[ Upstream commit f0308fb0708078d6c1d8a4d533941a7a191af634 ]
If an ICMP packet comes in on the UDP socket backing an AF_RXRPC socket as
the UDP socket is being shut down, rxrpc_error_report() may get called to
deal with it after sk_user_data on the UDP socket has been cleared, leading
to a NULL pointer access when this local endpoint record gets accessed.
Fix this by just returning immediately if sk_user_data was NULL.
The oops looks like the following:
#PF: supervisor read access in kernel mode
#PF: error_code(0x0000) - not-present page
RIP: 0010:rxrpc_error_report+0x1bd/0x6a9
Call Trace:
? sock_queue_err_skb+0xbd/0xde
? __udp4_lib_err+0x313/0x34d
icmp_unreach+0x1ee/0x207
icmp_rcv+0x25b/0x28f
ip_protocol_deliver_rcu+0x95/0x10e
ip_local_deliver+0xe9/0x148
__netif_receive_skb_one_core+0x52/0x6e
process_backlog+0xdc/0x177
net_rx_action+0xf9/0x270
__do_softirq+0x1b6/0x39a
? smpboot_register_percpu_thread+0xce/0xce
run_ksoftirqd+0x1d/0x42
smpboot_thread_fn+0x19e/0x1b3
kthread+0xf1/0xf6
? kthread_delayed_work_timer_fn+0x83/0x83
ret_from_fork+0x24/0x30
Fixes: 17926a79320a ("[AF_RXRPC]: Provide secure RxRPC sockets for use by userspace and kernel both")
Reported-by: syzbot+611164843bd48cc2190c@syzkaller.appspotmail.com
commit c48fc11b69e95007109206311b0187a3090591f3 upstream.
When sendmsg() finds a call to continue on with, if the call is in an
inappropriate state, it doesn't release the ref it just got on that call
before returning an error.
This causes the following symptom to show up with kasan:
BUG: KASAN: use-after-free in rxrpc_send_keepalive+0x8a2/0x940
net/rxrpc/output.c:635
Read of size 8 at addr ffff888064219698 by task kworker/0:3/11077
where line 635 is:
whdr.epoch = htonl(peer->local->rxnet->epoch);
The local endpoint (which cannot be pinned by the call) has been released,
but not the peer (which is pinned by the call).
Fix this by releasing the call in the error path.
Fixes: 37411cad633f ("rxrpc: Fix potential NULL-pointer exception")
Reported-by: syzbot+d850c266e3df14da1d31@syzkaller.appspotmail.com
[ Upstream commit e835ada07091f40dcfb1bc735082bd0a7c005e59 ]
If sendmsg() or sendmmsg() is called on a connected socket that hasn't had
bind() called on it, then an oops will occur when the kernel tries to
connect the call because no local endpoint has been allocated.
Fix this by implicitly binding the socket if it is in the
RXRPC_CLIENT_UNBOUND state, just like it does for the RXRPC_UNBOUND state.
Further, the state should be transitioned to RXRPC_CLIENT_BOUND after this
to prevent further attempts to bind it.
This can be tested with:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <sys/socket.h>
#include <arpa/inet.h>
#include <linux/rxrpc.h>
static const unsigned char inet6_addr[16] = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, -1, -1, 0xac, 0x14, 0x14, 0xaa
int main(void)
struct sockaddr_rxrpc srx;
struct cmsghdr *cm;
struct msghdr msg;
unsigned char control[16];
int fd;
memset(&srx, 0, sizeof(srx));
srx.srx_family = 0x21;
srx.srx_service = 0;
srx.transport_type = AF_INET;
srx.transport_len = 0x1c;
srx.transport.sin6.sin6_family = AF_INET6;
srx.transport.sin6.sin6_port = htons(0x4e22);
srx.transport.sin6.sin6_flowinfo = htons(0x4e22);
srx.transport.sin6.sin6_scope_id = htons(0xaa3b);
memcpy(&srx.transport.sin6.sin6_addr, inet6_addr, 16);
cm = (struct cmsghdr *)control;
cm->cmsg_len = CMSG_LEN(sizeof(unsigned long));
cm->cmsg_level = SOL_RXRPC;
cm->cmsg_type = RXRPC_USER_CALL_ID;
*(unsigned long *)CMSG_DATA(cm) = 0;
msg.msg_name = NULL;
msg.msg_namelen = 0;
msg.msg_iov = NULL;
msg.msg_iovlen = 0;
msg.msg_control = control;
msg.msg_controllen = cm->cmsg_len;
msg.msg_flags = 0;
fd = socket(AF_RXRPC, SOCK_DGRAM, AF_INET);
connect(fd, (struct sockaddr *)&srx, sizeof(srx));
sendmsg(fd, &msg, 0);
return 0;
Leading to the following oops:
BUG: kernel NULL pointer dereference, address: 0000000000000018
RIP: 0010:rxrpc_connect_call+0x42/0xa01
Call Trace:
? mark_held_locks+0x47/0x59
? __local_bh_enable_ip+0xb6/0xba
rxrpc_new_client_call+0x3b1/0x762
? rxrpc_do_sendmsg+0x3c0/0x92e
rxrpc_sendmsg+0x16b/0x1b5
sock_sendmsg+0x2d/0x39
___sys_sendmsg+0x1a4/0x22a
? release_sock+0x19/0x9e
? reacquire_held_locks+0x136/0x160
? find_held_lock+0x2b/0x6e
? __lock_acquire+0x268/0xf73
? rxrpc_connect+0xdd/0xe4
__sys_sendmsg+0x5e/0x94
do_syscall_64+0x7d/0x1bf
entry_SYSCALL_64_after_hwframe+0x49/0xbe
Fixes: 2341e0775747 ("rxrpc: Simplify connect() implementation and simplify sendmsg() op")
Reported-by: syzbot+7966f2a0b2c7da8939b4@syzkaller.appspotmail.com
Reviewed-by: Marc Dionne <marc.dionne@auristor.com>
[ Upstream commit b13023421b5179413421333f602850914f6a7ad8 ]
In rxrpc_destroy_all_calls(), there are two phases: (1) make sure the
->calls list is empty, emitting error messages if not, and (2) wait for the
RCU cleanup to happen on outstanding calls (ie. ->nr_calls becomes 0).
