[ Upstream commit b43d1f9f7067c6759b1051e8ecb84e82cef569fe ]
There is softlockup when using TPACKET_V3:
NMI watchdog: BUG: soft lockup - CPU#2 stuck for 60010ms!
(__irq_svc) from [<c0558a0c>] (_raw_spin_unlock_irqrestore+0x44/0x54)
(_raw_spin_unlock_irqrestore) from [<c027b7e8>] (mod_timer+0x210/0x25c)
(mod_timer) from [<c0549c30>]
(prb_retire_rx_blk_timer_expired+0x68/0x11c)
(prb_retire_rx_blk_timer_expired) from [<c027a7ac>]
(call_timer_fn+0x90/0x17c)
(call_timer_fn) from [<c027ab6c>] (run_timer_softirq+0x2d4/0x2fc)
(run_timer_softirq) from [<c021eaf4>] (__do_softirq+0x218/0x318)
(__do_softirq) from [<c021eea0>] (irq_exit+0x88/0xac)
(irq_exit) from [<c0240130>] (msa_irq_exit+0x11c/0x1d4)
(msa_irq_exit) from [<c0209cf0>] (handle_IPI+0x650/0x7f4)
(handle_IPI) from [<c02015bc>] (gic_handle_irq+0x108/0x118)
(gic_handle_irq) from [<c0558ee4>] (__irq_usr+0x44/0x5c)
If __ethtool_get_link_ksettings() is failed in
prb_calc_retire_blk_tmo(), msec and tmo will be zero, so tov_in_jiffies
is zero and the timer expire for retire_blk_timer is turn to
mod_timer(&pkc->retire_blk_timer, jiffies + 0),
which will trigger cpu usage of softirq is 100%.
Fixes: f6fb8f100b80 ("af-packet: TPACKET_V3 flexible buffer implementation.")
Tested-by: Xiao Jiangfeng <xiaojiangfeng@huawei.com>
Signed-off-by: Mao Wenan <maowenan@huawei.com>
[ Upstream commit 32d3182cd2cd29b2e7e04df7b0db350fbe11289f ]
packet_sendmsg() checks tx_ring.pg_vec to decide
if it must call tpacket_snd().
Problem is that the check is lockless, meaning another thread
can issue a concurrent setsockopt(PACKET_TX_RING ) to flip
tx_ring.pg_vec back to NULL.
Given that tpacket_snd() grabs pg_vec_lock mutex, we can
perform the check again to solve the race.
syzbot reported :
kasan: CONFIG_KASAN_INLINE enabled
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] PREEMPT SMP KASAN
CPU: 1 PID: 11429 Comm: syz-executor394 Not tainted 5.3.0-rc4+ #101
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
RIP: 0010:packet_lookup_frame+0x8d/0x270 net/packet/af_packet.c:474
Code: c1 ee 03 f7 73 0c 80 3c 0e 00 0f 85 cb 01 00 00 48 8b 0b 89 c0 4c 8d 24 c1 48 b8 00 00 00 00 00 fc ff df 4c 89 e1 48 c1 e9 03 <80> 3c 01 00 0f 85 94 01 00 00 48 8d 7b 10 4d 8b 3c 24 48 b8 00 00
RSP: 0018:ffff88809f82f7b8 EFLAGS: 00010246
RAX: dffffc0000000000 RBX: ffff8880a45c7030 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 1ffff110148b8e06 RDI: ffff8880a45c703c
RBP: ffff88809f82f7e8 R08: ffff888087aea200 R09: fffffbfff134ae50
R10: fffffbfff134ae4f R11: ffffffff89a5727f R12: 0000000000000000
R13: 0000000000000001 R14: ffff8880a45c6ac0 R15: 0000000000000000
FS: 00007fa04716f700(0000) GS:ffff8880ae900000(0000) knlGS:0000000000000000
CR2: 00007fa04716edb8 CR3: 0000000091eb4000 CR4: 00000000001406e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
packet_current_frame net/packet/af_packet.c:487 [inline]
tpacket_snd net/packet/af_packet.c:2667 [inline]
packet_sendmsg+0x590/0x6250 net/packet/af_packet.c:2975
sock_sendmsg_nosec net/socket.c:637 [inline]
sock_sendmsg+0xd7/0x130 net/socket.c:657
___sys_sendmsg+0x3e2/0x920 net/socket.c:2311
__sys_sendmmsg+0x1bf/0x4d0 net/socket.c:2413
__do_sys_sendmmsg net/socket.c:2442 [inline]
__se_sys_sendmmsg net/socket.c:2439 [inline]
__x64_sys_sendmmsg+0x9d/0x100 net/socket.c:2439
do_syscall_64+0xfd/0x6a0 arch/x86/entry/common.c:296
entry_SYSCALL_64_after_hwframe+0x49/0xbe
Fixes: 69e3c75f4d54 ("net: TX_RING and packet mmap")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit 55655e3d1197fff16a7a05088fb0e5eba50eac55 ]
syzbot found we can leak memory in packet_set_ring(), if user application
provides buggy parameters.
Fixes: 7f953ab2ba46 ("af_packet: TX_RING support for TPACKET_V3")
Cc: Sowmini Varadhan <sowmini.varadhan@oracle.com>
AF_PACKET
[ Upstream commit 89ed5b519004a7706f50b70f611edbd3aaacff2c ]
When an application is run that:
a) Sets its scheduler to be SCHED_FIFO
and
b) Opens a memory mapped AF_PACKET socket, and sends frames with the
MSG_DONTWAIT flag cleared, its possible for the application to hang
forever in the kernel. This occurs because when waiting, the code in
tpacket_snd calls schedule, which under normal circumstances allows
other tasks to run, including ksoftirqd, which in some cases is
responsible for freeing the transmitted skb (which in AF_PACKET calls a
destructor that flips the status bit of the transmitted frame back to
available, allowing the transmitting task to complete).
However, when the calling application is SCHED_FIFO, its priority is
such that the schedule call immediately places the task back on the cpu,
preventing ksoftirqd from freeing the skb, which in turn prevents the
transmitting task from detecting that the transmission is complete.
We can fix this by converting the schedule call to a completion
mechanism. By using a completion queue, we force the calling task, when
it detects there are no more frames to send, to schedule itself off the
cpu until such time as the last transmitted skb is freed, allowing
forward progress to be made.
