path: root/net/packet
2010-01-23Merge branch 'master' of ↵David S. Miller
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-11af_packet: Don't use skb after dev_queue_xmit()Jarek Poplawski
tpacket_snd() can change and kfree an skb after dev_queue_xmit(), which is illegal. With debugging by: Stephen Hemminger <shemminger@vyatta.com> Reported-by: Michael Breuer <mbreuer@majjas.com> With help from: David S. Miller <davem@davemloft.net> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Tested-by: Michael Breuer<mbreuer@majjas.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-15packet: dont call sleeping functions while holding rcu_read_lock()Eric Dumazet
commit 654d1f8a019dfa06d (packet: less dev_put() calls) introduced a problem, calling potentially sleeping functions from a rcu_read_lock() protected section. Fix this by releasing lock before the sock_wmalloc()/memcpy_fromiovec() calls. After skb allocation and copy from user space, we redo device lookup and appropriate tests. Reported-and-tested-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-10net: netlink_getname, packet_getname -- use DECLARE_SOCKADDR guardCyrill Gorcunov
Use guard DECLARE_SOCKADDR in a few more places which allow us to catch if the structure copied back is too big. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-02packet: less dev_put() callsEric Dumazet
- packet_sendmsg_spkt() can use dev_get_by_name_rcu() to avoid touching device refcount. - packet_getname_spkt() & packet_getname() can use dev_get_by_index_rcu() to avoid touching device refcount too. tpacket_snd() & packet_snd() can not use RCU yet because they can sleep when allocating skb. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-29Merge branch 'master' of ↵David S. Miller
2009-10-29net: Fix 'Re: PACKET_TX_RING: packet size is too long'Gabor Gombas
Currently PACKET_TX_RING forces certain amount of every frame to remain unused. This probably originates from an early version of the PACKET_TX_RING patch that in fact used the extra space when the (since removed) CONFIG_PACKET_MMAP_ZERO_COPY option was enabled. The current code does not make any use of this extra space. This patch removes the extra space reservation and lets userspace make use of the full frame size. Signed-off-by: Gabor Gombas <gombasg@sztaki.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-27vlan: allow null VLAN ID to be usedEric Dumazet
We currently use a 16 bit field (vlan_tci) to store VLAN ID/PRIO on a skb. Null value is used as a special value, meaning vlan tagging not enabled. This forbids use of null vlan ID. As pointed by David, some drivers use the 3 high order bits (PRIO) As VLAN ID is 12 bits, we can use the remaining bit (CFI) as a flag, and allow null VLAN ID. In case future code really wants to use VLAN_CFI_MASK, we'll have to use a bit outside of vlan_tci. #define VLAN_PRIO_MASK 0xe000 /* Priority Code Point */ #define VLAN_PRIO_SHIFT 13 #define VLAN_CFI_MASK 0x1000 /* Canonical Format Indicator */ #define VLAN_TAG_PRESENT VLAN_CFI_MASK #define VLAN_VID_MASK 0x0fff /* VLAN Identifier */ Reported-by: Gertjan Hofman <gertjan_hofman@yahoo.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-20af_packet: mc_drop/flush_mclist changesEric Dumazet
We hold RTNL, we can use __dev_get_by_index() instead of dev_get_by_index() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-20af_packet: Avoid cache line dirtyingEric Dumazet
While doing multiple captures, I found af_packet was dirtying cache line containing its prot_hook. This slow down machines where several cpus are necessary to handle capture traffic, as each prot_hook is traversed for each packet coming in or out the host. This patches moves "struct packet_type prot_hook" to the end of packet_sock, and uses a ____cacheline_aligned_in_smp to make sure this remains shared by all cpus. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-12net: Generalize socket rx gap / receive queue overflow cmsgNeil Horman
