[ Upstream commit cb66ddd156203daefb8d71158036b27b0e2caf63 ]
When it is to cleanup net namespace, rds_tcp_exit_net() will call
rds_tcp_kill_sock(), if t_sock is NULL, it will not call
rds_conn_destroy(), rds_conn_path_destroy() and rds_tcp_conn_free() to free
connection, and the worker cp_conn_w is not stopped, afterwards the net is freed in
net_drop_ns(); While cp_conn_w rds_connect_worker() will call rds_tcp_conn_path_connect()
and reference 'net' which has already been freed.
In rds_tcp_conn_path_connect(), rds_tcp_set_callbacks() will set t_sock = sock before
sock->ops->connect, but if connect() is failed, it will call
rds_tcp_restore_callbacks() and set t_sock = NULL, if connect is always
failed, rds_connect_worker() will try to reconnect all the time, so
rds_tcp_kill_sock() will never to cancel worker cp_conn_w and free the
connections.
Therefore, the condition !tc->t_sock is not needed if it is going to do
cleanup_net->rds_tcp_exit_net->rds_tcp_kill_sock, because tc->t_sock is always
NULL, and there is on other path to cancel cp_conn_w and free
connection. So this patch is to fix this.
rds_tcp_kill_sock():
if (net != c_net || !tc->t_sock)
Acked-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
BUG: KASAN: use-after-free in inet_create+0xbcc/0xd28
net/ipv4/af_inet.c:340
Read of size 4 at addr ffff8003496a4684 by task kworker/u8:4/3721
CPU: 3 PID: 3721 Comm: kworker/u8:4 Not tainted 5.1.0 #11
Hardware name: linux,dummy-virt (DT)
Workqueue: krdsd rds_connect_worker
Call trace:
dump_backtrace+0x0/0x3c0 arch/arm64/kernel/time.c:53
show_stack+0x28/0x38 arch/arm64/kernel/traps.c:152
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x120/0x188 lib/dump_stack.c:113
print_address_description+0x68/0x278 mm/kasan/report.c:253
kasan_report_error mm/kasan/report.c:351 [inline]
kasan_report+0x21c/0x348 mm/kasan/report.c:409
__asan_report_load4_noabort+0x30/0x40 mm/kasan/report.c:429
inet_create+0xbcc/0xd28 net/ipv4/af_inet.c:340
__sock_create+0x4f8/0x770 net/socket.c:1276
sock_create_kern+0x50/0x68 net/socket.c:1322
rds_tcp_conn_path_connect+0x2b4/0x690 net/rds/tcp_connect.c:114
rds_connect_worker+0x108/0x1d0 net/rds/threads.c:175
process_one_work+0x6e8/0x1700 kernel/workqueue.c:2153
worker_thread+0x3b0/0xdd0 kernel/workqueue.c:2296
kthread+0x2f0/0x378 kernel/kthread.c:255
ret_from_fork+0x10/0x18 arch/arm64/kernel/entry.S:1117
Allocated by task 687:
save_stack mm/kasan/kasan.c:448 [inline]
set_track mm/kasan/kasan.c:460 [inline]
kasan_kmalloc+0xd4/0x180 mm/kasan/kasan.c:553
kasan_slab_alloc+0x14/0x20 mm/kasan/kasan.c:490
slab_post_alloc_hook mm/slab.h:444 [inline]
slab_alloc_node mm/slub.c:2705 [inline]
slab_alloc mm/slub.c:2713 [inline]
kmem_cache_alloc+0x14c/0x388 mm/slub.c:2718
kmem_cache_zalloc include/linux/slab.h:697 [inline]
net_alloc net/core/net_namespace.c:384 [inline]
copy_net_ns+0xc4/0x2d0 net/core/net_namespace.c:424
create_new_namespaces+0x300/0x658 kernel/nsproxy.c:107
unshare_nsproxy_namespaces+0xa0/0x198 kernel/nsproxy.c:206
ksys_unshare+0x340/0x628 kernel/fork.c:2577
__do_sys_unshare kernel/fork.c:2645 [inline]
__se_sys_unshare kernel/fork.c:2643 [inline]
__arm64_sys_unshare+0x38/0x58 kernel/fork.c:2643
__invoke_syscall arch/arm64/kernel/syscall.c:35 [inline]
invoke_syscall arch/arm64/kernel/syscall.c:47 [inline]
el0_svc_common+0x168/0x390 arch/arm64/kernel/syscall.c:83
el0_svc_handler+0x60/0xd0 arch/arm64/kernel/syscall.c:129
