[ Upstream commit 67c8d22a73128ff910e2287567132530abcf5b71 ]
If we want to add a datapath flow, which has more than 500 vxlan outputs'
action, we will get the following error reports:
openvswitch: netlink: Flow action size 32832 bytes exceeds max
openvswitch: netlink: Actions may not be safe on all matching packets
It seems that we can simply enlarge the MAX_ACTIONS_BUFSIZE to fix it, but
this is not the root cause. For example, for a vxlan output action, we need
about 60 bytes for the nlattr, but after it is converted to the flow
action, it only occupies 24 bytes. This means that we can still support
more than 1000 vxlan output actions for a single datapath flow under the
the current 32k max limitation.
So even if the nla_len(attr) is larger than MAX_ACTIONS_BUFSIZE, we
shouldn't report EINVAL and keep it move on, as the judgement can be
done by the reserve_sfa_size.
Signed-off-by: zhangliping <zhangliping02@baidu.com>
Acked-by: Pravin B Shelar <pshelar@ovn.org>
[ Upstream commit 494bea39f3201776cdfddc232705f54a0bd210c4 ]
For sw_flow_actions, the actions_len only represents the kernel part's
size, and when we dump the actions to the userspace, we will do the
convertions, so it's true size may become bigger than the actions_len.
But unfortunately, for OVS_PACKET_ATTR_ACTIONS, we use the actions_len
to alloc the skbuff, so the user_skb's size may become insufficient and
oops will happen like this:
skbuff: skb_over_panic: text:ffffffff8148fabf len:1749 put:157 head:
ffff881300f39000 data:ffff881300f39000 tail:0x6d5 end:0x6c0 dev:<NULL>
kernel BUG at net/core/skbuff.c:129!
Call Trace:
<IRQ>
[<ffffffff8148be82>] skb_put+0x43/0x44
[<ffffffff8148fabf>] skb_zerocopy+0x6c/0x1f4
[<ffffffffa0290d36>] queue_userspace_packet+0x3a3/0x448 [openvswitch]
[<ffffffffa0292023>] ovs_dp_upcall+0x30/0x5c [openvswitch]
[<ffffffffa028d435>] output_userspace+0x132/0x158 [openvswitch]
[<ffffffffa01e6890>] ? ip6_rcv_finish+0x74/0x77 [ipv6]
[<ffffffffa028e277>] do_execute_actions+0xcc1/0xdc8 [openvswitch]
[<ffffffffa028e3f2>] ovs_execute_actions+0x74/0x106 [openvswitch]
[<ffffffffa0292130>] ovs_dp_process_packet+0xe1/0xfd [openvswitch]
[<ffffffffa0292b77>] ? key_extract+0x63c/0x8d5 [openvswitch]
[<ffffffffa029848b>] ovs_vport_receive+0xa1/0xc3 [openvswitch]
Also we can find that the actions_len is much little than the orig_len:
crash> struct sw_flow_actions 0xffff8812f539d000
struct sw_flow_actions {
rcu = {
next = 0xffff8812f5398800,
func = 0xffffe3b00035db32
orig_len = 1384,
actions_len = 592,
actions = 0xffff8812f539d01c
So as a quick fix, use the orig_len instead of the actions_len to alloc
the user_skb.
Last, this oops happened on our system running a relative old kernel, but
the same risk still exists on the mainline, since we use the wrong
actions_len from the beginning.
Fixes: ccea74457bbd ("openvswitch: include datapath actions with sampled-packet upcall to userspace")
Cc: Neil McKee <neil.mckee@inmon.com>
Signed-off-by: Liping Zhang <zlpnobody@gmail.com>
[ Upstream commit 69ec932e364b1ba9c3a2085fe96b76c8a3f71e7c ]
Before the 'type' is validated, we shouldn't use it to fetch the
ovs_ct_attr_lens's minlen and maxlen, else, out of bound access
may happen.
Fixes: 7f8a436eaa2c ("openvswitch: Add conntrack action")
[ Upstream commit 8f3dbfd79ed9ef9770305a7cc4e13dfd31ad2cd0 ]
Added a case for OVS_TUNNEL_KEY_ATTR_PAD to the switch statement
in ip_tun_from_nlattr in order to prevent the default case
returning an error.
Fixes: b46f6ded906e ("libnl: nla_put_be64(): align on a 64-bit area")
Signed-off-by: Kris Murphy <kriskend@linux.vnet.ibm.com>
Acked-by: Joe Stringer <joe@ovn.org>
[ Upstream commit 3d20f1f7bd575d147ffa75621fa560eea0aec690 ]
When dealing with ipv6 source tunnel key address attribute
(OVS_TUNNEL_KEY_ATTR_IPV6_SRC) we are wrongly setting the tunnel
dst ip, fix that.
Fixes: 6b26ba3a7d95 ('openvswitch: netlink attributes for IPv6 tunneling')
Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com>
Reported-by: Paul Blakey <paulb@mellanox.com>
Acked-by: Jiri Benc <jbenc@redhat.com>
[ Upstream commit 48cac18ecf1de82f76259a54402c3adb7839ad01 ]
Andrey reported a use-after-free in IPv6 stack.
Issue here is that we free the socket while it still has skb
in TX path and in some queues.
It happens here because IPv6 reassembly unit messes skb->truesize,
breaking skb_set_owner_w() badly.
