[ Upstream commit d00c362f1b0ff54161e0a42b4554ac621a9ef92d ]
Wrong ax25_cb refcounting in ax25_send_frame() and by its callers can
cause timer oopses (first reported with 2.6.29.6 kernel).
Fixes: http://bugzilla.kernel.org/show_bug.cgi?id=14905
Reported-by: Bernard Pidoux <bpidoux@free.fr>
Tested-by: Bernard Pidoux <bpidoux@free.fr>
Signed-off-by: Jarek Poplawski <jarkao2@gmail.com>
While hunting dev_put() for net-next-2.6, I found a device refcount
leak in ROSE, ioctl(SIOCADDRT) error path.
Fix is to not touch device refcount, as we hold RTNL
This provides safety against negative optlen at the type
level instead of depending upon (sometimes non-trivial)
checks against this sprinkled all over the the place, in
each and every implementation.
Based upon work done by Arjan van de Ven and feedback
from Linus Torvalds.
arch/microblaze/include/asm/socket.h
rose_getname() can leak kernel memory to user.
drivers/net/wireless/iwlwifi/iwl-3945.h
drivers/net/wireless/iwlwifi/iwl-tx.c
drivers/net/wireless/iwlwifi/iwl3945-base.c
The use of a static buffer in rose2asc() to return its result is not
threadproof and can result in corruption if multiple threads are trying
to use one of the procfs files based on rose2asc().
This patch is the result of an automatic spatch transformation to convert
all ndo_start_xmit() return values of 0 to NETDEV_TX_OK.
Some occurences are missed by the automatic conversion, those will be
handled in a seperate patch.
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80
(net: No more expensive sock_hold()/sock_put() on each tx)
changed initial sk_wmem_alloc value.
We need to take into account this offset when reporting
sk_wmem_alloc to user, in PROC_FS files or various
ioctls (SIOCOUTQ/TIOCOUTQ)
Some protocols check sk_wmem_alloc value to determine if a timer
must delay socket deallocation. We must take care of the sk_wmem_alloc
value being one instead of zero when no write allocations are pending.
Reported by Ingo Molnar, and full diagnostic from David Miller.
This patch introduces three helpers to get read/write allocations
and a followup patch will use these helpers to report correct
write allocations to user.
Reported-by: Ingo Molnar <mingo@elte.hu>
Convert magic values 1 and -1 to NETDEV_TX_BUSY and NETDEV_TX_LOCKED respectively.
0 (NETDEV_TX_OK) is not changed to keep the noise down, except in very few cases
where its in direct proximity to one of the other values.
This reverts commit 244f46ae6e9e18f6fc0be7d1f49febde4762c34b.
Alan Cox did the research, and just like the other radio protocols
zero-length frames have meaning because at the top level ROSE is
X.25 PLP.
So this zero-length filtering is invalid.
Otherwise we can wrap the sizes and end up sending garbage.
Closes #10423
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits)
net: Allow dependancies of FDDI & Tokenring to be modular.
igb: Fix build warning when DCA is disabled.
net: Fix warning fallout from recent NAPI interface changes.
gro: Fix potential use after free
sfc: If AN is enabled, always read speed/duplex from the AN advertising bits
sfc: When disabling the NIC, close the device rather than unregistering it
sfc: SFT9001: Add cable diagnostics
sfc: Add support for multiple PHY self-tests
sfc: Merge top-level functions for self-tests
sfc: Clean up PHY mode management in loopback self-test
sfc: Fix unreliable link detection in some loopback modes
sfc: Generate unique names for per-NIC workqueues
802.3ad: use standard ethhdr instead of ad_header
802.3ad: generalize out mac address initializer
802.3ad: initialize ports LACPDU from const initializer
802.3ad: remove typedef around ad_system
802.3ad: turn ports is_individual into a bool
802.3ad: turn ports is_enabled into a bool
802.3ad: make ntt bool
ixgbe: Fix set_ringparam in ixgbe to use the same memory pools.
Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due
to the conversion to %pI (in this networking merge) and the addition of
doing IPv6 addresses (from the earlier merge of CIFS).
fs/nfsd/nfs4recover.c
Manually fixed above to use new creds API functions, e.g.
nfs4_save_creds().
Signed-off-by: James Morris <jmorris@namei.org>
drivers/net/hp-plus.c
drivers/net/wireless/ath5k/base.c
drivers/net/wireless/ath9k/recv.c
net/wireless/reg.c
Since changeset e79ad711a0108475c1b3a03815527e7237020b08 from mainline,
>From David S. Miller,
empty packet can be transmitted on connected socket for datagram protocols.
However, this patch broke a high level application using ROSE network protocol with connected datagram.
Bulletin Board Stations perform bulletins forwarding between BBS stations via ROSE network using a forward protocol.
Now, if for some reason, a buffer in the application software happens to be empty at a specific moment,
ROSE sends an empty packet via unfiltered packet socket.
When received, this ROSE packet introduces perturbations of data exchange of BBS forwarding,
for the application message forwarding protocol is waiting for something else.
We agree that a more careful programming of the application protocol would avoid this situation and we are
willing to debug it.
But, as an empty frame is no use and does not have any meaning for ROSE protocol,
we may consider filtering zero length data both when sending and receiving socket data.
The proposed patch repaired BBS data exchange through ROSE network that were broken since 2.6.22.11 kernel.
Signed-off-by: Bernard Pidoux <f6bvp@amsat.org>
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Cc: linux-hams@vger.kernel.org
I want to compile out proc_* and sysctl_* handlers totally and
stub them to NULL depending on config options, however usage of &
will prevent this, since taking adress of NULL pointer will break
compilation.
So, drop & in front of every ->proc_handler and every ->strategy
handler, it was never needed in fact.
The new address list lock needs to handle the same device layering
issues that the _xmit_lock one does.
This integrates work done by Patrick McHardy.
Without CONFIG_NET_NS, namespace is always &init_net.
Compiler will be able to omit namespace comparisons with this patch.
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
alloc_netdev_mq() now allocates an array of netdev_queue
structures for TX, based upon the queue_count argument.
Furthermore, all accesses to the TX queues are now vectored
through the netdev_get_tx_queue() and netdev_for_each_tx_queue()
interfaces. This makes it easy to grep the tree for all
things that want to get to a TX queue of a net device.
Problem spots which are not really multiqueue aware yet, and
only work with one queue, can easily be spotted by grepping
for all netdev_get_tx_queue() calls that pass in a zero index.
Accesses are mostly structured such that when there are multiple TX
queues the code transformations will be a little bit simpler.
ROSE network is organized through nodes connected via hamradio or Internet.
AX25 packet radio frames sent to a remote ROSE address destination are routed
through these nodes.
Without the present patch, automatic routing mechanism did not work optimally
due to an improper parameter checking.
rose_get_neigh() function is called either by rose_connect() or by
rose_route_frame().
In the case of a call from rose_connect(), f0 timer is checked to find if a connection
is already pending. In that case it returns the address of the neighbour, or returns a NULL otherwise.
When called by rose_route_frame() the purpose was to route a packet AX25 frame
through an adjacent node given a destination rose address.
However, in that case, t0 timer checked does not indicate if the adjacent node
is actually connected even if the timer is not null. Thus, for each frame sent, the
function often tried to start a new connexion even if the adjacent node was already connected.
The patch adds a "new" parameter that is true when the function is called by
rose route_frame().
This instructs rose_get_neigh() to check node parameter "restarted".
If restarted is true it means that the route to the destination address is opened via a neighbour
node already connected.
If "restarted" is false the function returns a NULL.
In that case the calling function will initiate a new connection as before.
This results in a fast routing of frames, from nodes to nodes, until
destination is reached, as originaly specified by ROSE protocole.
This is the rose variant of changeset
9375cb8a1232d2a15fe34bec4d3474872e02faec
("ax25: Use sock_graft() and remove bogus sk_socket and sk_sleep init.")
