path: root/net/netlink
2018-01-02netlink: Add netns check on tapsKevin Cernekee
[ Upstream commit 93c647643b48f0131f02e45da3bd367d80443291 ] Currently, a nlmon link inside a child namespace can observe systemwide netlink activity. Filter the traffic so that nlmon can only sniff netlink messages from its own netns. Test case: vpnns -- bash -c "ip link add nlmon0 type nlmon; \ ip link set nlmon0 up; \ tcpdump -i nlmon0 -q -w /tmp/nlmon.pcap -U" & sudo ip xfrm state add src 10.1.1.1 dst 10.1.1.2 proto esp \ spi 0x1 mode transport \ auth sha1 0x6162633132330000000000000000000000000000 \ enc aes 0x00000000000000000000000000000000 grep --binary abc123 /tmp/nlmon.pcap Signed-off-by: Kevin Cernekee <cernekee@chromium.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-25crypto: deadlock between crypto_alg_sem/rtnl_mutex/genl_mutexHerbert Xu
[ Upstream commit 8a0f5ccfb33b0b8b51de65b7b3bf342ba10b4fb6 ] On Tue, Mar 14, 2017 at 10:44:10AM +0100, Dmitry Vyukov wrote: > > Yes, please. > Disregarding some reports is not a good way long term. Please try this patch. ---8<--- Subject: netlink: Annotate nlk cb_mutex by protocol Currently all occurences of nlk->cb_mutex are annotated by lockdep as a single class. This causes a false lcokdep cycle involving genl and crypto_user. This patch fixes it by dividing cb_mutex into individual classes based on the netlink protocol. As genl and crypto_user do not use the same netlink protocol this breaks the false dependency loop. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-05netlink: add a start callback for starting a netlink dumpTom Herbert
commit fc9e50f5a5a4e1fa9ba2756f745a13e693cf6a06 upstream. The start callback allows the caller to set up a context for the dump callbacks. Presumably, the context can then be destroyed in the done callback. Signed-off-by: Tom Herbert <tom@herbertland.com> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-24af_netlink: ensure that NLMSG_DONE never fails in dumpsJason A. Donenfeld
[ Upstream commit 0642840b8bb008528dbdf929cec9f65ac4231ad0 ] The way people generally use netlink_dump is that they fill in the skb as much as possible, breaking when nla_put returns an error. Then, they get called again and start filling out the next skb, and again, and so forth. The mechanism at work here is the ability for the iterative dumping function to detect when the skb is filled up and not fill it past the brim, waiting for a fresh skb for the rest of the data. However, if the attributes are small and nicely packed, it is possible that a dump callback function successfully fills in attributes until the skb is of size 4080 (libmnl's default page-sized receive buffer size). The dump function completes, satisfied, and then, if it happens to be that this is actually the last skb, and no further ones are to be sent, then netlink_dump will add on the NLMSG_DONE part: nlh = nlmsg_put_answer(skb, cb, NLMSG_DONE, sizeof(len), NLM_F_MULTI); It is very important that netlink_dump does this, of course. However, in this example, that call to nlmsg_put_answer will fail, because the previous filling by the dump function did not leave it enough room. And how could it possibly have done so? All of the nla_put variety of functions simply check to see if the skb has enough tailroom, independent of the context it is in. In order to keep the important assumptions of all netlink dump users, it is therefore important to give them an skb that has this end part of the tail already reserved, so that the call to nlmsg_put_answer does not fail. Otherwise, library authors are forced to find some bizarre sized receive buffer that has a large modulo relative to the common sizes of messages received, which is ugly and buggy. This patch thus saves the NLMSG_DONE for an additional message, for the case that things are dangerously close to the brim. This requires keeping track of the errno from ->dump() across calls. Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-08netlink: Allow direct reclaim for fallback allocationRoss Lagerwall
The backport of d35c99ff77ec ("netlink: do not enter direct reclaim from netlink_dump()") to the 4.4 branch (first in 4.4.32) mistakenly removed direct claim from the initial large allocation _and_ the fallback allocation which means that allocations can spuriously fail. Fix the issue by adding back the direct reclaim flag to the fallback allocation. Fixes: 6d123f1d396b ("netlink: do not enter direct reclaim from netlink_dump()") Signed-off-by: Ross Lagerwall <ross.lagerwall@citrix.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-22netlink: remove mmapped netlink supportFlorian Westphal
commit d1b4c689d4130bcfd3532680b64db562300716b6 upstream. mmapped netlink has a number of unresolved issues: - TX zerocopy support had to be disabled more than a year ago via commit 4682a0358639b29cf ("netlink: Always copy on mmap TX.") because the content of the mmapped area can change after netlink attribute validation but before message processing. - RX support was implemented mainly to speed up nfqueue dumping packet payload to userspace. However, since commit ae08ce0021087a5d812d2 ("netfilter: nfnetlink_queue: zero copy support") we avoid one copy with the socket-based interface too (via the skb_zerocopy helper). The other problem is that skbs attached to mmaped netlink socket behave different from normal skbs: - they don't have a shinfo area, so all functions that use skb_shinfo() (e.g. skb_clone) cannot be used. - reserving headroom prevents userspace from seeing the content as it expects message to start at skb->head. See for instance commit aa3a022094fa ("netlink: not trim skb for mmaped socket when dump"). - skbs handed e.g. to netlink_ack must have non-NULL skb->sk, else we crash because it needs the sk to check if a tx ring is attached. Also not obvious, leads to non-intuitive bug fixes such as 7c7bdf359 ("netfilter: nfnetlink: use original skbuff when acking batches"). mmaped netlink also didn't play nicely with the skb_zerocopy helper used by nfqueue and openvswitch. Daniel Borkmann fixed this via commit 6bb0fef489f6 ("netlink, mmap: fix edge-case