el0_svc+0x8/0xc arch/arm64/kernel/entry.S:960
Freed by task 264:
__kasan_slab_free+0x114/0x220 mm/kasan/kasan.c:521
kasan_slab_free+0x10/0x18 mm/kasan/kasan.c:528
slab_free_hook mm/slub.c:1370 [inline]
slab_free_freelist_hook mm/slub.c:1397 [inline]
slab_free mm/slub.c:2952 [inline]
kmem_cache_free+0xb8/0x3a8 mm/slub.c:2968
net_free net/core/net_namespace.c:400 [inline]
net_drop_ns.part.6+0x78/0x90 net/core/net_namespace.c:407
net_drop_ns net/core/net_namespace.c:406 [inline]
cleanup_net+0x53c/0x6d8 net/core/net_namespace.c:569
The buggy address belongs to the object at ffff8003496a3f80
which belongs to the cache net_namespace of size 7872
The buggy address is located 1796 bytes inside of
7872-byte region [ffff8003496a3f80, ffff8003496a5e40)
The buggy address belongs to the page:
page:ffff7e000d25a800 count:1 mapcount:0 mapping:ffff80036ce4b000
index:0x0 compound_mapcount: 0
flags: 0xffffe0000008100(slab|head)
raw: 0ffffe0000008100 dead000000000100 dead000000000200 ffff80036ce4b000
raw: 0000000000000000 0000000080040004 00000001ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8003496a4580: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8003496a4600: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
>ffff8003496a4680: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8003496a4700: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8003496a4780: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
Fixes: 467fa15356ac("RDS-TCP: Support multiple RDS-TCP listen endpoints, one per netns.")
Signed-off-by: Mao Wenan <maowenan@huawei.com>
commit f10b4cff98c6977668434fbf5dd58695eeca2897 upstream.
The rds_tcp_kill_sock() function parses the rds_tcp_conn_list
to find the rds_connection entries marked for deletion as part
of the netns deletion under the protection of the rds_tcp_conn_lock.
Since the rds_tcp_conn_list tracks rds_tcp_connections (which
have a 1:1 mapping with rds_conn_path), multiple tc entries in
the rds_tcp_conn_list will map to a single rds_connection, and will
be deleted as part of the rds_conn_destroy() operation that is
done outside the rds_tcp_conn_lock.
The rds_tcp_conn_list traversal done under the protection of
rds_tcp_conn_lock should not leave any doomed tc entries in
the list after the rds_tcp_conn_lock is released, else another
concurrently executiong netns delete (for a differnt netns) thread
may trip on these entries.
Reported-by: syzbot <syzkaller@googlegroups.com>
Signed-off-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
[ Upstream commit b21dd4506b71bdb9c5a20e759255cd2513ea7ebe ]
Commit a93d01f5777e ("RDS: TCP: avoid bad page reference in
rds_tcp_listen_data_ready") added the function
rds_tcp_listen_sock_def_readable() to handle the case when a
partially set-up acceptor socket drops into rds_tcp_listen_data_ready().
However, if the listen socket (rtn->rds_tcp_listen_sock) is itself going
through a tear-down via rds_tcp_listen_stop(), the (*ready)() will be
null and we would hit a panic of the form
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: (null)
? rds_tcp_listen_data_ready+0x59/0xb0 [rds_tcp]
tcp_data_queue+0x39d/0x5b0
tcp_rcv_established+0x2e5/0x660
tcp_v4_do_rcv+0x122/0x220
tcp_v4_rcv+0x8b7/0x980
In the above case, it is not fatal to encounter a NULL value for
ready- we should just drop the packet and let the flush of the
acceptor thread finish gracefully.