To avoid taking the call_lock, the function prechecks ->calls and if empty,
it returns to avoid taking the lock - this is wrong, however: it still
needs to go and do the second phase and wait for ->nr_calls to become 0.
Without this, the rxrpc_net struct may get deallocated before we get to the
RCU cleanup for the last calls. This can lead to:
Slab corruption (Not tainted): kmalloc-16k start=ffff88802b178000, len=16384
050: 6b 6b 6b 6b 6b 6b 6b 6b 61 6b 6b 6b 6b 6b 6b 6b kkkkkkkkakkkkkkk
Note the "61" at offset 0x58. This corresponds to the ->nr_calls member of
struct rxrpc_net (which is >9k in size, and thus allocated out of the 16k
slab).
Fix this by flipping the condition on the if-statement, putting the locked
section inside the if-body and dropping the return from there. The
function will then always go on to wait for the RCU cleanup on outstanding
calls.
Fixes: 2baec2c3f854 ("rxrpc: Support network namespacing")
[ Upstream commit 69ffaebb90369ce08657b5aea4896777b9d6e8fc ]
rxrpc_get_client_conn() adds a new call to the front of the waiting_calls
queue if the connection it's going to use already exists. This is bad as
it allows calls to get starved out.
Fix this by adding to the tail instead.
Also change the other enqueue point in the same function to put it on the
front (ie. when we have a new connection). This makes the point that in
the case of a new connection the new call goes at the front (though it
doesn't actually matter since the queue should be unoccupied).
Fixes: 45025bceef17 ("rxrpc: Improve management and caching of client connection objects")
[ Upstream commit 6dce3c20ac429e7a651d728e375853370c796e8d ]
When either "goto wait_interrupted;" or "goto wait_error;"
paths are taken, socket lock has already been released.
This patch fixes following syzbot splat :
WARNING: bad unlock balance detected!
5.0.0-rc4+ #59 Not tainted
syz-executor223/8256 is trying to release lock (sk_lock-AF_RXRPC) at:
[<ffffffff86651353>] rxrpc_recvmsg+0x6d3/0x3099 net/rxrpc/recvmsg.c:598
but there are no more locks to release!
1 lock held by syz-executor223/8256:
#0: 00000000fa9ed0f4 (slock-AF_RXRPC){+...}, at: spin_lock_bh include/linux/spinlock.h:334 [inline]
#0: 00000000fa9ed0f4 (slock-AF_RXRPC){+...}, at: release_sock+0x20/0x1c0 net/core/sock.c:2798
stack backtrace:
CPU: 1 PID: 8256 Comm: syz-executor223 Not tainted 5.0.0-rc4+ #59
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x172/0x1f0 lib/dump_stack.c:113
print_unlock_imbalance_bug kernel/locking/lockdep.c:3391 [inline]
print_unlock_imbalance_bug.cold+0x114/0x123 kernel/locking/lockdep.c:3368
__lock_release kernel/locking/lockdep.c:3601 [inline]
lock_release+0x67e/0xa00 kernel/locking/lockdep.c:3860
sock_release_ownership include/net/sock.h:1471 [inline]
release_sock+0x183/0x1c0 net/core/sock.c:2808
sock_recvmsg_nosec net/socket.c:794 [inline]
sock_recvmsg net/socket.c:801 [inline]
sock_recvmsg+0xd0/0x110 net/socket.c:797
__sys_recvfrom+0x1ff/0x350 net/socket.c:1845
__do_sys_recvfrom net/socket.c:1863 [inline]
__se_sys_recvfrom net/socket.c:1859 [inline]
__x64_sys_recvfrom+0xe1/0x1a0 net/socket.c:1859
do_syscall_64+0x103/0x610 arch/x86/entry/common.c:290
RIP: 0033:0x446379
Code: e8 2c b3 02 00 48 83 c4 18 c3 0f 1f 80 00 00 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 0f 83 2b 09 fc ff c3 66 2e 0f 1f 84 00 00 00 00
RSP: 002b:00007fe5da89fd98 EFLAGS: 00000246 ORIG_RAX: 000000000000002d
RAX: ffffffffffffffda RBX: 00000000006dbc28 RCX: 0000000000446379
RDX: 0000000000000000 RSI: 0000000000000000 RDI: 0000000000000003
RBP: 00000000006dbc20 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00000000006dbc2c
R13: 0000000000000000 R14: 0000000000000000 R15: 20c49ba5e353f7cf
Fixes: 248f219cb8bc ("rxrpc: Rewrite the data and ack handling code")
Reported-by: syzbot <syzkaller@googlegroups.com>
[ Upstream commit 647530924f47c93db472ee3cf43b7ef1425581b6 ]
Fix connection-level abort handling to cache the abort and error codes
properly so that a new incoming call can be properly aborted if it races
with the parent connection being aborted by another CPU.
