path: root/net/rose
2015-03-02net: Kill dev_rebuild_headerEric W. Biederman
Now that there are no more users kill dev_rebuild_header and all of it's implementations. This is long overdue. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02rose: Transmit packets in rose_xmit not rose_rebuild_headerEric W. Biederman
Patterned after the similar code in net/rom this turns out to be a trivial obviously correct transmformation. Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-hams@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02rose: Set the destination address in rose_headerEric W. Biederman
Not setting the destination address is a bug that I suspect causes no problems today, as only the arp code seems to call dev_hard_header and the description I have of rose is that it is expected to be used with a static neigbour table. I have derived the offset and the length of the rose destination address from rose_rebuild_header where arp_find calls neigh_ha_snapshot to set the destination address. Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-hams@vger.kernel.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-02net: Remove iocb argument from sendmsg and recvmsgYing Xue
After TIPC doesn't depend on iocb argument in its internal implementations of sendmsg() and recvmsg() hooks defined in proto structure, no any user is using iocb argument in them at all now. Then we can drop the redundant iocb argument completely from kinds of implementations of both sendmsg() and recvmsg() in the entire networking stack. Cc: Christoph Hellwig <hch@lst.de> Suggested-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Ying Xue <ying.xue@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-11-24new helper: memcpy_from_msg()Al Viro
2014-11-05net: Add and use skb_copy_datagram_msg() helper.David S. Miller
This encapsulates all of the skb_copy_datagram_iovec() callers with call argument signature "skb, offset, msghdr->msg_iov, length". When we move to iov_iters in the networking, the iov_iter object will sit in the msghdr. Having a helper like this means there will be less places to touch during that transformation. Based upon descriptions and patch from Al Viro. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-09-07rose: use %*ph specifierAndy Shevchenko
Instead of dereference each byte let's use %*ph specifier in the printk() calls. Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-15net: set name_assign_type in alloc_netdev()Tom Gundersen
Extend alloc_netdev{,_mq{,s}}() to take name_assign_type as argument, and convert all users to pass NET_NAME_UNKNOWN. Coccinelle patch: @@ expression sizeof_priv, name, setup, txqs, rxqs, count; @@ ( -alloc_netdev_mqs(sizeof_priv, name, setup, txqs, rxqs) +alloc_netdev_mqs(sizeof_priv, name, NET_NAME_UNKNOWN, setup, txqs, rxqs) | -alloc_netdev_mq(sizeof_priv, name, setup, count) +alloc_netdev_mq(sizeof_priv, name, NET_NAME_UNKNOWN, setup, count) | -alloc_netdev(sizeof_priv, name, setup) +alloc_netdev(sizeof_priv, name, NET_NAME_UNKNOWN, setup) ) v9: move comments here from the wrong commit Signed-off-by: Tom Gundersen <teg@jklm.no> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-04-11net: Fix use after free by removing length arg from sk_data_ready callbacks.David S. Miller
Several spots in the kernel perform a sequence like: skb_queue_tail(&sk->s_receive_queue, skb); sk->sk_data_ready(sk, skb->len); But at the moment we place the SKB onto the socket receive queue it can be consumed and freed up. So this skb->len access is potentially to freed up memory. Furthermore, the skb->len can be modified by the consumer so it is possible that the value isn't accurate. And finally, no actual implementation of this callback actually uses the length argument. And since nobody actually cared about it's value, lots of call sites pass arbitrary values in such as '0' and even '1'. So just remove the length argument from the callback, that way there is no confusion whatsoever and all of these use-after-free cases get fixed as a side effect. Based upon a patch by Eric Dumazet and his suggestion to audit this issue tree-wide. Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-18net: add build-time checks for msg->msg_name sizeSteffen Hurrle