Create a new socket level option to report number of queue overflows Recently I augmented the AF_PACKET protocol to report the number of frames lost on the socket receive queue between any two enqueued frames. This value was exported via a SOL_PACKET level cmsg. AFter I completed that work it was requested that this feature be generalized so that any datagram oriented socket could make use of this option. As such I've created this patch, It creates a new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue overflowed between any two given frames. It also augments the AF_PACKET protocol to take advantage of this new feature (as it previously did not touch sk->sk_drops, which this patch uses to record the overflow count). Tested successfully by me. Notes: 1) Unlike my previous patch, this patch simply records the sk_drops value, which is not a number of drops between packets, but rather a total number of drops. Deltas must be computed in user space. 2) While this patch currently works with datagram oriented protocols, it will also be accepted by non-datagram oriented protocols. I'm not sure if thats agreeable to everyone, but my argument in favor of doing so is that, for those protocols which aren't applicable to this option, sk_drops will always be zero, and reporting no drops on a receive queue that isn't used for those non-participating protocols seems reasonable to me. This also saves us having to code in a per-protocol opt in mechanism. 3) This applies cleanly to net-next assuming that commit 977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-12Revert "af_packet: add interframe drop cmsg (v6)"David S. Miller
This reverts commit 977750076d98c7ff6cbda51858bb5a5894a9d9ab. Neil is reimplementing this generically, outside of AF_PACKET. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: mark net_proto_ops as constStephen Hemminger
All usages of structure net_proto_ops should be declared const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07Use sk_mark for routing lookup in more placesEric Dumazet
Here is a followup on this area, thanks. [RFC] af_packet: fill skb->mark at xmit skb->mark may be used by classifiers, so fill it in case user set a SO_MARK option on socket. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-05af_packet: add interframe drop cmsg (v6)Neil Horman
Add Ancilliary data to better represent loss information I've had a few requests recently to provide more detail regarding frame loss during an AF_PACKET packet capture session. Specifically the requestors want to see where in a packet sequence frames were lost, i.e. they want to see that 40 frames were lost between frames 302 and 303 in a packet capture file. In order to do this we need: 1) The kernel to export this data to user space 2) The applications to make use of it This patch addresses item (1). It does this by doing the following: A) Anytime we drop a frame for which we would increment po->stats.tp_drops, we also no increment a stats called po->stats.tp_gap. B) Every time we successfully enqueue a frame to sk_receive_queue, we record the value of po->stats.tp_gap in skb->mark. skb->cb would nominally be the place to record this, but since all the space there is used up, we're overloading skb->mark. Its safe to do since any enqueued packet is guaranteed to be unshared at this point, and skb->mark isn't used for anything else in the rx path to the application. After we record tp_gap in the skb, we zero po->stats.tp_gap. This allows us to keep a counter of the number of frames lost between any two enqueued packets C) When the application goes to dequeue a frame from the packet socket, we look at skb->mark for that frame. If it is non-zero, we add a cmsg chunk to the msghdr of level SOL_PACKET and type PACKET_GAPDATA. Its a 32 bit integer that represents the number of frames lost between this packet and the last previous frame received. Note there is a chance that if there is frame loss after a receive, and then the socket is closed, some gap data might be lost. This is covered by the use of the PACKET_AUXDATA socket option, which gives total loss data. With a bit of math, the final gap can be determined that way. I've tested this patch myself, and it works well. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> include/linux/if_packet.h | 2 ++ net/packet/af_packet.c | 33 +++++++++++++++++++++++++++++++++ 2 files changed, 35 insertions(+) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: ax25: Fix possible oops in ax25_make_new net: restore tx timestamping for accelerated vlans Phonet: fix mutex imbalance sit: fix off-by-one in ipip6_tunnel_get_prl net: Fix sock_wfree() race net: Make setsockopt() optlen be unsigned.
