path: root/net/rxrpc
2009-11-25net: use net_eq to compare netsOctavian Purdila
Generated with the following semantic patch @@ struct net *n1; struct net *n2; @@ - n1 == n2 + net_eq(n1, n2) @@ struct net *n1; struct net *n2; @@ - n1 != n2 + !net_eq(n1, n2) applied over {include,net,drivers/net}. Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-05net: pass kern to net_proto_family create functionEric Paris
The generic __sock_create function has a kern argument which allows the security system to make decisions based on if a socket is being created by the kernel or by userspace. This patch passes that flag to the net_proto_family specific create function, so it can do the same thing. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-12net: Generalize socket rx gap / receive queue overflow cmsgNeil Horman
Create a new socket level option to report number of queue overflows Recently I augmented the AF_PACKET protocol to report the number of frames lost on the socket receive queue between any two enqueued frames. This value was exported via a SOL_PACKET level cmsg. AFter I completed that work it was requested that this feature be generalized so that any datagram oriented socket could make use of this option. As such I've created this patch, It creates a new SOL_SOCKET level option called SO_RXQ_OVFL, which when enabled exports a SOL_SOCKET level cmsg that reports the nubmer of times the sk_receive_queue overflowed between any two given frames. It also augments the AF_PACKET protocol to take advantage of this new feature (as it previously did not touch sk->sk_drops, which this patch uses to record the overflow count). Tested successfully by me. Notes: 1) Unlike my previous patch, this patch simply records the sk_drops value, which is not a number of drops between packets, but rather a total number of drops. Deltas must be computed in user space. 2) While this patch currently works with datagram oriented protocols, it will also be accepted by non-datagram oriented protocols. I'm not sure if thats agreeable to everyone, but my argument in favor of doing so is that, for those protocols which aren't applicable to this option, sk_drops will always be zero, and reporting no drops on a receive queue that isn't used for those non-participating protocols seems reasonable to me. This also saves us having to code in a per-protocol opt in mechanism. 3) This applies cleanly to net-next assuming that commit 977750076d98c7ff6cbda51858bb5a5894a9d9ab (my af packet cmsg patch) is reverted Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07net: mark net_proto_ops as constStephen Hemminger
All usages of structure net_proto_ops should be declared const. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-30net: Make setsockopt() optlen be unsigned.David S. Miller
This provides safety against negative optlen at the type level instead of depending upon (sometimes non-trivial) checks against this sprinkled all over the the place, in each and every implementation. Based upon work done by Arjan van de Ven and feedback from Linus Torvalds. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-21trivial: fix typo "to to" in multiple filesAnand Gadiyar
Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-16RxRPC: Use uX/sX rather than uintX_t/intX_t typesDavid Howells
Use uX rather than uintX_t types for consistency. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15RxRPC: Parse security index 5 keys (Kerberos 5)David Howells
Parse RxRPC security index 5 type keys (Kerberos 5 tokens). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15RxRPC: Allow RxRPC keys to be readDavid Howells
Allow RxRPC keys to be read. This is to allow pioctl() to be implemented in userspace. RxRPC keys are read out in XDR format. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15RxRPC: Allow key payloads to be passed in XDR formDavid Howells
Allow add_key() and KEYCTL_INSTANTIATE to accept key payloads in XDR form as described by openafs-1.4.10/src/auth/afs_token.xg. This provides a way of passing kaserver, Kerberos 4, Kerberos 5 and GSSAPI keys from userspace, and allows for future expansion. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-15RxRPC: Declare the security index constants symbolicallyDavid Howells
Declare the security index constants symbolically rather than just referring to them numerically. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05net: mark read-only arrays as constJan Engelhardt
String literals are constant, and usually, we can also tag the array of pointers const too, moving it to the .rodata section. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-07-09net: adding memory barrier to the poll and receive callbacksJiri Olsa
Adding memory barrier after the poll_wait function, paired with receive callbacks. Adding fuctions sock_poll_wait and sk_has_sleeper to wrap the memory barrier. Without the memory barrier, following race can happen. The race fires, when following code paths meet, and the tp->rcv_nxt and __add_wait_queue updates stay in CPU caches. CPU1 CPU2 sys_select receive packet ... ... __add_wait_queue update tp->rcv_nxt ... ... tp->rcv_nxt check sock_def_readable ... { schedule ... if (sk->sk_sleep && waitqueue_active(sk->sk_sleep)) wake_up_interruptible(sk->sk_sleep) ... } If there was no cache the code would work ok, since the wait_queue and rcv_nxt are opposit to each other. Meaning that once tp->rcv_nxt is updated by CPU2, the CPU1 either already passed the tp->rcv_nxt check and sleeps, or will get the new value for tp->rcv_nxt and will return with new data mask. In both cases the process (CPU1) is being added to the wait queue, so the waitqueue_active (CPU2) call cannot miss and will wake up CPU1. The bad case is when the __add_wait_queue changes done by CPU1 stay in its cache, and so does the tp->rcv_nxt update on CPU2 side. The CPU1 will then endup calling schedule and sleep forever if there are no more data on the socket. Calls to poll_wait in following modules were ommited: net/bluetooth/af_bluetooth.c net/irda/af_irda.c net/irda/irnet/irnet_ppp.c net/mac80211/rc80211_pid_debugfs.c net/phonet/socket.c net/rds/af_rds.c net/rfkill/core.c net/sunrpc/cache.c net/sunrpc/rpc_pipe.c net/tipc/socket.c Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16RxRPC: Don't attempt to reuse aborted connectionsDavid Howells