Tested by myself and the reporter, with good results
Change Notes:
V1->V2:
Enhance the sleep logic to support being interruptible and
allowing for honoring to SK_SNDTIMEO (Willem de Bruijn)
V2->V3:
Rearrage the point at which we wait for the completion queue, to
avoid needing to check for ph/skb being null at the end of the loop.
Also move the complete call to the skb destructor to avoid needing to
modify __packet_set_status. Also gate calling complete on
packet_read_pending returning zero to avoid multiple calls to complete.
(Willem de Bruijn)
Move timeo computation within loop, to re-fetch the socket
timeout since we also use the timeo variable to record the return code
from the wait_for_complete call (Neil Horman)
V3->V4:
Willem has requested that the control flow be restored to the
previous state. Doing so lets us eliminate the need for the
po->wait_on_complete flag variable, and lets us get rid of the
packet_next_frame function, but introduces another complexity.
Specifically, but using the packet pending count, we can, if an
applications calls sendmsg multiple times with MSG_DONTWAIT set, each
set of transmitted frames, when complete, will cause
tpacket_destruct_skb to issue a complete call, for which there will
never be a wait_on_completion call. This imbalance will lead to any
future call to wait_for_completion here to return early, when the frames
they sent may not have completed. To correct this, we need to re-init
the completion queue on every call to tpacket_snd before we enter the
loop so as to ensure we wait properly for the frames we send in this
iteration.
Change the timeout and interrupted gotos to out_put rather than
out_status so that we don't try to free a non-existant skb
Clean up some extra newlines (Willem de Bruijn)
Reviewed-by: Willem de Bruijn <willemb@google.com>
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
Reported-by: Matteo Croce <mcroce@redhat.com>
[ Upstream commit 36096f2f4fa05f7678bc87397665491700bae757 ]
kernel BUG at lib/list_debug.c:47!
invalid opcode: 0000 [#1
CPU: 0 PID: 12914 Comm: rmmod Tainted: G W 5.1.0+ #47
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.9.3-0-ge2fc41e-prebuilt.qemu-project.org 04/01/2014
RIP: 0010:__list_del_entry_valid+0x53/0x90
Code: 48 8b 32 48 39 fe 75 35 48 8b 50 08 48 39 f2 75 40 b8 01 00 00 00 5d c3 48
89 fe 48 89 c2 48 c7 c7 18 75 fe 82 e8 cb 34 78 ff <0f> 0b 48 89 fe 48 c7 c7 50 75 fe 82 e8 ba 34 78 ff 0f 0b 48 89 f2
RSP: 0018:ffffc90001c2fe40 EFLAGS: 00010286
RAX: 000000000000004e RBX: ffffffffa0184000 RCX: 0000000000000000
RDX: 0000000000000000 RSI: ffff888237a17788 RDI: 00000000ffffffff
RBP: ffffc90001c2fe40 R08: 0000000000000000 R09: 0000000000000000
R10: ffffc90001c2fe10 R11: 0000000000000000 R12: 0000000000000000
R13: ffffc90001c2fe50 R14: ffffffffa0184000 R15: 0000000000000000
FS: 00007f3d83634540(0000) GS:ffff888237a00000(0000) knlGS:0000000000000000
CR2: 0000555c350ea818 CR3: 0000000231677000 CR4: 00000000000006f0
Call Trace:
unregister_pernet_operations+0x34/0x120
unregister_pernet_subsys+0x1c/0x30
packet_exit+0x1c/0x369 [af_packet
__x64_sys_delete_module+0x156/0x260
? lockdep_hardirqs_on+0x133/0x1b0
? do_syscall_64+0x12/0x1f0
do_syscall_64+0x6e/0x1f0
When modprobe af_packet, register_pernet_subsys
fails and does a cleanup, ops->list is set to LIST_POISON1,
but the module init is considered to success, then while rmmod it,
BUG() is triggered in __list_del_entry_valid which is called from
unregister_pernet_subsys. This patch fix error handing path in
packet_init to avoid possilbe issue if some error occur.
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
[ Upstream commit 486efdc8f6ce802b27e15921d2353cc740c55451 ]
Packet sockets in datagram mode take a destination address. Verify its
length before passing to dev_hard_header.
Prior to 2.6.14-rc3, the send code ignored sll_halen. This is
established behavior. Directly compare msg_namelen to dev->addr_len.
Change v1->v2: initialize addr in all paths
Fixes: 6b8d95f1795c4 ("packet: validate address length if non-zero")
Suggested-by: David Laight <David.Laight@aculab.com>
Signed-off-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit a4dc6a49156b1f8d6e17251ffda17c9e6a5db78a ]
When using fanouts with AF_PACKET, the demux functions such as
fanout_demux_cpu will return an index in the fanout socket array, which
corresponds to the selected socket.
The ordering of this array depends on the order the sockets were added
to a given fanout group, so for FANOUT_CPU this means sockets are bound
to cpus in the order they are configured, which is OK.
However, when stopping then restarting the interface these sockets are
bound to, the sockets are reassigned to the fanout group in the reverse
order, due to the fact that they were inserted at the head of the
interface's AF_PACKET socket list.
This means that traffic that was directed to the first socket in the
fanout group is now directed to the last one after an interface restart.
In the case of FANOUT_CPU, traffic from CPU0 will be directed to the
socket that used to receive traffic from the last CPU after an interface
restart.
This commit introduces a helper to add a socket at the tail of a list,
then uses it to register AF_PACKET sockets.
Note that this changes the order in which sockets are listed in /proc and
with sock_diag.