leakages in nf queue zero-copy")' but at the cost of also needing to provide remaining length to the allocation function. nfqueue also has problems when used with mmaped rx netlink: - mmaped netlink doesn't allow use of nfqueue batch verdict messages. Problem is that in the mmap case, the allocation time also determines the ordering in which the frame will be seen by userspace (A allocating before B means that A is located in earlier ring slot, but this also means that B might get a lower sequence number then A since seqno is decided later. To fix this we would need to extend the spinlocked region to also cover the allocation and message setup which isn't desirable. - nfqueue can now be configured to queue large (GSO) skbs to userspace. Queing GSO packets is faster than having to force a software segmentation in the kernel, so this is a desirable option. However, with a mmap based ring one has to use 64kb per ring slot element, else mmap has to fall back to the socket path (NL_MMAP_STATUS_COPY) for all large packets. To use the mmap interface, userspace not only has to probe for mmap netlink support, it also has to implement a recv/socket receive path in order to handle messages that exceed the size of an rx ring element. Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: Ken-ichirou MATSUZAWA <chamaken@gmail.com> Cc: Pablo Neira Ayuso <pablo@netfilter.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Thomas Graf <tgraf@suug.ch> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Shi Yuejie <shiyuejie@outlook.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-10netlink: Do not schedule work from sk_destructHerbert Xu
[ Upstream commit ed5d7788a934a4b6d6d025e948ed4da496b4f12e ] It is wrong to schedule a work from sk_destruct using the socket as the memory reserve because the socket will be freed immediately after the return from sk_destruct. Instead we should do the deferral prior to sk_free. This patch does just that. Fixes: 707693c8a498 ("netlink: Call cb->done from a worker thread") Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-12-10netlink: Call cb->done from a worker threadHerbert Xu
[ Upstream commit 707693c8a498697aa8db240b93eb76ec62e30892 ] The cb->done interface expects to be called in process context. This was broken by the netlink RCU conversion. This patch fixes it by adding a worker struct to make the cb->done call where necessary. Fixes: 21e4902aea80 ("netlink: Lockless lookup with RCU grace...") Reported-by: Subash Abhinov Kasiviswanathan <subashab@codeaurora.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-15netlink: do not enter direct reclaim from netlink_dump()Eric Dumazet
[ Upstream commit d35c99ff77ecb2eb239731b799386f3b3637a31e ] Since linux-3.15, netlink_dump() can use up to 16384 bytes skb allocations. Due to struct skb_shared_info ~320 bytes overhead, we end up using order-3 (on x86) page allocations, that might trigger direct reclaim and add stress. The intent was really to attempt a large allocation but immediately fallback to a smaller one (order-1 on x86) in case of memory stress. On recent kernels (linux-4.4), we can remove __GFP_DIRECT_RECLAIM to meet the goal. Old kernels would need to remove __GFP_WAIT While we are at it, since we do an order-3 allocation, allow to use all the allocated bytes instead of 16384 to reduce syscalls during large dumps. iproute2 already uses 32KB recvmsg() buffer sizes. Alexei provided an initial patch downsizing to SKB_WITH_OVERHEAD(16384) Fixes: 9063e21fb026 ("netlink: autosize skb lengthes") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Alexei Starovoitov <ast@kernel.org> Cc: Greg Thelen <gthelen@google.com> Reviewed-by: Greg Rose <grose@lightfleet.com> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-24netlink: Fix dump skb leak/double freeHerbert Xu
[ Upstream commit 92964c79b357efd980812c4de5c1fd2ec8bb5520 ] When we free cb->skb after a dump, we do it after releasing the lock. This means that a new dump could have started in the time being and we'll end up freeing their skb instead of ours. This patch saves the skb and module before we unlock so we free the right memory. Fixes: 16b304f3404f ("netlink: Eliminate kmalloc in netlink dump operation.") Reported-by: Baozeng Ding <sploving1@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04netlink: don't send NETLINK_URELEASE for unbound socketsDmitry Ivanov
commit e27260203912b40751fa353d009eaa5a642c739f upstream. All existing users of NETLINK_URELEASE use it to clean up resources that were previously allocated to a socket via some command. As a result, no users require getting this notification for unbound sockets. Sending it for unbound sockets, however, is a problem because any user (including unprivileged users) can create a socket that uses the same ID as an existing socket. Binding this new socket will fail, but if the NETLINK_URELEASE notification is generated for such sockets, the users thereof will be tricked into thinking the socket that they allocated the resources for is closed. In the nl80211 case, this will cause destruction of virtual interfaces that still belong to an existing hostapd process; this is the case that Dmitry noticed. In the NFC case, it will cause a poll abort. In the case of netlink log/queue it will cause them to stop reporting events, as if NFULNL_CFG_CMD_UNBIND/NFQNL_CFG_CMD_UNBIND had been called. Fix this problem by checking that the socket is bound before generating the NETLINK_URELEASE notification. Signed-off-by: Dmitry Ivanov <dima@ubnt.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-06mm, page_alloc: distinguish between being unable to sleep, unwilling to ↵Mel Gorman
