[ Upstream commit 13fcb7bd322164c67926ffe272846d4860196dc6 ]
In 2.6.27, commit 393e52e33c6c2 (packet: deliver VLAN TCI to userspace)
added a small information leak.
Add padding field and make sure its zeroed before copy to user.
CC: Patrick McHardy <kaber@trash.net>
commit 67286640f638f5ad41a946b9a3dc75327950248f upstream.
packet_getname_spkt() doesn't initialize all members of sa_data field of
sockaddr struct if strlen(dev->name) < 13. This structure is then copied
to userland. It leads to leaking of contents of kernel stack memory.
We have to fully fill sa_data with strncpy() instead of strlcpy().
The same with packet_getname(): it doesn't initialize sll_pkttype field of
sockaddr_ll. Set it to zero.
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
Cc: Moritz Muehlenhoff <jmm@debian.org>
[jmm: Backported to 2.6.32]
[ Upstream commit eb70df13ee52dbc0f2c0ffd8ed34a8cd27440baf ]
tpacket_snd() can change and kfree an skb after dev_queue_xmit(),
which is illegal.
With debugging by: Stephen Hemminger <shemminger@vyatta.com>
Reported-by: Michael Breuer <mbreuer@majjas.com>
With help from: David S. Miller <davem@davemloft.net>
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
Tested-by: Michael Breuer<mbreuer@majjas.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (43 commits)
net: Fix 'Re: PACKET_TX_RING: packet size is too long'
netdev: usb: dm9601.c can drive a device not supported yet, add support for it
qlge: Fix firmware mailbox command timeout.
qlge: Fix EEH handling.
AF_RAW: Augment raw_send_hdrinc to expand skb to fit iphdr->ihl (v2)
bonding: fix a race condition in calls to slave MII ioctls
virtio-net: fix data corruption with OOM
sfc: Set ip_summed correctly for page buffers passed to GRO
cnic: Fix L2CTX_STATUSB_NUM offset in context memory.
MAINTAINERS: rt2x00 list is moderated
airo: Reorder tests, check bounds before element
mac80211: fix for incorrect sequence number on hostapd injected frames
libertas spi: fix sparse errors
mac80211: trivial: fix spelling in mesh_hwmp
cfg80211: sme: deauthenticate on assoc failure
mac80211: keep auth state when assoc fails
mac80211: fix ibss joining
b43: add 'struct b43_wl' missing declaration
b43: Fix Bugzilla #14181 and the bug from the previous 'fix'
rt2x00: Fix crypto in TX frame for rt2800usb
Currently PACKET_TX_RING forces certain amount of every frame to remain
unused. This probably originates from an early version of the
PACKET_TX_RING patch that in fact used the extra space when the (since
removed) CONFIG_PACKET_MMAP_ZERO_COPY option was enabled. The current
code does not make any use of this extra space.
This patch removes the extra space reservation and lets userspace make
use of the full frame size.
Signed-off-by: Gabor Gombas <gombasg@sztaki.hu>
ax25: Fix possible oops in ax25_make_new
net: restore tx timestamping for accelerated vlans
Phonet: fix mutex imbalance
sit: fix off-by-one in ipip6_tunnel_get_prl
net: Fix sock_wfree() race
net: Make setsockopt() optlen be unsigned.
This provides safety against negative optlen at the type
level instead of depending upon (sometimes non-trivial)
checks against this sprinkled all over the the place, in
each and every implementation.
Based upon work done by Arjan van de Ven and feedback
from Linus Torvalds.
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
Some style cleanups to match current code practices.
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80
(net: No more expensive sock_hold()/sock_put() on each tx)
changed initial sk_wmem_alloc value.
We need to take into account this offset when reporting
sk_wmem_alloc to user, in PROC_FS files or various
ioctls (SIOCOUTQ/TIOCOUTQ)
Define three accessors to get/set dst attached to a skb
struct dst_entry *skb_dst(const struct sk_buff *skb)
void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst)
void skb_dst_drop(struct sk_buff *skb)
This one should replace occurrences of :
dst_release(skb->dst)
skb->dst = NULL;
Delete skb->dst field
This patch converts unicast address list to standard list_head using
previously introduced struct netdev_hw_addr. It also relaxes the
locking. Original spinlock (still used for multicast addresses) is not
needed and is no longer used for a protection of this list. All
reading and writing takes place under rtnl (with no changes).