The abort_code and error parameters can then be dropped from
rxrpc_abort_calls().
Fixes: f5c17aaeb2ae ("rxrpc: Calls should only have one terminal state")
[ Upstream commit 298bc15b2079c324e82d0a6fda39c3d762af7282 ]
Move the out-of-order and duplicate ACK packet check to before the call to
rxrpc_input_ackinfo() so that the receive window size and MTU size are only
checked in the latest ACK packet and don't regress.
[ Upstream commit c479d5f2c2e1ce609da08c075054440d97ddff52 ]
We should only call the function to end a call's Tx phase if we rotated the
marked-last packet out of the transmission buffer.
Make rxrpc_rotate_tx_window() return an indication of whether it just
rotated the packet marked as the last out of the transmit buffer, carrying
the information out of the locked section in that function.
We can then check the return value instead of examining RXRPC_CALL_TX_LAST.
Fixes: 70790dbe3f66 ("rxrpc: Pass the last Tx packet marker in the annotation buffer")
[ Upstream commit c01f6c9b3207e52fc9973a066a856ddf7a0538d8 ]
There just check the user call ID isn't already in use, hence should
compare user_call_ID with xcall->user_call_ID, which is current
node's user_call_ID.
Fixes: 540b1c48c37a ("rxrpc: Fix deadlock between call creation and sendmsg/recvmsg")
Suggested-by: David Howells <dhowells@redhat.com>
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
[ Upstream commit 93864fc3ffcc4bf70e96cfb5cc6e941630419ad0 ]
Fix the kernel call initiation to set the minimum security level for kernel
initiated calls (such as from kAFS) from the sockopt value.
Fixes: 19ffa01c9c45 ("rxrpc: Use structs to hold connection params and protocol info")
[ Upstream commit f2aeed3a591ff29a82495eeaa92ac4780bad7487 ]
AF_RXRPC tries to turn on IP_RECVERR and IP_MTU_DISCOVER on the UDP socket
it just opened for communications with the outside world, regardless of the
type of socket. Unfortunately, this doesn't work with an AF_INET6 socket.
Fix this by turning on IPV6_RECVERR and IPV6_MTU_DISCOVER instead if the
socket is of the AF_INET6 family.
Without this, kAFS server and address rotation doesn't work correctly
because the algorithm doesn't detect received network errors.
Fixes: 75b54cb57ca3 ("rxrpc: Add IPv6 support")
[ Upstream commit 57b0c9d49b94bbeb53649b7fbd264603c1ebd585 ]
If a call-level abort is received for the previous call to complete on a
connection channel, then that abort is queued for the connection processor
to handle. Unfortunately, the connection processor then assumes without
checking that the abort is connection-level (ie. callNumber is 0) and
distributes it over all active calls on that connection, thereby
incorrectly aborting them.
Fix this by discarding aborts aimed at a completed call.
Further, discard all packets aimed at a call that's complete if there's
currently an active call on a channel, since the DATA packets associated
with the new call automatically terminate the old call.
Fixes: 18bfeba50dfd ("rxrpc: Perform terminal call ACK/ABORT retransmission from conn processor")
Reported-by: Marc Dionne <marc.dionne@auristor.com>
[ Upstream commit 03877bf6a30cca7d4bc3ffabd3c3e9464a7a1a19 ]
rxrpc calls have a ring of packets that are awaiting ACK or retransmission
and a parallel ring of annotations that tracks the state of those packets.
If the initial transmission of a packet on the underlying UDP socket fails
then the packet annotation is marked for resend - but the setting of this
mark accidentally erases the last-packet mark also stored in the same
annotation slot. If this happens, a call won't switch out of the Tx phase
when all the packets have been transmitted.
Fix this by retaining the last-packet mark and only altering the packet
state.
[ Upstream commit a16b8d0cf2ec1e626d24bc2a7b9e64ace6f7501d ]
Due to a check recently added to copy_to_user(), it's now not permitted to
copy from slab-held data to userspace unless the slab is whitelisted. This
affects rxrpc_recvmsg() when it attempts to place an RXRPC_USER_CALL_ID
control message in the userspace control message buffer. A warning is
generated by usercopy_warn() because the source is the copy of the
user_call_ID retained in the rxrpc_call struct.