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-23af_packet: style cleanupsEric Dumazet
Some style cleanups to match current code practices. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-29net: convert unicast addr listJiri Pirko
This patch converts unicast address list to standard list_head using previously introduced struct netdev_hw_addr. It also relaxes the locking. Original spinlock (still used for multicast addresses) is not needed and is no longer used for a protection of this list. All reading and writing takes place under rtnl (with no changes). I also removed a possibility to specify the length of the address while adding or deleting unicast address. It's always dev->addr_len. The convertion touched especially e1000 and ixgbe codes when the change is not so trivial. Signed-off-by: Jiri Pirko <jpirko@redhat.com> drivers/net/bnx2.c | 13 +-- drivers/net/e1000/e1000_main.c | 24 +++-- drivers/net/ixgbe/ixgbe_common.c | 14 ++-- drivers/net/ixgbe/ixgbe_common.h | 4 +- drivers/net/ixgbe/ixgbe_main.c | 6 +- drivers/net/ixgbe/ixgbe_type.h | 4 +- drivers/net/macvlan.c | 11 +- drivers/net/mv643xx_eth.c | 11 +- drivers/net/niu.c | 7 +- drivers/net/virtio_net.c | 7 +- drivers/s390/net/qeth_l2_main.c | 6 +- drivers/scsi/fcoe/fcoe.c | 16 ++-- include/linux/netdevice.h | 18 ++-- net/8021q/vlan.c | 4 +- net/8021q/vlan_dev.c | 10 +- net/core/dev.c | 195 +++++++++++++++++++++++++++----------- net/dsa/slave.c | 10 +- net/packet/af_packet.c | 4 +- 18 files changed, 227 insertions(+), 137 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-21af_packet: Teach to listen for multiple unicast addresses.Eric W. Biederman
The the PACKET_ADD_MEMBERSHIP and the PACKET_DROP_MEMBERSHIP setsockopt calls for af_packet already has all of the infrastructure needed to subscribe to multiple mac addresses. All that is missing is a flag to say that the address we want to listen on is a unicast address. So introduce PACKET_MR_UNICAST and wire it up to dev_unicast_add and dev_unicast_delete. Additionally I noticed that errors from dev_mc_add were not propagated from packet_dev_mc so fix that. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-18net: TX_RING and packet mmapJohann Baudy
New packet socket feature that makes packet socket more efficient for transmission. - It reduces number of system call through a PACKET_TX_RING mechanism, based on PACKET_RX_RING (Circular buffer allocated in kernel space which is mmapped from user space). - It minimizes CPU copy using fragmented SKB (almost zero copy). Signed-off-by: Johann Baudy <johann.baudy@gnu-log.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-15packet: avoid warnings when high-order page allocation failsEric Dumazet
Latest tcpdump/libpcap triggers annoying messages because of high order page allocation failures (when lowmem exhausted or fragmented) These allocation errors are correctly handled so could be silent. [22660.208901] tcpdump: page allocation failure. order:5, mode:0xc0d0 [22660.208921] Pid: 13866, comm: tcpdump Not tainted 2.6.30-rc2 #170 [22660.208936] Call Trace: [22660.208950] [<c04e2b46>] ? printk+0x18/0x1a [22660.208965] [<c02760f7>] __alloc_pages_internal+0x357/0x460 [22660.208980] [<c0276251>] __get_free_pages+0x21/0x40 [22660.208995] [<c04cc835>] packet_set_ring+0x105/0x3d0 [22660.209009] [<c04ccd1d>] packet_setsockopt+0x21d/0x4d0 [22660.209025] [<c0270400>] ? filemap_fault+0x0/0x450 [22660.209040] [<c0449e34>] sys_setsockopt+0x54/0xa0 [22660.209053] [<c044b97f>] sys_socketcall+0xef/0x270 [22660.209067] [<c0202e34>] sysenter_do_call+0x12/0x26 Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-13Network Drop Monitor: Adding kfree_skb_clean for non-drops and modifying ↵Neil Horman
end-of-line points for skbs Signed-off-by: Neil Horman <nhorman@tuxdriver.com> include/linux/skbuff.h | 4 +++- net/core/datagram.c | 2 +- net/core/skbuff.c | 22 ++++++++++++++++++++++ net/ipv4/arp.c | 2 +- net/ipv4/udp.c | 2 +- net/packet/af_packet.c | 2 +- 6 files changed, 29 insertions(+), 5 deletions(-) Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26packet: remove some pointless conditionals before kfree_skb()Wei Yongjun
Remove some pointless conditionals before kfree_skb(). Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: packet socket packet_lookup_frame fixSebastiano Di Paola
packet_lookup_frames() fails to get user frame if current frame header status contains extra flags. This is due to the wrong assumption on the operators precedence during frame status tests. Fixed by forcing the right operators precedence order with explicit brackets. Signed-off-by: Paolo Abeni <paolo.abeni@gmail.com> Signed-off-by: Sebastiano Di Paola <sebastiano.dipaola@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-30packet: Avoid lock_sock in mmap handlerHerbert Xu
As the mmap handler gets called under mmap_sem, and we may grab mmap_sem elsewhere under the socket lock to access user data, we should avoid grabbing the socket lock in the mmap handler. Since the only thing we care about in the mmap handler is for pg_vec* to be invariant, i.e., to exclude packet_set_ring, we can achieve this by simply using a new mutex. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Martin MOKREJŠ <mmokrejs@ribosome.natur.cuni.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-24net: Make sure BHs are disabled in sock_prot_inuse_add()Eric Dumazet