sleep and avoiding waking kswapd __GFP_WAIT has been used to identify atomic context in callers that hold spinlocks or are in interrupts. They are expected to be high priority and have access one of two watermarks lower than "min" which can be referred to as the "atomic reserve". __GFP_HIGH users get access to the first lower watermark and can be called the "high priority reserve". Over time, callers had a requirement to not block when fallback options were available. Some have abused __GFP_WAIT leading to a situation where an optimisitic allocation with a fallback option can access atomic reserves. This patch uses __GFP_ATOMIC to identify callers that are truely atomic, cannot sleep and have no alternative. High priority users continue to use __GFP_HIGH. __GFP_DIRECT_RECLAIM identifies callers that can sleep and are willing to enter direct reclaim. __GFP_KSWAPD_RECLAIM to identify callers that want to wake kswapd for background reclaim. __GFP_WAIT is redefined as a caller that is willing to enter direct reclaim and wake kswapd for background reclaim. This patch then converts a number of sites o __GFP_ATOMIC is used by callers that are high priority and have memory pools for those requests. GFP_ATOMIC uses this flag. o Callers that have a limited mempool to guarantee forward progress clear __GFP_DIRECT_RECLAIM but keep __GFP_KSWAPD_RECLAIM. bio allocations fall into this category where kswapd will still be woken but atomic reserves are not used as there is a one-entry mempool to guarantee progress. o Callers that are checking if they are non-blocking should use the helper gfpflags_allow_blocking() where possible. This is because checking for __GFP_WAIT as was done historically now can trigger false positives. Some exceptions like dm-crypt.c exist where the code intent is clearer if __GFP_DIRECT_RECLAIM is used instead of the helper due to flag manipulations. o Callers that built their own GFP flags instead of starting with GFP_KERNEL and friends now also need to specify __GFP_KSWAPD_RECLAIM. The first key hazard to watch out for is callers that removed __GFP_WAIT and was depending on access to atomic reserves for inconspicuous reasons. In some cases it may be appropriate for them to use __GFP_HIGH. The second key hazard is callers that assembled their own combination of GFP flags instead of starting with something like GFP_KERNEL. They may now wish to specify __GFP_KSWAPD_RECLAIM. It's almost certainly harmless if it's missed in most cases as other activity will wake kswapd. Signed-off-by: Mel Gorman <mgorman@techsingularity.net> Acked-by: Vlastimil Babka <vbabka@suse.cz> Acked-by: Michal Hocko <mhocko@suse.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Cc: Christoph Lameter <cl@linux.com> Cc: David Rientjes <rientjes@google.com> Cc: Vitaly Wool <vitalywool@gmail.com> Cc: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/ipv6/xfrm6_output.c net/openvswitch/flow_netlink.c net/openvswitch/vport-gre.c net/openvswitch/vport-vxlan.c net/openvswitch/vport.c net/openvswitch/vport.h The openvswitch conflicts were overlapping changes. One was the egress tunnel info fix in 'net' and the other was the vport ->send() op simplification in 'net-next'. The xfrm6_output.c conflicts was also a simplification overlapping a bug fix. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-22netlink: fix locking around NETLINK_LIST_MEMBERSHIPSDavid Herrmann
Currently, NETLINK_LIST_MEMBERSHIPS grabs the netlink table while copying the membership state to user-space. However, grabing the netlink table is effectively a write_lock_irq(), and as such we should not be triggering page-faults in the critical section. This can be easily reproduced by the following snippet: int s = socket(AF_NETLINK, SOCK_RAW, NETLINK_ROUTE); void *p = mmap(0, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANON, -1, 0); int r = getsockopt(s, 0x10e, 9, p, (void*)((char*)p + 4092)); This should work just fine, but currently triggers EFAULT and a possible WARN_ON below handle_mm_fault(). Fix this by reducing locking of NETLINK_LIST_MEMBERSHIPS to a read-side lock. The write-lock was overkill in the first place, and the read-lock allows page-faults just fine. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/usb/asix_common.c net/ipv4/inet_connection_sock.c net/switchdev/switchdev.c In the inet_connection_sock.c case the request socket hashing scheme is completely different in net-next. The other two conflicts were overlapping changes. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-18netlink: Trim skb to alloc size to avoid MSG_TRUNCArad, Ronen
netlink_dump() allocates skb based on the calculated min_dump_alloc or a per socket max_recvmsg_len. min_alloc_size is maximum space required for any single netdev attributes as calculated by rtnl_calcit(). max_recvmsg_len tracks the user provided buffer to netlink_recvmsg. It is capped at 16KiB. The intention is to avoid small allocations and to minimize the number of calls required to obtain dump information for all net devices. netlink_dump packs as many small messages as could fit within an skb that was sized for the largest single netdev information. The actual space available within an skb is larger than what is requested. It could be much larger and up to near 2x with align to next power of 2 approach. Allowing netlink_dump to use all the space available within the allocated skb increases the buffer size a user has to provide to avoid truncaion (i.e. MSG_TRUNG flag set). It was observed that with many VLANs configured on at least one netdev, a larger buffer of near 64KiB was necessary to avoid "Message truncated" error in "ip link" or "bridge [-c[ompressvlans]] vlan show" when min_alloc_size was only little over 32KiB. This patch trims skb to allocated size in order to allow the user to avoid truncation with more reasonable buffer size. Signed-off-by: Ronen Arad <ronen.arad@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-10-09net/netlink: lockdep_genl_is_held can be booleanYaowei Bai
This patch makes lockdep_genl_is_held return bool to improve readability due to this particular function only using either one or zero as its return value. No functional change. Signed-off-by: Yaowei Bai <bywxiaobai@163.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: net/ipv4/arp.c The net/ipv4/arp.c conflict was one commit adding a new local variable while another commit was deleting one. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-24genetlink: simplify genl_notifyJiri Benc
