path: root/net/packet
2007-11-12[AF_PACKET]: Fix minor code duplicationUrs Thuermann
Simplify some code by eliminating duplicate if-else clauses in packet_do_bind(). Signed-off-by: Urs Thuermann <urs@isnogud.escape.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-10[AF_PACKET]: Allow multicast traffic to be caught by ORIGDEV when bondedPeter P Waskiewicz Jr
The socket option for packet sockets to return the original ifindex instead of the bonded ifindex will not match multicast traffic. Since this socket option is the most useful for layer 2 traffic and multicast traffic, make the option multicast-aware. Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-10[PACKET]: Use existing sock refcnt debugging infrastructurePavel Emelyanov
The packet_socks_nr variable is used purely for debugging the number of sockets. As Arnaldo pointed out, there's already an infrastructure for this purposes, so switch to using it. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-18[PACKET]: Kill unused pg_vec_endpage() functionPatrick McHardy
The conversion to vm_insert_page() left this unused function behind, remove it. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Move hardware header operations out of netdevice.Stephen Hemminger
Since hardware header operations are part of the protocol class not the device instance, make them into a separate object and save memory. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Wrap hard_header_parseStephen Hemminger
Wrap the hard_header_parse function to simplify next step of header_ops conversion. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Wrap netdevice hardware header creation.Stephen Hemminger
Add inline for common usage of hardware header creation, and fix bug in IPV6 mcast where the assumption about negative return is an errno. Negative return from hard_header means not enough space was available,(ie -N bytes). Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make device event notification network namespace safeEric W. Biederman
Every user of the network device notifiers is either a protocol stack or a pseudo device. If a protocol stack that does not have support for multiple network namespaces receives an event for a device that is not in the initial network namespace it quite possibly can get confused and do the wrong thing. To avoid problems until all of the protocol stacks are converted this patch modifies all netdev event handlers to ignore events on devices that are not in the initial network namespace. As the rest of the code is made network namespace aware these checks can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make packet reception network namespace safeEric W. Biederman
This patch modifies every packet receive function registered with dev_add_pack() to drop packets if they are not from the initial network namespace. This should ensure that the various network stacks do not receive packets in a anything but the initial network namespace until the code has been converted and is ready for them. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[AF_PACKET]: Don't enable global timestamps.Stephen Hemminger
Andi mentioned he did something like this already, but never submitted it. The dhcp client application uses AF_PACKET with a packet filter to receive data. The application doesn't even use timestamps, but because the AF_PACKET API has timestamps, they get turned on globally which causes an expensive time of day lookup for every packet received on any system that uses the standard DHCP client. The fix is to not enable the timestamp (but use if if available). This causes the time lookup to only occur on those packets that are destined for the AF_PACKET socket. The timestamping occurs after packet filtering so all packets dropped by filtering to not cause a clock call. The one downside of this a a few microseconds additional delay added from the normal timestamping location (netif_rx) until the receive callback in AF_PACKET. But since the offset is fairly consistent it should not upset applications that do want really use timestamps, like wireshark. Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-19[NET] PACKET: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2007-07-10[NET]: Make all initialized struct seq_operations const.Philippe De Muyter
Make all initialized struct seq_operations in net/ const Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[AF_PACKET]: Kill CONFIG_PACKET_SOCKET.David S. Miller
Always set, but af_packet.c, not by the Kconfig subsystem, so just get rid of it. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-31[AF_PACKET]: Kill bogus CONFIG_PACKET_MULTICASTDavid S. Miller
It is unconditionally set by af_packet.c, not by the Kconfig subsystem, so just kill it off. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[AF_PACKET]: Add option to return orig_dev to userspace.Peter P. Waskiewicz Jr
Add a packet socket option to allow the orig_dev index to be returned to userspace when passing traffic through a decapsulated device, such as the bonding driver. This is very useful for layer 2 traffic being able to report which physical device actually received the traffic, instead of having the encapsulating device hide that information. The new option is called PACKET_ORIGDEV. Signed-off-by: Peter P. Waskiewicz Jr. <peter.p.waskiewicz.jr@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Convert skb->tail to sk_buff_data_tArnaldo Carvalho de Melo