In general, the tear-down sequence for listen() and accept() socket
that is ensured by this commit is:
rtn->rds_tcp_listen_sock = NULL; /* prevent any new accepts */
In rds_tcp_listen_stop():
serialize with, and prevent, further callbacks using lock_sock()
flush rds_wq
flush acceptor workq
sock_release(listen socket)
If some error is encountered in rds_tcp_init_net, make sure to
unregister_netdevice_notifier(), else we could trigger a panic
later on, when the modprobe from a netns fails.
Use RDS probe-ping to compute how many paths may be used with
the peer, and to synchronously start the multiple paths. If mprds is
supported, hash outgoing traffic to one of multiple paths in rds_sendmsg()
when multipath RDS is supported by the transport.
CC: Santosh Shilimkar <santosh.shilimkar@oracle.com>
Some code duplication in rds_tcp_reset_callbacks() can be avoided
by having the function call rds_tcp_restore_callbacks() and
rds_tcp_set_callbacks().
As the existing comments in rds_tcp_listen_data_ready() indicate,
it is possible under some race-windows to get to this function with the
accept() socket. If that happens, we could run into a sequence whereby
thread 1 thread 2
rds_tcp_accept_one() thread
sets up new_sock via ->accept().
The sk_user_data is now
sock_def_readable
data comes in for new_sock,
->sk_data_ready is called, and
we land in rds_tcp_listen_data_ready
takes the sk_callback_lock and
sets up sk_user_data to be the cp
read_lock sk_callback_lock
ready = cp
unlock sk_callback_lock
page fault on ready
In the above sequence, we end up with a panic on a bad page reference
when trying to execute (*ready)(). Instead we need to call
sock_def_readable() safely, which is what this patch achieves.
drivers/net/ethernet/mellanox/mlx5/core/en.h
drivers/net/ethernet/mellanox/mlx5/core/en_main.c
drivers/net/usb/r8152.c
All three conflicts were overlapping changes.
If register_pernet_subsys() fails, we shouldn't try to call
unregister_pernet_subsys().
Fixes: 467fa15356 ("RDS-TCP: Support multiple RDS-TCP listen endpoints, one per netns.")
Cc: stable@vger.kernel.org
Cc: Sowmini Varadhan <sowmini.varadhan@oracle.com>
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Acked-by: Sowmini Varadhan <sowmini.varadhan@oracle.com>
This patch adds ->conn_path_connect callbacks in the rds_transport
that are used to set up a single connection path.
The ->sk_user_data contains a pointer to the rds_conn_path
for the socket. Use this consistently in the rds_tcp_data_ready
callbacks to get the rds_conn_path for rds_recv_incoming.
The socket callbacks should all operate on a struct rds_conn_path,
in preparation for a MP capable RDS-TCP.
A single rds_connection may have multiple rds_conn_paths that have
to be carefully and correctly destroyed, for both rmmod and
netns-delete cases.
For both cases, we extract a single rds_tcp_connection for
each conn into a temporary list, and then invoke rds_conn_destroy()
which iteratively dismantles every path in the rds_connection.
For the netns deletion case, we additionally have to make sure
that we do not leave a socket in TIME_WAIT state, as this will
hold up the netns deletion. Thus we call rds_tcp_conn_paths_destroy()
to reset state quickly.
The struct rds_tcp_connection is the transport-specific private
data structure that tracks TCP information per rds_conn_path.
Modify this structure to have a back-pointer to the rds_conn_path
for which it is the ->cp_transport_data.
The c_passive bit is only intended for the IB transport and will
never be encountered in rds-tcp, so remove the dead logic that
predicates on this bit.
Refactor code to avoid separate indirections for single-path
and multipath transports. All transports (both single and mp-capable)
will get a pointer to the rds_conn_path, and can trivially derive
the rds_connection from the ->cp_conn.
Fixes the following sparse warnings:
net/rds/tcp.c:59:5: warning:
symbol 'rds_tcp_min_sndbuf' was not declared. Should it be static?
net/rds/tcp.c:60:5: warning:
symbol 'rds_tcp_min_rcvbuf' was not declared. Should it be static?
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
This commit changes rds_conn_shutdown to take a rds_conn_path *
argument, allowing it to shutdown paths other than c_path[0] for
MP-capable transports.
In preparation for multipath RDS, split the rds_connection
structure into a base structure, and a per-path struct rds_conn_path.
