path: root/net/rds/iw.h
2009-10-30RDS/IB+IW: Move recv processing to a taskletAndy Grover
Move receive processing from event handler to a tasklet. This should help prevent hangcheck timer from going off when RDS is under heavy load. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-20RDS/IW: Remove page_shift variable from iwarp transportAndy Grover
The existing code treated page_shift as a variable, when in fact we always want to have the fastreg page size be the same as the arch's page size -- and it is, so this doesn't need to be a variable. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-09RDS/IW+IB: Allow max credit advertise window.Steve Wise
Fix hack that restricts the credit advertisement to 127. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-02RDS: Use spinlock to protect 64b value update on 32b archsAndy Grover
We have a 64bit value that needs to be set atomically. This is easy and quick on all 64bit archs, and can also be done on x86/32 with set_64bit() (uses cmpxchg8b). However other 32b archs don't have this. I actually changed this to the current state in preparation for mainline because the old way (using a spinlock on 32b) resulted in unsightly #ifdefs in the code. But obviously, being correct takes precedence. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-02RDS: Rewrite connection cleanup, fixing oops on rmmodAndy Grover
This fixes a bug where a connection was unexpectedly not on *any* list while being destroyed. It also cleans up some code duplication and regularizes some function names. * Grab appropriate lock in conn_free() and explain in comment * Ensure via locking that a conn is never not on either a dev's list or the nodev list * Add rds_xx_remove_conn() to match rds_xx_add_conn() * Make rds_xx_add_conn() return void * Rename remove_{,nodev_}conns() to destroy_{,nodev_}conns() and unify their implementation in a helper function * Document lock ordering as nodev conn_lock before dev_conn_lock Reported-by: Yosef Etigin <yosefe@voltaire.com> Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-26RDS: Add iWARP supportAndy Grover
Support for iWARP NICs is implemented as a separate RDS transport from IB. The code, however, is very similar to IB (it was forked, basically.) so let's keep it in one changeset. The reason for this duplicationis that despite its similarity to IB, there are a number of places where it has different semantics. iwarp zcopy support is still under development, and giving it its own sandbox ensures that IB code isn't disrupted while iwarp changes. Over time these transports will re-converge. Signed-off-by: Andy Grover <andy.grover@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net>