We fixed a similar issue for IPV4 in commit 8282f27449bf ("inet: frag:
Always orphan skbs inside ip_defrag()")
BUG: KASAN: use-after-free in sock_wfree+0x118/0x120
Read of size 8 at addr ffff880062da0060 by task a.out/4140
page:ffffea00018b6800 count:1 mapcount:0 mapping: (null)
index:0x0 compound_mapcount: 0
flags: 0x100000000008100(slab|head)
raw: 0100000000008100 0000000000000000 0000000000000000 0000000180130013
raw: dead000000000100 dead000000000200 ffff88006741f140 0000000000000000
page dumped because: kasan: bad access detected
CPU: 0 PID: 4140 Comm: a.out Not tainted 4.10.0-rc3+ #59
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:15
dump_stack+0x292/0x398 lib/dump_stack.c:51
describe_address mm/kasan/report.c:262
kasan_report_error+0x121/0x560 mm/kasan/report.c:370
kasan_report mm/kasan/report.c:392
__asan_report_load8_noabort+0x3e/0x40 mm/kasan/report.c:413
sock_flag ./arch/x86/include/asm/bitops.h:324
sock_wfree+0x118/0x120 net/core/sock.c:1631
skb_release_head_state+0xfc/0x250 net/core/skbuff.c:655
skb_release_all+0x15/0x60 net/core/skbuff.c:668
__kfree_skb+0x15/0x20 net/core/skbuff.c:684
kfree_skb+0x16e/0x4e0 net/core/skbuff.c:705
inet_frag_destroy+0x121/0x290 net/ipv4/inet_fragment.c:304
inet_frag_put ./include/net/inet_frag.h:133
nf_ct_frag6_gather+0x1125/0x38b0 net/ipv6/netfilter/nf_conntrack_reasm.c:617
ipv6_defrag+0x21b/0x350 net/ipv6/netfilter/nf_defrag_ipv6_hooks.c:68
nf_hook_entry_hookfn ./include/linux/netfilter.h:102
nf_hook_slow+0xc3/0x290 net/netfilter/core.c:310
nf_hook ./include/linux/netfilter.h:212
__ip6_local_out+0x52c/0xaf0 net/ipv6/output_core.c:160
ip6_local_out+0x2d/0x170 net/ipv6/output_core.c:170
ip6_send_skb+0xa1/0x340 net/ipv6/ip6_output.c:1722
ip6_push_pending_frames+0xb3/0xe0 net/ipv6/ip6_output.c:1742
rawv6_push_pending_frames net/ipv6/raw.c:613
rawv6_sendmsg+0x2cff/0x4130 net/ipv6/raw.c:927
inet_sendmsg+0x164/0x5b0 net/ipv4/af_inet.c:744
sock_sendmsg_nosec net/socket.c:635
sock_sendmsg+0xca/0x110 net/socket.c:645
sock_write_iter+0x326/0x620 net/socket.c:848
new_sync_write fs/read_write.c:499
__vfs_write+0x483/0x760 fs/read_write.c:512
vfs_write+0x187/0x530 fs/read_write.c:560
SYSC_write fs/read_write.c:607
SyS_write+0xfb/0x230 fs/read_write.c:599
entry_SYSCALL_64_fastpath+0x1f/0xc2 arch/x86/entry/entry_64.S:203
RIP: 0033:0x7ff26e6f5b79
RSP: 002b:00007ff268e0ed98 EFLAGS: 00000206 ORIG_RAX: 0000000000000001
RAX: ffffffffffffffda RBX: 00007ff268e0f9c0 RCX: 00007ff26e6f5b79
RDX: 0000000000000010 RSI: 0000000020f50fe1 RDI: 0000000000000003
RBP: 00007ff26ebc1220 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000206 R12: 0000000000000000
R13: 00007ff268e0f9c0 R14: 00007ff26efec040 R15: 0000000000000003
The buggy address belongs to the object at ffff880062da0000
which belongs to the cache RAWv6 of size 1504
The buggy address ffff880062da0060 is located 96 bytes inside
of 1504-byte region [ffff880062da0000, ffff880062da05e0)
Freed by task 4113:
save_stack_trace+0x16/0x20 arch/x86/kernel/stacktrace.c:57
save_stack+0x43/0xd0 mm/kasan/kasan.c:502
set_track mm/kasan/kasan.c:514
kasan_slab_free+0x73/0xc0 mm/kasan/kasan.c:578
slab_free_hook mm/slub.c:1352
slab_free_freelist_hook mm/slub.c:1374
slab_free mm/slub.c:2951
kmem_cache_free+0xb2/0x2c0 mm/slub.c:2973
sk_prot_free net/core/sock.c:1377
__sk_destruct+0x49c/0x6e0 net/core/sock.c:1452
sk_destruct+0x47/0x80 net/core/sock.c:1460
__sk_free+0x57/0x230 net/core/sock.c:1468
sk_free+0x23/0x30 net/core/sock.c:1479
sock_put ./include/net/sock.h:1638
sk_common_release+0x31e/0x4e0 net/core/sock.c:2782
rawv6_close+0x54/0x80 net/ipv6/raw.c:1214
inet_release+0xed/0x1c0 net/ipv4/af_inet.c:425
inet6_release+0x50/0x70 net/ipv6/af_inet6.c:431
sock_release+0x8d/0x1e0 net/socket.c:599
sock_close+0x16/0x20 net/socket.c:1063
__fput+0x332/0x7f0 fs/file_table.c:208
____fput+0x15/0x20 fs/file_table.c:244
task_work_run+0x19b/0x270 kernel/task_work.c:116
exit_task_work ./include/linux/task_work.h:21
do_exit+0x186b/0x2800 kernel/exit.c:839
do_group_exit+0x149/0x420 kernel/exit.c:943
SYSC_exit_group kernel/exit.c:954
SyS_exit_group+0x1d/0x20 kernel/exit.c:952
Allocated by task 4115:
kasan_kmalloc+0xad/0xe0 mm/kasan/kasan.c:605
kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:544
slab_post_alloc_hook mm/slab.h:432
slab_alloc_node mm/slub.c:2708
slab_alloc mm/slub.c:2716
kmem_cache_alloc+0x1af/0x250 mm/slub.c:2721
sk_prot_alloc+0x65/0x2a0 net/core/sock.c:1334
sk_alloc+0x105/0x1010 net/core/sock.c:1396