I also removed a possibility to specify the length of the address
while adding or deleting unicast address. It's always dev->addr_len.
The convertion touched especially e1000 and ixgbe codes when the
change is not so trivial.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
drivers/net/bnx2.c | 13 +--
drivers/net/e1000/e1000_main.c | 24 +++--
drivers/net/ixgbe/ixgbe_common.c | 14 ++--
drivers/net/ixgbe/ixgbe_common.h | 4 +-
drivers/net/ixgbe/ixgbe_main.c | 6 +-
drivers/net/ixgbe/ixgbe_type.h | 4 +-
drivers/net/macvlan.c | 11 +-
drivers/net/mv643xx_eth.c | 11 +-
drivers/net/niu.c | 7 +-
drivers/net/virtio_net.c | 7 +-
drivers/s390/net/qeth_l2_main.c | 6 +-
drivers/scsi/fcoe/fcoe.c | 16 ++--
include/linux/netdevice.h | 18 ++--
net/8021q/vlan.c | 4 +-
net/8021q/vlan_dev.c | 10 +-
net/core/dev.c | 195 +++++++++++++++++++++++++++-----------
net/dsa/slave.c | 10 +-
net/packet/af_packet.c | 4 +-
18 files changed, 227 insertions(+), 137 deletions(-)
The the PACKET_ADD_MEMBERSHIP and the PACKET_DROP_MEMBERSHIP setsockopt
calls for af_packet already has all of the infrastructure needed to subscribe
to multiple mac addresses. All that is missing is a flag to say that
the address we want to listen on is a unicast address.
So introduce PACKET_MR_UNICAST and wire it up to dev_unicast_add and
dev_unicast_delete.
Additionally I noticed that errors from dev_mc_add were not propagated
from packet_dev_mc so fix that.
Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com>
New packet socket feature that makes packet socket more efficient for
transmission.
- It reduces number of system call through a PACKET_TX_RING mechanism,
based on PACKET_RX_RING (Circular buffer allocated in kernel space
which is mmapped from user space).
- It minimizes CPU copy using fragmented SKB (almost zero copy).
Signed-off-by: Johann Baudy <johann.baudy@gnu-log.net>
Latest tcpdump/libpcap triggers annoying messages because of high order page
allocation failures (when lowmem exhausted or fragmented)
These allocation errors are correctly handled so could be silent.
[22660.208901] tcpdump: page allocation failure. order:5, mode:0xc0d0
[22660.208921] Pid: 13866, comm: tcpdump Not tainted 2.6.30-rc2 #170
[22660.208936] Call Trace:
[22660.208950] [<c04e2b46>] ? printk+0x18/0x1a
[22660.208965] [<c02760f7>] __alloc_pages_internal+0x357/0x460
[22660.208980] [<c0276251>] __get_free_pages+0x21/0x40
[22660.208995] [<c04cc835>] packet_set_ring+0x105/0x3d0
[22660.209009] [<c04ccd1d>] packet_setsockopt+0x21d/0x4d0
[22660.209025] [<c0270400>] ? filemap_fault+0x0/0x450
[22660.209040] [<c0449e34>] sys_setsockopt+0x54/0xa0
[22660.209053] [<c044b97f>] sys_socketcall+0xef/0x270
[22660.209067] [<c0202e34>] sysenter_do_call+0x12/0x26
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
end-of-line points for skbs
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
include/linux/skbuff.h | 4 +++-
net/core/datagram.c | 2 +-
net/core/skbuff.c | 22 ++++++++++++++++++++++
net/ipv4/arp.c | 2 +-
net/ipv4/udp.c | 2 +-
net/packet/af_packet.c | 2 +-
6 files changed, 29 insertions(+), 5 deletions(-)
Remove some pointless conditionals before kfree_skb().
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
packet_lookup_frames() fails to get user frame if current frame header
status contains extra flags.
This is due to the wrong assumption on the operators precedence during
frame status tests.
Fixed by forcing the right operators precedence order with explicit brackets.