Fixes: dc99f600698d ("packet: Add fanout support")
Signed-off-by: Maxime Chevallier <maxime.chevallier@bootlin.com>
Acked-by: Willem de Bruijn <willemb@google.com>
[ Upstream commit 398f0132c14754fcd03c1c4f8e7176d001ce8ea1 ]
Since commit fc62814d690c ("net/packet: fix 4gb buffer limit due to overflow check")
one can now allocate packet ring buffers >= UINT_MAX. However, syzkaller
found that that triggers a warning:
[ 21.100000] WARNING: CPU: 2 PID: 2075 at mm/page_alloc.c:4584 __alloc_pages_nod0
[ 21.101490] Modules linked in:
[ 21.101921] CPU: 2 PID: 2075 Comm: syz-executor.0 Not tainted 5.0.0 #146
[ 21.102784] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 0.5.1 01/01/2011
[ 21.103887] RIP: 0010:__alloc_pages_nodemask+0x2a0/0x630
[ 21.104640] Code: fe ff ff 65 48 8b 04 25 c0 de 01 00 48 05 90 0f 00 00 41 bd 01 00 00 00 48 89 44 24 48 e9 9c fe 3
[ 21.107121] RSP: 0018:ffff88805e1cf920 EFLAGS: 00010246
[ 21.107819] RAX: 0000000000000000 RBX: ffffffff85a488a0 RCX: 0000000000000000
[ 21.108753] RDX: 0000000000000000 RSI: dffffc0000000000 RDI: 0000000000000000
[ 21.109699] RBP: 1ffff1100bc39f28 R08: ffffed100bcefb67 R09: ffffed100bcefb67
[ 21.110646] R10: 0000000000000001 R11: ffffed100bcefb66 R12: 000000000000000d
[ 21.111623] R13: 0000000000000000 R14: ffff88805e77d888 R15: 000000000000000d
[ 21.112552] FS: 00007f7c7de05700(0000) GS:ffff88806d100000(0000) knlGS:0000000000000000
[ 21.113612] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 21.114405] CR2: 000000000065c000 CR3: 000000005e58e006 CR4: 00000000001606e0
[ 21.115367] Call Trace:
[ 21.115705] ? __alloc_pages_slowpath+0x21c0/0x21c0
[ 21.116362] alloc_pages_current+0xac/0x1e0
[ 21.116923] kmalloc_order+0x18/0x70
[ 21.117393] kmalloc_order_trace+0x18/0x110
[ 21.117949] packet_set_ring+0x9d5/0x1770
[ 21.118524] ? packet_rcv_spkt+0x440/0x440
[ 21.119094] ? lock_downgrade+0x620/0x620
[ 21.119646] ? __might_fault+0x177/0x1b0
[ 21.120177] packet_setsockopt+0x981/0x2940
[ 21.120753] ? __fget+0x2fb/0x4b0
[ 21.121209] ? packet_release+0xab0/0xab0
[ 21.121740] ? sock_has_perm+0x1cd/0x260
[ 21.122297] ? selinux_secmark_relabel_packet+0xd0/0xd0
[ 21.123013] ? __fget+0x324/0x4b0
[ 21.123451] ? selinux_netlbl_socket_setsockopt+0x101/0x320
[ 21.124186] ? selinux_netlbl_sock_rcv_skb+0x3a0/0x3a0
[ 21.124908] ? __lock_acquire+0x529/0x3200
[ 21.125453] ? selinux_socket_setsockopt+0x5d/0x70
[ 21.126075] ? __sys_setsockopt+0x131/0x210
[ 21.126533] ? packet_release+0xab0/0xab0
[ 21.127004] __sys_setsockopt+0x131/0x210
[ 21.127449] ? kernel_accept+0x2f0/0x2f0
[ 21.127911] ? ret_from_fork+0x8/0x50
[ 21.128313] ? do_raw_spin_lock+0x11b/0x280
[ 21.128800] __x64_sys_setsockopt+0xba/0x150
[ 21.129271] ? lockdep_hardirqs_on+0x37f/0x560
[ 21.129769] do_syscall_64+0x9f/0x450
[ 21.130182] entry_SYSCALL_64_after_hwframe+0x49/0xbe
We should allocate with __GFP_NOWARN to handle this.
Cc: Kal Conley <kal.conley@dectris.com>
Cc: Andrey Konovalov <andreyknvl@google.com>
Fixes: fc62814d690c ("net/packet: fix 4gb buffer limit due to overflow check")
Signed-off-by: Christoph Paasch <cpaasch@apple.com>
[ Upstream commit fc62814d690cf62189854464f4bd07457d5e9e50 ]
When calculating rb->frames_per_block * req->tp_block_nr the result
can overflow. Check it for overflow without limiting the total buffer
size to UINT_MAX.
This change fixes support for packet ring buffers >= UINT_MAX.
Fixes: 8f8d28e4d6d8 ("net/packet: fix overflow in check for tp_frame_nr")
Signed-off-by: Kal Conley <kal.conley@dectris.com>
[ Upstream commit d972f3dce8d161e2142da0ab1ef25df00e2f21a9 ]
'dev' is non NULL when the addr_len check triggers so it must goto a label
that does the dev_put otherwise dev will have a leaked refcount.
This bug causes the ib_ipoib module to become unloadable when using
systemd-network as it triggers this check on InfiniBand links.
Fixes: 99137b7888f4 ("packet: validate address length")
Reported-by: Leon Romanovsky <leonro@mellanox.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
[ Upstream commit 6b8d95f1795c42161dc0984b6863e95d6acf24ed ]
Validate packet socket address length if a length is given. Zero
length is equivalent to not setting an address.
Reported-by: Ido Schimmel <idosch@idosch.org>
[ Upstream commit 99137b7888f4058087895d035d81c6b2d31015c5 ]
Packet sockets with SOCK_DGRAM may pass an address for use in
dev_hard_header. Ensure that it is of sufficient length.
[ Upstream commit 5cd8d46ea1562be80063f53c7c6a5f40224de623 ]
tpacket_snd sends packets with user pages linked into skb frags. It
notifies that pages can be reused when the skb is released by setting
skb->destructor to tpacket_destruct_skb.
This can cause data corruption if the skb is orphaned (e.g., on
transmit through veth) or cloned (e.g., on mirror to another psock).
Create a kernel-private copy of data in these cases, same as tun/tap
zerocopy transmission. Reuse that infrastructure: mark the skb as
SKBTX_ZEROCOPY_FRAG, which will trigger copy in skb_orphan_frags(_rx).
Unlike other zerocopy packets, do not set shinfo destructor_arg to
struct ubuf_info. tpacket_destruct_skb already uses that ptr to notify
when the original skb is released and a timestamp is recorded. Do not
change this timestamp behavior. The ubuf_info->callback is not needed
anyway, as no zerocopy notification is expected.