This is a follow-up patch to f3d3342602f8bc ("net: rework recvmsg handler msg_name and msg_namelen logic"). DECLARE_SOCKADDR validates that the structure we use for writing the name information to is not larger than the buffer which is reserved for msg->msg_name (which is 128 bytes). Also use DECLARE_SOCKADDR consistently in sendmsg code paths. Signed-off-by: Steffen Hurrle <steffen@hurrle.net> Suggested-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-01-06Merge branch 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/qlogic/qlcnic/qlcnic_sriov_pf.c net/ipv6/ip6_tunnel.c net/ipv6/ip6_vti.c ipv6 tunnel statistic bug fixes conflicting with consolidation into generic sw per-cpu net stats. qlogic conflict between queue counting bug fix and the addition of multiple MAC address support. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-29net: rose: restore old recvmsg behaviorFlorian Westphal
recvmsg handler in net/rose/af_rose.c performs size-check ->msg_namelen. After commit f3d3342602f8bcbf37d7c46641cb9bca7618eb1c (net: rework recvmsg handler msg_name and msg_namelen logic), we now always take the else branch due to namelen being initialized to 0. Digging in netdev-vger-cvs git repo shows that msg_namelen was initialized with a fixed-size since at least 1995, so the else branch was never taken. Compile tested only. Signed-off-by: Florian Westphal <fw@strlen.de> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-22rose: cleanup checkpatch errors,spaces requiredWeilong Chen
This patch add spaces to cleanup checkpatch errors. Signed-off-by: Weilong Chen <chenweilong@huawei.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-11-20net: rework recvmsg handler msg_name and msg_namelen logicHannes Frederic Sowa
This patch now always passes msg->msg_namelen as 0. recvmsg handlers must set msg_namelen to the proper size <= sizeof(struct sockaddr_storage) to return msg_name to the user. This prevents numerous uninitialized memory leaks we had in the recvmsg handlers and makes it harder for new code to accidentally leak uninitialized memory. Optimize for the case recvfrom is called with NULL as address. We don't need to copy the address at all, so set it to NULL before invoking the recvmsg handler. We can do so, because all the recvmsg handlers must cope with the case a plain read() is called on them. read() also sets msg_name to NULL. Also document these changes in include/linux/net.h as suggested by David Miller. Changes since RFC: Set msg->msg_name = NULL if user specified a NULL in msg_name but had a non-null msg_namelen in verify_iovec/verify_compat_iovec. This doesn't affect sendto as it would bail out earlier while trying to copy-in the address. It also more naturally reflects the logic by the callers of verify_iovec. With this change in place I could remove " if (!uaddr || msg_sys->msg_namelen == 0) msg->msg_name = NULL ". This change does not alter the user visible error logic as we ignore msg_namelen as long as msg_name is NULL. Also remove two unnecessary curly brackets in ___sys_recvmsg and change comments to netdev style. Cc: David Miller <davem@davemloft.net> Suggested-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-06-13net: Convert uses of typedef ctl_table to struct ctl_tableJoe Perches
Reduce the uses of this unnecessary typedef. Done via perl script: $ git grep --name-only -w ctl_table net | \ xargs perl -p -i -e '\ sub trim { my ($local) = @_; $local =~ s/(^\s+|\s+$)//g; return $local; } \ s/\b(?<!struct\s)ctl_table\b(\s*\*\s*|\s+\w+)/"struct ctl_table " . trim($1)/ge' Reflow the modified lines that now exceed 80 columns. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-28net: pass info struct via netdevice notifierJiri Pirko
So far, only net_device * could be passed along with netdevice notifier event. This patch provides a possibility to pass custom structure able to provide info that event listener needs to know. Signed-off-by: Jiri Pirko <jiri@resnulli.us> v2->v3: fix typo on simeth shortened dev_getter shortened notifier_info struct name v1->v2: fix notifier_call parameter in call_netdevice_notifier() Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-07rose: fix info leak via msg_name in rose_recvmsg()Mathias Krause
