path: root/net/phonet/Makefile
2008-10-05Phonet: implement GPRS virtual interface over PEP socketRémi Denis-Courmont
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-05Phonet: Pipe End Point for Phonet Pipes protocolRémi Denis-Courmont
This protocol provides some connection handling and negotiated congestion control. Nokia cellular modems use it for bulk transfers. It provides packet boundaries (hence SOCK_SEQPACKET). Congestion control is per packet rather per byte, so we do not re-use the generic socket memory accounting. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: proc interface for port rangeRemi Denis-Courmont
Phonet endpoints are bound to individual ports. This provides a /proc/sys/net/phonet (or sysctl) interface for selecting the range of automatically allocated ports (much like the ip_local_port_range with IPv4). Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: Phonet datagram transport protocolRemi Denis-Courmont
This provides the basic SOCK_DGRAM transport protocol for Phonet. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: common socket glueRemi Denis-Courmont
This provides the socket API for the Phonet protocols family. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: Netlink interfaceRemi Denis-Courmont
This provides support for configuring Phonet addresses, notifying Phonet configuration changes, and dumping the configuration. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: network device and address handlingRemi Denis-Courmont
This provides support for adding Phonet addresses to and removing Phonet addresses from network devices. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: add CONFIG_PHONETRemi Denis-Courmont
