path: root/net/netrom
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-10net: netrom: use seq_hlist_foo() helpersLi Zefan
Simplify seq_file code. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-16ax25: netrom: rose: Fix timer oopsesJarek Poplawski
Wrong ax25_cb refcounting in ax25_send_frame() and by its callers can cause timer oopses (first reported with 2.6.29.6 kernel). Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=14905 Reported-by: Bernard Pidoux <bpidoux@free.fr> Tested-by: Bernard Pidoux <bpidoux@free.fr> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: Introduce for_each_netdev_rcu() iteratorEric Dumazet
Adds RCU management to the list of netdevices. Convert some for_each_netdev() users to RCU version, if it can avoid read_lock-ing dev_base_lock Ie: read_lock(&dev_base_loack); for_each_netdev(net, dev) some_action(); read_unlock(&dev_base_lock); becomes : rcu_read_lock(); for_each_netdev_rcu(net, dev) some_action(); rcu_read_unlock(); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: mark net_proto_ops as constStephen Hemminger
All usages of structure net_proto_ops should be declared const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-02Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/yellowfin.c
2009-09-01convert hamradio drivers to netdev_txreturnt_tStephen Hemminger
2009-08-17NETROM: Fix use of static bufferRalf Baechle
The static variable used by nr_call_to_digi might result in corruption if multiple threads are trying to usee a node or neighbour via ioctl. Fixed by having the caller pass a structure in. This is safe because nr_add_node rsp. nr_add_neigh will allocate a permanent structure, if needed. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-08-06netrom: Fix nr_getname() leakEric Dumazet
nr_getname() can leak kernel memory to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-17net: sk_wmem_alloc has initial value of one, not zeroEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. Some protocols check sk_wmem_alloc value to determine if a timer must delay socket deallocation. We must take care of the sk_wmem_alloc value being one instead of zero when no write allocations are pending. Reported by Ingo Molnar, and full diagnostic from David Miller. This patch introduces three helpers to get read/write allocations and a followup patch will use these helpers to report correct write allocations to user. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-22net/netrom: Fix socket lockingJean Delvare
Patch "af_rose/x25: Sanity check the maximum user frame size" (commit 83e0bbcbe2145f160fbaa109b0439dae7f4a38a9) from Alan Cox got locking wrong. If we bail out due to user frame size being too large, we must unlock the socket beforehand. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-27Revert "netrom: zero length frame filtering in NetRom"David S. Miller
This reverts commit a3ac80a130300573de351083cf4a5b46d233e8bf. Alan Cox says that zero length writes do have special meaning and are useful in this protocol. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-27af_rose/x25: Sanity check the maximum user frame sizeAlan Cox
Otherwise we can wrap the sizes and end up sending garbage. Closes #10423 Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-21netrom: zero length frame filtering in NetRomBernard Pidoux
A zero length frame filter was recently introduced in ROSE protocole. Previous commit makes the same at AX25 protocole level. This patch has the same purpose for NetRom protocole. The reason is that empty frames have no meaning in NetRom protocole. Signed-off-by: Bernard Pidoux <f6bvp@amsat.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21netrom: convert to net_device_opsStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21netrom: convert to internal net_device_statsStephen Hemminger
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits) net: Allow dependancies of FDDI & Tokenring to be modular. igb: Fix build warning when DCA is disabled. net: Fix warning fallout from recent NAPI interface changes. gro: Fix potential use after free sfc: If AN is enabled, always read speed/duplex from the AN advertising bits sfc: When disabling the NIC, close the device rather than unregistering it sfc: SFT9001: Add cable diagnostics sfc: Add support for multiple PHY self-tests sfc: Merge top-level functions for self-tests sfc: Clean up PHY mode management in loopback self-test sfc: Fix unreliable link detection in some loopback modes sfc: Generate unique names for per-NIC workqueues 802.3ad: use standard ethhdr instead of ad_header 802.3ad: generalize out mac address initializer 802.3ad: initialize ports LACPDU from const initializer 802.3ad: remove typedef around ad_system 802.3ad: turn ports is_individual into a bool 802.3ad: turn ports is_enabled into a bool 802.3ad: make ntt bool ixgbe: Fix set_ringparam in ixgbe to use the same memory pools. ... Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due to the conversion to %pI (in this networking merge) and the addition of doing IPv6 addresses (from the earlier merge of CIFS).