Mark destructor_arg as not-a-uarg by setting the lower bit to 1. The
resulting value is not a valid ubuf_info pointer, nor a valid
tpacket_snd frame address. Add skb_zcopy_.._nouarg helpers for this.
The fix relies on features introduced in commit 52267790ef52 ("sock:
add MSG_ZEROCOPY"), so can be backported as is only to 4.14.
Tested with from `./in_netns.sh ./txring_overwrite` from
http://github.com/wdebruij/kerneltools/tests
Reported-by: Anand H. Krishnan <anandhkrishnan@gmail.com>
[ Upstream commit 9d2f67e43b73e8af7438be219b66a5de0cfa8bd9 ]
When we use raw socket as the vhost backend, a packet from virito with
gso offloading information, cannot be sent out in later validaton at
xmit path, as we did not set correct skb->protocol which is further used
for looking up the gso function.
To fix this, we set this field according to virito hdr information.
Fixes: e858fae2b0b8f4 ("virtio_net: use common code for virtio_net_hdr and skb GSO conversion")
Signed-off-by: Jianfeng Tan <jianfeng.tan@linux.alibaba.com>
commit 4576cd469d980317c4edd9173f8b694aa71ea3a3 upstream.
TPACKET_V3 stores variable length frames in fixed length blocks.
Blocks must be able to store a block header, optional private space
and at least one minimum sized frame.
Frames, even for a zero snaplen packet, store metadata headers and
optional reserved space.
In the block size bounds check, ensure that the frame of the
chosen configuration fits. This includes sockaddr_ll and optional
tp_reserve.
Syzbot was able to construct a ring with insuffient room for the
sockaddr_ll in the header of a zero-length frame, triggering an
out-of-bounds write in dev_parse_header.
Convert the comparison to less than, as zero is a valid snap len.
This matches the test for minimum tp_frame_size immediately below.
Fixes: eb73190f4fbe ("net/packet: refine check for priv area size")
[ Upstream commit 993675a3100b16a4c80dfd70cbcde8ea7127b31d ]
If variable length link layer headers result in a packet shorter
than dev->hard_header_len, reset the network header offset. Else
skb->mac_len may exceed skb->len after skb_mac_reset_len.
packet_sendmsg_spkt already has similar logic.
Fixes: b84bbaf7a6c8 ("packet: in packet_snd start writing at link layer allocation")
[ Upstream commit 945d015ee0c3095d2290e845565a23dedfd8027c ]
We should put copy_skb in receive_queue only after
a successful call to virtio_net_hdr_from_skb().
syzbot report :
BUG: KASAN: use-after-free in __skb_unlink include/linux/skbuff.h:1843 [inline]
BUG: KASAN: use-after-free in __skb_dequeue include/linux/skbuff.h:1863 [inline]
BUG: KASAN: use-after-free in skb_dequeue+0x16a/0x180 net/core/skbuff.c:2815
Read of size 8 at addr ffff8801b044ecc0 by task syz-executor217/4553
CPU: 0 PID: 4553 Comm: syz-executor217 Not tainted 4.18.0-rc1+ #111
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x1c9/0x2b4 lib/dump_stack.c:113
print_address_description+0x6c/0x20b mm/kasan/report.c:256
kasan_report_error mm/kasan/report.c:354 [inline]
kasan_report.cold.7+0x242/0x2fe mm/kasan/report.c:412
__asan_report_load8_noabort+0x14/0x20 mm/kasan/report.c:433
skb_queue_purge+0x26/0x40 net/core/skbuff.c:2852
packet_set_ring+0x675/0x1da0 net/packet/af_packet.c:4331
packet_release+0x630/0xd90 net/packet/af_packet.c:2991
__sock_release+0xd7/0x260 net/socket.c:603
sock_close+0x19/0x20 net/socket.c:1186
__fput+0x35b/0x8b0 fs/file_table.c:209
____fput+0x15/0x20 fs/file_table.c:243
task_work_run+0x1ec/0x2a0 kernel/task_work.c:113
exit_task_work include/linux/task_work.h:22 [inline]
do_exit+0x1b08/0x2750 kernel/exit.c:865
do_group_exit+0x177/0x440 kernel/exit.c:968
__do_sys_exit_group kernel/exit.c:979 [inline]
__se_sys_exit_group kernel/exit.c:977 [inline]
__x64_sys_exit_group+0x3e/0x50 kernel/exit.c:977
do_syscall_64+0x1b9/0x820 arch/x86/entry/common.c:290
RIP: 0033:0x4448e9
Code: Bad RIP value.