So that it is also an offset from skb->head, reduces its size from 8 to 4 bytes on 64bit architectures, allowing us to combine the 4 bytes hole left by the layer headers conversion, reducing struct sk_buff size to 256 bytes, i.e. 4 64byte cachelines, and since the sk_buff slab cache is SLAB_HWCACHE_ALIGN... :-) Many calculations that previously required that skb->{transport,network, mac}_header be first converted to a pointer now can be done directly, being meaningful as offsets or pointers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: unions of just one member don't get anything done, kill themArnaldo Carvalho de Melo
Renaming skb->h to skb->transport_header, skb->nh to skb->network_header and skb->mac to skb->mac_header, to match the names of the associated helpers (skb[_[re]set]_{transport,network,mac}_header). Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_offset()Arnaldo Carvalho de Melo
For the quite common 'skb->nh.raw - skb->data' sequence. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_network_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_mac_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the mac header, it is still legal to touch skb->mac.raw directly if just adding to, subtracting from or setting it to another layer header. This one also converts some more cases to skb_reset_mac_header() that my regex missed as it had no spaces before nor after '=', ugh. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: Introduce SIOCGSTAMPNS ioctl to get timestamps with nanosec resolutionEric Dumazet
Now network timestamps use ktime_t infrastructure, we can add a new ioctl() SIOCGSTAMPNS command to get timestamps in 'struct timespec'. User programs can thus access to nanosecond resolution. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[NET]: convert network timestamps to ktime_tEric Dumazet
We currently use a special structure (struct skb_timeval) and plain 'struct timeval' to store packet timestamps in sk_buffs and struct sock. This has some drawbacks : - Fixed resolution of micro second. - Waste of space on 64bit platforms where sizeof(struct timeval)=16 I suggest using ktime_t that is a nice abstraction of high resolution time services, currently capable of nanosecond resolution. As sizeof(ktime_t) is 8 bytes, using ktime_t in 'struct sock' permits a 8 byte shrink of this structure on 64bit architectures. Some other structures also benefit from this size reduction (struct ipq in ipv4/ip_fragment.c, struct frag_queue in ipv6/reassembly.c, ...) Once this ktime infrastructure adopted, we can more easily provide nanosecond resolution on top of it. (ioctl SIOCGSTAMPNS and/or SO_TIMESTAMPNS/SCM_TIMESTAMPNS) Note : this patch includes a bug correction in compat_sock_get_timestamp() where a "err = 0;" was missing (so this syscall returned -ENOENT instead of 0) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> CC: John find <linux.kernel@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-26[AF_PACKET]: Remove unnecessary casts.Jason Lunz
packet_lookup_frame() always returns tpacket_hdr*, so there's no reason to return char* and require casting by callers. Also, remove a cast of void*. Signed-off-by: Jason Lunz <lunz@falooley.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-12[PATCH] mark struct file_operations const 8Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-10[NET] PACKET: Fix whitespace errors.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[PACKET]: Fix skb->cb clobbering between aux and sockaddrHerbert Xu
Both aux data and sockaddr tries to use the same buffer which obviously doesn't work. We just happen to have 4 bytes free in the skb->cb if you take away the maximum length of sockaddr_ll. That's just enough to store the one piece of info from aux data that we can't generate at recvmsg(2) time. This is what the following patch does. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-08[PACKET]: Add optional checksum computation for recvmsgHerbert Xu
This patch is needed to make ISC's DHCP server (and probably other DHCP servers/clients using AF_PACKET) to be able to serve another client on the same Xen host. The problem is that packets between different domains on the same Xen host only have partial checksums. Unfortunately this piece of information is not passed along in AF_PACKET unless you're using the mmap interface. Since dhcpd doesn't support packet-mmap, UDP packets from the same host come out with apparently bogus checksums. This patch adds a mechanism for AF_PACKET recvmsg(2) to return the status along with the packet. It does so by adding a new cmsg that contains this information along with some other relevant data such as the original packet length. I didn't include the time stamp information since there is already a cmsg for that. This patch also changes the mmap code to set the CSUMNOTREADY flag on all packets instead of just outoing packets on cooked sockets. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-25[AF_PACKET]: Check device down state before hard header callbacks.David S. Miller
If the device is down, invoking the device hard header callbacks is not legal, so check it early. Based upon a shaper OOPS report from Frederik Deweerdt. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-01-24[AF_PACKET]: Fix BPF handling.David S. Miller
This fixes a bug introduced by: commit fda9ef5d679b07c9d9097aaf6ef7f069d794a8f9 Author: Dmitry Mishin <dim@openvz.org> Date: Thu Aug 31 15:28:39 2006 -0700 [NET]: Fix sk->sk_filter field access sk_run_filter() returns either 0 or an unsigned 32-bit length which says how much of the packet to retain. If that 32-bit unsigned integer is larger than the packet, this is fine we just leave the packet unchanged. The above commit caused all filter return values which were negative when interpreted as a signed integer to indicate a packet drop, which is wrong. Based upon a report and initial patch by Raivis Bucis. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-07[NET]: Memory barrier cleanupsRalf Baechle