In rose_node_start() as well as in rose_node_stop() __acquires() and
spin_lock_bh() were wrongly passing rose_neigh_list_lock instead of
rose_node_list_lock arguments.
[ INFO: possible recursive locking detected ]
2.6.25 #3
ax25ipd/3811 is trying to acquire lock:
(rose_node_list_lock){-+..}, at: [<f8d31f1a>] rose_get_neigh+0x1a/0xa0
[rose]
but task is already holding lock:
(rose_node_list_lock){-+..}, at: [<f8d31fed>]
rose_route_frame+0x4d/0x620 [rose]
6 locks held by ax25ipd/3811:
#0: (&tty->atomic_write_lock){--..}, at: [<c0259a1c>]
tty_write_lock+0x1c/0x50
#1: (rcu_read_lock){..--}, at: [<c02aea36>] net_rx_action+0x96/0x230
#2: (rcu_read_lock){..--}, at: [<c02ac5c0>] netif_receive_skb+0x100/0x2f0
#3: (rose_node_list_lock){-+..}, at: [<f8d31fed>]
#4: (rose_neigh_list_lock){-+..}, at: [<f8d31ff7>]
rose_route_frame+0x57/0x620 [rose]
#5: (rose_route_list_lock){-+..}, at: [<f8d32001>]
rose_route_frame+0x61/0x620 [rose]
stack backtrace:
Pid: 3811, comm: ax25ipd Not tainted 2.6.25 #3
[<c0147e27>] print_deadlock_bug+0xc7/0xd0
[<c0147eca>] check_deadlock+0x9a/0xb0
[<c0149cd2>] validate_chain+0x1e2/0x310
[<c0149b95>] ? validate_chain+0xa5/0x310
[<c010a7d8>] ? native_sched_clock+0x88/0xc0
[<c0149fa1>] __lock_acquire+0x1a1/0x750
[<c014a5d1>] lock_acquire+0x81/0xa0
[<f8d31f1a>] ? rose_get_neigh+0x1a/0xa0 [rose]
[<c03201a3>] _spin_lock_bh+0x33/0x60
[<f8d31f1a>] rose_get_neigh+0x1a/0xa0 [rose]
[<f8d32404>] rose_route_frame+0x464/0x620 [rose]
[<c031ffdd>] ? _read_unlock+0x1d/0x20
[<f8d31fa0>] ? rose_route_frame+0x0/0x620 [rose]
[<f8d1c396>] ax25_rx_iframe+0x66/0x3b0 [ax25]
[<f8d1f42f>] ? ax25_start_t3timer+0x1f/0x40 [ax25]
[<f8d1e65b>] ax25_std_frame_in+0x7fb/0x890 [ax25]
[<c0320005>] ? _spin_unlock_bh+0x25/0x30
[<f8d1bdf6>] ax25_kiss_rcv+0x2c6/0x800 [ax25]
[<c02a4769>] ? sock_def_readable+0x59/0x80
[<c014a8a7>] ? __lock_release+0x47/0x70
[<c02a4d3a>] ? sock_queue_rcv_skb+0x13a/0x1d0
[<c02a4c45>] ? sock_queue_rcv_skb+0x45/0x1d0
[<f8d1bb30>] ? ax25_kiss_rcv+0x0/0x800 [ax25]
[<c02ac715>] netif_receive_skb+0x255/0x2f0
[<c02ac5c0>] ? netif_receive_skb+0x100/0x2f0
[<c02af05c>] process_backlog+0x7c/0xf0
[<c02aeb0c>] net_rx_action+0x16c/0x230
[<c02aea36>] ? net_rx_action+0x96/0x230
[<c012bd53>] __do_softirq+0x93/0x120
[<f8d2a68a>] ? mkiss_receive_buf+0x33a/0x3f0 [mkiss]
[<c012be37>] do_softirq+0x57/0x60
[<c012c265>] local_bh_enable_ip+0xa5/0xe0
[<c0320005>] _spin_unlock_bh+0x25/0x30
[<f8d2a68a>] mkiss_receive_buf+0x33a/0x3f0 [mkiss]
[<c025ea37>] pty_write+0x47/0x60
[<c025c620>] write_chan+0x1b0/0x220
[<c0259a1c>] ? tty_write_lock+0x1c/0x50
[<c011fec0>] ? default_wake_function+0x0/0x10
[<c0259bea>] tty_write+0x12a/0x1c0
[<c025c470>] ? write_chan+0x0/0x220
[<c018bbc6>] vfs_write+0x96/0x130