The code in rose_recvmsg() does not initialize all of the members of struct sockaddr_rose/full_sockaddr_rose when filling the sockaddr info. Nor does it initialize the padding bytes of the structure inserted by the compiler for alignment. This will lead to leaking uninitialized kernel stack bytes in net/socket.c. Fix the issue by initializing the memory used for sockaddr info with memset(0). Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-27hlist: drop the node parameter from iteratorsSasha Levin
I'm not sure why, but the hlist for each entry iterators were conceived list_for_each_entry(pos, head, member) The hlist ones were greedy and wanted an extra parameter: hlist_for_each_entry(tpos, pos, head, member) Why did they need an extra pos parameter? I'm not quite sure. Not only they don't really need it, it also prevents the iterator from looking exactly like the list iterator, which is unfortunate. Besides the semantic patch, there was some manual work required: - Fix up the actual hlist iterators in linux/list.h - Fix up the declaration of other iterators based on the hlist ones. - A very small amount of places were using the 'node' parameter, this was modified to use 'obj->member' instead. - Coccinelle didn't handle the hlist_for_each_entry_safe iterator properly, so those had to be fixed up manually. The semantic patch which is mostly the work of Peter Senna Tschudin is here: @@ iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host; type T; expression a,c,d,e; identifier b; statement S; @@ -T b; <+... when != b ( hlist_for_each_entry(a, - b, c, d) S | hlist_for_each_entry_continue(a, - b, c) S | hlist_for_each_entry_from(a, - b, c) S | hlist_for_each_entry_rcu(a, - b, c, d) S | hlist_for_each_entry_rcu_bh(a, - b, c, d) S | hlist_for_each_entry_continue_rcu_bh(a, - b, c) S | for_each_busy_worker(a, c, - b, d) S | ax25_uid_for_each(a, - b, c) S | ax25_for_each(a, - b, c) S | inet_bind_bucket_for_each(a, - b, c) S | sctp_for_each_hentry(a, - b, c) S | sk_for_each(a, - b, c) S | sk_for_each_rcu(a, - b, c) S | sk_for_each_from -(a, b) +(a) S + sk_for_each_from(a) S | sk_for_each_safe(a, - b, c, d) S | sk_for_each_bound(a, - b, c) S | hlist_for_each_entry_safe(a, - b, c, d, e) S | hlist_for_each_entry_continue_rcu(a, - b, c) S | nr_neigh_for_each(a, - b, c) S | nr_neigh_for_each_safe(a, - b, c, d) S | nr_node_for_each(a, - b, c) S | nr_node_for_each_safe(a, - b, c, d) S | - for_each_gfn_sp(a, c, d, b) S + for_each_gfn_sp(a, c, d) S | - for_each_gfn_indirect_valid_sp(a, c, d, b) S + for_each_gfn_indirect_valid_sp(a, c, d) S | for_each_host(a, - b, c) S | for_each_host_safe(a, - b, c, d) S | for_each_mesh_entry(a, - b, c, d) S ) ...+> [akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c] [akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c] [akpm@linux-foundation.org: checkpatch fixes] [akpm@linux-foundation.org: fix warnings] [akpm@linux-foudnation.org: redo intrusive kvm changes] Tested-by: Peter Senna Tschudin <peter.senna@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Gleb Natapov <gleb@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-18net: proc: change proc_net_remove to remove_proc_entryGao feng
proc_net_remove is only used to remove proc entries that under /proc/net,it's not a general function for removing proc entries of netns. if we want to remove some proc entries which under /proc/net/stat/, we still need to call remove_proc_entry. this patch use remove_proc_entry to replace proc_net_remove. we can remove proc_net_remove after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-02-18net: proc: change proc_net_fops_create to proc_createGao feng
Right now, some modules such as bonding use proc_create to create proc entries under /proc/net/, and other modules such as ipv4 use proc_net_fops_create. It looks a little chaos.this patch changes all of proc_net_fops_create to proc_create. we can remove proc_net_fops_create after this patch. Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Convert all sysctl registrations to register_net_sysctlEric W. Biederman
