Retry loops on RT might loop forever when the modifying side was
preempted. Use cpu_chill() instead of cpu_relax() to let the system
make progress.
Cc: stable-rt@vger.kernel.org
[ Upstream commit a6506e1486181975d318344143aca722b2b91621 ]
no socket layer outputs a message for this error and neither should rds.
Signed-off-by: Dave Jones <davej@redhat.com>
[ Upstream commit efc3dbc37412c027e363736b4f4c74ee5e8ecffc ]
rds_sock_info() triggers locking warnings because we try to perform a
local_bh_enable() (via sock_i_ino()) while hardware interrupts are
disabled (via taking rds_sock_lock).
There is no reason for rds_sock_lock to be a hardware IRQ disabling
lock, none of these access paths run in hardware interrupt context.
Therefore making it a BH disabling lock is safe and sufficient to
fix this bug.
Reported-by: Kumar Sanghvi <kumaras@chelsio.com>
Reported-by: Josh Boyer <jwboyer@gmail.com>
Commit 1bc144b625 ("net, rds, Replace xlist in net/rds/xlist.h with
llist") added "select LLIST" to the RDS_RDMA Kconfig entry. But there is
no Kconfig symbol named LLIST. The select statement for that symbol is a
nop. Drop it.
lib/llist.o is builtin, so all that's needed to use the llist
functionality is to include linux/llist.h, which this commit also did.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
* 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits)
Revert "tracing: Include module.h in define_trace.h"
irq: don't put module.h into irq.h for tracking irqgen modules.
bluetooth: macroize two small inlines to avoid module.h
ip_vs.h: fix implicit use of module_get/module_put from module.h
nf_conntrack.h: fix up fallout from implicit moduleparam.h presence
include: replace linux/module.h with "struct module" wherever possible
include: convert various register fcns to macros to avoid include chaining
crypto.h: remove unused crypto_tfm_alg_modname() inline
uwb.h: fix implicit use of asm/page.h for PAGE_SIZE
pm_runtime.h: explicitly requires notifier.h
linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h
miscdevice.h: fix up implicit use of lists and types
stop_machine.h: fix implicit use of smp.h for smp_processor_id
of: fix implicit use of errno.h in include/linux/of.h
of_platform.h: delete needless include <linux/module.h>
acpi: remove module.h include from platform/aclinux.h
miscdevice.h: delete unnecessary inclusion of module.h
device_cgroup.h: delete needless include <linux/module.h>
net: sch_generic remove redundant use of <linux/module.h>
net: inet_timewait_sock doesnt need <linux/module.h>
Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in
- drivers/media/dvb/frontends/dibx000_common.c
- drivers/media/video/{mt9m111.c,ov6650.c}
- drivers/mfd/ab3550-core.c
- include/linux/dmaengine.h
Standardize the style for compiler based printf format verification.
Standardized the location of __printf too.
Done via script and a little typing.
$ grep -rPl --include=*.[ch] -w "__attribute__" * | \
grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \
xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }'
[akpm@linux-foundation.org: revert arch bits]
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
These files are non modular, but need to export symbols using
the macros now living in export.h -- call out the include so
that things won't break when we remove the implicit presence
of module.h from everywhere.
These files were getting access to these two via the implicit
presence of module.h everywhere. They aren't modules, so they
don't need the full module.h inclusion though.
With calls to modular infrastructure, these files really
needs the full module.h header. Call it out so some of the
cleanups of implicit and unrequired includes elsewhere can be
cleaned up.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1745 commits)
dp83640: free packet queues on remove
dp83640: use proper function to free transmit time stamping packets
ipv6: Do not use routes from locally generated RAs
|PATCH net-next] tg3: add tx_dropped counter
be2net: don't create multiple RX/TX rings in multi channel mode
be2net: don't create multiple TXQs in BE2
be2net: refactor VF setup/teardown code into be_vf_setup/clear()
be2net: add vlan/rx-mode/flow-control config to be_setup()
net_sched: cls_flow: use skb_header_pointer()
ipv4: avoid useless call of the function check_peer_pmtu
TCP: remove TCP_DEBUG
net: Fix driver name for mdio-gpio.c
ipv4: tcp: fix TOS value in ACK messages sent from TIME_WAIT
rtnetlink: Add missing manual netlink notification in dev_change_net_namespaces
ipv4: fix ipsec forward performance regression
jme: fix irq storm after suspend/resume
route: fix ICMP redirect validation
net: hold sock reference while processing tx timestamps
tcp: md5: add more const attributes
Add ethtool -g support to virtio_net
Fix up conflicts in:
- drivers/net/Kconfig:
The split-up generated a trivial conflict with removal of a
stale reference to Documentation/networking/net-modules.txt.
