path: root/net/rose
2011-07-07rose: Delete commented out references to ancient firewalling code.David S. Miller
These intefaces haven't existed since 2.2.x Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14NET: AX.25, NETROM, ROSE: Remove SOCK_DEBUG callsRalf Baechle
Nobody alive seems to recall when they last were useful. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-27rose: Add length checks to CALL_REQUEST parsingBen Hutchings
Define some constant offsets for CALL_REQUEST based on the description at <http://www.techfest.com/networking/wan/x25plp.htm> and the definition of ROSE as using 10-digit (5-byte) addresses. Use them consistently. Validate all implicit and explicit facilities lengths. Validate the address length byte rather than either trusting or assuming its value. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-27ROSE: prevent heap corruption with bad facilitiesDan Rosenberg
When parsing the FAC_NATIONAL_DIGIS facilities field, it's possible for a remote host to provide more digipeaters than expected, resulting in heap corruption. Check against ROSE_MAX_DIGIS to prevent overflows, and abort facilities parsing on failure. Additionally, when parsing the FAC_CCITT_DEST_NSAP and FAC_CCITT_SRC_NSAP facilities fields, a remote host can provide a length of less than 10, resulting in an underflow in a memcpy size, causing a kernel panic due to massive heap corruption. A length of greater than 20 results in a stack overflow of the callsign array. Abort facilities parsing on these invalid length values. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-14ROSE: AX25: finding routes simplificationBernard Pidoux
With previous patch, rose_get_neigh() routine investigates the full list of neighbor nodes until it finds or not an already connected node whether it is called locally or through a level 3 transit frame. If no routes are opened through an adjacent connected node then a classical connect request is attempted. Then there is no more reason for an extra loop such as the one removed by this patch. Signed-off-by: Bernard Pidoux <f6bvp@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-14ROSE: rose AX25 packet routing improvementBernard Pidoux
FPAC AX25 packet application is using Linux kernel ROSE routing skills in order to connect or send packets to remote stations knowing their ROSE address via a network of interconnected nodes. Each FPAC node has a ROSE routing table that Linux ROSE module is looking at each time a ROSE frame is relayed by the node or when a connect request to a neighbor node is received. A previous patch improved the system time response by looking at already established routes each time the system was looking for a route to relay a frame. If a neighbor node routing the destination address was already connected, then the frame would be sent through him. If not, a connection request would be issued. The present patch extends the same routing capability to a connect request asked by a user locally connected into an FPAC node. Without this patch, a connect request was not well handled unless it was directed to an immediate connected neighbor of the local node. Implemented at a number of ROSE FPAC node stations, the present patch improved dramatically FPAC ROSE routing time response and efficiency. Signed-off-by: Bernard Pidoux <f6bvp@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/qlcnic/qlcnic_init.c net/ipv4/ip_output.c
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-20rose: Fix signedness issues wrt. digi count.David S. Miller
Just use explicit casts, since we really can't change the types of structures exported to userspace which have been around for 15 years or so. Reported-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-01net/rose: Use GFP_ATOMICJulia Lawall
The other calls to kmalloc in the same function use GFP_ATOMIC, and indeed two locks are held within the body of the function. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier f; @@ *f(...,GFP_ATOMIC,...) ... when != spin_unlock(...) when != read_unlock(...) when != write_unlock(...) when != read_unlock_irq(...) when != write_unlock_irq(...) when != read_unlock_irqrestore(...) when != write_unlock_irqrestore(...) when != spin_unlock_irq(...) when != spin_unlock_irqrestore(...) *f(...,GFP_KERNEL,...) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-10net: rose: use seq_hlist_foo() helpersLi Zefan
Simplify seq_file code. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-16ax25: netrom: rose: Fix timer oopsesJarek Poplawski
Wrong ax25_cb refcounting in ax25_send_frame() and by its callers can cause timer oopses (first reported with 2.6.29.6 kernel). Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=14905 Reported-by: Bernard Pidoux <bpidoux@free.fr> Tested-by: Bernard Pidoux <bpidoux@free.fr> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03rose_loopback_timer sets VC number <= ROSE_DEFAULT_MAXVCBernard Pidoux F6BVP
cat /proc/net/rose displayed a rose sockets abnormal lci value, i.e. greater than maximum number of VCs per neighbour allowed. This number prevents further test of lci value during rose operations. Example (lines shortened) : [bernard]# cat /proc/net/rose dest_addr dest_call src_addr src_call dev lci neigh st vs vr va * * 2080175520 F6BVP-1 rose0 000 00000 0 0 0 0 2080175520 FPAD-0 2080175520 WP-0 rose0 FFE 00001 3 0 0 0 Here are the default parameters : linux/include/net/rose.h:#define ROSE_DEFAULT_MAXVC 50 /* Maximum number of VCs per neighbour */ linux/net/rose/af_rose.c:int sysctl_rose_maximum_vcs = ROSE_DEFAULT_MAXVC; With the following patch, rose_loopback_timer() attributes a VC number within limits. Signed-off-by: Bernard Pidoux <f6bvp@amsat.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17Merge commit 'v2.6.32-rc7'Eric W. Biederman
Resolve the conflict between v2.6.32-rc7 where dn_def_dev_handler gets a small bug fix and the sysctl tree where I am removing all sysctl strategy routines.