[<c0259ac0>] ? tty_write+0x0/0x1c0
[<c018c24d>] sys_write+0x3d/0x70
[<c0104d1e>] sysenter_past_esp+0x5f/0xa5
BUG: soft lockup - CPU#0 stuck for 61s! [ax25ipd:3811]
Pid: 3811, comm: ax25ipd Not tainted (2.6.25 #3)
EIP: 0060:[<c010a9db>] EFLAGS: 00000246 CPU: 0
EIP is at native_read_tsc+0xb/0x20
EAX: b404aa2c EBX: b404a9c9 ECX: 017f1000 EDX: 0000076b
ESI: 00000001 EDI: 00000000 EBP: ecc83afc ESP: ecc83afc
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
CR0: 8005003b CR2: b7f5f000 CR3: 2cd8e000 CR4: 000006f0
DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000
DR6: ffff0ff0 DR7: 00000400
[<c0204937>] delay_tsc+0x17/0x30
[<c02048e9>] __delay+0x9/0x10
[<c02127f6>] __spin_lock_debug+0x76/0xf0
[<c0212618>] ? spin_bug+0x18/0x100
[<c0147923>] ? __lock_contended+0xa3/0x110
[<c0212998>] _raw_spin_lock+0x68/0x90
[<c03201bf>] _spin_lock_bh+0x4f/0x60
Since rose_route_frame() does not use rose_node_list we can safely
remove rose_node_list_lock spin lock here and let it be free for
rose_get_neigh().
[ BUG: lock held when returning to user space! ]
xfbbd/3683 is leaving the kernel with locks still held!
1 lock held by xfbbd/3683:
#0: (sk_lock-AF_ROSE){--..}, at: [<c8cd1eb3>] rose_connect+0x73/0x420 [rose]
INFO: task xfbbd:3683 blocked for more than 120 seconds.
"echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
xfbbd D 00000246 0 3683 3669
c6965ee0 00000092 c02c5c40 00000246 c0f6b5f0 c0f6b5c0 c0f6b5f0 c0f6b5c0
c0f6b614 c6965f18 c024b74b ffffffff c06ba070 00000000 00000000 00000001
c6ab07c0 c012d450 c0f6b634 c0f6b634 c7b5bf10 c0d6004c c7b5bf10 c6965f40
Call Trace:
[<c024b74b>] lock_sock_nested+0x6b/0xd0
[<c012d450>] ? autoremove_wake_function+0x0/0x40
[<c02488f1>] sock_fasync+0x41/0x150
[<c0249e69>] sock_close+0x19/0x40
[<c0175d54>] __fput+0xb4/0x170
[<c0176018>] fput+0x18/0x20
[<c017300e>] filp_close+0x3e/0x70
[<c01744e9>] sys_close+0x69/0xb0
[<c0103bda>] sysenter_past_esp+0x5f/0xa5
INFO: lockdep is turned off.
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
drivers/net/s2io.c
rose_release() doesn't release sockets properly, e.g. it skips
sock_orphan(), so OOPSes are triggered in sock_def_write_space(),
which was observed especially while ROSE skbs were kfreed from
ax25_frames_acked(). There is also sock_hold() and lock_sock() added -
similarly to ax25_release(). Thanks to Bernard Pidoux for substantial
help in debugging this problem.
Reported-and-tested-by: Bernard Pidoux <bpidoux@free.fr>
Introduce per-sock inlines: sock_net(), sock_net_set()
and per-inet_timewait_sock inlines: twsk_net(), twsk_net_set().
Without CONFIG_NET_NS, no namespace other than &init_net exists.
Let's explicitly define them to help compiler optimizations.
