path: root/net/phonet/af_phonet.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-17Phonet: missing rcu_dereference()Rémi Denis-Courmont
Reported-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13Phonet: put protocols array under RCURémi Denis-Courmont
2009-11-10Phonet: put sockets in a hash tableRémi Denis-Courmont
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-14Phonet: forward incoming packetsRémi Denis-Courmont
2009-10-14Phonet: route outgoing packetsRémi Denis-Courmont
2009-10-14Phonet: deliver broadcast packets to broadcast socketsRémi Denis-Courmont
2009-10-07net: mark net_proto_ops as constStephen Hemminger
All usages of structure net_proto_ops should be declared const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24Phonet: error on broadcast sending (unimplemented)Rémi Denis-Courmont
If we ever implement this, then we can stop returning an error. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-10net: convert usage of packet_type to read_mostlyStephen Hemminger
Protocols that use packet_type can be __read_mostly section for better locality. Elminate any unnecessary initializations of NULL. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-01net: replace uses of __constant_{endian}Harvey Harrison
Base versions handle constant folding now. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-26Phonet: allow phonet_device_init() to fail, put it to __init sectionremi.denis-courmont@nokia
2009-01-26Phonet: check destination before delivering packets locallyremi.denis-courmont@nokia
2008-12-03Phonet: basic net namespace supportRémi Denis-Courmont
2008-11-19phonet: fix compilation with gcc-3.4Alexey Dobriyan
CC [M] net/phonet/af_phonet.o net/phonet/af_phonet.c: In function `pn_socket_create': net/phonet/af_phonet.c:38: sorry, unimplemented: inlining failed in call to 'phonet_proto_put': function body not available net/phonet/af_phonet.c:99: sorry, unimplemented: called from here make[3]: *** [net/phonet/af_phonet.o] Error 1 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-16Phonet: refuse to send bigger than MTU packetsRémi Denis-Courmont
2008-10-26Phonet: do not reply to indication reset packetsRemi Denis-Courmont
This fixes a potential error packet loop. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-16net: Remove CONFIG_KMOD from net/ (towards removing CONFIG_KMOD entirely)Johannes Berg
Some code here depends on CONFIG_KMOD to not try to load protocol modules or similar, replace by CONFIG_MODULES where more than just request_module depends on CONFIG_KMOD and and also use try_then_request_module in ebtables. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-05Phonet: Pipe End Point for Phonet Pipes protocolRémi Denis-Courmont
This protocol provides some connection handling and negotiated congestion control. Nokia cellular modems use it for bulk transfers. It provides packet boundaries (hence SOCK_SEQPACKET). Congestion control is per packet rather per byte, so we do not re-use the generic socket memory accounting. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-05Phonet: modules auto-loading supportRémi Denis-Courmont
2008-09-22Phonet: emit errors when a packet cannot be delivered locallyRemi Denis-Courmont
When there is no listener socket for a received packet, send an error back to the sender. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: proc interface for port rangeRemi Denis-Courmont
Phonet endpoints are bound to individual ports. This provides a /proc/sys/net/phonet (or sysctl) interface for selecting the range of automatically allocated ports (much like the ip_local_port_range with IPv4). Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: provide MAC header operationsRemi Denis-Courmont
2008-09-22Phonet: Phonet datagram transport protocolRemi Denis-Courmont
This provides the basic SOCK_DGRAM transport protocol for Phonet. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: common socket glueRemi Denis-Courmont
This provides the socket API for the Phonet protocols family. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: Netlink interfaceRemi Denis-Courmont
This provides support for configuring Phonet addresses, notifying Phonet configuration changes, and dumping the configuration. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: network device and address handlingRemi Denis-Courmont
This provides support for adding Phonet addresses to and removing Phonet addresses from network devices. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: PF_PHONET protocol family supportRemi Denis-Courmont
This is the basis for the Phonet protocol families, and introduces the ETH_P_PHONET packet type and the PF_PHONET socket family. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