Remove it from the new location instead.
- fs/sysfs/dir.c:
Fairly nasty conflicts with the sysfs rb-tree usage, conflicting
with Eric Biederman's changes for tagged directories.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (59 commits)
MAINTAINERS: linux-m32r is moderated for non-subscribers
linux@lists.openrisc.net is moderated for non-subscribers
Drop default from "DM365 codec select" choice
parisc: Kconfig: cleanup Kernel page size default
Kconfig: remove redundant CONFIG_ prefix on two symbols
cris: remove arch/cris/arch-v32/lib/nand_init.S
microblaze: add missing CONFIG_ prefixes
h8300: drop puzzling Kconfig dependencies
MAINTAINERS: microblaze-uclinux@itee.uq.edu.au is moderated for non-subscribers
tty: drop superfluous dependency in Kconfig
ARM: mxc: fix Kconfig typo 'i.MX51'
Fix file references in Kconfig files
aic7xxx: fix Kconfig references to READMEs
Fix file references in drivers/ide/
thinkpad_acpi: Fix printk typo 'bluestooth'
bcmring: drop commented out line in Kconfig
btmrvl_sdio: fix typo 'btmrvl_sdio_sd6888'
doc: raw1394: Trivial typo fix
CIFS: Don't free volume_info->UNC until we are entirely done with it.
treewide: Correct spelling of successfully in comments
net/batman-adv/soft-interface.c
In the rds_iw_mr_pool struct the free_pinned field keeps track of
memory pinned by free MRs. While this field is incremented properly
upon allocation, it is never decremented upon unmapping. This would
cause the rds_rdma module to crash the kernel upon unloading, by
triggering the BUG_ON in the rds_iw_destroy_mr_pool function.
This change keeps track of the MRs that become unpinned, so that
free_pinned can be decremented appropriately.
Signed-off-by: Jonathan Lallinger <jonathan@ogc.us>
Signed-off-by: Steve Wise <swise@ogc.us>
The functionality of xlist and llist is almost same. This patch
replace xlist with llist to avoid code duplication.
Known issues: don't know how to test this, need special hardware?
Signed-off-by: Huang Ying <ying.huang@intel.com>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Andy Grover <andy.grover@oracle.com>
We presently define all kinds of notifiers in notifier.h. This is not
necessary at all, since different subsystems use different notifiers, they
are almost non-related with each other.
This can also save much build time. Suppose I add a new netdevice event,
really I don't have to recompile all the source, just network related.
Without this patch, all the source will be recompiled.
I move the notify events near to their subsystem notifier registers, so
that they can be found more easily.
This patch:
It is not necessary to share the same notifier.h.
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Greg KH <greg@kroah.com>
Correct the syntax so that both array and pointer are const.
Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu>
Since printk_ratelimit() shouldn't be used anymore (see comment in
include/linux/printk.h), replace it with printk_ratelimited()
Signed-off-by: Manuel Zerpies <manuel.f.zerpies@ww.stud.uni-erlangen.de>
Signed-off-by: David S. Miller <davem@conan.davemloft.net>
* remove interrupt.g inclusion from netdevice.h -- not needed
* fixup fallout, add interrupt.h and hardirq.h back where needed.
The RDMA CM currently infers the QP type from the port space selected
by the user. In the future (eg with RDMA_PS_IB or XRC), there may not
be a 1-1 correspondence between port space and QP type. For netlink
export of RDMA CM state, we want to export the QP type to userspace,
so it is cleaner to explicitly associate a QP type to an ID.
Modify rdma_create_id() to allow the user to specify the QP type, and
use it to make our selections of datagram versus connected mode.
Signed-off-by: Sean Hefty <sean.hefty@intel.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
As a preparation for removing ext2 non-atomic bit operations from
asm/bitops.h. This converts ext2 non-atomic bit operations to
little-endian bit operations.
asm-generic/bitops/le.h is only intended to be included directly from
asm-generic/bitops/ext2-non-atomic.h or asm-generic/bitops/minix-le.h
which implements generic ext2 or minix bit operations.