The genl_notify function has too many arguments for no real reason - all callers use genl_info to get them anyway. Just pass the genl_info down to genl_notify. Signed-off-by: Jiri Benc <jbenc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-24netlink: Replace rhash_portid with boundHerbert Xu
On Mon, Sep 21, 2015 at 02:20:22PM -0400, Tejun Heo wrote: > > store_release and load_acquire are different from the usual memory > barriers and can't be paired this way. You have to pair store_release > and load_acquire. Besides, it isn't a particularly good idea to OK I've decided to drop the acquire/release helpers as they don't help us at all and simply pessimises the code by using full memory barriers (on some architectures) where only a write or read barrier is needed. > depend on memory barriers embedded in other data structures like the > above. Here, especially, rhashtable_insert() would have write barrier > *before* the entry is hashed not necessarily *after*, which means that > in the above case, a socket which appears to have set bound to a > reader might not visible when the reader tries to look up the socket > on the hashtable. But you are right we do need an explicit write barrier here to ensure that the hashing is visible. > There's no reason to be overly smart here. This isn't a crazy hot > path, write barriers tend to be very cheap, store_release more so. > Please just do smp_store_release() and note what it's paired with. It's not about being overly smart. It's about actually understanding what's going on with the code. I've seen too many instances of people simply sprinkling synchronisation primitives around without any knowledge of what is happening underneath, which is just a recipe for creating hard-to-debug races. > > @@ -1539,7 +1546,7 @@ static int netlink_bind(struct socket *sock, struct sockaddr *addr, > > } > > } > > > > - if (!nlk->portid) { > > + if (!nlk->bound) { > > I don't think you can skip load_acquire here just because this is the > second deref of the variable. That doesn't change anything. Race > condition could still happen between the first and second tests and > skipping the second would lead to the same kind of bug. The reason this one is OK is because we do not use nlk->portid or try to get nlk from the hash table before we return to user-space. However, there is a real bug here that none of these acquire/release helpers discovered. The two bound tests here used to be a single one. Now that they are separate it is entirely possible for another thread to come in the middle and bind the socket. So we need to repeat the portid check in order to maintain consistency. > > @@ -1587,7 +1594,7 @@ static int netlink_connect(struct socket *sock, struct sockaddr *addr, > > !netlink_allowed(sock, NL_CFG_F_NONROOT_SEND)) > > return -EPERM; > > > > - if (!nlk->portid) > > + if (!nlk->bound) > > Don't we need load_acquire here too? Is this path holding a lock > which makes that unnecessary? Ditto. ---8<--- The commit 1f770c0a09da855a2b51af6d19de97fb955eca85 ("netlink: Fix autobind race condition that leads to zero port ID") created some new races that can occur due to inconcsistencies between the two port IDs. Tejun is right that a barrier is unavoidable. Therefore I am reverting to the original patch that used a boolean to indicate that a user netlink socket has been bound. Barriers have been added where necessary to ensure that a valid portid and the hashed socket is visible. I have also changed netlink_insert to only return EBUSY if the socket is bound to a portid different to the requested one. This combined with only reading nlk->bound once in netlink_bind fixes a race where two threads that bind the socket at the same time with different port IDs may both succeed. Fixes: 1f770c0a09da ("netlink: Fix autobind race condition that leads to zero port ID") Reported-by: Tejun Heo <tj@kernel.org> Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Nacked-by: Tejun Heo <tj@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-20netlink: Fix autobind race condition that leads to zero port IDHerbert Xu
The commit c0bb07df7d981e4091432754e30c9c720e2c0c78 ("netlink: Reset portid after netlink_insert failure") introduced a race condition where if two threads try to autobind the same socket one of them may end up with a zero port ID. This led to kernel deadlocks that were observed by multiple people. This patch reverts that commit and instead fixes it by introducing a separte rhash_portid variable so that the real portid is only set after the socket has been successfully hashed. Fixes: c0bb07df7d98 ("netlink: Reset portid after netlink_insert failure") Reported-by: Tejun Heo <tj@kernel.org> Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-11netlink, mmap: transform mmap skb into full skb on tapsDaniel Borkmann
Ken-ichirou reported that running netlink in mmap mode for receive in combination with nlmon will throw a NULL pointer dereference in __kfree_skb() on nlmon_xmit(), in my case I can also trigger an "unable to handle kernel paging request". The problem is the skb_clone() in __netlink_deliver_tap_skb() for skbs that are mmaped. I.e. the cloned skb doesn't have a destructor, whereas the mmap netlink skb has it pointed to netlink_skb_destructor(), set in the handler netlink_ring_setup_skb(). There, skb->head is being set to NULL, so that in such cases, __kfree_skb() doesn't perform a skb_release_data() via skb_release_all(), where skb->head is possibly being freed through kfree(head) into slab allocator, although netlink mmap skb->head points to the mmap buffer. Similarly, the same has to be done also for large netlink skbs where the data area is vmalloced. Therefore, as discussed, make a copy for these rather rare cases for now. This fixes the issue on my and Ken-ichirou's test-cases. Reference: http://thread.gmane.org/gmane.linux.network/371129 Fixes: bcbde0d449ed ("net: netlink: virtual tap device management") Reported-by: Ken-ichirou MATSUZAWA <chamaken@gmail.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Tested-by: Ken-ichirou MATSUZAWA <chamaken@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-09netlink, mmap: fix edge-case leakages in nf queue zero-copyDaniel Borkmann