I believe all the below memory barriers only matter on SMP so therefore the smp_* variant of the barrier should be used. I'm wondering if the barrier in net/ipv4/inet_timewait_sock.c should be dropped entirely. schedule_work's implementation currently implies a memory barrier and I think sane semantics of schedule_work() should imply a memory barrier, as needed so the caller shouldn't have to worry. It's not quite obvious why the barrier in net/packet/af_packet.c is needed; maybe it should be implied through flush_dcache_page? Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-04[PATCH] severing skbuff.h -> highmem.hAl Viro
2006-12-02[AF_PACKET]: annotateAl Viro
Weirdness: the third argument of socket() is net-endian here. Oh, well - it's documented in packet(7). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[NET]: Fix sk->sk_filter field accessDmitry Mishin
Function sk_filter() is called from tcp_v{4,6}_rcv() functions with arg needlock = 0, while socket is not locked at that moment. In order to avoid this and similar issues in the future, use rcu for sk->sk_filter field read protection. Signed-off-by: Dmitry Mishin <dim@openvz.org> Signed-off-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: Kirill Korotaev <dev@openvz.org>
2006-09-22[NET]: Replace CHECKSUM_HW by CHECKSUM_PARTIAL/CHECKSUM_COMPLETEPatrick McHardy
Replace CHECKSUM_HW by CHECKSUM_PARTIAL (for outgoing packets, whose checksum still needs to be completed) and CHECKSUM_COMPLETE (for incoming packets, device supplied full checksum). Patch originally from Herbert Xu, updated by myself for 2.6.18-rc3. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-17[PACKET]: Don't truncate non-linear skbs with mmaped IOPatrick McHardy
Non-linear skbs are truncated to their linear part with mmaped IO. Fix by using skb_copy_bits instead of memcpy. Signed-off-by: Patrick McHardy <kaber@trash.net> Acked-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-23[NET]: Fix some whitespace issues in af_packet.cKris Katterjohn
Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-11[PATCH] capable/capability.h (net/)Randy Dunlap
net: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[NET]: Remove more unneeded typecasts on *malloc()Kris Katterjohn
This removes more unneeded casts on the return value for kmalloc(), sock_kmalloc(), and vmalloc(). Signed-off-by: Kris Katterjohn <kjak@users.sourceforge.net> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: Add a dev_ioctl() fallback to sock_ioctl()Christoph Hellwig
Currently all network protocols need to call dev_ioctl as the default fallback in their ioctl implementations. This patch adds a fallback to dev_ioctl to sock_ioctl if the protocol returned -ENOIOCTLCMD. This way all the procotol ioctl handlers can be simplified and we don't need to export dev_ioctl. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: move struct proto_ops to constEric Dumazet
I noticed that some of 'struct proto_ops' used in the kernel may share a cache line used by locks or other heavily modified data. (default linker alignement is 32 bytes, and L1_CACHE_LINE is 64 or 128 at least) This patch makes sure a 'struct proto_ops' can be declared as const, so that all cpus can share all parts of it without false sharing. This is not mandatory : a driver can still use a read/write structure if it needs to (and eventually a __read_mostly) I made a global stubstitute to change all existing occurences to make them const. This should reduce the possibility of false sharing on SMP, and speedup some socket system calls. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-06[AF_PACKET]: Convert PACKET_MMAP over to vm_insert_page().David S. Miller
So we can properly use __GFP_COMP and avoid the use of PG_reserved pages. With extremely helpful review from Hugh Dickins. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-03[NET]: Fix packet timestamping.Herbert Xu
I've found the problem in general. It affects any 64-bit architecture. The problem occurs when you change the system time. Suppose that when you boot your system clock is forward by a day. This gets recorded down in skb_tv_base. You then wind the clock back by a day. From that point onwards the offset will be negative which essentially overflows the 32-bit variables they're stored in. In fact, why don't we just store the real time stamp in those 32-bit variables? After all, we're not going to overflow for quite a while yet. When we do overflow, we'll need a better solution of course. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-26[AF_PACKET]: Remove bogus checks added to packet_sendmsg().David S. Miller
These broke existing apps, and the checks are superfluous as the values being verified aren't even used. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-09-21[AF_PACKET]: Allow for > 8 byte hardware addresses.Eric W. Biederman
The convention is that longer addresses will simply extend the hardeware address byte arrays at the end of sockaddr_ll and packet_mreq. In making this change a small information leak was also closed. The code only initializes the hardware address bytes that are used, but all of struct sockaddr_ll was copied to userspace. Now we just copy sockaddr_ll to the last byte of the hardware address used. For error checking larger structures than our internal maximums continue to be allowed but an error is signaled if we can not fit the hardware address into our internal structure. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