Work around the issue by copying the user_call_ID to a variable on the
stack and passing that to put_cmsg().
The warning generated looks like:
Bad or missing usercopy whitelist? Kernel memory exposure attempt detected from SLUB object 'dmaengine-unmap-128' (offset 680, size 8)!
WARNING: CPU: 0 PID: 1401 at mm/usercopy.c:81 usercopy_warn+0x7e/0xa0
RIP: 0010:usercopy_warn+0x7e/0xa0
Call Trace:
__check_object_size+0x9c/0x1a0
put_cmsg+0x98/0x120
rxrpc_recvmsg+0x6fc/0x1010 [rxrpc]
? finish_wait+0x80/0x80
___sys_recvmsg+0xf8/0x240
? __clear_rsb+0x25/0x3d
? __clear_rsb+0x15/0x3d
? finish_task_switch+0xa6/0x2b0
? trace_hardirqs_on_caller+0xed/0x180
? _raw_spin_unlock_irq+0x29/0x40
? __sys_recvmsg+0x4e/0x90
do_syscall_64+0x7a/0x220
entry_SYSCALL_64_after_hwframe+0x26/0x9b
Reported-by: Jonathan Billings <jsbillings@jsbillings.org>
Tested-by: Jonathan Billings <jsbillings@jsbillings.org>
[ Upstream commit 8c2f826dc36314059ac146c78d3bf8056b626446 ]
Don't put buffers of data to be handed to crypto on the stack as this may
cause an assertion failure in the kernel (see below). Fix this by using an
kmalloc'd buffer instead.
kernel BUG at ./include/linux/scatterlist.h:147!
RIP: 0010:rxkad_encrypt_response.isra.6+0x191/0x1b0 [rxrpc]
RSP: 0018:ffffbe2fc06cfca8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff989277d59900 RCX: 0000000000000028
RDX: 0000259dc06cfd88 RSI: 0000000000000025 RDI: ffffbe30406cfd88
RBP: ffffbe2fc06cfd60 R08: ffffbe2fc06cfd08 R09: ffffbe2fc06cfd08
R10: 0000000000000000 R11: 0000000000000000 R12: 1ffff7c5f80d9f95
R13: ffffbe2fc06cfd88 R14: ffff98927a3f7aa0 R15: ffffbe2fc06cfd08
FS: 0000000000000000(0000) GS:ffff98927fc00000(0000) knlGS:0000000000000000
CR2: 000055b1ff28f0f8 CR3: 000000001b412003 CR4: 00000000003606f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
rxkad_respond_to_challenge+0x297/0x330 [rxrpc]
rxrpc_process_connection+0xd1/0x690 [rxrpc]
? process_one_work+0x1c3/0x680
? __lock_is_held+0x59/0xa0
process_one_work+0x249/0x680
worker_thread+0x3a/0x390
? process_one_work+0x680/0x680
kthread+0x121/0x140
? kthread_create_worker_on_cpu+0x70/0x70
ret_from_fork+0x3a/0x50
[ Upstream commit 93c62c45ed5fad1b87e3a45835b251cd68de9c46 ]
All the kernel_sendmsg() calls in rxrpc_send_data_packet() need to send
both parts of the iov[] buffer, but one of them does not. Fix it so that
it does.
Without this, short IPv6 rxrpc DATA packets may be seen that have the rxrpc
header included, but no payload.
Fixes: 5a924b8951f8 ("rxrpc: Don't store the rxrpc header in the Tx queue sk_buffs")
[ Upstream commit f859ab61875978eeaa539740ff7f7d91f5d60006 ]
RxRPC service endpoints expire like they're supposed to by the following
means:
(1) Mark dead rxrpc_net structs (with ->live) rather than twiddling the
global service conn timeout, otherwise the first rxrpc_net struct to
die will cause connections on all others to expire immediately from
then on.
(2) Mark local service endpoints for which the socket has been closed
(->service_closed) so that the expiration timeout can be much
shortened for service and client connections going through that
endpoint.
(3) rxrpc_put_service_conn() needs to schedule the reaper when the usage
count reaches 1, not 0, as idle conns have a 1 count.
(4) The accumulator for the earliest time we might want to schedule for
should be initialised to jiffies + MAX_JIFFY_OFFSET, not ULONG_MAX as
the comparison functions use signed arithmetic.
(5) Simplify the expiration handling, adding the expiration value to the
idle timestamp each time rather than keeping track of the time in the
past before which the idle timestamp must go to be expired. This is
much easier to read.
(6) Ignore the timeouts if the net namespace is dead.
(7) Restart the service reaper work item rather the client reaper.
[ Upstream commit 9faaff593404a9c4e5abc6839a641635d7b9d0cd ]
Provide a different lockdep key for rxrpc_call::user_mutex when the call is
made on a kernel socket, such as by the AFS filesystem.
The problem is that lockdep registers a false positive between userspace
calling the sendmsg syscall on a user socket where call->user_mutex is held
whilst userspace memory is accessed whereas the AFS filesystem may perform
operations with mmap_sem held by the caller.