inet6_create+0x44d/0x1150 net/ipv6/af_inet6.c:183
__sock_create+0x4f6/0x880 net/socket.c:1199
sock_create net/socket.c:1239
SYSC_socket net/socket.c:1269
SyS_socket+0xf9/0x230 net/socket.c:1249
Memory state around the buggy address:
ffff880062d9ff00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff880062d9ff80: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>ffff880062da0000: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff880062da0080: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff880062da0100: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
Reported-by: Andrey Konovalov <andreyknvl@google.com>
[ Upstream commit 75f01a4c9cc291ff5cb28ca1216adb163b7a20ee ]
When executing conntrack actions on skbuffs with checksum mode
CHECKSUM_COMPLETE, the checksum must be updated to account for
header pushes and pulls. Otherwise we get "hw csum failure"
logs similar to this (ICMP packet received on geneve tunnel
via ixgbe NIC):
[ 405.740065] genev_sys_6081: hw csum failure
[ 405.740106] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G I 4.10.0-rc3+ #1
[ 405.740108] Call Trace:
[ 405.740110] <IRQ>
[ 405.740113] dump_stack+0x63/0x87
[ 405.740116] netdev_rx_csum_fault+0x3a/0x40
[ 405.740118] __skb_checksum_complete+0xcf/0xe0
[ 405.740120] nf_ip_checksum+0xc8/0xf0
[ 405.740124] icmp_error+0x1de/0x351 [nf_conntrack_ipv4]
[ 405.740132] nf_conntrack_in+0xe1/0x550 [nf_conntrack]
[ 405.740137] ? find_bucket.isra.2+0x62/0x70 [openvswitch]
[ 405.740143] __ovs_ct_lookup+0x95/0x980 [openvswitch]
[ 405.740145] ? netif_rx_internal+0x44/0x110
[ 405.740149] ovs_ct_execute+0x147/0x4b0 [openvswitch]
[ 405.740153] do_execute_actions+0x22e/0xa70 [openvswitch]
[ 405.740157] ovs_execute_actions+0x40/0x120 [openvswitch]
[ 405.740161] ovs_dp_process_packet+0x84/0x120 [openvswitch]
[ 405.740166] ovs_vport_receive+0x73/0xd0 [openvswitch]
[ 405.740168] ? udp_rcv+0x1a/0x20
[ 405.740170] ? ip_local_deliver_finish+0x93/0x1e0
[ 405.740172] ? ip_local_deliver+0x6f/0xe0
[ 405.740174] ? ip_rcv_finish+0x3a0/0x3a0
[ 405.740176] ? ip_rcv_finish+0xdb/0x3a0
[ 405.740177] ? ip_rcv+0x2a7/0x400
[ 405.740180] ? __netif_receive_skb_core+0x970/0xa00
[ 405.740185] netdev_frame_hook+0xd3/0x160 [openvswitch]
[ 405.740187] __netif_receive_skb_core+0x1dc/0xa00
[ 405.740194] ? ixgbe_clean_rx_irq+0x46d/0xa20 [ixgbe]
[ 405.740197] __netif_receive_skb+0x18/0x60
[ 405.740199] netif_receive_skb_internal+0x40/0xb0
[ 405.740201] napi_gro_receive+0xcd/0x120
[ 405.740204] gro_cell_poll+0x57/0x80 [geneve]
[ 405.740206] net_rx_action+0x260/0x3c0
[ 405.740209] __do_softirq+0xc9/0x28c
[ 405.740211] irq_exit+0xd9/0xf0
[ 405.740213] do_IRQ+0x51/0xd0
[ 405.740215] common_interrupt+0x93/0x93
Signed-off-by: Lance Richardson <lrichard@redhat.com>
If nf_ct_frag6_gather() returns an error other than -EINPROGRESS, it
means that we still have a reference to the skb. We should free it
before returning from handle_fragments, as stated in the comment above.
Fixes: daaa7d647f81 ("netfilter: ipv6: avoid nf_iterate recursion")
CC: Florian Westphal <fw@strlen.de>
CC: Pravin B Shelar <pshelar@ovn.org>
CC: Joe Stringer <joe@ovn.org>
Signed-off-by: Daniele Di Proietto <diproiettod@ovn.org>
The internal device does support 802.1AD offloading since 018c1dda5ff1
("openvswitch: 802.1AD Flow handling, actions, vlan parsing, netlink
attributes").
Signed-off-by: Jiri Benc <jbenc@redhat.com>
Acked-by: Eric Garver <e@erig.me>
When the packet has its vlan tag in skb->vlan_tci, the length of the VLAN
header is not counted in skb->len. It doesn't make sense to subtract it.
Fixes: 018c1dda5ff1 ("openvswitch: 802.1AD Flow handling, actions, vlan parsing, netlink attributes")
This code is called whenever flow key is being extracted from the packet.
The packet may be as likely vlan tagged as not.
skb_mpls_header is equivalent to mpls_hdr now. Use the existing helper
instead.
After the 48d2ab609b6b ("net: mpls: Fixups for GSO"), MPLS handling in
openvswitch was changed to have network header pointing to the start of the
MPLS headers and inner_network_header pointing after the MPLS headers.
However, key_extract was missed by the mentioned commit, causing incorrect
headers to be set when a MPLS packet just enters the bridge or after it is
recirculated.
Fixes: 48d2ab609b6b ("net: mpls: Fixups for GSO")
since commit commit db74a3335e0f6 ("openvswitch: use percpu
flow stats") flow alloc resets flow-key. So there is no need
to reset the flow-key again if OVS is using newly allocated
flow-key.