This results in code with less boiler plate that is a bit easier to read. Additionally stops us from using compatibility code in the sysctl core, hastening the day when the compatibility code can be removed. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-20net: Move all of the network sysctls without a namespace into init_net.Eric W. Biederman
This makes it clearer which sysctls are relative to your current network namespace. This makes it a little less error prone by not exposing sysctls for the initial network namespace in other namespaces. This is the same way we handle all of our other network interfaces to userspace and I can't honestly remember why we didn't do this for sysctls right from the start. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-15net: cleanup unsigned to unsigned intEric Dumazet
Use of "unsigned int" is preferred to bare "unsigned" in net tree. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Provide device string properly for USB i2400m wimax devices, also don't OOPS when providing firmware string. From Phil Sutter. 2) Add support for sh_eth SH7734 chips, from Nobuhiro Iwamatsu. 3) Add another device ID to USB zaurus driver, from Guan Xin. 4) Loop index start in pool vector iterator is wrong causing MAC to not get configured in bnx2x driver, fix from Dmitry Kravkov. 5) EQL driver assumes HZ=100, fix from Eric Dumazet. 6) Now that skb_add_rx_frag() can specify the truesize increment separately, do so in f_phonet and cdc_phonet, also from Eric Dumazet. 7) virtio_net accidently uses net_ratelimit() not only on the kernel warning but also the statistic bump, fix from Rick Jones. 8) ip_route_input_mc() uses fixed init_net namespace, oops, use dev_net(dev) instead. Fix from Benjamin LaHaise. 9) dev_forward_skb() needs to clear the incoming interface index of the SKB so that it looks like a new incoming packet, also from Benjamin LaHaise. 10) iwlwifi mistakenly initializes a channel entry as 2GHZ instead of 5GHZ, fix from Stanislav Yakovlev. 11) Missing kmalloc() return value checks in orinoco, from Santosh Nayak. 12) ath9k doesn't check for HT capabilities in the right way, it is checking ht_supported instead of the ATH9K_HW_CAP_HT flag. Fix from Sujith Manoharan. 13) Fix x86 BPF JIT emission of 16-bit immediate field of AND instructions, from Feiran Zhuang. 14) Avoid infinite loop in GARP code when registering sysfs entries. From David Ward. 15) rose protocol uses memcpy instead of memcmp in a device address comparison, oops. Fix from Daniel Borkmann. 16) Fix build of lpc_eth due to dev_hw_addr_rancom() interface being renamed to eth_hw_addr_random(). From Roland Stigge. 17) Make ipv6 RTM_GETROUTE interpret RTA_IIF attribute the same way that ipv4 does. Fix from Shmulik Ladkani. 18) via-rhine has an inverted bit test, causing suspend/resume regressions. Fix from Andreas Mohr. 19) RIONET assumes 4K page size, fix from Akinobu Mita. 20) Initialization of imask register in sky2 is buggy, because bits are "or'd" into an uninitialized local variable. Fix from Lino Sanfilippo. 21) Fix FCOE checksum offload handling, from Yi Zou. 22) Fix VLAN processing regression in e1000, from Jiri Pirko. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (52 commits) sky2: dont overwrite settings for PHY Quick link tg3: Fix 5717 serdes powerdown problem net: usb: cdc_eem: fix mtu net: sh_eth: fix endian check for architecture independent usb/rtl8150 : Remove duplicated definitions rionet: fix page allocation order of rionet_active via-rhine: fix wait-bit inversion. ipv6: Fix RTM_GETROUTE's interpretation of RTA_IIF to be consistent with ipv4 net: lpc_eth: Fix rename of dev_hw_addr_random net/netfilter/nfnetlink_acct.c: use linux/atomic.h rose_dev: fix memcpy-bug in rose_set_mac_address Fix non TBI PHY access; a bad merge undid bug fix in a previous commit. net/garp: avoid infinite loop if attribute already exists x86 bpf_jit: fix a bug in emitting the 16-bit immediate operand of AND bonding: emit event when bonding changes MAC mac80211: fix oper channel timestamp updation ath9k: Use HW HT capabilites properly MAINTAINERS: adding maintainer for ipw2x00 net: orinoco: add error handling for failed kmalloc(). net/wireless: ipw2x00: fix a typo in wiphy struct initilization ...