When netlink mmap on receive side is the consumer of nf queue data, it can happen that in some edge cases, we write skb shared info into the user space mmap buffer: Assume a possible rx ring frame size of only 4096, and the network skb, which is being zero-copied into the netlink skb, contains page frags with an overall skb->len larger than the linear part of the netlink skb. skb_zerocopy(), which is generic and thus not aware of the fact that shared info cannot be accessed for such skbs then tries to write and fill frags, thus leaking kernel data/pointers and in some corner cases possibly writing out of bounds of the mmap area (when filling the last slot in the ring buffer this way). I.e. the ring buffer slot is then of status NL_MMAP_STATUS_VALID, has an advertised length larger than 4096, where the linear part is visible at the slot beginning, and the leaked sizeof(struct skb_shared_info) has been written to the beginning of the next slot (also corrupting the struct nl_mmap_hdr slot header incl. status etc), since skb->end points to skb->data + ring->frame_size - NL_MMAP_HDRLEN. The fix adds and lets __netlink_alloc_skb() take the actual needed linear room for the network skb + meta data into account. It's completely irrelevant for non-mmaped netlink sockets, but in case mmap sockets are used, it can be decided whether the available skb_tailroom() is really large enough for the buffer, or whether it needs to internally fallback to a normal alloc_skb(). >From nf queue side, the information whether the destination port is an mmap RX ring is not really available without extra port-to-socket lookup, thus it can only be determined in lower layers i.e. when __netlink_alloc_skb() is called that checks internally for this. I chose to add the extra ldiff parameter as mmap will then still work: We have data_len and hlen in nfqnl_build_packet_message(), data_len is the full length (capped at queue->copy_range) for skb_zerocopy() and hlen some possible part of data_len that needs to be copied; the rem_len variable indicates the needed remaining linear mmap space. The only other workaround in nf queue internally would be after allocation time by f.e. cap'ing the data_len to the skb_tailroom() iff we deal with an mmap skb, but that would 1) expose the fact that we use a mmap skb to upper layers, and 2) trim the skb where we otherwise could just have moved the full skb into the normal receive queue. After the patch, in my test case the ring slot doesn't fit and therefore shows NL_MMAP_STATUS_COPY, where a full skb carries all the data and thus needs to be picked up via recv(). Fixes: 3ab1f683bf8b ("nfnetlink: add support for memory mapped netlink") Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-09netlink, mmap: don't walk rx ring on poll if receive queue non-emptyDaniel Borkmann
In case of netlink mmap, there can be situations where received frames have to be placed into the normal receive queue. The ring buffer indicates this through NL_MMAP_STATUS_COPY, so the user is asked to pick them up via recvmsg(2) syscall, and to put the slot back to NL_MMAP_STATUS_UNUSED. Commit 0ef707700f1c ("netlink: rx mmap: fix POLLIN condition") changed polling, so that we walk in the worst case the whole ring through the new netlink_has_valid_frame(), for example, when the ring would have no NL_MMAP_STATUS_VALID, but at least one NL_MMAP_STATUS_COPY frame. Since we do a datagram_poll() already earlier to pick up a mask that could possibly contain POLLIN | POLLRDNORM already (due to NL_MMAP_STATUS_COPY), we can skip checking the rx ring entirely. In case the kernel is compiled with !CONFIG_NETLINK_MMAP, then all this is irrelevant anyway as netlink_poll() is just defined as datagram_poll(). Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-30netlink: rx mmap: fix POLLIN conditionKen-ichirou MATSUZAWA
Poll() returns immediately after setting the kernel current frame (ring->head) to SKIP from user space even though there is no new frame. And in a case of all frames is VALID, user space program unintensionally sets (only) kernel current frame to UNUSED, then calls poll(), it will not return immediately even though there are VALID frames. To avoid situations like above, I think we need to scan all frames to find VALID frames at poll() like netlink_alloc_skb(), netlink_forward_ring() finding an UNUSED frame at skb allocation. Signed-off-by: Ken-ichirou MATSUZAWA <chamas@h4.dion.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-28netlink: mmap: fix lookup frame positionKen-ichirou MATSUZAWA
__netlink_lookup_frame() was always called with the same "pos" value in netlink_forward_ring(). It will look at the same ring entry header over and over again, every time through this loop. Then cycle through the whole ring, advancing ring->head, not "pos" until it equals the "ring->head != head" loop test fails. Signed-off-by: Ken-ichirou MATSUZAWA <chamas@h4.dion.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-28netlink: add NETLINK_CAP_ACK socket optionChristophe Ricard
Since commit c05cdb1b864f ("netlink: allow large data transfers from user-space"), the kernel may fail to allocate the necessary room for the acknowledgment message back to userspace. This patch introduces a new socket option that trims off the payload of the original netlink message. The netlink message header is still included, so the user can guess from the sequence number what is the message that has triggered the acknowledgment. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-23netlink: mmap: fix tx type checkKen-ichirou MATSUZAWA
I can't send netlink message via mmaped netlink socket since commit: a8866ff6a5bce7d0ec465a63bc482a85c09b0d39 netlink: make the check for "send from tx_ring" deterministic msg->msg_iter.type is set to WRITE (1) at SYSCALL_DEFINE6(sendto, ... import_single_range(WRITE, ... iov_iter_init(1, WRITE, ... call path, so that we need to check the type by iter_is_iovec() to accept the WRITE. Signed-off-by: Ken-ichirou MATSUZAWA <chamas@h4.dion.ne.jp> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-10netlink: make sure -EBUSY won't escape from netlink_insertDaniel Borkmann
