path: root/net/rfkill/core.c
2013-07-25net: rfkill: convert class code to use dev_groupsGreg Kroah-Hartman
The dev_attrs field of struct class is going away soon, dev_groups should be used instead. This converts the rfkill class code to use the correct field. Cc: John W. Linville <linville@tuxdriver.com> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-12rfkill: Add NFC to the list of supported radiosSamuel Ortiz
And return the proper string for it. Acked-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-10-28Merge branch 'master' into for-nextJiri Kosina
Sync up with Linus' tree to be able to apply Cesar's patch against newer version of the code. Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-10-25rfkill: error cannot be set here so simplifyAlan Cox
Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-09-24rfkill: prevent unnecessary event generationVitaly Wool
Prevent unnecessary rfkill event generation when the state has not actually changed. These events have to be delivered to relevant userspace processes, causing these processes to wake up and do something while they could as well have slept. This obviously results in more CPU usage, longer time-to-sleep-again and therefore higher power consumption. Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Mykyta Iziumtsev <nikita.izyumtsev@gmail.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-08-21Revert "rfkill: remove dead code"AceLan Kao
This reverts commit 2e48928d8a0f38c1b5c81eb3f1294de8a6382c68. Those functions are needed and should not be removed, or there is no way to set the rfkill led trigger name. Signed-off-by: AceLan Kao <acelan.kao@canonical.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2012-06-06rfkill: Add the capability to switch all devices of all type in ↵Alex Hung
__rfkill_switch_all(). __rfkill_switch_all() switches the state of devices of a given type; however, it does not switch devices of all type (RFKILL_TYPE_ALL). As a result, it ignores the keycode "KEY_RFKILL" from another module, i.e. eeepc-wmi. This fix is to make __rfkill_switch_all() to be able to switch not only devices of a given type but also all devices. Signed-off-by: Alex Hung <alex.hung@canonical.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-03-11device.h: cleanup users outside of linux/include (C files)Paul Gortmaker
For files that are actively using linux/device.h, make sure that they call it out. This will allow us to clean up some of the implicit uses of linux/device.h within include/* without introducing build regressions. Yes, this was created by "cheating" -- i.e. the headers were cleaned up, and then the fallout was found and fixed, and then the two commits were reordered. This ensures we don't introduce build regressions into the git history. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-11-09net/rfkill/core.c: use kstrtoul, etcJulia Lawall
Use kstrtoul, etc instead of the now deprecated strict_strtoul, etc. A semantic patch rule for the kstrtoul case is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression a,b; {int,long} *c; @@ -strict_strtoul +kstrtoul (a,b,c) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-09-19rfkill: properly assign a boolean typeMohammed Shafi Shajakhan
Signed-off-by: Mohammed Shafi Shajakhan <mohammed@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-05-16net/rfkill/core.c: Avoid leaving freed data in a listJulia Lawall
The list_for_each_entry loop can fail, in which case the list element is not removed from the list rfkill_fds. Since this list is not accessed by the loop, the addition of &data->list into the list is just moved after the loop. The sematic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E,E1,E2; identifier l; @@ *list_add(&E->l,E1); ... when != E1 when != list_del(&E->l) when != list_del_init(&E->l) when != E = E2 *kfree(E);// </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-11-15rfkill: remove dead codeStephen Hemminger
The following code is defined but never used. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-04-11Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/stmmac/stmmac_main.c drivers/net/wireless/wl12xx/wl1271_cmd.c drivers/net/wireless/wl12xx/wl1271_main.c drivers/net/wireless/wl12xx/wl1271_spi.c net/core/ethtool.c net/mac80211/scan.c
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-19rename new rfkill sysfs knobsflorian@mickler.org
This patch renames the (never officially released) sysfs-knobs "blocked_hw" and "blocked_sw" to "hard" and "soft", as the hardware vs software conotation is misleading. It also gets rid of not needed locks around u32-read-access. Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10enhance sysfs rfkill interfaceflorian@mickler.org
This commit introduces two new sysfs knobs. /sys/class/rfkill/rfkill[0-9]+/blocked_hw: (ro) hardblock kill state /sys/class/rfkill/rfkill[0-9]+/blocked_sw: (rw) softblock kill state Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-07net/rfkill/core.c: work around gcc-4.0.2 sillinessAndrew Morton
net/rfkill/core.c: In function 'rfkill_type_show': net/rfkill/core.c:610: warning: control may reach end of non-void function 'rfkill_get_type_str' being inlined A gcc bug, but simple enough to squish. Cc: John W. Linville <linville@tuxdriver.com> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-29Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/ieee802154/fakehard.c drivers/net/e1000e/ich8lan.c drivers/net/e1000e/phy.c drivers/net/netxen/netxen_nic_init.c drivers/net/wireless/ath/ath9k/main.c