Signed-off-by: Pravin B Shelar <pshelar@ovn.org>
There is no need to declare separate key on stack,
we can just use sw_flow->key to store the key directly.
This commit fixes following warning:
net/openvswitch/datapath.c: In function ‘ovs_flow_cmd_new’:
net/openvswitch/datapath.c:1080:1: warning: the frame size of 1040 bytes
is larger than 1024 bytes [-Wframe-larger-than=]
Instead of using flow stats per NUMA node, use it per CPU. When using
megaflows, the stats lock can be a bottleneck in scalability.
On a E5-2690 12-core system, usual throughput went from ~4Mpps to
~15Mpps when forwarding between two 40GbE ports with a single flow
configured on the datapath.
This has been tested on a system with possible CPUs 0-7,16-23. After
module removal, there were no corruption on the slab cache.
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@redhat.com>
Cc: pravin shelar <pshelar@ovn.org>
On a system with only node 1 as possible, all statistics is going to be
accounted on node 0 as it will have a single writer.
However, when getting and clearing the statistics, node 0 is not going
to be considered, as it's not a possible node.
Tested that statistics are not zero on a system with only node 1
possible. Also compile-tested with CONFIG_NUMA off.
The ovs kernel data path currently defers the execution of all
recirc actions until stack utilization is at a minimum.
This is too limiting for some packet forwarding scenarios due to
the small size of the deferred action FIFO (10 entries). For
example, broadcast traffic sent out more than 10 ports with
recirculation results in packet drops when the deferred action
FIFO becomes full, as reported here:
http://openvswitch.org/pipermail/dev/2016-March/067672.html
Since the current recursion depth is available (it is already tracked
by the exec_actions_level pcpu variable), we can use it to determine
whether to execute recirculation actions immediately (safe when
recursion depth is low) or defer execution until more stack space is
available.
With this change, the deferred action fifo size becomes a non-issue
for currently failing scenarios because it is no longer used when
there are three or fewer recursions through ovs_execute_actions().
Suggested-by: Pravin Shelar <pshelar@ovn.org>
When userspace tries to create datapaths and the module is not loaded,
it will simply fail. With this patch, the module will be automatically
loaded.
Add support for 802.1ad including the ability to push and pop double
tagged vlans. Add support for 802.1ad to netlink parsing and flow
conversion. Uses double nested encap attributes to represent double
tagged vlan. Inner TPID encoded along with ctci in nested attributes.
This is based on Thomas F Herbert's original v20 patch. I made some
small clean ups and bug fixes.
Signed-off-by: Thomas F Herbert <thomasfherbert@gmail.com>
Signed-off-by: Eric Garver <e@erig.me>
When an error occurs during conntrack template creation as part of
actions validation, we need to free the template. Previously we've been
using nf_ct_put() to do this, but nf_ct_tmpl_free() is more appropriate.
Signed-off-by: Joe Stringer <joe@ovn.org>
As reported by Lennert the MPLS GSO code is failing to properly segment
large packets. There are a couple of problems:
1. the inner protocol is not set so the gso segment functions for inner
protocol layers are not getting run, and
2 MPLS labels for packets that use the "native" (non-OVS) MPLS code
are not properly accounted for in mpls_gso_segment.
The MPLS GSO code was added for OVS. It is re-using skb_mac_gso_segment
to call the gso segment functions for the higher layer protocols. That
means skb_mac_gso_segment is called twice -- once with the network
protocol set to MPLS and again with the network protocol set to the
inner protocol.
This patch sets the inner skb protocol addressing item 1 above and sets
the network_header and inner_network_header to mark where the MPLS labels
start and end. The MPLS code in OVS is also updated to set the two
network markers.
>From there the MPLS GSO code uses the difference between the network
header and the inner network header to know the size of the MPLS header
that was pushed. It then pulls the MPLS header, resets the mac_len and
protocol for the inner protocol and then calls skb_mac_gso_segment
to segment the skb.
Afterward the inner protocol segmentation is done the skb protocol
is set to mpls for each segment and the network and mac headers
restored.
Reported-by: Lennert Buytenhek <buytenh@wantstofly.org>
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
The creation of a tunnel vport (geneve, gre, vxlan) brings up a
corresponding netdev, a multi-step operation which can fail.
For example, changing a vxlan vport's netdev state to 'up' binds the
vport's socket to a UDP port - if the binding fails (e.g. due to the
port being in use), the error is currently ignored giving the
appearance that the tunnel vport creation completed successfully.
Signed-off-by: Martynas Pumputis <martynas@weave.works>
net_device->ndo_set_rx_headroom (introduced in
871b642adebe300be2e50aa5f65a418510f636ec) says
"Setting a negtaive value reset the rx headroom
to the default value".
It seems that the OVS implementation in
3a927bc7cf9d0fbe8f4a8189dd5f8440228f64e7 overlooked this and sets
dev->needed_headroom unconditionally.
This doesn't have an immediate effect, but can mess up later
LL_RESERVED_SPACE calculations, such as done in
net/ipv6/mcast.c:mld_newpack. For reference, this issue was found
from a skb_panic raised there after the length calculations had given
the wrong result.
Note the other current users of this interface
(drivers/net/tun.c:tun_set_headroom and
drivers/net/veth.c:veth_set_rx_headroom) are both checking this
correctly thus need no modification.
Thanks to Ben for some pointers from the crash dumps!