In such a case, the following warning is produced.
WARNING: possible circular locking dependency detected
4.14.0-fscache+ #243 Tainted: G E
modpost/16701 is trying to acquire lock:
(&vnode->io_lock){+.+.}, at: [<ffffffffa000fc40>] afs_begin_vnode_operation+0x33/0x77 [kafs]
but task is already holding lock:
(&mm->mmap_sem){++++}, at: [<ffffffff8104376a>] __do_page_fault+0x1ef/0x486
which lock already depends on the new lock.
the existing dependency chain (in reverse order) is:
-> #3 (&mm->mmap_sem){++++}:
__might_fault+0x61/0x89
_copy_from_iter_full+0x40/0x1fa
rxrpc_send_data+0x8dc/0xff3
rxrpc_do_sendmsg+0x62f/0x6a1
rxrpc_sendmsg+0x166/0x1b7
___sys_sendmsg+0x1ad/0x22b
__sys_sendmsg+0x41/0x62
do_syscall_64+0x89/0x1be
return_from_SYSCALL_64+0x0/0x75
-> #2 (&call->user_mutex){+.+.}:
__mutex_lock+0x86/0x7d2
rxrpc_new_client_call+0x378/0x80e
rxrpc_kernel_begin_call+0xf3/0x154
afs_make_call+0x195/0x454 [kafs]
afs_vl_get_capabilities+0x193/0x198 [kafs]
afs_vl_lookup_vldb+0x5f/0x151 [kafs]
afs_create_volume+0x2e/0x2f4 [kafs]
afs_mount+0x56a/0x8d7 [kafs]
mount_fs+0x6a/0x109
vfs_kern_mount+0x67/0x135
do_mount+0x90b/0xb57
SyS_mount+0x72/0x98
-> #1 (k-sk_lock-AF_RXRPC){+.+.}:
lock_sock_nested+0x74/0x8a
rxrpc_kernel_begin_call+0x8a/0x154
afs_fs_get_capabilities+0x17a/0x17f [kafs]
afs_probe_fileserver+0xf7/0x2f0 [kafs]
afs_select_fileserver+0x83f/0x903 [kafs]
afs_fetch_status+0x89/0x11d [kafs]
afs_iget+0x16f/0x4f8 [kafs]
afs_mount+0x6c6/0x8d7 [kafs]
mount_fs+0x6a/0x109
SyS_mount+0x72/0x98
-> #0 (&vnode->io_lock){+.+.}:
lock_acquire+0x174/0x19f
afs_fetch_data+0x80/0x12a [kafs]
afs_readpages+0x314/0x405 [kafs]
__do_page_cache_readahead+0x203/0x2ba
filemap_fault+0x179/0x54d
__do_fault+0x17/0x60
__handle_mm_fault+0x6d7/0x95c
handle_mm_fault+0x24e/0x2a3
__do_page_fault+0x301/0x486
do_page_fault+0x236/0x259
page_fault+0x22/0x30
__clear_user+0x3d/0x60
padzero+0x1c/0x2b
load_elf_binary+0x785/0xdc7
search_binary_handler+0x81/0x1ff
do_execveat_common.isra.14+0x600/0x888
do_execve+0x1f/0x21
SyS_execve+0x28/0x2f
Chain exists of:
&vnode->io_lock --> &call->user_mutex --> &mm->mmap_sem
Possible unsafe locking scenario:
CPU0 CPU1
lock(&mm->mmap_sem);
lock(&call->user_mutex);
lock(&vnode->io_lock);
*** DEADLOCK ***
1 lock held by modpost/16701:
#0: (&mm->mmap_sem){++++}, at: [<ffffffff8104376a>] __do_page_fault+0x1ef/0x486
stack backtrace:
CPU: 0 PID: 16701 Comm: modpost Tainted: G E 4.14.0-fscache+ #243
Hardware name: ASUS All Series/H97-PLUS, BIOS 2306 10/09/2014
Call Trace:
dump_stack+0x67/0x8e
print_circular_bug+0x341/0x34f
check_prev_add+0x11f/0x5d4
? add_lock_to_list.isra.12+0x8b/0x8b
? __lock_acquire+0xf77/0x10b4
? afs_begin_vnode_operation+0x33/0x77 [kafs]
? filemap_fault+0x179/0x54d
RIP: 0010:__clear_user+0x3d/0x60
RSP: 0018:ffff880071e93da0 EFLAGS: 00010202
RAX: 0000000000000000 RBX: 000000000000011c RCX: 000000000000011c
RDX: 0000000000000000 RSI: 0000000000000008 RDI: 000000000060f720
RBP: 000000000060f720 R08: 0000000000000001 R09: 0000000000000000
R10: 0000000000000001 R11: ffff8800b5459b68 R12: ffff8800ce150e00
R13: 000000000060f720 R14: 00000000006127a8 R15: 0000000000000000
padzero+0x1c/0x2b
do_execve+0x1f/0x21
entry_SYSCALL64_slow_path+0x25/0x25
RIP: 0033:0x7fdb6009ee07
RSP: 002b:00007fff566d9728 EFLAGS: 00000246 ORIG_RAX: 000000000000003b
RAX: ffffffffffffffda RBX: 000055ba57280900 RCX: 00007fdb6009ee07
RDX: 000055ba5727f270 RSI: 000055ba5727cac0 RDI: 000055ba57280900
RBP: 000055ba57280900 R08: 00007fff566d9700 R09: 0000000000000000
R10: 000055ba5727cac0 R11: 0000000000000246 R12: 0000000000000000
R13: 000055ba5727cac0 R14: 000055ba5727f270 R15: 0000000000000000
[ Upstream commit 03a6c82218b9a87014b2c6c4e178294fdc8ebd8a ]
The caller of rxrpc_accept_call() must release the lock on call->user_mutex
returned by that function.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Don't release call mutex at the end of rxrpc_kernel_begin_call() if the
call pointer actually holds an error value.