2009-11-23Merge branch 'master' of ↵David S. Miller
2009-11-23rfkill: fix miscdev opsJohannes Berg
The /dev/rfkill ops don't refer to the module, so it is possible to unload the module while file descriptors are open. Fix this oversight. Reported-by: Maxim Levitsky <maximlevitsky@gmail.com> Cc: stable@kernel.org Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-11-18rfkill: Add constant for RFKILL_TYPE_FM radio devicesMarcel Holtmann
Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Janakiram Sistla <janakiram.sistla@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-10-04headers: remove sched.h from poll.hAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-04rfkill: add the GPS radio typeTomas Winkler
Althoug GPS is a technology w/o transmitting radio and thus not a primary candidate for rfkill switch, rfkill gives unified interface point for devices with wireless technology. The input key is not supplied as it is too be deprecated. Cc: johannes@sipsolutions.net Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-23Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwmc3200wifi/netdev.c net/wireless/scan.c
2009-07-21rfkill: fix rfkill_set_states() to set the hw stateAlan Jenkins
The point of this function is to set the software and hardware state at the same time. When I tried to use it, I found it was only setting the software state. Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-21rfkill: allow toggling soft state in sysfs againJohannes Berg
Apparently there actually _are_ tools that try to set this in sysfs even though it wasn't supposed to be used this way without claiming first. Guess what: now that I've cleaned it all up it doesn't matter and we can simply allow setting the soft-block state in sysfs. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Tested-By: Darren Salt <linux@youmustbejoking.demon.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10rfkill: prep for rfkill API changesJohannes Berg
We've designed the /dev/rfkill API in a way that we can increase the event struct by adding members at the end, should it become necessary. To validate the events, userspace and the kernel need to have the proper event size to check for -- when reading from the other end they need to verify that it's at least version 1 of the event API, with the current struct size, so define a constant for that and make the code a little more 'future proof'. Not that I expect that we'll have to change the event size any time soon, but it's better to write the code in a way that lends itself to extending. Due to the current size of the event struct, the code is currently equivalent, but should the event struct ever need to be increased the new code might not need changing. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19rfkill: export persistent attribute in sysfsAlan Jenkins
This information allows userspace to implement a hybrid policy where it can store the rfkill soft-blocked state in platform non-volatile storage if available, and if not then file-based storage can be used. Some users prefer platform non-volatile storage because of the behaviour when dual-booting multiple versions of Linux, or if the rfkill setting is changed in the BIOS setting screens, or if the BIOS responds to wireless-toggle hotkeys itself before the relevant platform driver has been loaded. Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19rfkill: don't restore software blocked state on persistent devicesAlan Jenkins
The setting of the "persistent" flag is also made more explicit using a new rfkill_init_sw_state() function, instead of special-casing rfkill_set_sw_state() when it is called before registration. Suspend is a bit of a corner case so we try to get away without adding another hack to rfkill-input - it's going to be removed soon. If the state does change over suspend, users will simply have to prod rfkill-input twice in order to toggle the state. Userspace policy agents will be able to implement a more consistent user experience. For example, they can avoid the above problem if they toggle devices individually. Then there would be no "global state" to get out of sync. Currently there are only two rfkill drivers with persistent soft-blocked state. thinkpad-acpi already checks the software state on resume. eeepc-laptop will require modification. Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> CC: Marcel Holtmann <marcel@holtmann.org> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-19rfkill: rfkill_set_block() when suspended nitpickAlan Jenkins
If we return after fiddling with the state, userspace will see the wrong state and rfkill_set_sw_state() won't work until the next call to rfkill_set_block(). At the moment rfkill_set_block() will always be called from rfkill_resume(), but this will change in future. Also, presumably the point of this test is to avoid bothering devices which may be suspended. If we don't want to call set_block(), we probably don't want to call query() either :-). Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10rfkill: don't impose global states on resume (just restore the previous states)Alan Jenkins
