path: root/net/rxrpc
2008-08-13net/rxrpc: Use an IS_ERR test rather than a NULL testJulien Brunel
In case of error, the function rxrpc_get_transport returns an ERR pointer, but never returns a NULL pointer. So after a call to this function, a NULL test should be replaced by an IS_ERR test. A simplified version of the semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @correct_null_test@ expression x,E; statement S1, S2; @@ x = rxrpc_get_transport(...) <... when != x = E if ( ( - x@p2 != NULL + ! IS_ERR ( x ) | - x@p2 == NULL + IS_ERR( x ) ) ) S1 else S2 ...> ? x = E; // </smpl> Signed-off-by: Julien Brunel <brunel@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25net: convert BUG_TRAP to generic WARN_ONIlpo Järvinen
Removes legacy reinvent-the-wheel type thing. The generic machinery integrates much better to automated debugging aids such as kerneloops.org (and others), and is unambiguous due to better naming. Non-intuively BUG_TRAP() is actually equal to WARN_ON() rather than BUG_ON() though some might actually be promoted to BUG_ON() but I left that to future. I could make at least one BUILD_BUG_ON conversion. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05MIB: add struct net to UDP_INC_STATS_BHPavel Emelyanov
Two special cases here - one is rxrpc - I put init_net there explicitly, since we haven't touched this part yet. The second place is in __udp4_lib_rcv - we already have a struct net there, but I have to move its initialization above to make it ready at the "drop" label. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02net: Add missing braces to multi-statement if()sIlpo Järvinen
One finds all kinds of crazy things with some shell pipelining. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-24RxRPC: Fix a regression in the RXKAD security moduleDavid Howells
Fix a regression in the RXKAD security module introduced in: commit 91e916cffec7c0153c5cbaa447151862a7a9a047 Author: Al Viro <viro@ftp.linux.org.uk> Date: Sat Mar 29 03:08:38 2008 +0000 net/rxrpc trivial annotations A variable was declared as a 16-bit type rather than a 32-bit type. Signed-off-by: David Howells <dhowells@redhat.com> Acked-with-apologies-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-of-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2008-04-16AFS: Do not describe debug parameters with their valuePaul Bolle
Describe debug parameters with their names (and not their values). Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-03rxrpc: remove smp_processor_id() from debug macroSven Schnelle
Signed-off-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-03Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
2008-03-30net/rxrpc trivial annotationsAl Viro
2008-03-18Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/rt2x00/rt2x00dev.c net/8021q/vlan_dev.c
2008-03-05net: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05RxRPC: fix rxrpc_recvmsg()'s returning of msg_nameDavid Howells
Fix rxrpc_recvmsg() to return msg_name correctly. We shouldn't overwrite the *msg struct, but should rather write into msg->msg_name (there's a '&' unary operator that shouldn't be there). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-29[NETFILTER/RXRPC]: Don't use seq_release_private where inappropriate.Pavel Emelyanov
Some netfilter code and rxrpc one use seq_open() to open a proc file, but seq_release_private to release one. This is harmless, but ambiguous. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-17net/rxrpc: Use BUG_ONJulia Lawall
if (...) BUG(); should be replaced with BUG_ON(...) when the test has no side-effects to allow a definition of BUG_ON that drops the code completely. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @ disable unlikely @ expression E,f; @@ ( if (<... f(...) ...>) { BUG(); } | - if (unlikely(E)) { BUG(); } + BUG_ON(E); ) @@ expression E,f; @@ ( if (<... f(...) ...>) { BUG(); } | - if (E) { BUG(); } + BUG_ON(E); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-07Convert ERR_PTR(PTR_ERR(p)) instances to ERR_CAST(p)David Howells
Convert instances of ERR_PTR(PTR_ERR(p)) to ERR_CAST(p) using: perl -spi -e 's/ERR_PTR[(]PTR_ERR[(](.*)[)][)]/ERR_CAST(\1)/' `grep -rl 'ERR_PTR[(]*PTR_ERR' fs crypto net security` Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31[AF_RXRPC]: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add namespace parameter to ip_route_output_key.Denis V. Lunev
Needed to propagate it down to the ip_route_output_flow. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[RXRPC]: Use cpu_to_be32() where appropriate.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[UDP]: Restore missing inDatagrams incrementsHerbert Xu
The previous move of the the UDP inDatagrams counter caused the counting of encapsulated packets, SUNRPC data (as opposed to call) packets and RXRPC packets to go missing. This patch restores all of these. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Name magic constants in sock_wake_async()Pavel Emelyanov