Signed-off-by: Paolo Abeni <paolo.abeni@gmail.com>
Signed-off-by: Sebastiano Di Paola <sebastiano.dipaola@gmail.com>
As the mmap handler gets called under mmap_sem, and we may grab
mmap_sem elsewhere under the socket lock to access user data, we
should avoid grabbing the socket lock in the mmap handler.
Since the only thing we care about in the mmap handler is for
pg_vec* to be invariant, i.e., to exclude packet_set_ring, we
can achieve this by simply using a new mutex.
Tested-by: Martin MOKREJŠ <mmokrejs@ribosome.natur.cuni.cz>
The rule of calling sock_prot_inuse_add() is that BHs must
be disabled. Some new calls were added where this was not
true and this tiggers warnings as reported by Ilpo.
Fix this by adding explicit BH disabling around those call sites,
or moving sock_prot_inuse_add() call inside an existing BH disabled
section.
This patch is a preparation to namespace conversion of /proc/net/protocols
In order to have relevant information for PACKET protocols, we should use
sock_prot_inuse_add() to update a (percpu and pernamespace) counter of
inuse sockets.
Removes legacy reinvent-the-wheel type thing. The generic
machinery integrates much better to automated debugging aids
such as kerneloops.org (and others), and is unambiguous due to
better naming. Non-intuively BUG_TRAP() is actually equal to
WARN_ON() rather than BUG_ON() though some might actually be
promoted to BUG_ON() but I left that to future.
I could make at least one BUILD_BUG_ON conversion.
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Without CONFIG_NET_NS, namespace is always &init_net.
Compiler will be able to omit namespace comparisons with this patch.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Add new sockopt to reserve some headroom in the mmaped ring frames in
front of the packet payload. This can be used f.i. when the VLAN header
needs to be (re)constructed to avoid moving the entire payload.
Store the VLAN tag in the auxillary data/tpacket2_hdr so userspace can
properly deal with hardware VLAN tagging/stripping.
The tpacket_hdr is not 64 bit clean due to use of an unsigned long
and can't be extended because the following struct sockaddr_ll needs
to be at a fixed offset.
Add support for a version 2 tpacket protocol that removes these
limitations.
Userspace can query the header size through a new getsockopt option
and change the protocol version through a setsockopt option. The
changes needed to switch to the new protocol version are:
1. replace struct tpacket_hdr by struct tpacket2_hdr
2. query header len and save
3. set protocol version to 2
- set up ring as usual
4. for getting the sockaddr_ll, use (void *)hdr + TPACKET_ALIGN(hdrlen)
instead of (void *)hdr + TPACKET_ALIGN(sizeof(struct tpacket_hdr))
Steps 2 and 4 can be omitted if the struct sockaddr_ll isn't needed.
dev_set_promiscuity/allmulti might overflow. Commit: "netdevice: Fix
promiscuity and allmulti overflow" in net-next makes
dev_set_promiscuity/allmulti return error number if overflow happened.
In af_packet, we check all positive increment for promiscuity and
allmulti to get error return.
Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com>
Acked-by: Patrick McHardy <kaber@trash.net>
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This patch adds needed_headroom/needed_tailroom members to struct
net_device and updates many places that allocate sbks to use them. Not
all of them can be converted though, and I'm sure I missed some (I
mostly grepped for LL_RESERVED_SPACE)
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Introduce per-sock inlines: sock_net(), sock_net_set()
and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
Introduce per-net_device inlines: dev_net(), dev_net_set().
Signed-off-by: Jiri Olsa <olsajiri@gmail.com>
CHECK net/packet/af_packet.c
net/packet/af_packet.c:1876:14: warning: context imbalance in 'packet_seq_start' - wrong count at exit
net/packet/af_packet.c:1888:13: warning: context imbalance in 'packet_seq_stop' - unexpected unlock
The seq_open_net patch changed the meaning of seq->private.
Unfortunately it missed two spots in AF_PACKET, which still
used the old way of dereferencing seq->private, thus causing
weird and wonderful crashes when reading /proc/net/packet.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
This is done by making packet_sklist_lock and packet_sklist per
network namespace and adding an additional filter condition on
received packets to ensure they came from the proper network
namespace.
Changes from v1:
- prohibit to call inet_dgram_ops.ioctl in other than init_net
Simplify some code by eliminating duplicate if-else clauses in
packet_do_bind().
