path: root/net/phonet
2014-06-26net: Use netlink_ns_capable to verify the permisions of netlink messagesEric W. Biederman
[ Upstream commit 90f62cf30a78721641e08737bda787552428061e ] It is possible by passing a netlink socket to a more privileged executable and then to fool that executable into writing to the socket data that happens to be valid netlink message to do something that privileged executable did not intend to do. To keep this from happening replace bare capable and ns_capable calls with netlink_capable, netlink_net_calls and netlink_ns_capable calls. Which act the same as the previous calls except they verify that the opener of the socket had the desired permissions as well. Reported-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-08inet: prevent leakage of uninitialized memory to user in recv syscallsHannes Frederic Sowa
[ Upstream commit bceaa90240b6019ed73b49965eac7d167610be69 ] Only update *addr_len when we actually fill in sockaddr, otherwise we can return uninitialized memory from the stack to the caller in the recvfrom, recvmmsg and recvmsg syscalls. Drop the the (addr_len == NULL) checks because we only get called with a valid addr_len pointer either from sock_common_recvmsg or inet_recvmsg. If a blocking read waits on a socket which is concurrently shut down we now return zero and set msg_msgnamelen to 0. Reported-by: mpb <mpb.mail@gmail.com> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-22rtnetlink: Remove passing of attributes into rtnl_doit functionsThomas Graf
With decnet converted, we can finally get rid of rta_buf and its computations around it. It also gets rid of the minimal header length verification since all message handlers do that explicitly anyway. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-18net: proc: change proc_net_remove to remove_proc_entryGao feng
proc_net_remove is only used to remove proc entries that under /proc/net,it's not a general function for removing proc entries of netns. if we want to remove some proc entries which under /proc/net/stat/, we still need to call remove_proc_entry. this patch use remove_proc_entry to replace proc_net_remove. we can remove proc_net_remove after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18net: proc: change proc_net_fops_create to proc_createGao feng
Right now, some modules such as bonding use proc_create to create proc entries under /proc/net/, and other modules such as ipv4 use proc_net_fops_create. It looks a little chaos.this patch changes all of proc_net_fops_create to proc_create. we can remove proc_net_fops_create after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-11-18net: Push capable(CAP_NET_ADMIN) into the rtnl methodsEric W. Biederman
- In rtnetlink_rcv_msg convert the capable(CAP_NET_ADMIN) check to ns_capable(net->user-ns, CAP_NET_ADMIN). Allowing unprivileged users to make netlink calls to modify their local network namespace. - In the rtnetlink doit methods add capable(CAP_NET_ADMIN) so that calls that are not safe for unprivileged users are still protected. Later patches will remove the extra capable calls from methods that are safe for unprivilged users. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-09-10netlink: Rename pid to portid to avoid confusionEric W. Biederman
It is a frequent mistake to confuse the netlink port identifier with a process identifier. Try to reduce this confusion by renaming fields that hold port identifiers portid instead of pid. I have carefully avoided changing the structures exported to userspace to avoid changing the userspace API. I have successfully built an allyesconfig kernel with this change. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-14userns: Print out socket uids in a user namespace aware fashion.Eric W. Biederman
Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: James Morris <jmorris@namei.org> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Sridhar Samudrala <sri@us.ibm.com> Acked-by: Vlad Yasevich <vyasevich@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-06-17net: remove my future former mail addressRémi Denis-Courmont