The sock_wake_async() performs a bit different actions depending on "how" argument. Unfortunately this argument ony has numerical magic values. I propose to give names to their constants to help people reading this function callers understand what's going on without looking into this function all the time. I suppose this is 2.6.25 material, but if it's not (or the naming seems poor/bad/awful), I can rework it against the current net-2.6 tree. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-07[AF_RXRPC]: Add a missing gotoDavid Howells
Add a missing goto to error handling in the RXKAD security module for AF_RXRPC. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-30[RXRPC]: Add missing select on CRYPTODavid Howells
AF_RXRPC uses the crypto services, so should depend on or select CRYPTO. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-12[NET]: Add the helper kernel_sock_shutdown()Trond Myklebust
...and fix a couple of bugs in the NBD, CIFS and OCFS2 socket handlers. Looking at the sock->op->shutdown() handlers, it looks as if all of them take a SHUT_RD/SHUT_WR/SHUT_RDWR argument instead of the RCV_SHUTDOWN/SEND_SHUTDOWN arguments. Add a helper, and then define the SHUT_* enum to ensure that kernel users of shutdown() don't get confused. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Mark Fasheh <mark.fasheh@oracle.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-02[SG] Get rid of __sg_mark_end()Jens Axboe
sg_mark_end() overwrites the page_link information, but all users want __sg_mark_end() behaviour where we just set the end bit. That is the most natural way to use the sg list, since you'll fill it in and then mark the end point. So change sg_mark_end() to only set the termination bit. Add a sg_magic debug check as well, and clear a chain pointer if it is set. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-30[NET]: Fix incorrect sg_mark_end() calls.David S. Miller
This fixes scatterlist corruptions added by commit 68e3f5dd4db62619fdbe520d36c9ebf62e672256 [CRYPTO] users: Fix up scatterlist conversion errors The issue is that the code calls sg_mark_end() which clobbers the sg_page() pointer of the final scatterlist entry. The first part fo the fix makes skb_to_sgvec() do __sg_mark_end(). After considering all skb_to_sgvec() call sites the most correct solution is to call __sg_mark_end() in skb_to_sgvec() since that is what all of the callers would end up doing anyways. I suspect this might have fixed some problems in virtio_net which is the sole non-crypto user of skb_to_sgvec(). Other similar sg_mark_end() cases were converted over to __sg_mark_end() as well. Arguably sg_mark_end() is a poorly named function because it doesn't just "mark", it clears out the page pointer as a side effect, which is what led to these bugs in the first place. The one remaining plain sg_mark_end() call is in scsi_alloc_sgtable() and arguably it could be converted to __sg_mark_end() if only so that we can delete this confusing interface from linux/scatterlist.h Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-27[CRYPTO] users: Fix up scatterlist conversion errorsHerbert Xu
This patch fixes the errors made in the users of the crypto layer during the sg_init_table conversion. It also adds a few conversions that were missing altogether. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17KEYS: Make request_key() and co fundamentally asynchronousDavid Howells
Make request_key() and co fundamentally asynchronous to make it easier for NFS to make use of them. There are now accessor functions that do asynchronous constructions, a wait function to wait for construction to complete, and a completion function for the key type to indicate completion of construction. Note that the construction queue is now gone. Instead, keys under construction are linked in to the appropriate keyring in advance, and that anyone encountering one must wait for it to be complete before they can use it. This is done automatically for userspace. The following auxiliary changes are also made: (1) Key type implementation stuff is split from linux/key.h into linux/key-type.h. (2) AF_RXRPC provides a way to allocate null rxrpc-type keys so that AFS does not need to call key_instantiate_and_link() directly. (3) Adjust the debugging macros so that they're -Wformat checked even if they are disabled, and make it so they can be enabled simply by defining __KDEBUG to be consistent with other code of mine. (3) Documentation. [alan@lxorguk.ukuu.org.uk: keys: missing word in documentation] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[NET]: Make /proc/net per network namespaceEric W. Biederman