When an RxRPC service packet comes in, the target connection is looked up
by an rb-tree search under RCU and a read-locked seqlock; the seqlock retry
check is, however, currently skipped if we got a match, but probably
shouldn't be in case the connection we found gets replaced whilst we're
doing a search.
Make the lookup procedure always go through need_seqretry(), even if the
lookup was successful. This makes sure we always pick up on a write-lock
event.
On the other hand, since we don't take a ref on the object, but rely on RCU
to prevent its destruction after dropping the seqlock, I'm not sure this is
necessary.
Allow a client call that failed on network error to be retried, provided
that the Tx queue still holds DATA packet 1. This allows an operation to
be submitted to another server or another address for the same server
without having to repackage and re-encrypt the data so far processed.
Two new functions are provided:
(1) rxrpc_kernel_check_call() - This is used to find out the completion
state of a call to guess whether it can be retried and whether it
should be retried.
(2) rxrpc_kernel_retry_call() - Disconnect the call from its current
connection, reset the state and submit it as a new client call to a
new address. The new address need not match the previous address.
A call may be retried even if all the data hasn't been loaded into it yet;
a partially constructed will be retained at the same point it was at when
an error condition was detected. msg_data_left() can be used to find out
how much data was packaged before the error occurred.
Add a callback to rxrpc_kernel_send_data() so that a kernel service can get
a notification that the AF_RXRPC call has transitioned out the Tx phase and
is now waiting for a reply or a final ACK.
This is called from AF_RXRPC with the call state lock held so the
notification is guaranteed to come before any reply is passed back.
Further, modify the AFS filesystem to make use of this so that we don't have
to change the afs_call state before sending the last bit of data.
Remove indentation from some blank lines.
call->error is stored as 0 or a negative error code. Don't negate this
value (ie. make it positive) before returning it from a kernel function
(though it should still be negated before passing to userspace through a
control message).
Fix IPv6 support in AF_RXRPC in the following ways:
(1) When extracting the address from a received IPv4 packet, if the local
transport socket is open for IPv6 then fill out the sockaddr_rxrpc
struct for an IPv4-mapped-to-IPv6 AF_INET6 transport address instead
of an AF_INET one.
(2) When sending CHALLENGE or RESPONSE packets, the transport length needs
to be set from the sockaddr_rxrpc::transport_len field rather than
sizeof() on the IPv4 transport address.
(3) When processing an IPv4 ICMP packet received by an IPv6 socket, set up
the address correctly before searching for the affected peer.
When an XDR-encoded Kerberos 5 ticket is added as an rxrpc-type key, the
expiry time should be drawn from the k5 part of the token union (which was
what was filled in), rather than the kad part of the union.
Since the 'expiry' variable of 'struct key_preparsed_payload' has been
changed to 'time64_t' type, which is year 2038 safe on 32bits system.
In net/rxrpc subsystem, we need convert 'u32' type to 'time64_t' type
when copying ticket expires time to 'prep->expiry', then this patch
introduces two helper functions to help convert 'u32' to 'time64_t'
type.
This patch also uses ktime_get_real_seconds() to get current time instead
of get_seconds() which is not year 2038 safe on 32bits system.
Signed-off-by: Baolin Wang <baolin.wang@linaro.org>
rxrpc_service_prealloc_one() doesn't set the socket pointer on any new call
it preallocates, but does add it to the rxrpc net namespace call list.
This, however, causes rxrpc_put_call() to oops when the call is discarded
when the socket is closed. rxrpc_put_call() needs the socket to be able to
reach the namespace so that it can use a lock held therein.
Fix this by setting a call's socket pointer immediately before discarding
it.