Signed-off-by: Rémi Denis-Courmont <remi@remlab.net> Cc: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Convert all sysctl registrations to register_net_sysctlEric W. Biederman
This results in code with less boiler plate that is a bit easier to read. Additionally stops us from using compatibility code in the sysctl core, hastening the day when the compatibility code can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Move all of the network sysctls without a namespace into init_net.Eric W. Biederman
This makes it clearer which sysctls are relative to your current network namespace. This makes it a little less error prone by not exposing sysctls for the initial network namespace in other namespaces. This is the same way we handle all of our other network interfaces to userspace and I can't honestly remember why we didn't do this for sysctls right from the start. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-13Phonet: missing headers (sparse)Rémi Denis-Courmont
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-13Phonet: phonet_net_id can be static (sparse)Rémi Denis-Courmont
2012-04-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Pull in the 'net' tree to get CAIF bug fixes upon which the following set of CAIF feature patches depend. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-13phonet: Sort out initiailziation and cleanup code.Eric W. Biederman
Recently an oops was reported in phonet if there was a failure during network namespace creation. [ 163.733755] ------------[ cut here ]------------ [ 163.734501] kernel BUG at include/net/netns/generic.h:45! [ 163.734501] invalid opcode: 0000 [#1] PREEMPT SMP [ 163.734501] CPU 2 [ 163.734501] Pid: 19145, comm: trinity Tainted: G W 3.4.0-rc1-next-20120405-sasha-dirty #57 [ 163.734501] RIP: 0010:[<ffffffff824d6062>] [<ffffffff824d6062>] phonet_pernet+0x182/0x1a0 [ 163.734501] RSP: 0018:ffff8800674d5ca8 EFLAGS: 00010246 [ 163.734501] RAX: 000000003fffffff RBX: 0000000000000000 RCX: ffff8800678c88d8 [ 163.734501] RDX: 00000000003f4000 RSI: ffff8800678c8910 RDI: 0000000000000282 [ 163.734501] RBP: ffff8800674d5cc8 R08: 0000000000000000 R09: 0000000000000000 [ 163.734501] R10: 0000000000000000 R11: 0000000000000000 R12: ffff880068bec920 [ 163.734501] R13: ffffffff836b90c0 R14: 0000000000000000 R15: 0000000000000000 [ 163.734501] FS: 00007f055e8de700(0000) GS:ffff88007d000000(0000) knlGS:0000000000000000 [ 163.734501] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 163.734501] CR2: 00007f055e6bb518 CR3: 0000000070c16000 CR4: 00000000000406e0 [ 163.734501] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 163.734501] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 163.734501] Process trinity (pid: 19145, threadinfo ffff8800674d4000, task ffff8800678c8000) [ 163.734501] Stack: [ 163.734501] ffffffff824d5f00 ffffffff810e2ec1 ffff880067ae0000 00000000ffffffd4 [ 163.734501] ffff8800674d5cf8 ffffffff824d667a ffff880067ae0000 00000000ffffffd4 [ 163.734501] ffffffff836b90c0 0000000000000000 ffff8800674d5d18 ffffffff824d707d [ 163.734501] Call Trace: [ 163.734501] [<ffffffff824d5f00>] ? phonet_pernet+0x20/0x1a0 [ 163.734501] [<ffffffff810e2ec1>] ? get_parent_ip+0x11/0x50 [ 163.734501] [<ffffffff824d667a>] phonet_device_destroy+0x1a/0x100 [ 163.734501] [<ffffffff824d707d>] phonet_device_notify+0x3d/0x50 [ 163.734501] [<ffffffff810dd96e>] notifier_call_chain+0xee/0x130 [ 163.734501] [<ffffffff810dd9d1>] raw_notifier_call_chain+0x11/0x20 [ 163.734501] [<ffffffff821cce12>] call_netdevice_notifiers+0x52/0x60 [ 163.734501] [<ffffffff821cd235>] rollback_registered_many+0x185/0x270 [ 163.734501] [<ffffffff821cd334>] unregister_netdevice_many+0x14/0x60 [ 163.734501] [<ffffffff823123e3>] ipip_exit_net+0x1b3/0x1d0 [ 163.734501] [<ffffffff82312230>] ? ipip_rcv+0x420/0x420 [ 163.734501] [<ffffffff821c8515>] ops_exit_list+0x35/0x70 [ 163.734501] [<ffffffff821c911b>] setup_net+0xab/0xe0 [ 163.734501] [<ffffffff821c9416>] copy_net_ns+0x76/0x100 [ 163.734501] [<ffffffff810dc92b>] create_new_namespaces+0xfb/0x190 [ 163.734501] [<ffffffff810dca21>] unshare_nsproxy_namespaces+0x61/0x80 [ 163.734501] [<ffffffff810afd1f>] sys_unshare+0xff/0x290 [ 163.734501] [<ffffffff8187622e>] ? trace_hardirqs_on_thunk+0x3a/0x3f [ 163.734501] [<ffffffff82665539>] system_call_fastpath+0x16/0x1b [ 163.734501] Code: e0 c3 fe 66 0f 1f 44 00 00 48 c7 c2 40 60 4d 82 be 01 00 00 00 48 c7 c7 80 d1 23 83 e8 48 2a c4 fe e8 73 06 c8 fe 48 85 db 75 0e <0f> 0b 0f 1f 40 00 eb fe 66 0f 1f 44 00 00 48 83 c4 10 48 89 d8 [ 163.734501] RIP [<ffffffff824d6062>] phonet_pernet+0x182/0x1a0 [ 163.734501] RSP <ffff8800674d5ca8> [ 163.861289] ---[ end trace fb5615826c548066 ]--- After investigation it turns out there were two issues. 