RSP: 002b:00007ffd5f777ca8 EFLAGS: 00000202 ORIG_RAX: 00000000000000e7
RAX: ffffffffffffffda RBX: 0000000000000000 RCX: 00000000004448e9
RDX: 00000000004448e9 RSI: 000000000000fcfb RDI: 0000000000000001
RBP: 00000000006cf018 R08: 00007ffd0000a45b R09: 0000000000000000
R10: 00007ffd5f777e48 R11: 0000000000000202 R12: 00000000004021f0
R13: 0000000000402280 R14: 0000000000000000 R15: 0000000000000000
Allocated by task 4553:
save_stack+0x43/0xd0 mm/kasan/kasan.c:448
set_track mm/kasan/kasan.c:460 [inline]
kasan_kmalloc+0xc4/0xe0 mm/kasan/kasan.c:553
kasan_slab_alloc+0x12/0x20 mm/kasan/kasan.c:490
kmem_cache_alloc+0x12e/0x760 mm/slab.c:3554
skb_clone+0x1f5/0x500 net/core/skbuff.c:1282
tpacket_rcv+0x28f7/0x3200 net/packet/af_packet.c:2221
deliver_skb net/core/dev.c:1925 [inline]
deliver_ptype_list_skb net/core/dev.c:1940 [inline]
__netif_receive_skb_core+0x1bfb/0x3680 net/core/dev.c:4611
__netif_receive_skb+0x2c/0x1e0 net/core/dev.c:4693
netif_receive_skb_internal+0x12e/0x7d0 net/core/dev.c:4767
netif_receive_skb+0xbf/0x420 net/core/dev.c:4791
tun_rx_batched.isra.55+0x4ba/0x8c0 drivers/net/tun.c:1571
tun_get_user+0x2af1/0x42f0 drivers/net/tun.c:1981
tun_chr_write_iter+0xb9/0x154 drivers/net/tun.c:2009
call_write_iter include/linux/fs.h:1795 [inline]
new_sync_write fs/read_write.c:474 [inline]
__vfs_write+0x6c6/0x9f0 fs/read_write.c:487
vfs_write+0x1f8/0x560 fs/read_write.c:549
ksys_write+0x101/0x260 fs/read_write.c:598
__do_sys_write fs/read_write.c:610 [inline]
__se_sys_write fs/read_write.c:607 [inline]
__x64_sys_write+0x73/0xb0 fs/read_write.c:607
Freed by task 4553:
__kasan_slab_free+0x11a/0x170 mm/kasan/kasan.c:521
kasan_slab_free+0xe/0x10 mm/kasan/kasan.c:528
__cache_free mm/slab.c:3498 [inline]
kmem_cache_free+0x86/0x2d0 mm/slab.c:3756
kfree_skbmem+0x154/0x230 net/core/skbuff.c:582
__kfree_skb net/core/skbuff.c:642 [inline]
kfree_skb+0x1a5/0x580 net/core/skbuff.c:659
tpacket_rcv+0x189e/0x3200 net/packet/af_packet.c:2385
The buggy address belongs to the object at ffff8801b044ecc0
which belongs to the cache skbuff_head_cache of size 232
The buggy address is located 0 bytes inside of
232-byte region [ffff8801b044ecc0, ffff8801b044eda8)
The buggy address belongs to the page:
page:ffffea0006c11380 count:1 mapcount:0 mapping:ffff8801d9be96c0 index:0x0
flags: 0x2fffc0000000100(slab)
raw: 02fffc0000000100 ffffea0006c17988 ffff8801d9bec248 ffff8801d9be96c0
raw: 0000000000000000 ffff8801b044e040 000000010000000c 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8801b044eb80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff8801b044ec00: 00 00 00 00 00 00 00 00 00 00 00 00 00 fc fc fc
>ffff8801b044ec80: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
ffff8801b044ed00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8801b044ed80: fb fb fb fb fb fc fc fc fc fc fc fc fc fc fc fc
Fixes: 58d19b19cd99 ("packet: vnet_hdr support for tpacket_rcv")
Cc: Willem de Bruijn <willemb@google.com>
[ Upstream commit fd3a88625844907151737fc3b4201676effa6d27 ]
Tun, tap, virtio, packet and uml vector all use struct virtio_net_hdr
to communicate packet metadata to userspace.
For skbuffs with vlan, the first two return the packet as it may have
existed on the wire, inserting the VLAN tag in the user buffer. Then
virtio_net_hdr.csum_start needs to be adjusted by VLAN_HLEN bytes.
Commit f09e2249c4f5 ("macvtap: restore vlan header on user read")
added this feature to macvtap. Commit 3ce9b20f1971 ("macvtap: Fix
csum_start when VLAN tags are present") then fixed up csum_start.
Virtio, packet and uml do not insert the vlan header in the user
buffer.
When introducing virtio_net_hdr_from_skb to deduplicate filling in
the virtio_net_hdr, the variant from macvtap which adds VLAN_HLEN was
applied uniformly, breaking csum offset for packets with vlan on
virtio and packet.
Make insertion of VLAN_HLEN optional. Convert the callers to pass it
when needed.
Fixes: 1276f24eeef2 ("packet: use common code for virtio_net_hdr and skb GSO conversion")
[ Upstream commit 9aad13b087ab0a588cd68259de618f100053360e ]
Commit b84bbaf7a6c8 ("packet: in packet_snd start writing at link
layer allocation") ensures that packet_snd always starts writing
the link layer header in reserved headroom allocated for this
purpose.
This is needed because packets may be shorter than hard_header_len,
in which case the space up to hard_header_len may be zeroed. But
that necessary padding is not accounted for in skb->len.
The fix, however, is buggy. It calls skb_push, which grows skb->len
when moving skb->data back. But in this case packet length should not
change.
Instead, call skb_reserve, which moves both skb->data and skb->tail
back, without changing length.
Reported-by: Tariq Toukan <tariqt@mellanox.com>
Acked-by: Soheil Hassas Yeganeh <soheil@google.com>
[ Upstream commit eb73190f4fbeedf762394e92d6a4ec9ace684c88 ]
syzbot was able to trick af_packet again [1]
Various commits tried to address the problem in the past,
but failed to take into account V3 header size.