This can be triggered by unloading the kafs module, resulting in an oops
like the following:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000030
IP: rxrpc_put_call+0x1e2/0x32d
PGD 0
P4D 0
Oops: 0000 [#1] SMP
Modules linked in: kafs(E-)
CPU: 3 PID: 3037 Comm: rmmod Tainted: G E 4.12.0-fscache+ #213
task: ffff8803fc92e2c0 task.stack: ffff8803fef74000
RIP: 0010:rxrpc_put_call+0x1e2/0x32d
RSP: 0018:ffff8803fef77e08 EFLAGS: 00010282
RAX: 0000000000000000 RBX: ffff8803fab99ac0 RCX: 000000000000000f
RDX: ffffffff81c50a40 RSI: 000000000000000c RDI: ffff8803fc92ea88
RBP: ffff8803fef77e30 R08: ffff8803fc87b941 R09: ffffffff82946d20
R10: ffff8803fef77d10 R11: 00000000000076fc R12: 0000000000000005
R13: ffff8803fab99c20 R14: 0000000000000001 R15: ffffffff816c6aee
FS: 00007f915a059700(0000) GS:ffff88041fb80000(0000) knlGS:0000000000000000
CR2: 0000000000000030 CR3: 00000003fef39000 CR4: 00000000001406e0
Call Trace:
rxrpc_discard_prealloc+0x325/0x341
rxrpc_listen+0xf9/0x146
kernel_listen+0xb/0xd
afs_close_socket+0x3e/0x173 [kafs]
afs_exit+0x1f/0x57 [kafs]
SyS_delete_module+0x10f/0x19a
do_syscall_64+0x8a/0x149
Move the protocol description header file into net/rxrpc/ and rename it to
protocol.h. It's no longer necessary to expose it as packets are no longer
exposed to kernel services (such as AFS) that use the facility.
The abort codes are transferred to the UAPI header instead as we pass these
back to userspace and also to kernel services.
refcount_t type and corresponding API should be
used instead of atomic_t when the variable is used as
a reference counter. This allows to avoid accidental
refcounter overflows that might lead to use-after-free
situations.
This patch uses refcount_inc_not_zero() instead of
atomic_inc_not_zero_hint() due to absense of a _hint()
version of refcount API. If the hint() version must
be used, we might need to revisit API.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
situations.
situations.
Two entries being added at the same time to the IFLA
policy table, whilst parallel bug fixes to decnet
routing dst handling overlapping with the dst gc removal
in net-next.
There were many places that my previous spatch didn't find,
as pointed out by yuan linyu in various patches.
The following spatch found many more and also removes the
now unnecessary casts:
identifier p, p2;
expression len;
expression skb;
type t, t2;
-p = skb_put(skb, len);
+p = skb_put_zero(skb, len);
-p = (t)skb_put(skb, len);
... when != p
p2 = (t2)p;
-memset(p2, 0, len);
-memset(p, 0, len);
type t, t2;
identifier p, p2;
expression skb;
t *p;
-p = skb_put(skb, sizeof(t));
+p = skb_put_zero(skb, sizeof(t));
-p = (t *)skb_put(skb, sizeof(t));
... when != p
p2 = (t2)p;
-memset(p2, 0, sizeof(*p));
-memset(p, 0, sizeof(*p));
expression skb, len;
-memset(skb_put(skb, len), 0, len);
+skb_put_zero(skb, len);
Apply it to the tree (with one manual fixup to keep the
comment in vxlan.c, which spatch removed.)
This fixes CVE-2017-7482.
When a kerberos 5 ticket is being decoded so that it can be loaded into an
rxrpc-type key, there are several places in which the length of a
variable-length field is checked to make sure that it's not going to
overrun the available data - but the data is padded to the nearest
four-byte boundary and the code doesn't check for this extra. This could
lead to the size-remaining variable wrapping and the data pointer going
over the end of the buffer.
Fix this by making the various variable-length data checks use the padded
length.
Reported-by: 石磊 <shilei-c@360.cn>
Reviewed-by: Marc Dionne <marc.c.dionne@auristor.com>
Reviewed-by: Dan Carpenter <dan.carpenter@oracle.com>
Cache the congestion window setting that was determined during a call's
transmission phase when it finishes so that it can be used by the next call
to the same peer, thereby shortcutting the slow-start algorithm.
The value is stored in the rxrpc_peer struct and is accessed without
locking. Each call takes the value that happens to be there when it starts
and just overwrites the value when it finishes.
Provide a control message that can be specified on the first sendmsg() of a
client call or the first sendmsg() of a service response to indicate the
total length of the data to be transmitted for that call.
Currently, because the length of the payload of an encrypted DATA packet is
encrypted in front of the data, the packet cannot be encrypted until we
know how much data it will hold.
By specifying the length at the beginning of the transmit phase, each DATA
packet length can be set before we start loading data from userspace (where
several sendmsg() calls may contribute to a particular packet).
An error will be returned if too little or too much data is presented in
the Tx phase.
Consolidate the sendmsg control message parameters into a struct rather
than passing them individually through the argument list of
rxrpc_sendmsg_cmsg(). This makes it easier to add more parameters.
Provide a getsockopt() call that can query what cmsg types are supported by
AF_RXRPC.
Make it possible for a client to use AuriStor's service upgrade facility.
The client does this by adding an RXRPC_UPGRADE_SERVICE control message to
the first sendmsg() of a call. This takes no parameters.
When recvmsg() starts returning data from the call, the service ID field in
the returned msg_name will reflect the result of the upgrade attempt. If
the upgrade was ignored, srx_service will match what was set in the
sendmsg(); if the upgrade happened the srx_service will be altered to
indicate the service the server upgraded to.