This stops including asm-generic/bitops/le.h directly and use ext2
non-atomic bit operations instead.
It seems odd to use ext2_*_bit() on rds, but it will replaced with
__{set,clear,test}_bit_le() after introducing little endian bit operations
for all architectures. This indirect step is necessary to maintain
bisectability for some architectures which have their own little-endian
bit operations.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1480 commits)
bonding: enable netpoll without checking link status
xfrm: Refcount destination entry on xfrm_lookup
net: introduce rx_handler results and logic around that
bonding: get rid of IFF_SLAVE_INACTIVE netdev->priv_flag
bonding: wrap slave state work
net: get rid of multiple bond-related netdevice->priv_flags
bonding: register slave pointer for rx_handler
be2net: Bump up the version number
be2net: Copyright notice change. Update to Emulex instead of ServerEngines
e1000e: fix kconfig for crc32 dependency
netfilter ebtables: fix xt_AUDIT to work with ebtables
xen network backend driver
bonding: Improve syslog message at device creation time
bonding: Call netif_carrier_off after register_netdevice
bonding: Incorrect TX queue offset
net_sched: fix ip_tos2prio
xfrm: fix __xfrm_route_forward()
be2net: Fix UDP packet detected status in RX compl
Phonet: fix aligned-mode pipe socket buffer header reserve
netxen: support for GbE port settings
Fix up conflicts in drivers/staging/brcm80211/brcmsmac/wl_mac80211.c
with the staging updates.
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: fix build failure introduced by s/freezeable/freezable/
workqueue: add system_freezeable_wq
rds/ib: use system_wq instead of rds_ib_fmr_wq
net/9p: replace p9_poll_task with a work
net/9p: use system_wq instead of p9_mux_wq
xfs: convert to alloc_workqueue()
reiserfs: make commit_wq use the default concurrency level
ocfs2: use system_wq instead of ocfs2_quota_wq
ext4: convert to alloc_workqueue()
scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path
scsi/be2iscsi,qla2xxx: convert to alloc_workqueue()
misc/iwmc3200top: use system_wq instead of dedicated workqueues
i2o: use alloc_workqueue() instead of create_workqueue()
acpi: kacpi*_wq don't need WQ_MEM_RECLAIM
fs/aio: aio_wq isn't used in memory reclaim path
input/tps6507x-ts: use system_wq instead of dedicated workqueue
cpufreq: use system_wq instead of dedicated workqueues
wireless/ipw2x00: use system_wq instead of dedicated workqueues
arm/omap: use system_wq in mailbox
workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
drivers/net/bnx2x/bnx2x_cmn.c
Recently had this bug halt reported to me:
kernel BUG at net/rds/send.c:329!
Oops: Exception in kernel mode, sig: 5 [#1]
SMP NR_CPUS=1024 NUMA pSeries
Modules linked in: rds sunrpc ipv6 dm_mirror dm_region_hash dm_log ibmveth sg
ext4 jbd2 mbcache sd_mod crc_t10dif ibmvscsic scsi_transport_srp scsi_tgt
dm_mod [last unloaded: scsi_wait_scan]
NIP: d000000003ca68f4 LR: d000000003ca67fc CTR: d000000003ca8770
REGS: c000000175cab980 TRAP: 0700 Not tainted (2.6.32-118.el6.ppc64)
MSR: 8000000000029032 <EE,ME,CE,IR,DR> CR: 44000022 XER: 00000000
TASK = c00000017586ec90[1896] 'krdsd' THREAD: c000000175ca8000 CPU: 0
GPR00: 0000000000000150 c000000175cabc00 d000000003cb7340 0000000000002030
GPR04: ffffffffffffffff 0000000000000030 0000000000000000 0000000000000030
GPR08: 0000000000000001 0000000000000001 c0000001756b1e30 0000000000010000
GPR12: d000000003caac90 c000000000fa2500 c0000001742b2858 c0000001742b2a00
GPR16: c0000001742b2a08 c0000001742b2820 0000000000000001 0000000000000001
GPR20: 0000000000000040 c0000001742b2814 c000000175cabc70 0800000000000000
GPR24: 0000000000000004 0200000000000000 0000000000000000 c0000001742b2860
GPR28: 0000000000000000 c0000001756b1c80 d000000003cb68e8 c0000001742b27b8
NIP [d000000003ca68f4] .rds_send_xmit+0x4c4/0x8a0 [rds]
LR [d000000003ca67fc] .rds_send_xmit+0x3cc/0x8a0 [rds]