This patch makes /proc/net per network namespace. It modifies the global variables proc_net and proc_net_stat to be per network namespace. The proc_net file helpers are modified to take a network namespace argument, and all of their callers are fixed to pass &init_net for that argument. This ensures that all of the /proc/net files are only visible and usable in the initial network namespace until the code behind them has been updated to be handle multiple network namespaces. Making /proc/net per namespace is necessary as at least some files in /proc/net depend upon the set of network devices which is per network namespace, and even more files in /proc/net have contents that are relevant to a single network namespace. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-26net/* misc endianness annotationsAl Viro
2007-07-25Cleanup non-arch xtime uses, use get_seconds() or current_kernel_time().john stultz
This avoids use of the kernel-internal "xtime" variable directly outside of the actual time-related functions. Instead, use the helper functions that we already have available to us. This doesn't actually change any behaviour, but this will allow us to fix the fact that "xtime" isn't updated very often with CONFIG_NO_HZ (because much of the realtime information is maintained as separate offsets to 'xtime'), which has caused interfaces that use xtime directly to get a time that is out of sync with the real-time clock by up to a third of a second or so. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19[NET] RXRPC: Fix whitespace errors.YOSHIFUJI Hideaki
2007-07-10[NET]: Make all initialized struct seq_operations const.Philippe De Muyter
Make all initialized struct seq_operations in net/ const Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-10[NET]: Make some network-related proc files use seq_list_xxx helpersPavel Emelianov
This includes /proc/net/protocols, /proc/net/rxrpc_calls and /proc/net/rxrpc_connections files. All three need seq_list_start_head to show some header. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-18[AF_RXRPC]: Return the number of bytes buffered in rxrpc_send_data()David Howells
Return the number of bytes buffered in rxrpc_send_data(). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-06-15[RXRPC] net/rxrpc/ar-connection.c: fix NULL dereferenceAdrian Bunk
This patch fixes a NULL dereference spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-22[AF_RXRPC]: Make call state names available if CONFIG_PROC_FS=nDavid Howells
Make the call state names array available even if CONFIG_PROC_FS is disabled as it's used in other places (such as debugging statements) too. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-22[AF_RXRPC]: AF_RXRPC depends on IPv4David Howells
Add a dependency for CONFIG_AF_RXRPC on CONFIG_INET. This fixes this error: net/built-in.o: In function `rxrpc_get_peer': (.text+0x42824): undefined reference to `ip_route_output_key' Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-10AF_RXRPC: reduce debugging noiseDavid Howells
Reduce debugging noise generated by AF_RXRPC. Signed-off-by: David Howells <dhowells@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04[AF_RXRPC]: Sort out MTU handling.David Howells
Sort out the MTU determination and handling in AF_RXRPC: (1) If it's present, parse the additional information supplied by the peer at the end of the ACK packet (struct ackinfo) to determine the MTU sizes that peer is willing to support. (2) Initialise the MTU size to that peer from the kernel's routing records. (3) Send ACKs rather than ACKALLs as the former carry the additional info, and the latter do not. (4) Declare the interface MTU size in outgoing ACKs as a maximum amount of data that can be stuffed into an RxRPC packet without it having to be fragmented to come in this computer's NIC. (5) If sendmsg() is given MSG_MORE then it should allocate an skb of the maximum size rather than one just big enough for the data it's got left to process on the theory that there is more data to come that it can append to that packet. This means, for example, that if AFS does a large StoreData op, all the packets barring the last will be filled to the maximum unfragmented size. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-03[AFS/AF_RXRPC]: Miscellaneous fixes.David Howells
Make miscellaneous fixes to AFS and AF_RXRPC: (*) Make AF_RXRPC select KEYS rather than RXKAD or AFS_FS in Kconfig. (*) Don't use FS_BINARY_MOUNTDATA. (*) Remove a done 'TODO' item in a comemnt on afs_get_sb(). (*) Don't pass a void * as the page pointer argument of kmap_atomic() as this breaks on m68k. Patch from Geert Uytterhoeven <geert@linux-m68k.org>. (*) Use match_*() functions rather than doing my own parsing. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-27[AF_RXRPC/AFS]: Arch-specific fixes.David Howells
Fixes for various arch compilation problems: (*) Missing module exports. (*) Variable name collision when rxkad and af_rxrpc both built in (rxrpc_debug). (*) Large constant representation problem (AFS_UUID_TO_UNIX_TIME). (*) Configuration dependencies. (*) printk() format warnings. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[RXRPC]: Fix pointers passed to bitops.David S. Miller