Cc: Benjamin Poirier <bpoirier@suse.com>
Cc: Paolo Abeni <pabeni@redhat.com>
Bugzilla: https://bugzilla.redhat.com/show_bug.cgi?id=1361414
Signed-off-by: Ian Wienand <iwienand@redhat.com>
ovs_ct_find_existing() issues a warning if an existing conntrack entry
classified as IP_CT_NEW is found, with the premise that this should
not happen. However, a newly confirmed, non-expected conntrack entry
remains IP_CT_NEW as long as no reply direction traffic is seen. This
has resulted into somewhat confusing kernel log messages. This patch
removes this check and warning.
Fixes: 289f2253 ("openvswitch: Find existing conntrack entry after upcall.")
Suggested-by: Joe Stringer <joe@ovn.org>
Signed-off-by: Jarno Rajahalme <jarno@ovn.org>
The conntrack label extension is currently variable-sized, e.g. if
only 2 labels are used by iptables rules then the labels->bits[] array
will only contain one element.
We track size of each label storage area in the 'words' member.
But in nftables and openvswitch we always have to ask for worst-case
since we don't know what bit will be used at configuration time.
As most arches are 64bit we need to allocate 24 bytes in this case:
struct nf_conn_labels {
u8 words; /* 0 1 */
/* XXX 7 bytes hole, try to pack */
long unsigned bits[2]; /* 8 24 */
Make bits a fixed size and drop the words member, it simplifies
the code and only increases memory requirements on x86 when
less than 64bit labels are required.
We still only allocate the extension if its needed.
Several cases of overlapping changes, except the packet scheduler
conflicts which deal with the addition of the free list parameter
to qdisc_enqueue().
Only the first and last netlink message for a particular conntrack are
actually sent. The first message is sent through nf_conntrack_confirm when
the conntrack is committed. The last one is sent when the conntrack is
destroyed on timeout. The other conntrack state change messages are not
advertised.
When the conntrack subsystem is used from netfilter, nf_conntrack_confirm
is called for each packet, from the postrouting hook, which in turn calls
nf_ct_deliver_cached_events to send the state change netlink messages.
This commit fixes the problem by calling nf_ct_deliver_cached_events in the
non-commit case as well.
CC: Joe Stringer <joestringer@nicira.com>
CC: Justin Pettit <jpettit@nicira.com>
CC: Andy Zhou <azhou@nicira.com>
CC: Thomas Graf <tgraf@suug.ch>
Signed-off-by: Samuel Gauthier <samuel.gauthier@6wind.com>
Only set conntrack mark or labels when the commit flag is specified.
This makes sure we can not set them before the connection has been
persisted, as in that case the mark and labels would be lost in an
event of an userspace upcall.
OVS userspace already requires the commit flag to accept setting
ct_mark and/or ct_labels. Validate for this in the kernel API.
Set conntrack mark and labels right before committing so that
the initial conntrack NEW event has the mark and labels.
The commit f2a4d086ed4c ("openvswitch: Add packet truncation support.")
introduces packet truncation before sending to userspace upcall receiver.
This patch passes up the skb->len before truncation so that the upcall
receiver knows the original packet size. Potentially this will be used
by sFlow, where OVS translates sFlow config header=N to a sample action,
truncating packet to N byte in kernel datapath. Thus, only N bytes instead
of full-packet size is copied from kernel to userspace, saving the
kernel-to-userspace bandwidth.
Signed-off-by: William Tu <u9012063@gmail.com>
Cc: Pravin Shelar <pshelar@nicira.com>
The patch adds a new OVS action, OVS_ACTION_ATTR_TRUNC, in order to
truncate packets. A 'max_len' is added for setting up the maximum
packet size, and a 'cutlen' field is to record the number of bytes
to trim the packet when the packet is outputting to a port, or when
the packet is sent to userspace.
Set name_assign_type of internal port to NET_NAME_USER.
Signed-off-by: Zhang Shengju <zhangshengju@cmss.chinamobile.com>
In the case of CHECKSUM_COMPLETE the skb checksum should be updated in
{push,pop}_mpls() as they the type in the ethernet header.
As suggested by Pravin Shelar.
Fixes: 25cd9ba0abc0 ("openvswitch: Add basic MPLS support to kernel")
Signed-off-by: Simon Horman <simon.horman@netronome.com>
The nf_conntrack_core.c fix in 'net' is not relevant in 'net-next'
because we no longer have a per-netns conntrack hash.
The ip_gre.c conflict as well as the iwlwifi ones were cases of
overlapping changes.
drivers/net/wireless/intel/iwlwifi/mvm/tx.c
net/ipv4/ip_gre.c
net/netfilter/nf_conntrack_core.c
When using conntrack helpers from OVS, a common configuration is to
perform a lookup without specifying a helper, then go through a
firewalling policy, only to decide to attach a helper afterwards.
In this case, the initial lookup will cause a ct entry to be attached to
the skb, then the later commit with helper should attach the helper and
confirm the connection. However, the helper attachment has been missing.
If the user has enabled automatic helper attachment, then this issue
will be masked as it will be applied in init_conntrack(). It is also
masked if the action is executed from ovs_packet_cmd_execute() as that
will construct a fresh skb.
This patch fixes the issue by making an explicit call to try to assign
the helper if there is a discrepancy between the action's helper and the
current skb->nfct.
Fixes: cae3a2627520 ("openvswitch: Allow attaching helpers to ct action")
Pablo Neira Ayuso says:
Netfilter updates for net-next
The following large patchset contains Netfilter updates for your
net-next tree. My initial intention was to send you this in two goes but
when I looked back twice I already had this burden on top of me.
Several updates for IPVS from Marco Angaroni:
1) Allow SIP connections originating from real-servers to be load
balanced by the SIP persistence engine as is already implemented
in the other direction.
2) Release connections immediately for One-packet-scheduling (OPS)
in IPVS, instead of making it via timer and rcu callback.
3) Skip deleting conntracks for each one packet in OPS, and don't call
nf_conntrack_alter_reply() since no reply is expected.