1) Phonet was not implementing network devices but was using register_pernet_device instead of register_pernet_subsys. This was allowing there to be cases when phonenet was not initialized and the phonet net_generic was not set for a network namespace when network device events were being reported on the netdevice_notifier for a network namespace leading to the oops above. 2) phonet_exit_net was implementing a confusing and special case of handling all network devices from going away that it was hard to see was correct, and would only occur when the phonet module was removed. Now that unregister_netdevice_notifier has been modified to synthesize unregistration events for the network devices that are extant when called this confusing special case in phonet_exit_net is no longer needed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
2012-04-05phonet: Check input from user before allocatingSasha Levin
A phonet packet is limited to USHRT_MAX bytes, this is never checked during tx which means that the user can specify any size he wishes, and the kernel will attempt to allocate that size. In the good case, it'll lead to the following warning, but it may also cause the kernel to kick in the OOM and kill a random task on the server. [ 8921.744094] WARNING: at mm/page_alloc.c:2255 __alloc_pages_slowpath+0x65/0x730() [ 8921.749770] Pid: 5081, comm: trinity Tainted: G W 3.4.0-rc1-next-20120402-sasha #46 [ 8921.756672] Call Trace: [ 8921.758185] [<ffffffff810b2ba7>] warn_slowpath_common+0x87/0xb0 [ 8921.762868] [<ffffffff810b2be5>] warn_slowpath_null+0x15/0x20 [ 8921.765399] [<ffffffff8117eae5>] __alloc_pages_slowpath+0x65/0x730 [ 8921.769226] [<ffffffff81179c8a>] ? zone_watermark_ok+0x1a/0x20 [ 8921.771686] [<ffffffff8117d045>] ? get_page_from_freelist+0x625/0x660 [ 8921.773919] [<ffffffff8117f3a8>] __alloc_pages_nodemask+0x1f8/0x240 [ 8921.776248] [<ffffffff811c03e0>] kmalloc_large_node+0x70/0xc0 [ 8921.778294] [<ffffffff811c4bd4>] __kmalloc_node_track_caller+0x34/0x1c0 [ 8921.780847] [<ffffffff821b0e3c>] ? sock_alloc_send_pskb+0xbc/0x260 [ 8921.783179] [<ffffffff821b3c65>] __alloc_skb+0x75/0x170 [ 8921.784971] [<ffffffff821b0e3c>] sock_alloc_send_pskb+0xbc/0x260 [ 8921.787111] [<ffffffff821b002e>] ? release_sock+0x7e/0x90 [ 8921.788973] [<ffffffff821b0ff0>] sock_alloc_send_skb+0x10/0x20 [ 8921.791052] [<ffffffff824cfc20>] pep_sendmsg+0x60/0x380 [ 8921.792931] [<ffffffff824cb4a6>] ? pn_socket_bind+0x156/0x180 [ 8921.794917] [<ffffffff824cb50f>] ? pn_socket_autobind+0x3f/0x90 [ 8921.797053] [<ffffffff824cb63f>] pn_socket_sendmsg+0x4f/0x70 [ 8921.798992] [<ffffffff821ab8e7>] sock_aio_write+0x187/0x1b0 [ 8921.801395] [<ffffffff810e325e>] ? sub_preempt_count+0xae/0xf0 [ 8921.803501] [<ffffffff8111842c>] ? __lock_acquire+0x42c/0x4b0 [ 8921.805505] [<ffffffff821ab760>] ? __sock_recv_ts_and_drops+0x140/0x140 [ 8921.807860] [<ffffffff811e07cc>] do_sync_readv_writev+0xbc/0x110 [ 8921.809986] [<ffffffff811958e7>] ? might_fault+0x97/0xa0 [ 8921.811998] [<ffffffff817bd99e>] ? security_file_permission+0x1e/0x90 [ 8921.814595] [<ffffffff811e17e2>] do_readv_writev+0xe2/0x1e0 [ 8921.816702] [<ffffffff810b8dac>] ? do_setitimer+0x1ac/0x200 [ 8921.818819] [<ffffffff810e2ec1>] ? get_parent_ip+0x11/0x50 [ 8921.820863] [<ffffffff810e325e>] ? sub_preempt_count+0xae/0xf0 [ 8921.823318] [<ffffffff811e1926>] vfs_writev+0x46/0x60 [ 8921.825219] [<ffffffff811e1a3f>] sys_writev+0x4f/0xb0 [ 8921.827127] [<ffffffff82658039>] system_call_fastpath+0x16/0x1b [ 8921.829384] ---[ end trace dffe390f30db9eb7 ]--- Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-01phonet: Stop using NLA_PUT*().David S. Miller