CC [M] net/rxrpc/ar-input.o net/rxrpc/ar-input.c: In function ‘rxrpc_fast_process_data’: net/rxrpc/ar-input.c:171: warning: passing argument 2 of ‘__test_and_set_bit’ from incompatible pointer type net/rxrpc/ar-input.c:180: warning: passing argument 2 of ‘__clear_bit’ from incompatible pointer type net/rxrpc/ar-input.c:218: warning: passing argument 2 of ‘__clear_bit’ from incompatible pointer type Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[RXRPC]: Remove bogus atomic_* overrides.David S. Miller
These are done with CPP defines which several platforms use for their atomic.h implementation, which floods the build with warnings and breaks the build. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Delete the old RxRPC code.David Howells
Delete the old RxRPC code as it's now no longer used. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Add an interface to the AF_RXRPC module for the AFS filesystem ↵David Howells
to use Add an interface to the AF_RXRPC module so that the AFS filesystem module can more easily make use of the services available. AFS still opens a socket but then uses the action functions in lieu of sendmsg() and registers an intercept functions to grab messages before they're queued on the socket Rx queue. This permits AFS (or whatever) to: (1) Avoid the overhead of using the recvmsg() call. (2) Use different keys directly on individual client calls on one socket rather than having to open a whole slew of sockets, one for each key it might want to use. (3) Avoid calling request_key() at the point of issue of a call or opening of a socket. This is done instead by AFS at the point of open(), unlink() or other VFS operation and the key handed through. (4) Request the use of something other than GFP_KERNEL to allocate memory. Furthermore: (*) The socket buffer markings used by RxRPC are made available for AFS so that it can interpret the cooked RxRPC messages itself. (*) rxgen (un)marshalling abort codes are made available. The following documentation for the kernel interface is added to Documentation/networking/rxrpc.txt: ========================= AF_RXRPC KERNEL INTERFACE ========================= The AF_RXRPC module also provides an interface for use by in-kernel utilities such as the AFS filesystem. This permits such a utility to: (1) Use different keys directly on individual client calls on one socket rather than having to open a whole slew of sockets, one for each key it might want to use. (2) Avoid having RxRPC call request_key() at the point of issue of a call or opening of a socket. Instead the utility is responsible for requesting a key at the appropriate point. AFS, for instance, would do this during VFS operations such as open() or unlink(). The key is then handed through when the call is initiated. (3) Request the use of something other than GFP_KERNEL to allocate memory. (4) Avoid the overhead of using the recvmsg() call. RxRPC messages can be intercepted before they get put into the socket Rx queue and the socket buffers manipulated directly. To use the RxRPC facility, a kernel utility must still open an AF_RXRPC socket, bind an addess as appropriate and listen if it's to be a server socket, but then it passes this to the kernel interface functions. The kernel interface functions are as follows: (*) Begin a new client call. struct rxrpc_call * rxrpc_kernel_begin_call(struct socket *sock, struct sockaddr_rxrpc *srx, struct key *key, unsigned long user_call_ID, gfp_t gfp); This allocates the infrastructure to make a new RxRPC call and assigns call and connection numbers. The call will be made on the UDP port that the socket is bound to. The call will go to the destination address of a connected client socket unless an alternative is supplied (srx is non-NULL). If a key is supplied then this will be used to secure the call instead of the key bound to the socket with the RXRPC_SECURITY_KEY sockopt. Calls secured in this way will still share connections if at all possible. The user_call_ID is equivalent to that supplied to sendmsg() in the control data buffer. It is entirely feasible to use this to point to a kernel data structure. If this function is successful, an opaque reference to the RxRPC call is returned. The caller now holds a reference on this and it must be properly ended. (*) End a client call. void rxrpc_kernel_end_call(struct rxrpc_call *call); This is used to end a previously begun call. The user_call_ID is expunged from AF_RXRPC's knowledge and will not be seen again in association with the specified call. (*) Send data through a call. int rxrpc_kernel_send_data(struct rxrpc_call *call, struct msghdr *msg, size_t len); This is used to supply either the request part of a client call or the reply part of a server call. msg.msg_iovlen and msg.msg_iov specify the data buffers to be used. msg_iov may not be NULL and must point exclusively to in-kernel virtual addresses. msg.msg_flags may be given MSG_MORE