[1]
tpacket_rcv: packet too big, clamped from 72 to 4294967224. macoff=96
BUG: KASAN: use-after-free in prb_run_all_ft_ops net/packet/af_packet.c:1016 [inline]
BUG: KASAN: use-after-free in prb_fill_curr_block.isra.59+0x4e5/0x5c0 net/packet/af_packet.c:1039
Write of size 2 at addr ffff8801cb62000e by task kworker/1:2/2106
CPU: 1 PID: 2106 Comm: kworker/1:2 Not tainted 4.17.0-rc7+ #77
Workqueue: ipv6_addrconf addrconf_dad_work
Call Trace:
dump_stack+0x1b9/0x294 lib/dump_stack.c:113
__asan_report_store2_noabort+0x17/0x20 mm/kasan/report.c:436
__packet_lookup_frame_in_block net/packet/af_packet.c:1094 [inline]
packet_current_rx_frame net/packet/af_packet.c:1117 [inline]
tpacket_rcv+0x1866/0x3340 net/packet/af_packet.c:2282
dev_queue_xmit_nit+0x891/0xb90 net/core/dev.c:2018
xmit_one net/core/dev.c:3049 [inline]
dev_hard_start_xmit+0x16b/0xc10 net/core/dev.c:3069
__dev_queue_xmit+0x2724/0x34c0 net/core/dev.c:3584
dev_queue_xmit+0x17/0x20 net/core/dev.c:3617
neigh_resolve_output+0x679/0xad0 net/core/neighbour.c:1358
neigh_output include/net/neighbour.h:482 [inline]
ip6_finish_output2+0xc9c/0x2810 net/ipv6/ip6_output.c:120
ip6_finish_output+0x5fe/0xbc0 net/ipv6/ip6_output.c:154
NF_HOOK_COND include/linux/netfilter.h:277 [inline]
ip6_output+0x227/0x9b0 net/ipv6/ip6_output.c:171
dst_output include/net/dst.h:444 [inline]
NF_HOOK include/linux/netfilter.h:288 [inline]
ndisc_send_skb+0x100d/0x1570 net/ipv6/ndisc.c:491
ndisc_send_ns+0x3c1/0x8d0 net/ipv6/ndisc.c:633
addrconf_dad_work+0xbef/0x1340 net/ipv6/addrconf.c:4033
process_one_work+0xc1e/0x1b50 kernel/workqueue.c:2145
worker_thread+0x1cc/0x1440 kernel/workqueue.c:2279
kthread+0x345/0x410 kernel/kthread.c:240
ret_from_fork+0x3a/0x50 arch/x86/entry/entry_64.S:412
page:ffffea00072d8800 count:0 mapcount:-127 mapping:0000000000000000 index:0xffff8801cb620e80
flags: 0x2fffc0000000000()
raw: 02fffc0000000000 0000000000000000 ffff8801cb620e80 00000000ffffff80
raw: ffffea00072e3820 ffffea0007132d20 0000000000000002 0000000000000000
ffff8801cb61ff00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff8801cb61ff80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
>ffff8801cb620000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ffff8801cb620080: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
ffff8801cb620100: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Fixes: 2b6867c2ce76 ("net/packet: fix overflow in check for priv area size")
Fixes: dc808110bb62 ("packet: handle too big packets for PACKET_V3")
[ Upstream commit b84bbaf7a6c8cca24f8acf25a2c8e46913a947ba ]
Packet sockets allow construction of packets shorter than
dev->hard_header_len to accommodate protocols with variable length
link layer headers. These packets are padded to dev->hard_header_len,
because some device drivers interpret that as a minimum packet size.
packet_snd reserves dev->hard_header_len bytes on allocation.
SOCK_DGRAM sockets call skb_push in dev_hard_header() to ensure that
link layer headers are stored in the reserved range. SOCK_RAW sockets
do the same in tpacket_snd, but not in packet_snd.
Syzbot was able to send a zero byte packet to a device with massive
116B link layer header, causing padding to cross over into skb_shinfo.
Fix this by writing from the start of the llheader reserved range also
in the case of packet_snd/SOCK_RAW.
Update skb_set_network_header to the new offset. This also corrects
it for SOCK_DGRAM, where it incorrectly double counted reserve due to
the skb_push in dev_hard_header.
Fixes: 9ed988cd5915 ("packet: validate variable length ll headers")
Reported-by: syzbot+71d74a5406d02057d559@syzkaller.appspotmail.com
[ Upstream commit a6361f0ca4b25460f2cdf3235ebe8115f622901e ]
Updates to the bitfields in struct packet_sock are not atomic.
Serialize these read-modify-write cycles.
Move po->running into a separate variable. Its writes are protected by
po->bind_lock (except for one startup case at packet_create). Also
replace a textual precondition warning with lockdep annotation.
All others are set only in packet_setsockopt. Serialize these
updates by holding the socket lock. Analogous to other field updates,
also hold the lock when testing whether a ring is active (pg_vec).
Fixes: 8dc419447415 ("[PACKET]: Add optional checksum computation for recvmsg")
Reported-by: DaeRyong Jeong <threeearcat@gmail.com>
Reported-by: Byoungyoung Lee <byoungyoung@purdue.edu>
[ Upstream commit 5171b37d959641bbc619781caf62e61f7b940871 ]
In order to remove the race caught by syzbot [1], we need
to lock the socket before using po->tp_version as this could
change under us otherwise.
This means lock_sock() and release_sock() must be done by
packet_set_ring() callers.
[1] :
BUG: KMSAN: uninit-value in packet_set_ring+0x1254/0x3870 net/packet/af_packet.c:4249
CPU: 0 PID: 20195 Comm: syzkaller707632 Not tainted 4.16.0+ #83
Call Trace:
__dump_stack lib/dump_stack.c:17 [inline]
dump_stack+0x185/0x1d0 lib/dump_stack.c:53
kmsan_report+0x142/0x240 mm/kmsan/kmsan.c:1067
__msan_warning_32+0x6c/0xb0 mm/kmsan/kmsan_instr.c:676
packet_setsockopt+0x12c6/0x5a90 net/packet/af_packet.c:3662
SYSC_setsockopt+0x4b8/0x570 net/socket.c:1849
SyS_setsockopt+0x76/0xa0 net/socket.c:1828
do_syscall_64+0x309/0x430 arch/x86/entry/common.c:287
entry_SYSCALL_64_after_hwframe+0x3d/0xa2
RIP: 0033:0x449099
RSP: 002b:00007f42b5307ce8 EFLAGS: 00000246 ORIG_RAX: 0000000000000036
RAX: ffffffffffffffda RBX: 000000000070003c RCX: 0000000000449099
RDX: 0000000000000005 RSI: 0000000000000107 RDI: 0000000000000003
RBP: 0000000000700038 R08: 000000000000001c R09: 0000000000000000
R10: 00000000200000c0 R11: 0000000000000246 R12: 0000000000000000
R13: 000000000080eecf R14: 00007f42b53089c0 R15: 0000000000000001
Local variable description: ----req_u@packet_setsockopt
Variable was created at:
packet_setsockopt+0x13f/0x5a90 net/packet/af_packet.c:3612
[ Upstream commit 15fe076edea787807a7cdc168df832544b58eba6 ]
syzbot reported crashes [1] and provided a C repro easing bug hunting.
When/if packet_do_bind() calls __unregister_prot_hook() and releases
po->bind_lock, another thread can run packet_notifier() and process an
NETDEV_UP event.
This calls register_prot_hook() and hooks again the socket right before
first thread is able to grab again po->bind_lock.
Fixes this issue by temporarily setting po->num to 0, as suggested by
David Miller.