These macros contain a hidden goto, and are thus extremely error prone and make code hard to audit. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-12net: reintroduce missing rcu_assign_pointer() callsEric Dumazet
commit a9b3cd7f32 (rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTER) did a lot of incorrect changes, since it did a complete conversion of rcu_assign_pointer(x, y) to RCU_INIT_POINTER(x, y). We miss needed barriers, even on x86, when y is not NULL. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Stephen Hemminger <shemminger@vyatta.com> CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-18Phonet: set the pipe handle using setsockoptDinesh Kumar Sharma
This provides flexibility to set the pipe handle using setsockopt. The pipe can be enabled (if disabled) later using ioctl. Signed-off-by: Hemant Ramdasi <hemant.ramdasi@stericsson.com> Signed-off-by: Dinesh Kumar Sharma <dinesh.sharma@stericsson.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31net: Fix files explicitly needing to include module.hPaul Gortmaker
With calls to modular infrastructure, these files really needs the full module.h header. Call it out so some of the cleanups of implicit and unrequired includes elsewhere can be cleaned up. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-08-02rcu: convert uses of rcu_assign_pointer(x, NULL) to RCU_INIT_POINTERStephen Hemminger
When assigning a NULL value to an RCU protected pointer, no barrier is needed. The rcu_assign_pointer, used to handle that but will soon change to not handle the special case. Convert all rcu_assign_pointer of NULL value. //smpl @@ expression P; @@ - rcu_assign_pointer(P, NULL) + RCU_INIT_POINTER(P, NULL) // </smpl> Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-09rtnetlink: Compute and store minimum ifinfo dump sizeGreg Rose
The message size allocated for rtnl ifinfo dumps was limited to a single page. This is not enough for additional interface info available with devices that support SR-IOV and caused a bug in which VF info would not be displayed if more than approximately 40 VFs were created per interface. Implement a new function pointer for the rtnl_register service that will calculate the amount of data required for the ifinfo dump and allocate enough data to satisfy the request. Signed-off-by: Greg Rose <gregory.v.rose@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-05-24net: convert %p usage to %pKDan Rosenberg
The %pK format specifier is designed to hide exposed kernel pointers, specifically via /proc interfaces. Exposing these pointers provides an easy target for kernel write vulnerabilities, since they reveal the locations of writable structures containing easily triggerable function pointers. The behavior of %pK depends on the kptr_restrict sysctl. If kptr_restrict is set to 0, no deviation from the standard %p behavior occurs. If kptr_restrict is set to 1, the default, if the current user (intended to be a reader via seq_printf(), etc.) does not have CAP_SYSLOG (currently in the LSM tree), kernel pointers using %pK are printed as 0's. If kptr_restrict is set to 2, kernel pointers using %pK are printed as 0's regardless of privileges. Replacing with 0's was chosen over the default "(null)", which cannot be parsed by userland %p, which expects "(nil)". The supporting code for kptr_restrict and %pK are currently in the -mm tree. This patch converts users of %p in net/ to %pK. Cases of printing pointers to the syslog are not covered, since this would eliminate useful information for postmortem debugging and the reading of the syslog is already optionally protected by the dmesg_restrict sysctl. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: James Morris <jmorris@namei.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Thomas Graf <tgraf@infradead.org> Cc: Eugene Teo <eugeneteo@kernel.org> Cc: Kees Cook <kees.cook@canonical.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David S. Miller <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Eric Paris <eparis@parisplace.