Note that:
(1) The choice of upgrade service is up to the server
(2) Further client calls to the same server that would share a connection
are blocked if an upgrade probe is in progress.
(3) This should only be used to probe the service. Clients should then
use the returned service ID in all subsequent communications with that
server (and not set the upgrade). Note that the kernel will not
retain this information should the connection expire from its cache.
(4) If a server that supports upgrading is replaced by one that doesn't,
whilst a connection is live, and if the replacement is running, say,
OpenAFS 1.6.4 or older or an older IBM AFS, then the replacement
server will not respond to packets sent to the upgraded connection.
At this point, calls will time out and the server must be reprobed.
Implement AuriStor's service upgrade facility. There are three problems
that this is meant to deal with:
(1) Various of the standard AFS RPC calls have IPv4 addresses in their
requests and/or replies - but there's no room for including IPv6
addresses.
(2) Definition of IPv6-specific RPC operations in the standard operation
sets has not yet been achieved.
(3) One could envision the creation a new service on the same port that as
the original service. The new service could implement improved
operations - and the client could try this first, falling back to the
original service if it's not there.
Unfortunately, certain servers ignore packets addressed to a service
they don't implement and don't respond in any way - not even with an
ABORT. This means that the client must then wait for the call timeout
to occur.
What service upgrade does is to see if the connection is marked as being
'upgradeable' and if so, change the service ID in the server and thus the
request and reply formats. Note that the upgrade isn't mandatory - a
server that supports only the original call set will ignore the upgrade
request.
In the protocol, the procedure is then as follows:
(1) To request an upgrade, the first DATA packet in a new connection must
have the userStatus set to 1 (this is normally 0). The userStatus
value is normally ignored by the server.
(2) If the server doesn't support upgrading, the reply packets will
contain the same service ID as for the first request packet.
(3) If the server does support upgrading, all future reply packets on that
connection will contain the new service ID and the new service ID will
be applied to *all* further calls on that connection as well.
(4) The RPC op used to probe the upgrade must take the same request data
as the shadow call in the upgrade set (but may return a different
reply). GetCapability RPC ops were added to all standard sets for
just this purpose. Ops where the request formats differ cannot be
used for probing.
(5) The client must wait for completion of the probe before sending any
further RPC ops to the same destination. It should then use the
service ID that recvmsg() reported back in all future calls.
(6) The shadow service must have call definitions for all the operation
IDs defined by the original service.
To support service upgrading, a server should:
(1) Call bind() twice on its AF_RXRPC socket before calling listen().
Each bind() should supply a different service ID, but the transport
addresses must be the same. This allows the server to receive
requests with either service ID.
(2) Enable automatic upgrading by calling setsockopt(), specifying
RXRPC_UPGRADEABLE_SERVICE and passing in a two-member array of
unsigned shorts as the argument:
unsigned short optval[2];
This specifies a pair of service IDs. They must be different and must
match the service IDs bound to the socket. Member 0 is the service ID
to upgrade from and member 1 is the service ID to upgrade to.
Permit bind() to be called on an AF_RXRPC socket more than once (currently
maximum twice) to bind multiple listening services to it. There are some
restrictions:
(1) All bind() calls involved must have a non-zero service ID.
(2) The service IDs must all be different.
(3) The rest of the address (notably the transport part) must be the same
in all (a single UDP socket is shared).
(4) This must be done before listen() or sendmsg() is called.
This allows someone to connect to the service socket with different service
IDs and lays the foundation for service upgrading.
The service ID used by an incoming call can be extracted from the msg_name
returned by recvmsg().
Keep the rxrpc_connection struct's idea of the service ID that is exposed
in the protocol separate from the service ID that's used as a lookup key.
This allows the protocol service ID on a client connection to get upgraded
without making the connection unfindable for other client calls that also
would like to use the upgraded connection.
The connection's actual service ID is then returned through recvmsg() by
way of msg_name.
Whilst we're at it, we get rid of the last_service_id field from each
channel. The service ID is per-connection, not per-call and an entire
connection is upgraded in one go.
Signed-off-by: Jason A. Donenfeld <Jason@zx2c4.com>
The proc_remove call is dead code as it occurs after a return and
hence can never be called. Remove it.
Detected by CoverityScan, CID#1437743 ("Logically dead code")
Support network namespacing in AF_RXRPC with the following changes:
(1) All the local endpoint, peer and call lists, locks, counters, etc. are
moved into the per-namespace record.
(2) All the connection tracking is moved into the per-namespace record
with the exception of the client connection ID tree, which is kept
global so that connection IDs are kept unique per-machine.
(3) Each namespace gets its own epoch. This allows each network namespace
to pretend to be a separate client machine.
(4) The /proc/net/rxrpc_xxx files are now called /proc/net/rxrpc/xxx and
the contents reflect the namespace.
fs/afs/ should be okay with this patch as it explicitly requires the current
net namespace to be init_net to permit a mount to proceed at the moment. It
will, however, need updating so that cells, IP addresses and DNS records are
per-namespace also.