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/cdc_ether.c All CDC ethernet devices of type USB_CLASS_COMM need to use '&mbm_info'. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05rose: device refcount leakEric Dumazet
While hunting dev_put() for net-next-2.6, I found a device refcount leak in ROSE, ioctl(SIOCADDRT) error path. Fix is to not touch device refcount, as we hold RTNL Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-04net: Introduce for_each_netdev_rcu() iteratorEric Dumazet
Adds RCU management to the list of netdevices. Convert some for_each_netdev() users to RCU version, if it can avoid read_lock-ing dev_base_lock Ie: read_lock(&dev_base_loack); for_each_netdev(net, dev) some_action(); read_unlock(&dev_base_lock); becomes : rcu_read_lock(); for_each_netdev_rcu(net, dev) some_action(); rcu_read_unlock(); Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: mark net_proto_ops as constStephen Hemminger
All usages of structure net_proto_ops should be declared const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-14net: constify remaining proto_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01convert hamradio drivers to netdev_txreturnt_tStephen Hemminger
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-08-06rose: Fix rose_getname() leakEric Dumazet
rose_getname() can leak kernel memory to user. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-30Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-3945.h drivers/net/wireless/iwlwifi/iwl-tx.c drivers/net/wireless/iwlwifi/iwl3945-base.c
2009-07-26NET: ROSE: Don't use static buffer.Ralf Baechle
The use of a static buffer in rose2asc() to return its result is not threadproof and can result in corruption if multiple threads are trying to use one of the procfs files based on rose2asc(). Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-05net: use NETDEV_TX_OK instead of 0 in ndo_start_xmit() functionsPatrick McHardy
This patch is the result of an automatic spatch transformation to convert all ndo_start_xmit() return values of 0 to NETDEV_TX_OK. Some occurences are missed by the automatic conversion, those will be handled in a seperate patch. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18net: correct off-by-one write allocations reportsEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. We need to take into account this offset when reporting sk_wmem_alloc to user, in PROC_FS files or various ioctls (SIOCOUTQ/TIOCOUTQ) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-17net: sk_wmem_alloc has initial value of one, not zeroEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. Some protocols check sk_wmem_alloc value to determine if a timer must delay socket deallocation. We must take care of the sk_wmem_alloc value being one instead of zero when no write allocations are pending. Reported by Ingo Molnar, and full diagnostic from David Miller. This patch introduces three helpers to get read/write allocations and a followup patch will use these helpers to report correct write allocations to user. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13net: use symbolic values for ndo_start_xmit() return codesPatrick McHardy
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively. 0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases where its in direct proximity to one of the other values. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-14Revert "rose: zero length frame filtering in af_rose.c"David S. Miller
This reverts commit 244f46ae6e9e18f6fc0be7d1f49febde4762c34b. Alan Cox did the research, and just like the other radio protocols zero-length frames have meaning because at the top level ROSE is X.25 PLP. So this zero-length filtering is invalid. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-03-27af_rose/x25: Sanity check the maximum user frame sizeAlan Cox
Otherwise we can wrap the sizes and end up sending garbage. Closes #10423 Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21rose: convert to network_device_opsStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-01-21rose: convert to internal net_device_statsStephen Hemminger