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1446 commits) macvlan: fix panic if lowerdev in a bond tg3: Add braces around 5906 workaround. tg3: Fix NETIF_F_LOOPBACK error macvlan: remove one synchronize_rcu() call networking: NET_CLS_ROUTE4 depends on INET irda: Fix error propagation in ircomm_lmp_connect_response() irda: Kill set but unused variable 'bytes' in irlan_check_command_param() irda: Kill set but unused variable 'clen' in ircomm_connect_indication() rxrpc: Fix set but unused variable 'usage' in rxrpc_get_transport() be2net: Kill set but unused variable 'req' in lancer_fw_download() irda: Kill set but unused vars 'saddr' and 'daddr' in irlan_provider_connect_indication() atl1c: atl1c_resume() is only used when CONFIG_PM_SLEEP is defined. rxrpc: Fix set but unused variable 'usage' in rxrpc_get_peer(). rxrpc: Kill set but unused variable 'local' in rxrpc_UDP_error_handler() rxrpc: Kill set but unused variable 'sp' in rxrpc_process_connection() rxrpc: Kill set but unused variable 'sp' in rxrpc_rotate_tx_window() pkt_sched: Kill set but unused variable 'protocol' in tc_classify() isdn: capi: Use pr_debug() instead of ifdefs. tg3: Update version to 3.119 tg3: Apply rx_discards fix to 5719/5720 ... Fix up trivial conflicts in arch/x86/Kconfig and net/mac80211/agg-tx.c as per Davem.
2011-05-07net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu()Lai Jiangshan
The rcu callback phonet_device_rcu_free() just calls a kfree(), so we use kfree_rcu() instead of the call_rcu(phonet_device_rcu_free). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-02net: dont hold rtnl mutex during netlink dump callbacksEric Dumazet
Four years ago, Patrick made a change to hold rtnl mutex during netlink dump callbacks. I believe it was a wrong move. This slows down concurrent dumps, making good old /proc/net/ files faster than rtnetlink in some situations. This occurred to me because one "ip link show dev ..." was _very_ slow on a workload adding/removing network devices in background. All dump callbacks are able to use RCU locking now, so this patch does roughly a revert of commits : 1c2d670f366 : [RTNETLINK]: Hold rtnl_mutex during netlink dump callbacks 6313c1e0992 : [RTNETLINK]: Remove unnecessary locking in dump callbacks This let writers fight for rtnl mutex and readers going full speed. It also takes care of phonet : phonet_route_get() is now called from rcu read section. I renamed it to phonet_route_get_rcu() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14Phonet: convert bound sockets hash list to RCURémi Denis-Courmont
This gets rid of the last spinlock in the Phonet stack proper. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-15Phonet: fix aligned-mode pipe socket buffer header reserveRémi Denis-Courmont
When the pipe uses aligned-mode data packets, we must reserve 4 bytes instead of 3 for the pipe protocol header. Otherwise the Phonet header would not be aligned, resulting in potentially corrupted headers with later unaligned memory writes. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: kill the ST-Ericsson pipe controller KconfigRémi Denis-Courmont
This is now a run-time choice so that a single kernel can support both old and new generation ISI modems. Support for manually enabling the pipe flow is removed as it did not work properly, does not fit well with the socket API, and I am not aware of any use at the moment. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: support active connection without pipe controller on modemRémi Denis-Courmont
This provides support for newer ISI modems with no need for the earlier experimental compile-time alternative choice. With this, we can now use the same kernel and userspace with both types of modems. This also avoids confusing two different and incompatible state machines, actively connected vs accepted sockets, and adds connection response error handling (processing "SYN/RST" of sorts). Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: provide pipe socket option to retrieve the pipe identifierRémi Denis-Courmont