if there will be subsequent data sends for this call. The msg must not specify a destination address, control data or any flags other than MSG_MORE. len is the total amount of data to transmit. (*) Abort a call. void rxrpc_kernel_abort_call(struct rxrpc_call *call, u32 abort_code); This is used to abort a call if it's still in an abortable state. The abort code specified will be placed in the ABORT message sent. (*) Intercept received RxRPC messages. typedef void (*rxrpc_interceptor_t)(struct sock *sk, unsigned long user_call_ID, struct sk_buff *skb); void rxrpc_kernel_intercept_rx_messages(struct socket *sock, rxrpc_interceptor_t interceptor); This installs an interceptor function on the specified AF_RXRPC socket. All messages that would otherwise wind up in the socket's Rx queue are then diverted to this function. Note that care must be taken to process the messages in the right order to maintain DATA message sequentiality. The interceptor function itself is provided with the address of the socket and handling the incoming message, the ID assigned by the kernel utility to the call and the socket buffer containing the message. The skb->mark field indicates the type of message: MARK MEANING =============================== ======================================= RXRPC_SKB_MARK_DATA Data message RXRPC_SKB_MARK_FINAL_ACK Final ACK received for an incoming call RXRPC_SKB_MARK_BUSY Client call rejected as server busy RXRPC_SKB_MARK_REMOTE_ABORT Call aborted by peer RXRPC_SKB_MARK_NET_ERROR Network error detected RXRPC_SKB_MARK_LOCAL_ERROR Local error encountered RXRPC_SKB_MARK_NEW_CALL New incoming call awaiting acceptance The remote abort message can be probed with rxrpc_kernel_get_abort_code(). The two error messages can be probed with rxrpc_kernel_get_error_number(). A new call can be accepted with rxrpc_kernel_accept_call(). Data messages can have their contents extracted with the usual bunch of socket buffer manipulation functions. A data message can be determined to be the last one in a sequence with rxrpc_kernel_is_data_last(). When a data message has been used up, rxrpc_kernel_data_delivered() should be called on it.. Non-data messages should be handled to rxrpc_kernel_free_skb() to dispose of. It is possible to get extra refs on all types of message for later freeing, but this may pin the state of a call until the message is finally freed. (*) Accept an incoming call. struct rxrpc_call * rxrpc_kernel_accept_call(struct socket *sock, unsigned long user_call_ID); This is used to accept an incoming call and to assign it a call ID. This function is similar to rxrpc_kernel_begin_call() and calls accepted must be ended in the same way. If this function is successful, an opaque reference to the RxRPC call is returned. The caller now holds a reference on this and it must be properly ended. (*) Reject an incoming call. int rxrpc_kernel_reject_call(struct socket *sock); This is used to reject the first incoming call on the socket's queue with a BUSY message. -ENODATA is returned if there were no incoming calls. Other errors may be returned if the call had been aborted (-ECONNABORTED) or had timed out (-ETIME). (*) Record the delivery of a data message and free it. void rxrpc_kernel_data_delivered(struct sk_buff *skb); This is used to record a data message as having been delivered and to update the ACK state for the call. The socket buffer will be freed. (*) Free a message. void rxrpc_kernel_free_skb(struct sk_buff *skb); This is used to free a non-DATA socket buffer intercepted from an AF_RXRPC socket. (*) Determine if a data message is the last one on a call. bool rxrpc_kernel_is_data_last(struct sk_buff *skb); This is used to determine if a socket buffer holds the last data message to be received for a call (true will be returned if it does, false if not). The data message will be part of the reply on a client call and the request on an incoming call. In the latter case there will be more messages, but in the former case there will not. (*) Get the abort code from an abort message. u32 rxrpc_kernel_get_abort_code(struct sk_buff *skb); This is used to extract the abort code from a remote abort message. (*) Get the error number from a local or network error message. int rxrpc_kernel_get_error_number(struct sk_buff *skb); This is used to extract the error number from a message indicating either a local error occurred or a network error occurred. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Provide secure RxRPC sockets for use by userspace and kernel bothDavid Howells
Provide AF_RXRPC sockets that can be used to talk to AFS servers, or serve answers to AFS clients. KerberosIV security is fully supported. The patches and some example test programs can be found in: http://people.redhat.com/~dhowells/rxrpc/ This will eventually replace the old implementation of kernel-only RxRPC currently resident in net/rxrpc/. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