The base structure tracks information and locks common to all
paths. The workqs for send/recv/shutdown etc are tracked per
rds_conn_path. Thus the workq callbacks now work with rds_conn_path.
This commit allows for one rds_conn_path per rds_connection, and will
be extended into multiple conn_paths in subsequent commits.
The send path needs to be quiesced before resetting callbacks from
rds_tcp_accept_one(), and commit eb192840266f ("RDS:TCP: Synchronize
rds_tcp_accept_one with rds_send_xmit when resetting t_sock") achieves
this using the c_state and RDS_IN_XMIT bit following the pattern
used by rds_conn_shutdown(). However this leaves the possibility
of a race window as shown in the sequence below
take t_conn_lock in rds_tcp_conn_connect
send outgoing syn to peer
drop t_conn_lock in rds_tcp_conn_connect
incoming from peer triggers rds_tcp_accept_one, conn is
marked CONNECTING
wait for RDS_IN_XMIT to quiesce any rds_send_xmit threads
call rds_tcp_reset_callbacks
[.. race-window where incoming syn-ack can cause the conn
to be marked UP from rds_tcp_state_change ..]
lock_sock called from rds_tcp_reset_callbacks, and we set
t_sock to null
As soon as the conn is marked UP in the race-window above, rds_send_xmit()
threads will proceed to rds_tcp_xmit and may encounter a null-pointer
deref on the t_sock.
Given that rds_tcp_state_change() is invoked in softirq context, whereas
rds_tcp_reset_callbacks() is in workq context, and testing for RDS_IN_XMIT
after lock_sock could result in a deadlock with tcp_sendmsg, this
commit fixes the race by using a new c_state, RDS_TCP_RESETTING, which
will prevent a transition to RDS_CONN_UP from rds_tcp_state_change().
When we switch a connection's sockets in rds_tcp_rest_callbacks,
any partially sent datagram must be retransmitted on the new
socket so that the receiver can correctly reassmble the RDS
datagram. Use rds_send_reset() which is designed for this purpose.
When rds_tcp_accept_one() has to replace the existing tcp socket
with a newer tcp socket (duelling-syn resolution), it must lock_sock()
to suppress the rds_tcp_data_recv() path while callbacks are being
changed. Also, existing RDS datagram reassembly state must be reset,
so that the next datagram on the new socket does not have corrupted
state. Similarly when resetting the newly accepted socket, appropriate
locks and synchronization is needed.
This commit ensures correct synchronization by invoking
kernel_sock_shutdown to reset a newly accepted sock, and by taking
appropriate lock_sock()s (for old and new sockets) when resetting
existing callbacks.
An arbitration scheme for duelling SYNs is implemented as part of
commit 241b271952eb ("RDS-TCP: Reset tcp callbacks if re-using an
outgoing socket in rds_tcp_accept_one()") which ensures that both nodes
involved will arrive at the same arbitration decision. However, this
needs to be synchronized with an outgoing SYN to be generated by
rds_tcp_conn_connect(). This commit achieves the synchronization
through the t_conn_lock mutex in struct rds_tcp_connection.
The rds_conn_state is checked in rds_tcp_conn_connect() after acquiring
the t_conn_lock mutex. A SYN is sent out only if the RDS connection is
not already UP (an UP would indicate that rds_tcp_accept_one() has
completed 3WH, so no SYN needs to be generated).
Similarly, the rds_conn_state is checked in rds_tcp_accept_one() after
acquiring the t_conn_lock mutex. The only acceptable states (to
allow continuation of the arbitration logic) are UP (i.e., outgoing SYN
was SYN-ACKed by peer after it sent us the SYN) or CONNECTING (we sent
outgoing SYN before we saw incoming SYN).
There is a race condition between rds_send_xmit -> rds_tcp_xmit
and the code that deals with resolution of duelling syns added
by commit 241b271952eb ("RDS-TCP: Reset tcp callbacks if re-using an
outgoing socket in rds_tcp_accept_one()").