Linus reports the following deadlock on rtnl_mutex; triggered only once so far (extract): [12236.694209] NetworkManager D 0000000000013b80 0 1047 1 0x00000000 [12236.694218] ffff88003f902640 0000000000000000 ffffffff815d15a9 0000000000000018 [12236.694224] ffff880119538000 ffff88003f902640 ffffffff81a8ff84 00000000ffffffff [12236.694230] ffffffff81a8ff88 ffff880119c47f00 ffffffff815d133a ffffffff81a8ff80 [12236.694235] Call Trace: [12236.694250] [<ffffffff815d15a9>] ? schedule_preempt_disabled+0x9/0x10 [12236.694257] [<ffffffff815d133a>] ? schedule+0x2a/0x70 [12236.694263] [<ffffffff815d15a9>] ? schedule_preempt_disabled+0x9/0x10 [12236.694271] [<ffffffff815d2c3f>] ? __mutex_lock_slowpath+0x7f/0xf0 [12236.694280] [<ffffffff815d2cc6>] ? mutex_lock+0x16/0x30 [12236.694291] [<ffffffff814f1f90>] ? rtnetlink_rcv+0x10/0x30 [12236.694299] [<ffffffff8150ce3b>] ? netlink_unicast+0xfb/0x180 [12236.694309] [<ffffffff814f5ad3>] ? rtnl_getlink+0x113/0x190 [12236.694319] [<ffffffff814f202a>] ? rtnetlink_rcv_msg+0x7a/0x210 [12236.694331] [<ffffffff8124565c>] ? sock_has_perm+0x5c/0x70 [12236.694339] [<ffffffff814f1fb0>] ? rtnetlink_rcv+0x30/0x30 [12236.694346] [<ffffffff8150d62c>] ? netlink_rcv_skb+0x9c/0xc0 [12236.694354] [<ffffffff814f1f9f>] ? rtnetlink_rcv+0x1f/0x30 [12236.694360] [<ffffffff8150ce3b>] ? netlink_unicast+0xfb/0x180 [12236.694367] [<ffffffff8150d344>] ? netlink_sendmsg+0x484/0x5d0 [12236.694376] [<ffffffff810a236f>] ? __wake_up+0x2f/0x50 [12236.694387] [<ffffffff814cad23>] ? sock_sendmsg+0x33/0x40 [12236.694396] [<ffffffff814cb05e>] ? ___sys_sendmsg+0x22e/0x240 [12236.694405] [<ffffffff814cab75>] ? ___sys_recvmsg+0x135/0x1a0 [12236.694415] [<ffffffff811a9d12>] ? eventfd_write+0x82/0x210 [12236.694423] [<ffffffff811a0f9e>] ? fsnotify+0x32e/0x4c0 [12236.694429] [<ffffffff8108cb70>] ? wake_up_q+0x60/0x60 [12236.694434] [<ffffffff814cba09>] ? __sys_sendmsg+0x39/0x70 [12236.694440] [<ffffffff815d4797>] ? entry_SYSCALL_64_fastpath+0x12/0x6a It seems so far plausible that the recursive call into rtnetlink_rcv() looks suspicious. One way, where this could trigger is that the senders NETLINK_CB(skb).portid was wrongly 0 (which is rtnetlink socket), so the rtnl_getlink() request's answer would be sent to the kernel instead to the actual user process, thus grabbing rtnl_mutex() twice. One theory would be that netlink_autobind() triggered via netlink_sendmsg() internally overwrites the -EBUSY error to 0, but where it is wrongly originating from __netlink_insert() instead. That would reset the socket's portid to 0, which is then filled into NETLINK_CB(skb).portid later on. As commit d470e3b483dc ("[NETLINK]: Fix two socket hashing bugs.") also puts it, -EBUSY should not be propagated from netlink_insert(). It looks like it's very unlikely to reproduce. We need to trigger the rhashtable_insert_rehash() handler under a situation where rehashing currently occurs (one /rare/ way would be to hit ht->elasticity limits while not filled enough to expand the hashtable, but that would rather require a specifically crafted bind() sequence with knowledge about destination slots, seems unlikely). It probably makes sense to guard __netlink_insert() in any case and remap that error. It was suggested that EOVERFLOW might be better than an already overloaded ENOMEM. Reference: http://thread.gmane.org/gmane.linux.network/372676 Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-21netlink: don't hold mutex in rcu callback when releasing mmapd ringFlorian Westphal
Kirill A. Shutemov says: This simple test-case trigers few locking asserts in kernel: int main(int argc, char **argv) { unsigned int block_size = 16 * 4096; struct nl_mmap_req req = { .nm_block_size = block_size, .nm_block_nr = 64, .nm_frame_size = 16384, .nm_frame_nr = 64 * block_size / 16384, }; unsigned int ring_size; int fd; fd = socket(AF_NETLINK, SOCK_RAW, NETLINK_GENERIC); if (setsockopt(fd, SOL_NETLINK, NETLINK_RX_RING, &req, sizeof(req)) < 0) exit(1); if (setsockopt(fd, SOL_NETLINK, NETLINK_TX_RING, &req, sizeof(req)) < 0) exit(1); ring_size = req.nm_block_nr * req.nm_block_size; mmap(NULL, 2 * ring_size, PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0); return 0; } +++ exited with 0 +++ BUG: sleeping function called from invalid context at /home/kas/git/public/linux-mm/kernel/locking/mutex.c:616 in_atomic(): 1, irqs_disabled(): 0, pid: 1, name: init 3 locks held by init/1: #0: (reboot_mutex){+.+...}, at: [<ffffffff81080959>] SyS_reboot+0xa9/0x220 #1: ((reboot_notifier_list).rwsem){.+.+..}, at: [<ffffffff8107f379>] __blocking_notifier_call_chain+0x39/0x70 #2: (rcu_callback){......}, at: [<ffffffff810d32e0>] rcu_do_batch.isra.49+0x160/0x10c0 Preemption disabled at:[<ffffffff8145365f>] __delay+0xf/0x20 CPU: 1 PID: 1 Comm: init Not tainted 4.1.0-00009-gbddf4c4818e0 #253 Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS Debian-1.8.2-1 04/01/2014 ffff88017b3d8000 ffff88027bc03c38 ffffffff81929ceb 0000000000000102 0000000000000000 ffff88027bc03c68 ffffffff81085a9d 0000000000000002 ffffffff81ca2a20 0000000000000268 0000000000000000 ffff88027bc03c98 Call Trace: <IRQ> [<ffffffff81929ceb>] dump_stack+0x4f/0x7b [<ffffffff81085a9d>] ___might_sleep+0x16d/0x270 [<ffffffff81085bed>] __might_sleep+0x4d/0x90 [<ffffffff8192e96f>] mutex_lock_nested+0x2f/0x430 [<ffffffff81932fed>] ? _raw_spin_unlock_irqrestore+0x5d/0x80 [<ffffffff81464143>] ? __this_cpu_preempt_check+0x13/0x20 [<ffffffff8182fc3d>] netlink_set_ring+0x1ed/0x350 [<ffffffff8182e000>] ? netlink_undo_bind+0x70/0x70 [<ffffffff8182fe20>] netlink_sock_destruct+0x80/0x150 [<ffffffff817e484d>] __sk_free+0x1d/0x160 [<ffffffff817e49a9>] sk_free+0x19/0x20 [..] Cong Wang says: We can't hold mutex lock in a rcu callback, [..] Thomas Graf says: The socket should be dead at this point. It might be simpler to add a netlink_release_ring() function which doesn't require locking at all. Reported-by: "Kirill A. Shutemov" <kirill@shutemov.name> Diagnosed-by: Cong Wang <cwang@twopensource.com> Suggested-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-07-03netlink: Delete an unnecessary check before the function call "module_put"Markus Elfring