4) Enable drop on exhaustion for OPS + SIP persistence.
Miscelaneous conntrack updates from Florian Westphal, including fix for
hash resize:
5) Move conntrack generation counter out of conntrack pernet structure
since this is only used by the init_ns to allow hash resizing.
6) Use get_random_once() from packet path to collect hash random seed
instead of our compound.
7) Don't disable BH from ____nf_conntrack_find() for statistics,
use NF_CT_STAT_INC_ATOMIC() instead.
8) Fix lookup race during conntrack hash resizing.
9) Introduce clash resolution on conntrack insertion for connectionless
protocol.
Then, Florian's netns rework to get rid of per-netns conntrack table,
thus we use one single table for them all. There was consensus on this
change during the NFWS 2015 and, on top of that, it has recently been
pointed as a source of multiple problems from unpriviledged netns:
11) Use a single conntrack hashtable for all namespaces. Include netns
in object comparisons and make it part of the hash calculation.
Adapt early_drop() to consider netns.
12) Use single expectation and NAT hashtable for all namespaces.
13) Use a single slab cache for all namespaces for conntrack objects.
14) Skip full table scanning from nf_ct_iterate_cleanup() if the pernet
conntrack counter tells us the table is empty (ie. equals zero).
Fixes for nf_tables interval set element handling, support to set
conntrack connlabels and allow set names up to 32 bytes.
15) Parse element flags from element deletion path and pass it up to the
backend set implementation.
16) Allow adjacent intervals in the rbtree set type for dynamic interval
updates.
17) Add support to set connlabel from nf_tables, from Florian Westphal.
18) Allow set names up to 32 bytes in nf_tables.
Several x_tables fixes and updates:
19) Fix incorrect use of IS_ERR_VALUE() in x_tables, original patch
from Andrzej Hajda.
And finally, miscelaneous netfilter updates such as:
20) Disable automatic helper assignment by default. Note this proc knob
was introduced by a9006892643a ("netfilter: nf_ct_helper: allow to
disable automatic helper assignment") 4 years ago to start moving
towards explicit conntrack helper configuration via iptables CT
target.
21) Get rid of obsolete and inconsistent debugging instrumentation
in x_tables.
22) Remove unnecessary check for null after ip6_route_output().
If the protocol is not natively supported, this assigns generic protocol
tracker so we can always assume a valid pointer after these calls.
Acked-by: Jarno Rajahalme <jrajahalme@nicira.com>
I also fix commit 8b32ab9e6ef1: use nla_total_size_64bit() for
OVS_FLOW_ATTR_USED in ovs_flow_cmd_msg_size().
Fixes: 8b32ab9e6ef1 ("ovs: use nla_put_u64_64bit()")
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
The following patchset contains Netfilter updates for your net-next
tree, mostly from Florian Westphal to sort out the lack of sufficient
validation in x_tables and connlabel preparation patches to add
nf_tables support. They are:
1) Ensure we don't go over the ruleset blob boundaries in
mark_source_chains().
2) Validate that target jumps land on an existing xt_entry. This extra
sanitization comes with a performance penalty when loading the ruleset.
3) Introduce xt_check_entry_offsets() and use it from {arp,ip,ip6}tables.
4) Get rid of the smallish check_entry() functions in {arp,ip,ip6}tables.
5) Make sure the minimal possible target size in x_tables.
6) Similar to #3, add xt_compat_check_entry_offsets() for compat code.
7) Check that standard target size is valid.
8) More sanitization to ensure that the target_offset field is correct.
9) Add xt_check_entry_match() to validate that matches are well-formed.
10-12) Three patch to reduce the number of parameters in
translate_compat_table() for {arp,ip,ip6}tables by using a container
structure.
13) No need to return value from xt_compat_match_from_user(), so make
it void.
14) Consolidate translate_table() so it can be used by compat code too.
15) Remove obsolete check for compat code, so we keep consistent with
what was already removed in the native layout code (back in 2007).
16) Get rid of target jump validation from mark_source_chains(),
obsoleted by #2.
17) Introduce xt_copy_counters_from_user() to consolidate counter
copying, and use it from {arp,ip,ip6}tables.
18,22) Get rid of unnecessary explicit inlining in ctnetlink for dump
functions.
19) Move nf_connlabel_match() to xt_connlabel.
20) Skip event notification if connlabel did not change.
21) Update of nf_connlabels_get() to make the upcoming nft connlabel
support easier.
23) Remove spinlock to read protocol state field in conntrack.
nla_data() is now aligned on a 64-bit area.
A temporary version (nla_put_be64_32bit()) is added for nla_put_net64().
This function is removed in the next patch.
Conflicts were two cases of simple overlapping changes,
nothing serious.
In the UDP case, we need to add a hlist_add_tail_rcu()
to linux/rculist.h, because we've moved UDP socket handling
away from using nulls lists.
When using masked actions the ipv6_proto field of an action
to set IPv6 fields may be zero rather than the prevailing protocol
which will result in skipping checksum recalculation.
This patch resolves the problem by relying on the protocol
in the flow key rather than that in the set field action.
Fixes: 83d2b9ba1abc ("net: openvswitch: Support masked set actions.")
Cc: Jarno Rajahalme <jrajahalme@nicira.com>
This is the IPv6 counterpart to commit 8282f27449bf ("inet: frag: Always
orphan skbs inside ip_defrag()").
Prior to commit 029f7f3b8701 ("netfilter: ipv6: nf_defrag: avoid/free
clone operations"), ipv6 fragments sent to nf_ct_frag6_gather() would be
cloned (implicitly orphaning) prior to queueing for reassembly. As such,
when the IPv6 message is eventually reassembled, the skb->sk for all
fragments would be NULL. After that commit was introduced, rather than
cloning, the original skbs were queued directly without orphaning. The
end result is that all frags except for the first and last may have a
socket attached.