User-space sometimes needs this information. In particular, the GPRS context or the AT commands pipe setups may use the pipe handle as a reference. This removes the settable pipe handle with CONFIG_PHONET_PIPECTRLR. It did not handle error cases correctly. Furthermore, the kernel *could* implement a smart scheme for allocating handles (if ever needed), but userspace really cannot. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: allocate sock from accept syscall rather than soft IRQRémi Denis-Courmont
This moves most of the accept logic to process context like other socket stacks do. Then we can use a few more common socket helpers and simplify a bit. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: factor common code to send control messagesRémi Denis-Courmont
With the addition of the pipe controller, there is now quite a bit of repetitive code for small signaling messages. Lets factor it. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: correct pipe backlog callback return valuesRémi Denis-Courmont
In some cases, the Phonet pipe backlog callbacks returned negative errno instead of NET_RX_* values. In other cases, NET_RX_DROP was returned for invalid packets, even though it seems only intended for buffering problems (not for deliberately discarded packets). Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: return an error when packet TX failsRémi Denis-Courmont
Phonet assumes that packets are never dropped. We try our best to avoid this situation. But lets return ENOBUFS if queueing to the network device fails so that the caller knows things went wrong. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: fix NULL dereference on TX path with implicit sourceRémi Denis-Courmont
The previous Phonet patch series introduced per-socket implicit destination (i.e. connect()). In that case, the destination socket address is NULL in the transmit function. However commit a8059512b120362b15424f152b2548fe8b11bd0c ("Phonet: implement per-socket destination/peer address") is incomplete and would trigger a NULL dereference. (Fortunately, the code is not in released kernel, and in fact currently not reachable.) Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-25phonet: Protect pipe_do_remove() with appropriate ifdefs.David S. Miller
It is only used when CONFIG_PHONET_PIPECTRLR is not set. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-25Phonet: fix flawed "SYN/ACK" logicRémi Denis-Courmont
* Do not fail if the peer supports more or less than 3 algorithms. * Ignore unknown congestion control algorithms instead of failing. * Simplify congestion algorithm negotiation (largest is best). * Do not use a static buffer. * Fix off-by-two read overflow. * Avoid extra memory copy (in addition to skb_copy_bits()). The previous code really made no sense. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-25Phonet: don't bother with transaction IDs (especially for indications)Rémi Denis-Courmont
2011-02-25Phonet: remove redumdant pep->pipe_stateRémi Denis-Courmont
sk->sk_state already contains the pipe state. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-25Phonet: use socket destination in pipe protocolRémi Denis-Courmont
2011-02-25Phonet: implement per-socket destination/peer addressRémi Denis-Courmont
2011-02-25Phonet: allow multiple listen() and fix small race conditionRémi Denis-Courmont
2011-01-10phonet: some signedness bugsDan Carpenter
Dan Rosenberg pointed out that there were some signed comparison bugs in the phonet protocol. http://marc.info/?l=full-disclosure&m=129424528425330&w=2 The problem is that we check for array overflows but "protocol" is signed and we don't check for array underflows. If you have already have CAP_SYS_ADMIN then you could use the bugs to get root, or someone could cause an oops by mistake. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-11-22Net: phonet: Makefile: Remove deprecated kbuild goal definitionsTracey Dent
Changed Makefile to use <modules>-y instead of <modules>-objs because -objs is deprecated and not mentioned in Documentation/kbuild/makefiles.txt. Signed-off-by: Tracey Dent <tdent48227@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-20phonet: remove the unused variable pnChangli Gao
Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