2012-04-01rose_dev: fix memcpy-bug in rose_set_mac_addressdanborkmann@iogearbox.net
If both addresses equal, nothing needs to be done. If the device is down, then we simply copy the new address to dev->dev_addr. If the device is up, then we add another loopback device with the new address, and if that does not fail, we remove the loopback device with the old address. And only then, we update the dev->dev_addr. Signed-off-by: Daniel Borkmann <daniel.borkmann@tik.ee.ethz.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2011-10-31net: Add export.h for EXPORT_SYMBOL/THIS_MODULE to non-modulesPaul Gortmaker
These files are non modular, but need to export symbols using the macros now living in export.h -- call out the include so that things won't break when we remove the implicit presence of module.h from everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-07-07rose: Delete commented out references to ancient firewalling code.David S. Miller
These intefaces haven't existed since 2.2.x Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-14NET: AX.25, NETROM, ROSE: Remove SOCK_DEBUG callsRalf Baechle
Nobody alive seems to recall when they last were useful. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-27rose: Add length checks to CALL_REQUEST parsingBen Hutchings
Define some constant offsets for CALL_REQUEST based on the description at <http://www.techfest.com/networking/wan/x25plp.htm> and the definition of ROSE as using 10-digit (5-byte) addresses. Use them consistently. Validate all implicit and explicit facilities lengths. Validate the address length byte rather than either trusting or assuming its value. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-27ROSE: prevent heap corruption with bad facilitiesDan Rosenberg
When parsing the FAC_NATIONAL_DIGIS facilities field, it's possible for a remote host to provide more digipeaters than expected, resulting in heap corruption. Check against ROSE_MAX_DIGIS to prevent overflows, and abort facilities parsing on failure. Additionally, when parsing the FAC_CCITT_DEST_NSAP and FAC_CCITT_SRC_NSAP facilities fields, a remote host can provide a length of less than 10, resulting in an underflow in a memcpy size, causing a kernel panic due to massive heap corruption. A length of greater than 20 results in a stack overflow of the callsign array. Abort facilities parsing on these invalid length values. Signed-off-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: stable@kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-14ROSE: AX25: finding routes simplificationBernard Pidoux
With previous patch, rose_get_neigh() routine investigates the full list of neighbor nodes until it finds or not an already connected node whether it is called locally or through a level 3 transit frame. If no routes are opened through an adjacent connected node then a classical connect request is attempted. Then there is no more reason for an extra loop such as the one removed by this patch. Signed-off-by: Bernard Pidoux <f6bvp@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-14ROSE: rose AX25 packet routing improvementBernard Pidoux
FPAC AX25 packet application is using Linux kernel ROSE routing skills in order to connect or send packets to remote stations knowing their ROSE address via a network of interconnected nodes. Each FPAC node has a ROSE routing table that Linux ROSE module is looking at each time a ROSE frame is relayed by the node or when a connect request to a neighbor node is received. A previous patch improved the system time response by looking at already established routes each time the system was looking for a route to relay a frame. If a neighbor node routing the destination address was already connected, then the frame would be sent through him. If not, a connection request would be issued. The present patch extends the same routing capability to a connect request asked by a user locally connected into an FPAC node. Without this patch, a connect request was not well handled unless it was directed to an immediate connected neighbor of the local node. Implemented at a number of ROSE FPAC node stations, the present patch improved dramatically FPAC ROSE routing time response and efficiency. Signed-off-by: Bernard Pidoux <f6bvp@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/qlcnic/qlcnic_init.c net/ipv4/ip_output.c
2010-09-23net: return operator cleanupEric Dumazet
Change "return (EXPR);" to "return EXPR;" return is not a function, parentheses are not required. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-20rose: Fix signedness issues wrt. digi count.David S. Miller
Just use explicit casts, since we really can't change the types of structures exported to userspace which have been around for 15 years or so. Reported-by: Dan Rosenberg <dan.j.rosenberg@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-01net/rose: Use GFP_ATOMICJulia Lawall