This commit explicitly orphans such skbs during nf_ct_frag6_gather() to
prevent BUG_ON(skb->sk) during a later call to ip6_fragment().
kernel BUG at net/ipv6/ip6_output.c:631!
Call Trace:
<IRQ>
[<ffffffff810be8f7>] ? __lock_acquire+0x927/0x20a0
[<ffffffffa042c7c0>] ? do_output.isra.28+0x1b0/0x1b0 [openvswitch]
[<ffffffff810bb8a2>] ? __lock_is_held+0x52/0x70
[<ffffffffa042c587>] ovs_fragment+0x1f7/0x280 [openvswitch]
[<ffffffff810bdab5>] ? mark_held_locks+0x75/0xa0
[<ffffffff817be416>] ? _raw_spin_unlock_irqrestore+0x36/0x50
[<ffffffff81697ea0>] ? dst_discard_out+0x20/0x20
[<ffffffff81697e80>] ? dst_ifdown+0x80/0x80
[<ffffffffa042c703>] do_output.isra.28+0xf3/0x1b0 [openvswitch]
[<ffffffffa042d279>] do_execute_actions+0x709/0x12c0 [openvswitch]
[<ffffffffa04340a4>] ? ovs_flow_stats_update+0x74/0x1e0 [openvswitch]
[<ffffffffa04340d1>] ? ovs_flow_stats_update+0xa1/0x1e0 [openvswitch]
[<ffffffff817be387>] ? _raw_spin_unlock+0x27/0x40
[<ffffffffa042de75>] ovs_execute_actions+0x45/0x120 [openvswitch]
[<ffffffffa0432d65>] ovs_dp_process_packet+0x85/0x150 [openvswitch]
[<ffffffffa042def4>] ovs_execute_actions+0xc4/0x120 [openvswitch]
[<ffffffffa04337f2>] ? key_extract+0x442/0xc10 [openvswitch]
[<ffffffffa043b26d>] ovs_vport_receive+0x5d/0xb0 [openvswitch]
[<ffffffffa043c11d>] internal_dev_xmit+0x6d/0x150 [openvswitch]
[<ffffffffa043c0b5>] ? internal_dev_xmit+0x5/0x150 [openvswitch]
[<ffffffff8168fb5f>] dev_hard_start_xmit+0x2df/0x660
[<ffffffff8168f5ea>] ? validate_xmit_skb.isra.105.part.106+0x1a/0x2b0
[<ffffffff81690925>] __dev_queue_xmit+0x8f5/0x950
[<ffffffff81690080>] ? __dev_queue_xmit+0x50/0x950
[<ffffffff81690990>] dev_queue_xmit+0x10/0x20
[<ffffffff8169a418>] neigh_resolve_output+0x178/0x220
[<ffffffff81752759>] ? ip6_finish_output2+0x219/0x7b0
[<ffffffff81752759>] ip6_finish_output2+0x219/0x7b0
[<ffffffff817525a5>] ? ip6_finish_output2+0x65/0x7b0
[<ffffffff816cde2b>] ? ip_idents_reserve+0x6b/0x80
[<ffffffff8175488f>] ? ip6_fragment+0x93f/0xc50
[<ffffffff81754af1>] ip6_fragment+0xba1/0xc50
[<ffffffff81752540>] ? ip6_flush_pending_frames+0x40/0x40
[<ffffffff81754c6b>] ip6_finish_output+0xcb/0x1d0
[<ffffffff81754dcf>] ip6_output+0x5f/0x1a0
[<ffffffff81754ba0>] ? ip6_fragment+0xc50/0xc50
[<ffffffff81797fbd>] ip6_local_out+0x3d/0x80
[<ffffffff817554df>] ip6_send_skb+0x2f/0xc0
[<ffffffff817555bd>] ip6_push_pending_frames+0x4d/0x50
[<ffffffff817796cc>] icmpv6_push_pending_frames+0xac/0xe0
[<ffffffff8177a4be>] icmpv6_echo_reply+0x42e/0x500
[<ffffffff8177acbf>] icmpv6_rcv+0x4cf/0x580
[<ffffffff81755ac7>] ip6_input_finish+0x1a7/0x690
[<ffffffff81755925>] ? ip6_input_finish+0x5/0x690
[<ffffffff817567a0>] ip6_input+0x30/0xa0
[<ffffffff81755920>] ? ip6_rcv_finish+0x1a0/0x1a0
[<ffffffff817557ce>] ip6_rcv_finish+0x4e/0x1a0
[<ffffffff8175640f>] ipv6_rcv+0x45f/0x7c0
[<ffffffff81755fe6>] ? ipv6_rcv+0x36/0x7c0
[<ffffffff81755780>] ? ip6_make_skb+0x1c0/0x1c0
[<ffffffff8168b649>] __netif_receive_skb_core+0x229/0xb80
[<ffffffff8168c07f>] ? process_backlog+0x6f/0x230
[<ffffffff8168bfb6>] __netif_receive_skb+0x16/0x70
[<ffffffff8168c088>] process_backlog+0x78/0x230
[<ffffffff8168c0ed>] ? process_backlog+0xdd/0x230
[<ffffffff8168db43>] net_rx_action+0x203/0x480
[<ffffffff817c156e>] __do_softirq+0xde/0x49f
[<ffffffff81752768>] ? ip6_finish_output2+0x228/0x7b0
[<ffffffff817c070c>] do_softirq_own_stack+0x1c/0x30
<EOI>
[<ffffffff8106f88b>] do_softirq.part.18+0x3b/0x40
[<ffffffff8106f946>] __local_bh_enable_ip+0xb6/0xc0
[<ffffffff81752791>] ip6_finish_output2+0x251/0x7b0
[<ffffffff81754af1>] ? ip6_fragment+0xba1/0xc50
[<ffffffff81778558>] rawv6_sendmsg+0xa28/0xe30
[<ffffffff81719097>] ? inet_sendmsg+0xc7/0x1d0
[<ffffffff817190d6>] inet_sendmsg+0x106/0x1d0
[<ffffffff81718fd5>] ? inet_sendmsg+0x5/0x1d0
[<ffffffff8166d078>] sock_sendmsg+0x38/0x50
[<ffffffff8166d4d6>] SYSC_sendto+0xf6/0x170
[<ffffffff8100201b>] ? trace_hardirqs_on_thunk+0x1b/0x1d
[<ffffffff8166e38e>] SyS_sendto+0xe/0x10
[<ffffffff817bebe5>] entry_SYSCALL_64_fastpath+0x18/0xa8
Code: 06 48 83 3f 00 75 26 48 8b 87 d8 00 00 00 2b 87 d0 00 00 00 48 39 d0 72 14 8b 87 e4 00 00 00 83 f8 01 75 09 48 83 7f 18 00 74 9a <0f> 0b 41 8b 86 cc 00 00 00 49 8#
RIP [<ffffffff8175468a>] ip6_fragment+0x73a/0xc50
RSP <ffff880072803120>
Fixes: 029f7f3b8701 ("netfilter: ipv6: nf_defrag: avoid/free clone
operations")
Reported-by: Daniele Di Proietto <diproiettod@vmware.com>
nf_connlabel_set() takes the bit number that we would like to set.