Specifically, we may end up derefencing a null pointer in rds_send_xmit
if we have the interleaving sequence:
rds_tcp_accept_one rds_send_xmit
conn is RDS_CONN_UP, so
invoke rds_tcp_xmit
tc = conn->c_transport_data
/* reset t_sock */
null ptr deref from tc->t_sock
The race condition can be avoided without adding the overhead of
additional locking in the xmit path: have rds_tcp_accept_one wait
for rds_tcp_xmit threads to complete before resetting callbacks.
The synchronization can be done in the same manner as rds_conn_shutdown().
First set the rds_conn_state to something other than RDS_CONN_UP
(so that new threads cannot get into rds_tcp_xmit()), then wait for
RDS_IN_XMIT to be cleared in the conn->c_flags indicating that any
threads in rds_tcp_xmit are done.
Fixes: 241b271952eb ("RDS-TCP: Reset tcp callbacks if re-using an
RDS_TCP_DEFAULT_BUFSIZE has been unused since commit 1edd6a14d24f
("RDS-TCP: Do not bloat sndbuf/rcvbuf in rds_tcp_tune").
Add per-net sysctl tunables to set the size of sndbuf and
rcvbuf on the kernel tcp socket.
The tunables are added at /proc/sys/net/rds/tcp/rds_tcp_sndbuf
and /proc/sys/net/rds/tcp/rds_tcp_rcvbuf.
These values must be set before accept() or connect(),
and there may be an arbitrary number of existing rds-tcp
sockets when the tunable is modified. To make sure that all
connections in the netns pick up the same value for the tunable,
we reset existing rds-tcp connections in the netns, so that
they can reconnect with the new parameters.
Duplicate include detected.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Using the value of RDS_TCP_DEFAULT_BUFSIZE (128K)
clobbers efficient use of TSO because it inflates the size_goal
that is computed in tcp_sendmsg/tcp_sendpage and skews packet
latency, and the default values for these parameters actually
results in significantly better performance.
In request-response tests using rds-stress with a packet size of
100K with 16 threads (test parameters -q 100000 -a 256 -t16 -d16)
between a single pair of IP addresses achieves a throughput of
6-8 Gbps. Without this patch, throughput maxes at 2-3 Gbps under
equivalent conditions on these platforms.
Register pernet subsys init/stop functions that will set up
and tear down per-net RDS-TCP listen endpoints. Unregister
pernet subusys functions on 'modprobe -r' to clean up these
end points.
Enable keepalive on both accept and connect socket endpoints.
The keepalive timer expiration will ensure that client socket
endpoints will be removed as appropriate from the netns when
an interface is removed from a namespace.
Register a device notifier callback that will clean up all
sockets (and thus avoid the need to wait for keepalive timeout)
when the loopback device is unregistered from the netns indicating
that the netns is getting deleted.
init_net
Open the sockets calling sock_create_kern() with the correct struct net
pointer, and use that struct net pointer when verifying the
address passed to rds_bind().
With calls to modular infrastructure, these files really
needs the full module.h header. Call it out so some of the
cleanups of implicit and unrequired includes elsewhere can be
cleaned up.
All the rds_tcp_connection objects are stored list, but when
being freed it should be removed from there.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
The RDS protocol has lots of functions that should be
declared static. rds_message_get/add_version_extension is
removed since it defined but never used.
The trivial amount of memory saved isn't worth the cost of dealing with section
mismatches.
Signed-off-by: Zach Brown <zach.brown@oracle.com>
We now ask the transport to give us a rm for the congestion
map, and then we handle it normally. Previously, the
transport defined a function that we would call to send
a congestion map.
Convert TCP and loop transports to new cong map method.
Signed-off-by: Andy Grover <andy.grover@oracle.com>
Favor "if (foo)" style over "if (foo != NULL)".
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Now that transports can be loaded in arbitrary order,
it is important for rds_trans_get_preferred() to look
for them in a particular order, instead of walking the list
until it finds a transport that works for a given address.
Now, each transport registers for a specific transport slot,
and these are ordered so that preferred transports come first,
and then if they are not loaded, other transports are queried.
This code allows RDS to be tunneled over a TCP connection.
RDMA operations are disabled when using TCP transport,
but this frees RDS from the IB/RDMA stack dependency, and allows
it to be used with standard Ethernet adapters, or in a VM.