The module_put() function tests whether its argument is NULL and then returns immediately. Thus the test around the call is not needed. This issue was detected by using the Coccinelle software. Signed-off-by: Markus Elfring <elfring@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-06-21netlink: add API to retrieve all group membershipsDavid Herrmann
This patch adds getsockopt(SOL_NETLINK, NETLINK_LIST_MEMBERSHIPS) to retrieve all groups a socket is a member of. Currently, we have to use getsockname() and look at the nl.nl_groups bitmask. However, this mask is limited to 32 groups. Hence, similar to NETLINK_ADD_MEMBERSHIP and NETLINK_DROP_MEMBERSHIP, this adds a separate sockopt to manager higher groups IDs than 32. This new NETLINK_LIST_MEMBERSHIPS option takes a pointer to __u32 and the size of the array. The array is filled with the full membership-set of the socket, and the required array size is returned in optlen. Hence, user-space can retry with a properly sized array in case it was too small. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/cadence/macb.c drivers/net/phy/phy.c include/linux/skbuff.h net/ipv4/tcp.c net/switchdev/switchdev.c Switchdev was a case of RTNH_H_{EXTERNAL --> OFFLOAD} renaming overlapping with net-next changes of various sorts. phy.c was a case of two changes, one adding a local variable to a function whilst the second was removing one. tcp.c overlapped a deadlock fix with the addition of new tcp_info statistic values. macb.c involved the addition of two zyncq device entries. skbuff.h involved adding back ipv4_daddr to nf_bridge_info whilst net-next changes put two other existing members of that struct into a union. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-17netlink: Use random autobind roverHerbert Xu
Currently we use a global rover to select a port ID that is unique. This used to work consistently when it was protected with a global lock. However as we're now lockless, the global rover can exhibit pathological behaviour should multiple threads all stomp on it at the same time. Granted this will eventually resolve itself but the process is suboptimal. This patch replaces the global rover with a pseudorandom starting point to avoid this issue. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-16netlink: Reset portid after netlink_insert failureHerbert Xu
The commit c5adde9468b0714a051eac7f9666f23eb10b61f7 ("netlink: eliminate nl_sk_hash_lock") breaks the autobind retry mechanism because it doesn't reset portid after a failed netlink_insert. This means that should autobind fail the first time around, then the socket will be stuck in limbo as it can never be bound again since it already has a non-zero portid. Fixes: c5adde9468b0 ("netlink: eliminate nl_sk_hash_lock") Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-14netlink: move nl_table in read_mostly sectionEric Dumazet
netlink sockets creation and deletion heavily modify nl_table_users and nl_table_lock. If nl_table is sharing one cache line with one of them, netlink performance is really bad on SMP. ffffffff81ff5f00 B nl_table ffffffff81ff5f0c b nl_table_users Putting nl_table in read_mostly section increased performance of my open/delete netlink sockets test by about 80 % This came up while diagnosing a getaddrinfo() problem. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Four minor merge conflicts: 1) qca_spi.c renamed the local variable used for the SPI device from spi_device to spi, meanwhile the spi_set_drvdata() call got moved further up in the probe function. 2) Two changes were both adding new members to codel params structure, and thus we had overlapping changes to the initializer function. 3) 'net' was making a fix to sk_release_kernel() which is completely removed in 'net-next'. 4) In net_namespace.c, the rtnl_net_fill() call for GET operations had the command value fixed, meanwhile 'net-next' adjusted the argument signature a bit. This also matches example merge resolutions posted by Stephen Rothwell over the past two days. Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-11netlink: Create kernel netlink sockets in the proper network namespaceEric W. Biederman
Utilize the new functionality of sk_alloc so that nothing needs to be done to suprress the reference counting on kernel sockets. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-11net: Pass kern from net_proto_family.create to sk_allocEric W. Biederman
In preparation for changing how struct net is refcounted on kernel sockets pass the knowledge that we are creating a kernel socket from sock_create_kern through to sk_alloc. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-09netlink: allow to listen "all" netnsNicolas Dichtel
More accurately, listen all netns that have a nsid assigned into the netns where the netlink socket is opened. For this purpose, a netlink socket option is added: NETLINK_LISTEN_ALL_NSID. When this option is set on a netlink socket, this socket will receive netlink notifications from all netns that have a nsid assigned into the netns where the socket has been opened. The nsid is sent to userland via an anscillary data. With this patch, a daemon needs only one socket to listen many netns. This is useful when the number of netns is high. Because 0 is a valid value for a nsid, the field nsid_is_set indicates if the field nsid is valid or not. skb->cb is initialized to 0 on skb allocation, thus we are sure that we will never send a nsid 0 by error to the userland. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-09netlink: rename private flags and statesNicolas Dichtel
These flags and states have the same prefix (NETLINK_) that netlink socket options. To avoid confusion and to be able to name a flag like a socket option, let's use an other prefix: NETLINK_[S|F]_. Note: a comment has been fixed, it was talking about NETLINK_RECV_NO_ENOBUFS socket option instead of NETLINK_NO_ENOBUFS. Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-03netlink: Remove max_size settingHerbert Xu