The other calls to kmalloc in the same function use GFP_ATOMIC, and indeed two locks are held within the body of the function. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ identifier f; @@ *f(...,GFP_ATOMIC,...) ... when != spin_unlock(...) when != read_unlock(...) when != write_unlock(...) when != read_unlock_irq(...) when != write_unlock_irq(...) when != read_unlock_irqrestore(...) when != write_unlock_irqrestore(...) when != spin_unlock_irq(...) when != spin_unlock_irqrestore(...) *f(...,GFP_KERNEL,...) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20net: sk_sleep() helperEric Dumazet
Define a new function to return the waitqueue of a "struct sock". static inline wait_queue_head_t *sk_sleep(struct sock *sk) { return sk->sk_sleep; } Change all read occurrences of sk_sleep by a call to this function. Needed for a future RCU conversion. sk_sleep wont be a field directly available. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-10net: rose: use seq_hlist_foo() helpersLi Zefan
Simplify seq_file code. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-16ax25: netrom: rose: Fix timer oopsesJarek Poplawski
Wrong ax25_cb refcounting in ax25_send_frame() and by its callers can cause timer oopses (first reported with 2.6.29.6 kernel). Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=14905 Reported-by: Bernard Pidoux <bpidoux@free.fr> Tested-by: Bernard Pidoux <bpidoux@free.fr> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-03rose_loopback_timer sets VC number <= ROSE_DEFAULT_MAXVCBernard Pidoux F6BVP
cat /proc/net/rose displayed a rose sockets abnormal lci value, i.e. greater than maximum number of VCs per neighbour allowed. This number prevents further test of lci value during rose operations. Example (lines shortened) : [bernard]# cat /proc/net/rose dest_addr dest_call src_addr src_call dev lci neigh st vs vr va * * 2080175520 F6BVP-1 rose0 000 00000 0 0 0 0 2080175520 FPAD-0 2080175520 WP-0 rose0 FFE 00001 3 0 0 0 Here are the default parameters : linux/include/net/rose.h:#define ROSE_DEFAULT_MAXVC 50 /* Maximum number of VCs per neighbour */ linux/net/rose/af_rose.c:int sysctl_rose_maximum_vcs = ROSE_DEFAULT_MAXVC; With the following patch, rose_loopback_timer() attributes a VC number within limits. Signed-off-by: Bernard Pidoux <f6bvp@amsat.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-08Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1815 commits) mac80211: fix reorder buffer release iwmc3200wifi: Enable wimax core through module parameter iwmc3200wifi: Add wifi-wimax coexistence mode as a module parameter iwmc3200wifi: Coex table command does not expect a response iwmc3200wifi: Update wiwi priority table iwlwifi: driver version track kernel version iwlwifi: indicate uCode type when fail dump error/event log iwl3945: remove duplicated event logging code b43: fix two warnings ipw2100: fix rebooting hang with driver loaded cfg80211: indent regulatory messages with spaces iwmc3200wifi: fix NULL pointer dereference in pmkid update mac80211: Fix TX status reporting for injected data frames ath9k: enable 2GHz band only if the device supports it airo: Fix integer overflow warning rt2x00: Fix padding bug on L2PAD devices. WE: Fix set events not propagated b43legacy: avoid PPC fault during resume b43: avoid PPC fault during resume tcp: fix a timewait refcnt race ... Fix up conflicts due to sysctl cleanups (dead sysctl_check code and CTL_UNNUMBERED removed) in kernel/sysctl_check.c net/ipv4/sysctl_net_ipv4.c net/ipv6/addrconf.c net/sctp/sysctl.c
2009-11-29net: Move && and || to end of previous lineJoe Perches
Not including net/atm/ Compiled tested x86 allyesconfig only Added a > 80 column line or two, which I ignored. Existing checkpatch plaints willfully, cheerfully ignored. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-17Merge commit 'v2.6.32-rc7'Eric W. Biederman
Resolve the conflict between v2.6.32-rc7 where dn_def_dev_handler gets a small bug fix and the sysctl tree where I am removing all sysctl strategy routines.
2009-11-12sysctl net: Remove unused binary sysctl codeEric W. Biederman
Now that sys_sysctl is a compatiblity wrapper around /proc/sys all sysctl strategy routines, and all ctl_name and strategy entries in the sysctl tables are unused, and can be revmoed. In addition neigh_sysctl_register has been modified to no longer take a strategy argument and it's callers have been modified not to pass one. Cc: "David Miller" <davem@davemloft.net> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: netdev@vger.kernel.org Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2009-11-06Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/usb/cdc_ether.c All CDC ethernet devices of type USB_CLASS_COMM need to use '&mbm_info'. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
