10-28[PATCH] gfp_t: net/*Al Viro
2005-10-26[NETLINK]: Remove dead code in af_netlink.cJayachandran C
Remove the variable nlk & call to nlk_sk as it does not have any side effect. Signed-off-by: Jayachandran C. <c.jayachandran at gmail.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-06[NETLINK]: Don't prevent creating sockets when no kernel socket is registeredPatrick McHardy
This broke the pam audit module which includes an incorrect check for -ENOENT instead of -EPROTONOTSUPP. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Fix sparse warningsArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Add "groups" argument to netlink_kernel_createPatrick McHardy
2005-08-29[NETLINK]: Add set/getsockopt options to support more than 32 groupsPatrick McHardy
NETLINK_ADD_MEMBERSHIP/NETLINK_DROP_MEMBERSHIP are used to join/leave groups, NETLINK_PKTINFO is used to enable nl_pktinfo control messages for received packets to get the extended destination group number. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Support dynamic number of multicast groups per netlink familyPatrick McHardy
2005-08-29[NETLINK]: Return -EPROTONOSUPPORT in netlink_create() if no kernel socket ↵Patrick McHardy
is registered This is necessary for dynamic number of netlink groups to make sure we know the number of possible groups before bind() is called. With this change pure userspace communication using unused netlink protocols becomes impossible. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Use group numbers instead of bitmasks internallyPatrick McHardy
Using the group number allows increasing the number of groups without beeing limited by the size of the bitmask. It introduces one limitation for netlink users: messages can't be broadcasted to multiple groups anymore, however this feature was never used inside the kernel. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Fix module refcounting problemsPatrick McHardy
Use-after-free: the struct proto_ops containing the module pointer is freed when a socket with pid=0 is released, which besides for kernel sockets is true for all unbound sockets. Module refcount leak: when the kernel socket is closed before all user sockets have been closed the proto_ops struct for this family is replaced by the generic one and the module refcount can't be dropped. The second problem can't be solved cleanly using module refcounting in the generic socket code, so this patch adds explicit refcounting to netlink_create/netlink_release. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Remove unused groups member from struct netlink_skb_parmsPatrick McHardy
2005-08-29[NETLINK]: Add properly module refcounting for kernel netlink sockets.Harald Welte
- Remove bogus code for compiling netlink as module - Add module refcounting support for modules implementing a netlink protocol - Add support for autoloading modules that implement a netlink protocol as soon as someone opens a socket for that protocol Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-18[NETLINK]: Fix "nocast type" warningsVictor Fusco
From: Victor Fusco <victor@cetuc.puc-rio.br> Fix the sparse warning "implicit cast to nocast type" Signed-off-by: Victor Fusco <victor@cetuc.puc-rio.br> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-07-08[NET]: Transform skb_queue_len() binary tests into skb_queue_empty()David S. Miller
This is part of the grand scheme to eliminate the qlen member of skb_queue_head, and subsequently remove the 'list' member of sk_buff. Most users of skb_queue_len() want to know if the queue is empty or not, and that's trivially done with skb_queue_empty() which doesn't use the skb_queue_head->qlen member and instead uses the queue list emptyness as the test. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-26[NETLINK]: Fix two socket hashing bugs.David S. Miller
1) netlink_release() should only decrement the hash entry count if the socket was actually hashed. This was causing hash->entries to underflow, which resulting in all kinds of troubles. On 64-bit systems, this would cause the following conditional to erroneously trigger: err = -ENOMEM; if (BITS_PER_LONG > 32 && unlikely(hash->entries >= UINT_MAX)) goto err; 2) netlink_autobind() needs to propagate the error return from netlink_insert(). Otherwise, callers will not see the error as they should and thus try to operate on a socket with a zero pid, which is very bad. However, it should not propagate -EBUSY. If two threads race to autobind the socket, that is fine. This is consistent with the autobind behavior in other protocols. So bug #1 above, combined with this one, resulted in hangs on netlink_sendmsg() calls to the rtnetlink socket. We'd try to do the user sendmsg() with the socket's pid set to zero, later we do a socket lookup using that pid (via the value we stashed away in NETLINK_CB(skb).pid), but that won't give us the user socket, it will give us the rtnetlink socket. So when we try to wake up the receive queue, we dive back into rtnetlink_rcv() which tries to recursively take the rtnetlink semaphore. Thanks to Jakub Jelink for providing backtraces. Also, thanks to Herbert Xu for supplying debugging patches to help track this down, and also finding a mistake in an earlier version of this fix. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-18[NETLINK]: Introduce NLMSG_NEW macro to better handle netlink flagsThomas Graf