2008-11-14CRED: Wrap task credential accesses in the netrom protocolDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: linux-hams@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-11-03net: '&' reduxAlexey Dobriyan
I want to compile out proc_* and sysctl_* handlers totally and stub them to NULL depending on config options, however usage of & will prevent this, since taking adress of NULL pointer will break compilation. So, drop & in front of every ->proc_handler and every ->strategy handler, it was never needed in fact. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-06netrom: Fix sock_orphan() use in nr_releaseJarek Poplawski
While debugging another bug it was found that NetRom socks are sometimes seen unorphaned in sk_free(). This patch moves sock_orphan() in nr_release() to the beginning (like in ax25, or rose). Reported-and-tested-by: Bernard Pidoux f6bvp <f6bvp@free.fr> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22netdev: Handle ->addr_list_lock just like ->_xmit_lock for lockdep.David S. Miller
The new address list lock needs to handle the same device layering issues that the _xmit_lock one does. This integrates work done by Patrick McHardy. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19netns: Use net_eq() to compare net-namespaces for optimization.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, namespace is always &init_net. Compiler will be able to omit namespace comparisons with this patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Allocate multiple queues for TX.David S. Miller
alloc_netdev_mq() now allocates an array of netdev_queue structures for TX, based upon the queue_count argument. Furthermore, all accesses to the TX queues are now vectored through the netdev_get_tx_queue() and netdev_for_each_tx_queue() interfaces. This makes it easy to grep the tree for all things that want to get to a TX queue of a net device. Problem spots which are not really multiqueue aware yet, and only work with one queue, can easily be spotted by grepping for all netdev_get_tx_queue() calls that pass in a zero index. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-08netdev: Move _xmit_lock and xmit_lock_owner into netdev_queue.David S. Miller
Accesses are mostly structured such that when there are multiple TX queues the code transformations will be a little bit simpler. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-17netrom: Kill spurious NULL'ing of sk->sk_socket.David S. Miller
In nr_release(), one code path calls sock_orphan() which will NULL out sk->sk_socket already. In the other case, handling states other than NR_STATE_{0,1,2,3}, seems to not be possible other than due to bugs. Even for an uninitialized nr->state value, that would be zero or NR_STATE_0. It might be wise to stick a WARN_ON() here. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-17netrom: Use sock_graft() and remove bogus sk_socket and sk_sleep init.David S. Miller
This is the netrom variant of changeset 9375cb8a1232d2a15fe34bec4d3474872e02faec ("ax25: Use sock_graft() and remove bogus sk_socket and sk_sleep init.") Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-01-28[NET]: Simple ctl_table to ctl_path conversions.Pavel Emelyanov
This patch includes many places, that only required replacing the ctl_table-s with appropriate ctl_paths and call register_sysctl_paths(). Nothing special was done with them. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Convert init_timer into setup_timerPavel Emelyanov
Many-many code in the kernel initialized the timer->function and timer->data together with calling init_timer(timer). There is already a helper for this. Use it for networking code. The patch is HUGE, but makes the code 130 lines shorter (98 insertions(+), 228 deletions(-)). Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-20[NET]: Correct two mistaken skb_reset_mac_header() conversions.David S. Miller
This operation helper abstracts: skb->mac_header = skb->data; but it was done in two more places which were actually: skb->mac_header = skb->network_header; and those are corrected here. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Move hardware header operations out of netdevice.Stephen Hemminger
Since hardware header operations are part of the protocol class not the device instance, make them into a separate object and save memory. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make device event notification network namespace safeEric W. Biederman
Every user of the network device notifiers is either a protocol stack or a pseudo device. If a protocol stack that does not have support for multiple network namespaces receives an event for a device that is not in the initial network namespace it quite possibly can get confused and do the wrong thing. To avoid problems until all of the protocol stacks are converted this patch modifies all netdev event handlers to ignore events on devices that are not in the initial network namespace. As the rest of the code is made network namespace aware these checks can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-19[NET] NETROM: Fix whitespace errors.YOSHIFUJI Hideaki
2007-07-10[NET]: Make all initialized struct seq_operations const.Philippe De Muyter
Make all initialized struct seq_operations in net/ const Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[NET]: Rework dev_base via list_head (v3)Pavel Emelianov
Cleanup of dev_base list use, with the aim to simplify making device list per-namespace. In almost every occasion, use of dev_base variable and dev->next pointer could be easily replaced by for_each_netdev loop. A few most complicated places were converted to using first_netdev()/next_netdev(). Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[AX25/NETROM/ROSE]: Convert to use modern wait queue APIRalf Baechle
2007-04-25[SK_BUFF]: Some more conversions to skb_copy_from_linear_dataArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