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits) net: Allow dependancies of FDDI & Tokenring to be modular. igb: Fix build warning when DCA is disabled. net: Fix warning fallout from recent NAPI interface changes. gro: Fix potential use after free sfc: If AN is enabled, always read speed/duplex from the AN advertising bits sfc: When disabling the NIC, close the device rather than unregistering it sfc: SFT9001: Add cable diagnostics sfc: Add support for multiple PHY self-tests sfc: Merge top-level functions for self-tests sfc: Clean up PHY mode management in loopback self-test sfc: Fix unreliable link detection in some loopback modes sfc: Generate unique names for per-NIC workqueues 802.3ad: use standard ethhdr instead of ad_header 802.3ad: generalize out mac address initializer 802.3ad: initialize ports LACPDU from const initializer 802.3ad: remove typedef around ad_system 802.3ad: turn ports is_individual into a bool 802.3ad: turn ports is_enabled into a bool 802.3ad: make ntt bool ixgbe: Fix set_ringparam in ixgbe to use the same memory pools. ... Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due to the conversion to %pI (in this networking merge) and the addition of doing IPv6 addresses (from the earlier merge of CIFS).
2008-12-04Merge branch 'master' into nextJames Morris
Conflicts: fs/nfsd/nfs4recover.c Manually fixed above to use new creds API functions, e.g. nfs4_save_creds(). Signed-off-by: James Morris <jmorris@namei.org>
2008-11-26Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/hp-plus.c drivers/net/wireless/ath5k/base.c drivers/net/wireless/ath9k/recv.c net/wireless/reg.c
2008-11-25rose: zero length frame filtering in af_rose.cBernard Pidoux
Since changeset e79ad711a0108475c1b3a03815527e7237020b08 from mainline, >From David S. Miller, empty packet can be transmitted on connected socket for datagram protocols. However, this patch broke a high level application using ROSE network protocol with connected datagram. Bulletin Board Stations perform bulletins forwarding between BBS stations via ROSE network using a forward protocol. Now, if for some reason, a buffer in the application software happens to be empty at a specific moment, ROSE sends an empty packet via unfiltered packet socket. When received, this ROSE packet introduces perturbations of data exchange of BBS forwarding, for the application message forwarding protocol is waiting for something else. We agree that a more careful programming of the application protocol would avoid this situation and we are willing to debug it. But, as an empty frame is no use and does not have any meaning for ROSE protocol, we may consider filtering zero length data both when sending and receiving socket data. The proposed patch repaired BBS data exchange through ROSE network that were broken since 2.6.22.11 kernel. Signed-off-by: Bernard Pidoux <f6bvp@amsat.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-14CRED: Wrap task credential accesses in the ROSE protocolDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: linux-hams@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-11-03net: '&' reduxAlexey Dobriyan
I want to compile out proc_* and sysctl_* handlers totally and stub them to NULL depending on config options, however usage of & will prevent this, since taking adress of NULL pointer will break compilation. So, drop & in front of every ->proc_handler and every ->strategy handler, it was never needed in fact. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-22netdev: Handle ->addr_list_lock just like ->_xmit_lock for lockdep.David S. Miller
The new address list lock needs to handle the same device layering issues that the _xmit_lock one does. This integrates work done by Patrick McHardy. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-19netns: Use net_eq() to compare net-namespaces for optimization.YOSHIFUJI Hideaki
Without CONFIG_NET_NS, namespace is always &init_net. Compiler will be able to omit namespace comparisons with this patch. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-17netdev: Allocate multiple queues for TX.David S. Miller
alloc_netdev_mq() now allocates an array of netdev_queue structures for TX, based upon the queue_count argument. Furthermore, all accesses to the TX queues are now vectored through the netdev_get_tx_queue() and netdev_for_each_tx_queue() interfaces. This makes it easy to grep the tree for all things that want to get to a TX queue of a net device. Problem spots which are not really multiqueue aware yet, and only work with one queue, can easily be spotted by grepping for all netdev_get_tx_queue() calls that pass in a zero index. Signed-off-by: David S. Miller <davem@davemloft.net>