nf_connlabels_get() however took the number of bits that we want to
support.
So e.g. nf_connlabels_get(32) support bits 0 to 31, but not 32.
This changes nf_connlabels_get() to take the highest bit that we want
to set.
Callers then don't have to cope with a potential integer wrap
when using nf_connlabels_get(bit + 1) anymore.
Current callers are fine, this change is only to make folloup
nft ct label set support simpler.
Signed-off-by: Phil Sutter <phil@nwl.cc>
Netfilter fixes for net
The following patchset contains Netfilter fixes for you net tree,
they are:
1) There was a race condition between parallel save/swap and delete,
which resulted a kernel crash due to the increase ref for save, swap,
wrong ref decrease operations. Reported and fixed by Vishwanath Pai.
2) OVS should call into CT NAT for packets of new expected connections only
when the conntrack state is persisted with the 'commit' option to the
OVS CT action. From Jarno Rajahalme.
3) Resolve kconfig dependencies with new OVS NAT support. From Arnd Bergmann.
4) Early validation of entry->target_offset to make sure it doesn't take us
out from the blob, from Florian Westphal.
5) Again early validation of entry->next_offset to make sure it doesn't take
out from the blob, also from Florian.
6) Check that entry->target_offset is always of of sizeof(struct xt_entry)
for unconditional entries, when checking both from check_underflow()
and when checking for loops in mark_source_chains(), again from
Florian.
7) Fix inconsistent behaviour in nfnetlink_queue when
NFQA_CFG_F_FAIL_OPEN is set and netlink_unicast() fails due to buffer
overrun, we have to reinject the packet as the user expects.
8) Enforce nul-terminated table names from getsockopt GET_ENTRIES
requests.
9) Don't assume skb->sk is set from nft_bridge_reject and synproxy,
this fixes a recent update of the code to namespaceify
ip_default_ttl, patch from Liping Zhang.
This batch comes with four patches to validate x_tables blobs coming
from userspace. CONFIG_USERNS exposes the x_tables interface to
unpriviledged users and to be honest this interface never received the
attention for this move away from the CAP_NET_ADMIN domain. Florian is
working on another round with more patches with more sanity checks, so
expect a bit more Netfilter fixes in this development cycle than usual.
The openvswitch code has gained support for calling into the
nf-nat-ipv4/ipv6 modules, however those can be loadable modules
in a configuration in which openvswitch is built-in, leading
to link errors:
net/built-in.o: In function `__ovs_ct_lookup':
:(.text+0x2cc2c8): undefined reference to `nf_nat_icmp_reply_translation'
:(.text+0x2cc66c): undefined reference to `nf_nat_icmpv6_reply_translation'
The dependency on (!NF_NAT || NF_NAT) prevents similar issues,
but NF_NAT is set to 'y' if any of the symbols selecting
it are built-in, but the link error happens when any of them
are modular.
A second issue is that even if CONFIG_NF_NAT_IPV6 is built-in,
CONFIG_NF_NAT_IPV4 might be completely disabled. This is unlikely
to be useful in practice, but the driver currently only handles
IPv6 being optional.
This patch improves the Kconfig dependency so that openvswitch
cannot be built-in if either of the two other symbols are set
to 'm', and it replaces the incorrect #ifdef in ovs_ct_nat_execute()
with two "if (IS_ENABLED())" checks that should catch all corner
cases also make the code more readable.
The same #ifdef exists ovs_ct_nat_to_attr(), where it does not
cause a link error, but for consistency I'm changing it the same
way.
Fixes: 05752523e565 ("openvswitch: Interface with NAT.")
OVS CT action. The test for this condition is doubly wrong, as the CT
status field is ANDed with the bit number (IPS_EXPECTED_BIT) rather
than the mask (IPS_EXPECTED), and due to the wrong assumption that the
expected bit would apply only for the first (i.e., 'new') packet of a
connection, while in fact the expected bit remains on for the lifetime of
an expected connection. The 'ctinfo' value IP_CT_RELATED derived from
the ct status can be used instead, as it is only ever applicable to
the 'new' packets of the expected connection.
Fixes: 05752523e565 ('openvswitch: Interface with NAT.')
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