Signed-off-by: Urs Thuermann <urs@isnogud.escape.de>
The socket option for packet sockets to return the original ifindex instead
of the bonded ifindex will not match multicast traffic. Since this socket
option is the most useful for layer 2 traffic and multicast traffic, make
the option multicast-aware.
Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com>
The packet_socks_nr variable is used purely for debugging
the number of sockets.
As Arnaldo pointed out, there's already an infrastructure
for this purposes, so switch to using it.
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Finally, the zero_it argument can be completely removed from
the callers and from the function prototype.
Besides, fix the checkpatch.pl warnings about using the
assignments inside if-s.
This patch is rather big, and it is a part of the previous one.
I splitted it wishing to make the patches more readable. Hope
this particular split helped.
The conversion to vm_insert_page() left this unused function behind,
remove it.
Since hardware header operations are part of the protocol class
not the device instance, make them into a separate object and
save memory.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Wrap the hard_header_parse function to simplify next step of
header_ops conversion.
Add inline for common usage of hardware header creation, and
fix bug in IPV6 mcast where the assumption about negative return is
an errno. Negative return from hard_header means not enough space
was available,(ie -N bytes).
This patch makes most of the generic device layer network
namespace safe. This patch makes dev_base_head a
network namespace variable, and then it picks up
a few associated variables. The functions:
dev_getbyhwaddr
dev_getfirsthwbytype
dev_get_by_flags
dev_get_by_name
__dev_get_by_name
dev_get_by_index
__dev_get_by_index
dev_ioctl
dev_ethtool
dev_load
wireless_process_ioctl
were modified to take a network namespace argument, and
deal with it.
vlan_ioctl_set and brioctl_set were modified so their
hooks will receive a network namespace argument.
So basically anthing in the core of the network stack that was
affected to by the change of dev_base was modified to handle
multiple network namespaces. The rest of the network stack was
simply modified to explicitly use &init_net the initial network
namespace. This can be fixed when those components of the network
stack are modified to handle multiple network namespaces.
For now the ifindex generator is left global.
Fundametally ifindex numbers are per namespace, or else
we will have corner case problems with migration when
we get that far.
At the same time there are assumptions in the network stack
that the ifindex of a network device won't change. Making
the ifindex number global seems a good compromise until
the network stack can cope with ifindex changes when
you change namespaces, and the like.
Every user of the network device notifiers is either a protocol
stack or a pseudo device. If a protocol stack that does not have
support for multiple network namespaces receives an event for a
device that is not in the initial network namespace it quite possibly
can get confused and do the wrong thing.
To avoid problems until all of the protocol stacks are converted
this patch modifies all netdev event handlers to ignore events on
devices that are not in the initial network namespace.
As the rest of the code is made network namespace aware these
checks can be removed.
This patch modifies every packet receive function
registered with dev_add_pack() to drop packets if they
are not from the initial network namespace.
This should ensure that the various network stacks do
not receive packets in a anything but the initial network
namespace until the code has been converted and is ready
for them.
This patch passes in the namespace a new socket should be created in
and has the socket code do the appropriate reference counting. By
virtue of this all socket create methods are touched. In addition
the socket create methods are modified so that they will fail if
you attempt to create a socket in a non-default network namespace.
Failing if we attempt to create a socket outside of the default
network namespace ensures that as we incrementally make the network stack
network namespace aware we will not export functionality that someone
has not audited and made certain is network namespace safe.
Allowing us to partially enable network namespaces before all of the
exotic protocols are supported.
Any protocol layers I have missed will fail to compile because I now
pass an extra parameter into the socket creation code.
[ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ]
This patch makes /proc/net per network namespace. It modifies the global
variables proc_net and proc_net_stat to be per network namespace.
The proc_net file helpers are modified to take a network namespace argument,
and all of their callers are fixed to pass &init_net for that argument.
This ensures that all of the /proc/net files are only visible and
usable in the initial network namespace until the code behind them
has been updated to be handle multiple network namespaces.
Making /proc/net per namespace is necessary as at least some files
in /proc/net depend upon the set of network devices which is per
network namespace, and even more files in /proc/net have contents
that are relevant to a single network namespace.