Connections that have seen a connection-level abort should not be reused as the far end will just abort them again; instead a new connection should be made. Connection-level aborts occur due to such things as authentication failures. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-21RxRPC: Error handling for rxrpc_alloc_connection()Dan Carpenter
rxrpc_alloc_connection() doesn't return an error code on failure, it just returns NULL. IS_ERR(NULL) is false. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-06RxRPC: Fix a potential NULL dereferenceDavid Howells
Fix a potential NULL dereference bug during error handling in rxrpc_kernel_begin_call(), whereby rxrpc_put_transport() may be handed a NULL pointer. This was found with a code checker (http://repo.or.cz/w/smatch.git/). Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1429 commits) net: Allow dependancies of FDDI & Tokenring to be modular. igb: Fix build warning when DCA is disabled. net: Fix warning fallout from recent NAPI interface changes. gro: Fix potential use after free sfc: If AN is enabled, always read speed/duplex from the AN advertising bits sfc: When disabling the NIC, close the device rather than unregistering it sfc: SFT9001: Add cable diagnostics sfc: Add support for multiple PHY self-tests sfc: Merge top-level functions for self-tests sfc: Clean up PHY mode management in loopback self-test sfc: Fix unreliable link detection in some loopback modes sfc: Generate unique names for per-NIC workqueues 802.3ad: use standard ethhdr instead of ad_header 802.3ad: generalize out mac address initializer 802.3ad: initialize ports LACPDU from const initializer 802.3ad: remove typedef around ad_system 802.3ad: turn ports is_individual into a bool 802.3ad: turn ports is_enabled into a bool 802.3ad: make ntt bool ixgbe: Fix set_ringparam in ixgbe to use the same memory pools. ... Fixed trivial IPv4/6 address printing conflicts in fs/cifs/connect.c due to the conversion to %pI (in this networking merge) and the addition of doing IPv6 addresses (from the earlier merge of CIFS).
2008-12-10net: Make staticRoel Kluin
Sparse asked whether these could be static. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-14CRED: Inaugurate COW credentialsDavid Howells
Inaugurate copy-on-write credentials management. This uses RCU to manage the credentials pointer in the task_struct with respect to accesses by other tasks. A process may only modify its own credentials, and so does not need locking to access or modify its own credentials. A mutex (cred_replace_mutex) is added to the task_struct to control the effect of PTRACE_ATTACHED on credential calculations, particularly with respect to execve(). With this patch, the contents of an active credentials struct may not be changed directly; rather a new set of credentials must be prepared, modified and committed using something like the following sequence of events: struct cred *new = prepare_creds(); int ret = blah(new); if (ret < 0) { abort_creds(new); return ret; } return commit_creds(new); There are some exceptions to this rule: the keyrings pointed to by the active credentials may be instantiated - keyrings violate the COW rule as managing COW keyrings is tricky, given that it is possible for a task to directly alter the keys in a keyring in use by another task. To help enforce this, various pointers to sets of credentials, such as those in the task_struct, are declared const. The purpose of this is compile-time discouragement of altering credentials through those pointers. Once a set of credentials has been made public through one of these pointers, it may not be modified, except under special circumstances: (1) Its reference count may incremented and decremented. (2) The keyrings to which it points may be modified, but not replaced. The only safe way to modify anything else is to create a replacement and commit using the functions described in Documentation/credentials.txt (which will be added by a later patch). This patch and the preceding patches have been tested with the LTP SELinux testsuite. This patch makes several logical sets of alteration: (1) execve(). This now prepares and commits credentials in various places in the security code rather than altering the current creds directly. (2) Temporary credential overrides. do_coredump() and sys_faccessat() now prepare their own credentials and temporarily override the ones currently on the acting thread, whilst preventing interference from other threads by holding cred_replace_mutex on the thread being dumped. This will be replaced in a future patch by something that hands down the credentials directly to the functions being called, rather than altering the task's objective credentials. (3) LSM interface. A number of functions have been changed, added or removed: (*) security_capset_check(), ->capset_check() (*) security_capset_set(), ->capset_set() Removed in favour of security_capset(). (*) security_capset(), ->capset() New. This is passed a pointer to the new creds, a pointer to the old creds and the proposed capability sets. It should fill in the new creds or return an error. All pointers, barring