[1]
dev_remove_pack: ffff8801bf16fa80 not found
kernel BUG at net/core/dev.c:7945! ( BUG_ON(!list_empty(&dev->ptype_all)); )
invalid opcode: 0000 [#1] SMP KASAN
Dumping ftrace buffer:
(ftrace buffer empty)
Modules linked in:
device syz0 entered promiscuous mode
CPU: 0 PID: 3161 Comm: syzkaller404108 Not tainted 4.14.0+ #190
task: ffff8801cc57a500 task.stack: ffff8801cc588000
RIP: 0010:netdev_run_todo+0x772/0xae0 net/core/dev.c:7945
RSP: 0018:ffff8801cc58f598 EFLAGS: 00010293
RAX: ffff8801cc57a500 RBX: dffffc0000000000 RCX: ffffffff841f75b2
RDX: 0000000000000000 RSI: 1ffff100398b1ede RDI: ffff8801bf1f8810
RBP: ffff8801cc58f898 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000000 R12: ffff8801bf1f8cd8
R13: ffff8801cc58f870 R14: ffff8801bf1f8780 R15: ffff8801cc58f7f0
FS: 0000000001716880(0000) GS:ffff8801db400000(0000) knlGS:0000000000000000
CR2: 0000000020b13000 CR3: 0000000005e25000 CR4: 00000000001406f0
Call Trace:
rtnl_unlock+0xe/0x10 net/core/rtnetlink.c:106
tun_detach drivers/net/tun.c:670 [inline]
tun_chr_close+0x49/0x60 drivers/net/tun.c:2845
__fput+0x333/0x7f0 fs/file_table.c:210
____fput+0x15/0x20 fs/file_table.c:244
task_work_run+0x199/0x270 kernel/task_work.c:113
do_exit+0x9bb/0x1ae0 kernel/exit.c:865
do_group_exit+0x149/0x400 kernel/exit.c:968
SYSC_exit_group kernel/exit.c:979 [inline]
SyS_exit_group+0x1d/0x20 kernel/exit.c:977
entry_SYSCALL_64_fastpath+0x1f/0x96
RIP: 0033:0x44ad19
Fixes: 30f7ea1c2b5f ("packet: race condition in packet_bind")
Cc: Francesco Ruggeri <fruggeri@aristanetworks.com>
syzkaller found a race condition fanout_demux_rollover() while removing
a packet socket from a fanout group.
po->rollover is read and operated on during packet_rcv_fanout(), via
fanout_demux_rollover(), but the pointer is currently cleared before the
synchronization in packet_release(). It is safer to delay the cleanup
until after synchronize_net() has been called, ensuring all calls to
packet_rcv_fanout() for this socket have finished.
To further simplify synchronization around the rollover structure, set
po->rollover in fanout_add() only if there are no errors. This removes
the need for rcu in the struct and in the call to
packet_getsockopt(..., PACKET_ROLLOVER_STATS, ...).
Crashing stack trace:
fanout_demux_rollover+0xb6/0x4d0 net/packet/af_packet.c:1392
packet_rcv_fanout+0x649/0x7c8 net/packet/af_packet.c:1487
dev_queue_xmit_nit+0x835/0xc10 net/core/dev.c:1953
xmit_one net/core/dev.c:2975 [inline]
dev_hard_start_xmit+0x16b/0xac0 net/core/dev.c:2995
__dev_queue_xmit+0x17a4/0x2050 net/core/dev.c:3476
dev_queue_xmit+0x17/0x20 net/core/dev.c:3509
neigh_connected_output+0x489/0x720 net/core/neighbour.c:1379
ip6_finish_output2+0xad1/0x22a0 net/ipv6/ip6_output.c:120
ip6_finish_output+0x2f9/0x920 net/ipv6/ip6_output.c:146
NF_HOOK_COND include/linux/netfilter.h:239 [inline]
ip6_output+0x1f4/0x850 net/ipv6/ip6_output.c:163
dst_output include/net/dst.h:459 [inline]
NF_HOOK.constprop.35+0xff/0x630 include/linux/netfilter.h:250
mld_sendpack+0x6a8/0xcc0 net/ipv6/mcast.c:1660
mld_send_initial_cr.part.24+0x103/0x150 net/ipv6/mcast.c:2072
mld_send_initial_cr net/ipv6/mcast.c:2056 [inline]
ipv6_mc_dad_complete+0x99/0x130 net/ipv6/mcast.c:2079
addrconf_dad_completed+0x595/0x970 net/ipv6/addrconf.c:4039
addrconf_dad_work+0xac9/0x1160 net/ipv6/addrconf.c:3971
process_one_work+0xbf0/0x1bc0 kernel/workqueue.c:2113
worker_thread+0x223/0x1990 kernel/workqueue.c:2247
kthread+0x35e/0x430 kernel/kthread.c:231
ret_from_fork+0x2a/0x40 arch/x86/entry/entry_64.S:432
Fixes: 0648ab70afe6 ("packet: rollover prepare: per-socket state")
Fixes: 509c7a1ecc860 ("packet: avoid panic in packet_getsockopt()")
Signed-off-by: Mike Maloney <maloney@google.com>
Reviewed-by: Eric Dumazet <edumazet@google.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
syzkaller got crashes in packet_getsockopt() processing
PACKET_ROLLOVER_STATS command while another thread was managing
to change po->rollover
Using RCU will fix this bug. We might later add proper RCU annotations
for sparse sake.
In v2: I replaced kfree(rollover) in fanout_add() to kfree_rcu()
variant, as spotted by John.
Fixes: a9b6391814d5 ("packet: rollover statistics")
Cc: John Sperbeck <jsperbeck@google.com>
Packet socket option po->has_vnet_hdr can be updated concurrently with
other operations if no ring is attached.
Do not test the option twice in packet_snd, as the value may change in
between calls. A race on setsockopt disable may cause a packet > mtu
to be sent without having GSO options set.
Fixes: bfd5f4a3d605 ("packet: Add GSO/csum offload support.")
Once a socket has po->fanout set, it remains a member of the group
until it is destroyed. The prot_hook must be constant and identical
across sockets in the group.
If fanout_add races with packet_do_bind between the test of po->fanout
and taking the lock, the bind call may make type or dev inconsistent
with that of the fanout group.
Hold po->bind_lock when testing po->fanout to avoid this race.
I had to introduce artificial delay (local_bh_enable) to actually
observe the race.
Fixes: dc99f600698d ("packet: Add fanout support.")