Introduces a new macro NLMSG_NEW which extends NLMSG_PUT but takes a flags argument. NLMSG_PUT stays there for compatibility but now calls NLMSG_NEW with flags == 0. NLMSG_PUT_ANSWER is renamed to NLMSG_NEW_ANSWER which now also takes a flags argument. Also converts the users of NLMSG_PUT_ANSWER to use NLMSG_NEW_ANSWER and fixes the two direct users of __nlmsg_put to either provide the flags or use NLMSG_NEW(_ANSWER). Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-19[NETLINK]: Defer socket destruction a bitTommy S. Christensen
In netlink_broadcast() we're sending shared skb's to netlink listeners when possible (saves some copying). This is OK, since we hold the only other reference to the skb. However, this implies that we must drop our reference on the skb, before allowing a receiving socket to disappear. Otherwise, the socket buffer accounting is disrupted. Signed-off-by: Tommy S. Christensen <tommy.christensen@tpack.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-19[NETLINK]: Move broadcast skb_orphan to the skb_get path.Tommy S. Christensen
Cloned packets don't need the orphan call. Signed-off-by: Tommy S. Christensen <tommy.christensen@tpack.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-19[NETLINK]: Fix race with recvmsg().Tommy S. Christensen
This bug causes: assertion (!atomic_read(&sk->sk_rmem_alloc)) failed at net/netlink/af_netlink.c (122) What's happening is that: 1) The skb is sent to socket 1. 2) Someone does a recvmsg on socket 1 and drops the ref on the skb. Note that the rmalloc is not returned at this point since the skb is still referenced. 3) The same skb is now sent to socket 2. This version of the fix resurrects the skb_orphan call that was moved out, last time we had 'shared-skb troubles'. It is practically a no-op in the common case, but still prevents the possible race with recvmsg. Signed-off-by: Tommy S. Christensen <tommy.christensen@tpack.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-05-05Merge with master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6.gitDavid Woodhouse
2005-05-03[NETLINK]: cb_lock does not needs ref count on skHerbert Xu
Here is a little optimisation for the cb_lock used by netlink_dump. While fixing that race earlier, I noticed that the reference count held by cb_lock is completely useless. The reason is that in order to obtain the protection of the reference count, you have to take the cb_lock. But the only way to take the cb_lock is through dereferencing the socket. That is, you must already possess a reference count on the socket before you can take advantage of the reference count held by cb_lock. As a corollary, we can remve the reference count held by the cb_lock. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-04-30netlink audit warning fixAndrew Morton
scumbags! net/netlink/af_netlink.c: In function `netlink_sendmsg': net/netlink/af_netlink.c:908: warning: implicit declaration of function `audit_get_loginuid' Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-04-29Add audit uid to netlink credentialsSerge Hallyn
Most audit control messages are sent over netlink.In order to properly log the identity of the sender of audit control messages, we would like to add the loginuid to the netlink_creds structure, as per the attached patch. Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2005-04-25[PATCH] kill gratitious includes of major.h under net/*Al Viro
A lot of places in there are including major.h for no reason whatsoever. Removed. And yes, it still builds. The history of that stuff is often amusing. E.g. for net/core/sock.c the story looks so, as far as I've been able to reconstruct it: we used to need major.h in net/socket.c circa 1.1.early. In 1.1.13 that need had disappeared, along with register_chrdev(SOCKET_MAJOR, "socket", &net_fops) in sock_init(). Include had not. When 1.2 -> 1.3 reorg of net/* had moved a lot of stuff from net/socket.c to net/core/sock.c, this crap had followed... Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