Introduce per-net_device inlines: dev_net(), dev_net_set().
CHECK net/rose/af_rose.c
net/rose/af_rose.c:125:11: warning: expensive signed divide
net/rose/af_rose.c:976:46: warning: expensive signed divide
net/rose/af_rose.c:1379:13: warning: context imbalance in 'rose_info_start' - wrong count at exit
net/rose/af_rose.c:1406:13: warning: context imbalance in 'rose_info_stop' - unexpected unlock
CHECK net/rose/rose_in.c
net/rose/rose_in.c:185:25: warning: expensive signed divide
CHECK net/rose/rose_route.c
net/rose/rose_route.c:997:46: warning: expensive signed divide
net/rose/rose_route.c:1070:13: warning: context imbalance in 'rose_node_start' - wrong count at exit
net/rose/rose_route.c:1093:13: warning: context imbalance in 'rose_node_stop' - unexpected unlock
net/rose/rose_route.c:1146:13: warning: context imbalance in 'rose_neigh_start' - wrong count at exit
net/rose/rose_route.c:1169:13: warning: context imbalance in 'rose_neigh_stop' - unexpected unlock
net/rose/rose_route.c:1229:13: warning: context imbalance in 'rose_route_start' - wrong count at exit
net/rose/rose_route.c:1252:13: warning: context imbalance in 'rose_route_stop' - unexpected unlock
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
This patch includes many places, that only required
replacing the ctl_table-s with appropriate ctl_paths
and call register_sysctl_paths().
Nothing special was done with them.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Many-many code in the kernel initialized the timer->function
and timer->data together with calling init_timer(timer). There
is already a helper for this. Use it for networking code.
The patch is HUGE, but makes the code 130 lines shorter
(98 insertions(+), 228 deletions(-)).
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
The rose_rebuild_header() consists only of some variables in
case INET=n, and gcc will warn us about it.
Finally, the zero_it argument can be completely removed from
the callers and from the function prototype.
Besides, fix the checkpatch.pl warnings about using the
assignments inside if-s.
This patch is rather big, and it is a part of the previous one.
I splitted it wishing to make the patches more readable. Hope
this particular split helped.
Since hardware header operations are part of the protocol class
not the device instance, make them into a separate object and
save memory.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
This patch makes most of the generic device layer network
namespace safe. This patch makes dev_base_head a
network namespace variable, and then it picks up
a few associated variables. The functions:
dev_getbyhwaddr
dev_getfirsthwbytype
dev_get_by_flags
dev_get_by_name
__dev_get_by_name
dev_get_by_index
__dev_get_by_index
dev_ioctl
dev_ethtool
dev_load
wireless_process_ioctl
were modified to take a network namespace argument, and
deal with it.
vlan_ioctl_set and brioctl_set were modified so their
hooks will receive a network namespace argument.
So basically anthing in the core of the network stack that was
affected to by the change of dev_base was modified to handle
multiple network namespaces. The rest of the network stack was
simply modified to explicitly use &init_net the initial network
namespace. This can be fixed when those components of the network
stack are modified to handle multiple network namespaces.
For now the ifindex generator is left global.
Fundametally ifindex numbers are per namespace, or else
we will have corner case problems with migration when
we get that far.
At the same time there are assumptions in the network stack
that the ifindex of a network device won't change. Making
the ifindex number global seems a good compromise until
the network stack can cope with ifindex changes when
you change namespaces, and the like.
Every user of the network device notifiers is either a protocol
stack or a pseudo device. If a protocol stack that does not have
support for multiple network namespaces receives an event for a
device that is not in the initial network namespace it quite possibly
can get confused and do the wrong thing.
To avoid problems until all of the protocol stacks are converted
this patch modifies all netdev event handlers to ignore events on
devices that are not in the initial network namespace.
As the rest of the code is made network namespace aware these
checks can be removed.
This patch passes in the namespace a new socket should be created in
and has the socket code do the appropriate reference counting. By
virtue of this all socket create methods are touched. In addition
the socket create methods are modified so that they will fail if
you attempt to create a socket in a non-default network namespace.