Call Trace:
[c000000175cabc00] [d000000003ca67fc] .rds_send_xmit+0x3cc/0x8a0 [rds]
(unreliable)
[c000000175cabd30] [d000000003ca7e64] .rds_send_worker+0x54/0x100 [rds]
[c000000175cabdb0] [c0000000000b475c] .worker_thread+0x1dc/0x3c0
[c000000175cabed0] [c0000000000baa9c] .kthread+0xbc/0xd0
[c000000175cabf90] [c000000000032114] .kernel_thread+0x54/0x70
Instruction dump:
4bfffd50 60000000 60000000 39080001 935f004c f91f0040 41820024 813d017c
7d094a78 7d290074 7929d182 394a0020 <0b090000> 40e2ff68 4bffffa4 39200000
Kernel panic - not syncing: Fatal exception
Call Trace:
[c000000175cab560] [c000000000012e04] .show_stack+0x74/0x1c0 (unreliable)
[c000000175cab610] [c0000000005a365c] .panic+0x80/0x1b4
[c000000175cab6a0] [c00000000002fbcc] .die+0x21c/0x2a0
[c000000175cab750] [c000000000030000] ._exception+0x110/0x220
[c000000175cab910] [c000000000004b9c] program_check_common+0x11c/0x180
With cmwq, there's no reason to use dedicated rds_ib_fmr_wq - it's not
in the memory reclaim path and the maximum number of concurrent work
items is bound by the number of devices. Drop it and use system_wq
instead. This rds_ib_fmr_init/exit() noops. Both removed.
Clean up some unused macros in net/*.
1. be left for code change. e.g. PGV_FROM_VMALLOC, PGV_FROM_VMALLOC, KMEM_SAFETYZONE.
2. never be used since introduced to kernel.
e.g. P9_RDMA_MAX_SGE, UTIL_CTRL_PKT_SIZE.
Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com>
Acked-by: Sjur Braendeland <sjur.brandeland@stericsson.com>
Changed Makefile to use <modules>-y instead of <modules>-objs
because -objs is deprecated and not mentioned in
Documentation/kbuild/makefiles.txt.
Also, use the ccflags-$ flag instead of EXTRA_CFLAGS because EXTRA_CFLAGS is
deprecated and should now be switched.
Last but not least, took out if-conditionals.
Signed-off-by: Tracey Dent <tdent48227@gmail.com>
In rds_cmsg_rdma_args(), the user-provided args->nr_local value is
restricted to less than UINT_MAX. This seems to need a tighter upper
bound, since the calculation of total iov_size can overflow, resulting
in a small sock_kmalloc() allocation. This would probably just result
in walking off the heap and crashing when calling rds_rdma_pages() with
a high count value. If it somehow doesn't crash here, then memory
corruption could occur soon after.
Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com>
The sgs allocation error path leaks the allocated message.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Acked-by: Andy Grover <andy.grover@oracle.com>
All the rds_tcp_connection objects are stored list, but when
being freed it should be removed from there.
The conn is removed from list in there and this requires
proper lock protection.
Even with the previous fix, we still are reading the iovecs once
to determine SGs needed, and then again later on. Preallocating
space for sg lists as part of rds_message seemed like a good idea
but it might be better to not do this. While working to redo that
code, this patch attempts to protect against userspace rewriting
the rds_iovec array between the first and second accesses.
The consequences of this would be either a too-small or too-large
sg list array. Too large is not an issue. This patch changes all
callers of message_alloc_sgs to handle running out of preallocated
sgs, and fail gracefully.
Signed-off-by: Andy Grover <andy.grover@oracle.com>
Change rds_rdma_pages to take a passed-in rds_iovec array instead
of doing copy_from_user itself.
Change rds_cmsg_rdma_args to copy rds_iovec array once only. This
eliminates the possibility of userspace changing it after our
sanity checks.
Implement stack-based storage for small numbers of iovecs, based
on net/socket.c, to save an alloc in the extremely common case.
Although this patch reduces iovec copies in cmsg_rdma_args to 1,
we still do another one in rds_rdma_extra_size. Getting rid of
that one will be trickier, so it'll be a separate patch.