We currently limit the hash table size to 64K which is very bad as even 10 years ago it was relatively easy to generate millions of sockets. Since the hash table is naturally limited by memory allocation failure, we don't really need an explicit limit so this patch removes it. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Thomas Graf <tgraf@noironetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-04-25net: fix crash in build_skb()Eric Dumazet
When I added pfmemalloc support in build_skb(), I forgot netlink was using build_skb() with a vmalloc() area. In this patch I introduce __build_skb() for netlink use, and build_skb() is a wrapper handling both skb->head_frag and skb->pfmemalloc This means netlink no longer has to hack skb->head_frag [ 1567.700067] kernel BUG at arch/x86/mm/physaddr.c:26! [ 1567.700067] invalid opcode: 0000 [#1] PREEMPT SMP KASAN [ 1567.700067] Dumping ftrace buffer: [ 1567.700067] (ftrace buffer empty) [ 1567.700067] Modules linked in: [ 1567.700067] CPU: 9 PID: 16186 Comm: trinity-c182 Not tainted 4.0.0-next-20150424-sasha-00037-g4796e21 #2167 [ 1567.700067] task: ffff880127efb000 ti: ffff880246770000 task.ti: ffff880246770000 [ 1567.700067] RIP: __phys_addr (arch/x86/mm/physaddr.c:26 (discriminator 3)) [ 1567.700067] RSP: 0018:ffff8802467779d8 EFLAGS: 00010202 [ 1567.700067] RAX: 000041000ed8e000 RBX: ffffc9008ed8e000 RCX: 000000000000002c [ 1567.700067] RDX: 0000000000000004 RSI: 0000000000000000 RDI: ffffffffb3fd6049 [ 1567.700067] RBP: ffff8802467779f8 R08: 0000000000000019 R09: ffff8801d0168000 [ 1567.700067] R10: ffff8801d01680c7 R11: ffffed003a02d019 R12: ffffc9000ed8e000 [ 1567.700067] R13: 0000000000000f40 R14: 0000000000001180 R15: ffffc9000ed8e000 [ 1567.700067] FS: 00007f2a7da3f700(0000) GS:ffff8801d1000000(0000) knlGS:0000000000000000 [ 1567.700067] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 1567.700067] CR2: 0000000000738308 CR3: 000000022e329000 CR4: 00000000000007e0 [ 1567.700067] Stack: [ 1567.700067] ffffc9000ed8e000 ffff8801d0168000 ffffc9000ed8e000 ffff8801d0168000 [ 1567.700067] ffff880246777a28 ffffffffad7c0a21 0000000000001080 ffff880246777c08 [ 1567.700067] ffff88060d302e68 ffff880246777b58 ffff880246777b88 ffffffffad9a6821 [ 1567.700067] Call Trace: [ 1567.700067] build_skb (include/linux/mm.h:508 net/core/skbuff.c:316) [ 1567.700067] netlink_sendmsg (net/netlink/af_netlink.c:1633 net/netlink/af_netlink.c:2329) [ 1567.774369] ? sched_clock_cpu (kernel/sched/clock.c:311) [ 1567.774369] ? netlink_unicast (net/netlink/af_netlink.c:2273) [ 1567.774369] ? netlink_unicast (net/netlink/af_netlink.c:2273) [ 1567.774369] sock_sendmsg (net/socket.c:614 net/socket.c:623) [ 1567.774369] sock_write_iter (net/socket.c:823) [ 1567.774369] ? sock_sendmsg (net/socket.c:806) [ 1567.774369] __vfs_write (fs/read_write.c:479 fs/read_write.c:491) [ 1567.774369] ? get_lock_stats (kernel/locking/lockdep.c:249) [ 1567.774369] ? default_llseek (fs/read_write.c:487) [ 1567.774369] ? vtime_account_user (kernel/sched/cputime.c:701) [ 1567.774369] ? rw_verify_area (fs/read_write.c:406 (discriminator 4)) [ 1567.774369] vfs_write (fs/read_write.c:539) [ 1567.774369] SyS_write (fs/read_write.c:586 fs/read_write.c:577) [ 1567.774369] ? SyS_read (fs/read_write.c:577) [ 1567.774369] ? __this_cpu_preempt_check (lib/smp_processor_id.c:63) [ 1567.774369] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2594 kernel/locking/lockdep.c:2636) [ 1567.774369] ? trace_hardirqs_on_thunk (arch/x86/lib/thunk_64.S:42) [ 1567.774369] system_call_fastpath (arch/x86/kernel/entry_64.S:261) Fixes: 79930f5892e ("net: do not deplete pfmemalloc reserve") Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-25rhashtable: provide len to obj_hashfnPatrick McHardy
nftables sets will be converted to use so called setextensions, moving the key to a non-fixed position. To hash it, the obj_hashfn must be used, however it so far doesn't receive the length parameter. Pass the key length to obj_hashfn() and convert existing users. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2015-03-24rhashtable: Disable automatic shrinking by defaultThomas Graf
Introduce a new bool automatic_shrinking to require the user to explicitly opt-in to automatic shrinking of tables. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-23netlink: Use default rhashtable hashfnHerbert Xu
This patch removes the explicit jhash value for the hashfn parameter of rhashtable. As the key length is a multiple of 4, this means that we will actually end up using jhash2. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-21netlink: Remove netlink_compare_arg.trailerHerbert Xu
Instead of computing the offset from trailer, this patch computes netlink_compare_arg_len from the offset of portid and then adds 4 to it. This allows trailer to be removed. Reported-by: David Miller <davem@davemloft.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-20netlink: Move namespace into hash keyHerbert Xu
Currently the name space is a de facto key because it has to match before we find an object in the hash table. However, it isn't in the hash value so all objects from different name spaces with the same port ID hash to the same bucket. This is bad as the number of name spaces is unbounded. This patch fixes this by using the namespace when doing the hash. Because the namespace field doesn't lie next to the portid field in the netlink socket, this patch switches over to the rhashtable interface without a fixed key. This patch also uses the new inlined rhashtable interface where possible. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-18netlink: Use rhashtable max_size instead of max_shiftHerbert Xu
This patch converts netlink to use rhashtable max_size instead of the obsolete max_shift. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-03Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/rocker/rocker.c The rocker commit was two overlapping changes, one to rename the ->vport member to ->pport, and another making the bitmask expression use '1ULL' instead of plain '1'. Signed-off-by: David S. Miller <davem@davemloft.net>