Failing if we attempt to create a socket outside of the default
network namespace ensures that as we incrementally make the network stack
network namespace aware we will not export functionality that someone
has not audited and made certain is network namespace safe.
Allowing us to partially enable network namespaces before all of the
exotic protocols are supported.
Any protocol layers I have missed will fail to compile because I now
pass an extra parameter into the socket creation code.
[ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ]
This patch makes /proc/net per network namespace. It modifies the global
variables proc_net and proc_net_stat to be per network namespace.
The proc_net file helpers are modified to take a network namespace argument,
and all of their callers are fixed to pass &init_net for that argument.
This ensures that all of the /proc/net files are only visible and
usable in the initial network namespace until the code behind them
has been updated to be handle multiple network namespaces.
Making /proc/net per namespace is necessary as at least some files
in /proc/net depend upon the set of network devices which is per
network namespace, and even more files in /proc/net have contents
that are relevant to a single network namespace.
Commit a3d384029aa304f8f3f5355d35f0ae274454f7cd aka
"[AX.25]: Fix unchecked rose_add_loopback_neigh uses"
transformed rose_loopback_neigh var into statically allocated one.
However, on unload it will be kfree's which can't work.
Steps to reproduce:
modprobe rose
rmmod rose
BUG: unable to handle kernel NULL pointer dereference at virtual address 00000008
printing eip:
c014c664
*pde = 00000000
Oops: 0000 [#1]
PREEMPT DEBUG_PAGEALLOC
Modules linked in: rose ax25 fan ufs loop usbhid rtc snd_intel8x0 snd_ac97_codec ehci_hcd ac97_bus uhci_hcd thermal usbcore button processor evdev sr_mod cdrom
CPU: 0
EIP: 0060:[<c014c664>] Not tainted VLI
EFLAGS: 00210086 (2.6.23-rc9 #3)
EIP is at kfree+0x48/0xa1
eax: 00000556 ebx: c1734aa0 ecx: f6a5e000 edx: f7082000
esi: 00000000 edi: f9a55d20 ebp: 00200287 esp: f6a5ef28
ds: 007b es: 007b fs: 0000 gs: 0033 ss: 0068
Process rmmod (pid: 1823, ti=f6a5e000 task=f7082000 task.ti=f6a5e000)
Stack: f9a55d20 f9a5200c 00000000 00000000 00000000 f6a5e000 f9a5200c f9a55a00
00000000 bf818cf0 f9a51f3f f9a55a00 00000000 c0132c60 65736f72 00000000
f69f9630 f69f9528 c014244a f6a4e900 00200246 f7082000 c01025e6 00000000
Call Trace:
[<f9a5200c>] rose_rt_free+0x1d/0x49 [rose]
[<f9a51f3f>] rose_exit+0x4c/0xd5 [rose]
[<c0132c60>] sys_delete_module+0x15e/0x186
[<c014244a>] remove_vma+0x40/0x45
[<c01025e6>] sysenter_past_esp+0x8f/0x99
[<c012bacf>] trace_hardirqs_on+0x118/0x13b
[<c01025b6>] sysenter_past_esp+0x5f/0x99
Code: 05 03 1d 80 db 5b c0 8b 03 25 00 40 02 00 3d 00 40 02 00 75 03 8b 5b 0c 8b 73 10 8b 44 24 18 89 44 24 04 9c 5d fa e8 77 df fd ff <8b> 56 08 89 f8 e8 84 f4 fd ff e8 bd 32 06 00 3b 5c 86 60 75 0f
EIP: [<c014c664>] kfree+0x48/0xa1 SS:ESP 0068:f6a5ef28
Make all initialized struct seq_operations in net/ const
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Cleanup of dev_base list use, with the aim to simplify making device
list per-namespace. In almost every occasion, use of dev_base variable
and dev->next pointer could be easily replaced by for_each_netdev
loop. A few most complicated places were converted to using
first_netdev()/next_netdev().
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
Acked-by: Kirill Korotaev <dev@openvz.org>