We don't need to set ret = 0 at the end -- it's initialized to 0.
Also, don't increment s_send_rdma stat if we're exiting with an
error.
rds_cmsg_rdma_args would still return success even if rds_rdma_pages
returned an error (or overflowed).
As reported by Thomas Pollet, the rdma page counting can overflow. We
get the rdma sizes in 64-bit unsigned entities, but then limit it to
UINT_MAX bytes and shift them down to pages (so with a possible "+1" for
an unaligned address).
So each individual page count fits comfortably in an 'unsigned int' (not
even close to overflowing into signed), but as they are added up, they
might end up resulting in a signed return value. Which would be wrong.
Catch the case of tot_pages turning negative, and return the appropriate
error code.
Reported-by: Thomas Pollet <thomas.pollet@gmail.com>
net/core/dev.c
The RDS protocol has lots of functions that should be
declared static. rds_message_get/add_version_extension is
removed since it defined but never used.
Don't try to "optimize" rds_page_copy_user() by using kmap_atomic() and
the unsafe atomic user mode accessor functions. It's actually slower
than the straightforward code on any reasonable modern CPU.
Back when the code was written (although probably not by the time it was
actually merged, though), 32-bit x86 may have been the dominant
architecture. And there kmap_atomic() can be a lot faster than kmap()
(unless you have very good locality, in which case the virtual address
caching by kmap() can overcome all the downsides).
But these days, x86-64 may not be more populous, but it's getting there
(and if you care about performance, it's definitely already there -
you'd have upgraded your CPU's already in the last few years). And on
x86-64, the non-kmap_atomic() version is faster, simply because the code
is simpler and doesn't have the "re-try page fault" case.
People with old hardware are not likely to care about RDS anyway, and
the optimization for the 32-bit case is simply buggy, since it doesn't
verify the user addresses properly.
Reported-by: Dan Rosenberg <drosenberg@vsecurity.com>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Cc: stable@kernel.org
drivers/net/qlcnic/qlcnic_init.c
net/ipv4/ip_output.c
We have for each socket :
One spinlock (sk_slock.slock)
One rwlock (sk_callback_lock)
Possible scenarios are :
(A) (this is used in net/sunrpc/xprtsock.c)
read_lock(&sk->sk_callback_lock) (without blocking BH)
<BH>
spin_lock(&sk->sk_slock.slock);
read_lock(&sk->sk_callback_lock);
(B)
write_lock_bh(&sk->sk_callback_lock)
stuff
write_unlock_bh(&sk->sk_callback_lock)
(C)
spin_lock_bh(&sk->sk_slock)
stuff
spin_unlock_bh(&sk->sk_slock)
This (C) case conflicts with (A) :
CPU1 [A] CPU2 [C]
read_lock(callback_lock)
<BH> spin_lock_bh(slock)
<wait to spin_lock(slock)>
<wait to write_lock_bh(callback_lock)>
We have one problematic (C) use case in inet_csk_listen_stop() :
local_bh_disable();
bh_lock_sock(child); // spin_lock_bh(&sk->sk_slock)
WARN_ON(sock_owned_by_user(child));
sock_orphan(child); // write_lock_bh(&sk->sk_callback_lock)
lockdep is not happy with this, as reported by Tetsuo Handa
It seems only way to deal with this is to use read_lock_bh(callbacklock)
everywhere.
Thanks to Jarek for pointing a bug in my first attempt and suggesting
this solution.
Reported-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Tested-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
CC: Jarek Poplawski <jarkao2@gmail.com>
Tested-by: Eric Dumazet <eric.dumazet@gmail.com>
This is basically just a cleanup. IRQs were disabled on the previous
line so we don't need to do it again here. In the current code IRQs
would get turned on one line earlier than intended.
We unlock after we goto out.
In the original code if the copy_from_user() fails in rds_rdma_pages()
then the error handling fails and we get a stack trace from kmalloc().
Add two CMSGs for masked versions of cswp and fadd. args
struct modified to use a union for different atomic op type's
arguments. Change IB to do masked atomic ops. Atomic op type
in rds_message similarly unionized.
This prints the constant identifier for work completion status and rdma
cm event types, like we already do for IB event types.
A core string array helper is added that each string type uses.
Signed-off-by: Zach Brown <zach.brown@oracle.com>
Nothing was canceling the send and receive work that might have been
queued as a conn was being destroyed.