Once rfkill-input is disabled, the "global" states will only be used as default initial states. Since the states will always be the same after resume, we shouldn't generate events on resume. Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10rfkill: remove set_global_sw_stateAlan Jenkins
rfkill_set_global_sw_state() (previously rfkill_set_default()) will no longer be exported by the rewritten rfkill core. Instead, platform drivers which can provide persistent soft-rfkill state across power-down/reboot should indicate their initial state by calling rfkill_set_sw_state() before registration. Otherwise, they will be initialized to a default value during registration by a set_block call. We remove existing calls to rfkill_set_sw_state() which happen before registration, since these had no effect in the old model. If these drivers do have persistent state, the calls can be put back (subject to testing :-). This affects hp-wmi and acer-wmi. Drivers with persistent state will affect the global state only if rfkill-input is enabled. This is required, otherwise booting with wireless soft-blocked and pressing the wireless-toggle key once would have no apparent effect. This special case will be removed in future along with rfkill-input, in favour of a more flexible userspace daemon (see Documentation/feature-removal-schedule.txt). Now rfkill_global_states[n].def is only used to preserve global states over EPO, it is renamed to ".sav". Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10rfkill: print events when input handler is disabled/enabledJohannes Berg
It is useful for debugging when we know if something disabled the in-kernel rfkill input handler. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03rfkill: always init poll delayed workJohannes Berg
The rfkill core didn't initialise the poll delayed work because it assumed that polling was always done by specifying the poll function. cfg80211, however, would like to start polling only later, which is a valid use case and easy to support, so change rfkill to always initialise the poll delayed work and thus allow starting polling by calling the rfkill_resume_polling() function after registration. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03rfkill: add function to query stateJohannes Berg
Sometimes it is necessary to know how the state is, and it is easier to query rfkill than keep track of it somewhere else, so add a function for that. This could later be expanded to return hard/soft block, but so far that isn't necessary. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03rfkill: create useful userspace interfaceJohannes Berg
The new code added by this patch will make rfkill create a misc character device /dev/rfkill that userspace can use to control rfkill soft blocks and get status of devices as well as events when the status changes. Using it is very simple -- when you open it you can read a number of times to get the initial state, and every further read blocks (you can poll) on getting the next event from the kernel. The same structure you read is also used when writing to it to change the soft block of a given device, all devices of a given type, or all devices. This also makes CONFIG_RFKILL_INPUT selectable again in order to be able to test without it present since its functionality can now be replaced by userspace entirely and distros and users may not want the input part of rfkill interfering with their userspace code. We will also write a userspace daemon to handle all that and consequently add the input code to the feature removal schedule. In order to have rfkilld support both kernels with and without CONFIG_RFKILL_INPUT (or new kernels after its eventual removal) we also add an ioctl (that only exists if rfkill-input is present) to disable rfkill-input. It is not very efficient, but at least gives the correct behaviour in all cases. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03rfkill: rewriteJohannes Berg
This patch completely rewrites the rfkill core to address the following deficiencies: * all rfkill drivers need to implement polling where necessary rather than having one central implementation * updating the rfkill state cannot be done from arbitrary contexts, forcing drivers to use schedule_work and requiring lots of code * rfkill drivers need to keep track of soft/hard blocked internally -- the core should do this * the rfkill API has many unexpected quirks, for example being asymmetric wrt. alloc/free and register/unregister * rfkill can call back into a driver from within a function the driver called -- this is prone to deadlocks and generally should be avoided * rfkill-input pointlessly is a separate module * drivers need to #ifdef rfkill functions (unless they want to depend on or select RFKILL) -- rfkill should provide inlines that do nothing if it isn't compiled in * the rfkill structure is not opaque -- drivers need to initialise it correctly (lots of sanity checking code required) -- instead force drivers to pass the right variables to rfkill_alloc() * the documentation is hard to read because it always assumes the reader is completely clueless and contains way TOO MANY CAPS * the rfkill code needlessly uses a lot of locks and atomic operations in locked sections * fix LED trigger to actually change the LED when the radio state changes -- this wasn't done before Tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> [thinkpad] Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