Packet socket bind operations must hold the po->bind_lock. This keeps
po->running consistent with whether the socket is actually on a ptype
list to receive packets.
fanout_add unbinds a socket and its packet_rcv/tpacket_rcv call, then
binds the fanout object to receive through packet_rcv_fanout.
Make it hold the po->bind_lock when testing po->running and rebinding.
Else, it can race with other rebind operations, such as that in
packet_set_ring from packet_rcv to tpacket_rcv. Concurrent updates
can result in a socket being added to a fanout group twice, causing
use-after-free KASAN bug reports, among others.
Reported independently by both trinity and syzkaller.
Verified that the syzkaller reproducer passes after this patch.
Reported-by: nixioaming <nixiaoming@huawei.com>
Three cases of simple overlapping changes.
... which may happen with certain values of tp_reserve and maclen.
Signed-off-by: Benjamin Poirier <bpoirier@suse.com>
Mainline had UFO fixes, but UFO is removed in net-next so we
take the HEAD hunks.
Minor context conflict in bcmsysport statistics bug fix.
Updates to tp_reserve can race with reads of the field in
packet_set_ring. Avoid this by holding the socket lock during
updates in setsockopt PACKET_RESERVE.
This bug was discovered by syzkaller.
Fixes: 8913336a7e8d ("packet: add PACKET_RESERVE sockopt")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Two minor conflicts in virtio_net driver (bug fix overlapping addition
of a helper) and MAINTAINERS (new driver edit overlapping revamp of
PHY entry).
There are multiple reports showing we have a use-after-free in
the timer prb_retire_rx_blk_timer_expired(), where we use struct
tpacket_kbdq_core::pkbdq, a pg_vec, after it gets freed by
free_pg_vec().
The interesting part is it is not freed via packet_release() but
via packet_setsockopt(), which means we are not closing the socket.
Looking into the big and fat function packet_set_ring(), this could
happen if we satisfy the following conditions:
1. closing == 0, not on packet_release() path
2. req->tp_block_nr == 0, we don't allocate a new pg_vec
3. rx_ring->pg_vec is already set as V3, which means we already called
packet_set_ring() wtih req->tp_block_nr > 0 previously
4. req->tp_frame_nr == 0, pass sanity check
5. po->mapped == 0, never called mmap()
In this scenario we are clearing the old rx_ring->pg_vec, so we need
to free this pg_vec, but we don't stop the timer on this path because
of closing==0.
The timer has to be stopped as long as we need to free pg_vec, therefore
the check on closing!=0 is wrong, we should check pg_vec!=NULL instead.
Thanks to liujian for testing different fixes.
Reported-by: alexander.levin@verizon.com
Reported-by: Dave Jones <davej@codemonkey.org.uk>
Reported-by: liujian (CE) <liujian56@huawei.com>
Tested-by: liujian (CE) <liujian56@huawei.com>
Cc: Ding Tianhong <dingtianhong@huawei.com>
Cc: Willem de Bruijn <willemdebruijn.kernel@gmail.com>
This patch removes the definition of PGV_FROM_VMALLOC from af_packet.c.
The PGV_FROM_VMALLOC definition was already removed by
commit 441c793a5650 ("net: cleanup unused macros in net directory"),
and its usage was removed even before by commit c56b4d90123b
("af_packet: remove pgv.flags"); but it was added back by mistake later on,
in commit f6fb8f100b80 ("af-packet: TPACKET_V3 flexible buffer implementation").
Signed-off-by: Rami Rosen <rami.rosen@intel.com>
When PACKET_QDISC_BYPASS is not used, Tx queue selection will be done
before the packet is enqueued, taking into account any mappings set by
a queuing discipline such as mqprio without hardware offloading. This
selection may be affected by a previously saved queue_mapping, either on
the Rx path, or done before the packet reaches the device, as it's
currently the case for AF_PACKET.
In order for queue selection to work as expected when using traffic
control, there can't be another selection done before that point is
reached, so move the call to packet_pick_tx_queue to
packet_direct_xmit, leaving the default xmit path as it was before
PACKET_QDISC_BYPASS was introduced.
A forward declaration of packet_pick_tx_queue() is introduced to avoid
the need to reorder the functions within the file.
Fixes: d346a3fae3ff ("packet: introduce PACKET_QDISC_BYPASS socket option")
Signed-off-by: Iván Briano <ivan.briano@intel.com>
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
situations.
This patch uses refcount_inc_not_zero() instead of
atomic_inc_not_zero_hint() due to absense of a _hint()
version of refcount API. If the hint() version must
be used, we might need to revisit API.
situations.
This patch removes unneeded forward declaration of tpacket_snd()
in net/packet/af_packet.c.
This patch removes unused parameter from prb_curr_blk_in_use() method
When using a TX ring buffer, if an error occurs processing a control
message (e.g. invalid message), the net_device reference is not
released.
Fixes c14ac9451c348 ("sock: enable timestamping using control messages")
Signed-off-by: Douglas Caetano dos Santos <douglascs@taghos.com.br>
In the case getsockopt() is called with PACKET_HDRLEN and optlen < 4
|val| remains uninitialized and the syscall may behave differently
depending on its value, and even copy garbage to userspace on certain
architectures. To fix this we now return -EINVAL if optlen is too small.
This bug has been detected with KMSAN.
Signed-off-by: Alexander Potapenko <glider@google.com>
Fanout uses a per net global namespace. A process that intends to create
a new fanout group can accidentally join an existing group. It is not
possible to detect this.
Add socket option PACKET_FANOUT_FLAG_UNIQUEID. When specified the
supplied fanout group id must be set to 0, and the kernel chooses an id
that is not already in use. This is an ephemeral flag so that
other sockets can be added to this group using setsockopt, but NOT
specifying this flag. The current getsockopt(..., PACKET_FANOUT, ...)
can be used to retrieve the new group id.
We assume that there are not a lot of fanout groups and that this is not
a high frequency call.
The method assigns ids starting at zero and increases until it finds an
unused id. It keeps track of the last assigned id, and uses it as a
starting point to find new ids.
When calculating po->tp_hdrlen + po->tp_reserve the result can overflow.
Fix by checking that tp_reserve <= INT_MAX on assign.
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
can overflow.
Add a check that tp_block_size * tp_block_nr <= UINT_MAX.
Since frames_per_block <= tp_block_size, the expression would
never overflow.
