path: root/net/phonet/pn_dev.c
2010-04-26phonet: use phonet_pernet instead of directly net_genericJiri Pirko
As in for example pppoe introduce phonet_pernet and use it instead of calling net_generic directly. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-15phonet: use for_each_set_bit()Akinobu Mita
Replace open-coded loop with for_each_set_bit(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-17net: spread __net_init, __net_exitAlexey Dobriyan
__net_init/__net_exit are apparently not going away, so use them to full extent. In some cases __net_init was removed, because it was called from __net_exit code. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-01net: Simplify phonet pernet operations.Eric W. Biederman
Take advantage of the new pernet automatic storage management, and stop using compatibility network namespace functions. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18Phonet: convert devices list to RCURémi Denis-Courmont
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18netns: net_identifiers should be read_mostlyEric Dumazet
Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-13Phonet: convert routing table to RCURémi Denis-Courmont
2009-10-14Phonet: routing table Netlink interfaceRémi Denis-Courmont
2009-10-14Phonet: routing table backendRémi Denis-Courmont
The Phonet "universe" only has 64 addresses, so we keep a trivial flat routing table. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14Phonet: Netlink event for autoconfigured addressesRémi Denis-Courmont
From: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-11Phonet: back-end for autoconfigured addressesRémi Denis-Courmont
In some cases, the network device driver knows what layer-3 address the device should have. This adds support for the Phonet stack to automatically request from the driver and add that address to the network device. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-27phonet: phonet_device_get() fixEric Dumazet
net/phonet/pn_dev.c: In function `phonet_device_get': net/phonet/pn_dev.c:99: warning: 'dev' might be used uninitialized in this function Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-26phonet: Fix build.David S. Miller
As reported by Oliver Hartkopp: net/phonet/pn_dev.c: In function ‘phonet_init_net’: net/phonet/pn_dev.c:221: error: implicit declaration of function ‘proc_net_fops_create’ net/phonet/pn_dev.c: In function ‘phonet_exit_net’: net/phonet/pn_dev.c:242: error: implicit declaration of function ‘proc_net_remove’ Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-23Phonet: sockets list through proc_fsRémi Denis-Courmont
This provides a list of sockets with their Phonet bind addresses and some socket debug informations through /proc/net/phonet. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25Phonet: generate Netlink RTM_DELADDR when destroying a deviceRémi Denis-Courmont
Netlink address deletion events were not sent when a network device vanished neither when Phonet was unloaded. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-26Phonet: use per-namespace devices listremi.denis-courmont@nokia
2009-01-26Phonet: remove useless locking in device cleanupremi.denis-courmont@nokia
Incoming packets and sockets are already gone. The netdevice notifier is unregistered under the RTNL lock There remains a race with the rtnetlink handlers unregistration, but it is a generic RTNL issue that was already present before this change. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-26Phonet: handle rtnetlink registration failureremi.denis-courmont@nokia
2009-01-26Phonet: allow phonet_device_init() to fail, put it to __init sectionremi.denis-courmont@nokia
2008-12-03Phonet: basic net namespace supportRémi Denis-Courmont
2008-11-26Phonet: fix oops in phonet_address_del() on non-Phonet deviceRémi Denis-Courmont
A NULL dereference would occur when trying to delete an addres from a network device that does not have any Phonet address. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: network device and address handlingRemi Denis-Courmont
This provides support for adding Phonet addresses to and removing Phonet addresses from network devices. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