The rule of calling sock_prot_inuse_add() is that BHs must be disabled. Some new calls were added where this was not true and this tiggers warnings as reported by Ilpo. Fix this by adding explicit BH disabling around those call sites, or moving sock_prot_inuse_add() call inside an existing BH disabled section. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19net: af_packet should update its inuse counterEric Dumazet
This patch is a preparation to namespace conversion of /proc/net/protocols In order to have relevant information for PACKET protocols, we should use sock_prot_inuse_add() to update a (percpu and pernamespace) counter of inuse sockets. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25net: convert BUG_TRAP to generic WARN_ONIlpo Järvinen
Removes legacy reinvent-the-wheel type thing. The generic machinery integrates much better to automated debugging aids such as kerneloops.org (and others), and is unambiguous due to better naming. Non-intuively BUG_TRAP() is actually equal to WARN_ON() rather than BUG_ON() though some might actually be promoted to BUG_ON() but I left that to future. I could make at least one BUILD_BUG_ON conversion. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19netns: Use net_eq() to compare net-namespaces for optimization.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, namespace is always &init_net. Compiler will be able to omit namespace comparisons with this patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-18packet: add PACKET_RESERVE sockoptPatrick McHardy
Add new sockopt to reserve some headroom in the mmaped ring frames in front of the packet payload. This can be used f.i. when the VLAN header needs to be (re)constructed to avoid moving the entire payload. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14packet: deliver VLAN TCI to userspacePatrick McHardy
Store the VLAN tag in the auxillary data/tpacket2_hdr so userspace can properly deal with hardware VLAN tagging/stripping. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14packet: support extensible, 64 bit clean mmaped ring structurePatrick McHardy
The tpacket_hdr is not 64 bit clean due to use of an unsigned long and can't be extended because the following struct sockaddr_ll needs to be at a fixed offset. Add support for a version 2 tpacket protocol that removes these limitations. Userspace can query the header size through a new getsockopt option and change the protocol version through a setsockopt option. The changes needed to switch to the new protocol version are: 1. replace struct tpacket_hdr by struct tpacket2_hdr 2. query header len and save 3. set protocol version to 2 - set up ring as usual 4. for getting the sockaddr_ll, use (void *)hdr + TPACKET_ALIGN(hdrlen) instead of (void *)hdr + TPACKET_ALIGN(sizeof(struct tpacket_hdr)) Steps 2 and 4 can be omitted if the struct sockaddr_ll isn't needed. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-14af_packet: Check return of dev_set_promiscuity/allmultiWang Chen
dev_set_promiscuity/allmulti might overflow. Commit: "netdevice: Fix promiscuity and allmulti overflow" in net-next makes dev_set_promiscuity/allmulti return error number if overflow happened. In af_packet, we check all positive increment for promiscuity and allmulti to get error return. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-12net: Allow netdevices to specify needed head/tailroomJohannes Berg
This patch adds needed_headroom/needed_tailroom members to struct net_device and updates many places that allocate sbks to use them. Not all of them can be converted though, and I'm sure I missed some (I mostly grepped for LL_RESERVED_SPACE) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NET] NETNS: Omit sock->sk_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-sock inlines: sock_net(), sock_net_set() and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-26[NET] NETNS: Omit net_device->nd_net without CONFIG_NET_NS.YOSHIFUJI Hideaki
Introduce per-net_device inlines: dev_net(), dev_net_set(). Without CONFIG_NET_NS, no namespace other than &init_net exists. Let's explicitly define them to help compiler optimizations. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-23[AF_PACKET]: Remove unused variable.Jiri Olsa
Signed-off-by: Jiri Olsa <olsajiri@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[PACKET]: Fix sparse warnings in af_packet.cEric Dumazet
CHECK net/packet/af_packet.c net/packet/af_packet.c:1876:14: warning: context imbalance in 'packet_seq_start' - wrong count at exit net/packet/af_packet.c:1888:13: warning: context imbalance in 'packet_seq_stop' - unexpected unlock Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[PACKET]: Fix /proc/net/packet crash due to bogus private pointerHerbert Xu
The seq_open_net patch changed the meaning of seq->private. Unfortunately it missed two spots in AF_PACKET, which still used the old way of dereferencing seq->private, thus causing weird and wonderful crashes when reading /proc/net/packet. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: separate af_packet netns dataDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Consolidate net namespace related proc files creation.Denis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