the pointer to the new creds, are now const. (*) security_bprm_apply_creds(), ->bprm_apply_creds() Changed; now returns a value, which will cause the process to be killed if it's an error. (*) security_task_alloc(), ->task_alloc_security() Removed in favour of security_prepare_creds(). (*) security_cred_free(), ->cred_free() New. Free security data attached to cred->security. (*) security_prepare_creds(), ->cred_prepare() New. Duplicate any security data attached to cred->security. (*) security_commit_creds(), ->cred_commit() New. Apply any security effects for the upcoming installation of new security by commit_creds(). (*) security_task_post_setuid(), ->task_post_setuid() Removed in favour of security_task_fix_setuid(). (*) security_task_fix_setuid(), ->task_fix_setuid() Fix up the proposed new credentials for setuid(). This is used by cap_set_fix_setuid() to implicitly adjust capabilities in line with setuid() changes. Changes are made to the new credentials, rather than the task itself as in security_task_post_setuid(). (*) security_task_reparent_to_init(), ->task_reparent_to_init() Removed. Instead the task being reparented to init is referred directly to init's credentials. NOTE! This results in the loss of some state: SELinux's osid no longer records the sid of the thread that forked it. (*) security_key_alloc(), ->key_alloc() (*) security_key_permission(), ->key_permission() Changed. These now take cred pointers rather than task pointers to refer to the security context. (4) sys_capset(). This has been simplified and uses less locking. The LSM functions it calls have been merged. (5) reparent_to_kthreadd(). This gives the current thread the same credentials as init by simply using commit_thread() to point that way. (6) __sigqueue_alloc() and switch_uid() __sigqueue_alloc() can't stop the target task from changing its creds beneath it, so this function gets a reference to the currently applicable user_struct which it then passes into the sigqueue struct it returns if successful. switch_uid() is now called from commit_creds(), and possibly should be folded into that. commit_creds() should take care of protecting __sigqueue_alloc(). (7) [sg]et[ug]id() and co and [sg]et_current_groups. The set functions now all use prepare_creds(), commit_creds() and abort_creds() to build and check a new set of credentials before applying it. security_task_set[ug]id() is called inside the prepared section. This guarantees that nothing else will affect the creds until we've finished. The calling of set_dumpable() has been moved into commit_creds(). Much of the functionality of set_user() has been moved into commit_creds(). The get functions all simply access the data directly. (8) security_task_prctl() and cap_task_prctl(). security_task_prctl() has been modified to return -ENOSYS if it doesn't want to handle a function, or otherwise return the return value directly rather than through an argument. Additionally, cap_task_prctl() now prepares a new set of credentials, even if it doesn't end up using it. (9) Keyrings. A number of changes have been made to the keyrings code: (a) switch_uid_keyring(), copy_keys(), exit_keys() and suid_keys() have all been dropped and built in to the credentials functions directly. They may want separating out again later. (b) key_alloc() and search_process_keyrings() now take a cred pointer rather than a task pointer to specify the security context. (c) copy_creds() gives a new thread within the same thread group a new thread keyring if its parent had one, otherwise it discards the thread keyring. (d) The authorisation key now points directly to the credentials to extend the search into rather pointing to the task that carries them. (e) Installing thread, process or session keyrings causes a new set of credentials to be created, even though it's not strictly necessary for process or session keyrings (they're shared). (10) Usermode helper. The usermode helper code now carries a cred struct pointer in its subprocess_info struct instead of a new session keyring pointer. This set of credentials is derived from init_cred and installed on the new process after it has been cloned. call_usermodehelper_setup() allocates the new credentials and call_usermodehelper_freeinfo() discards them if they haven't been used. A special cred function (prepare_usermodeinfo_creds()) is provided specifically for call_usermodehelper_setup() to call. call_usermodehelper_setkeys() adjusts the credentials to sport the supplied keyring as the new session keyring. (11) SELinux. SELinux has a number of changes, in addition to those to support the LSM interface changes mentioned above: (a) selinux_setprocattr() no longer does its check for whether the current ptracer can access processes with the new SID inside the lock that covers getting the ptracer's SID. Whilst this lock ensures that the check is done with the ptracer pinned, the result is only valid until the lock is released, so there's no point doing it inside the lock. (12) is_single_threaded(). This function has been extracted from selinux_setprocattr() and put into a file of its own in the lib/ directory as join_session_keyring() now wants to use it too. The code in SELinux just checked to see whether a task shared mm_structs with other tasks (CLONE_VM), but that isn't good enough. We really want to know if they're part of the same thread group (CLONE_THREAD). (13) nfsd. The NFS server daemon now has to use the COW credentials to set the credentials it is going to use. It really needs to pass the credentials down to the functions it calls, but it can't do that until other patches in this series have been applied. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-31net: replace NIPQUAD() in net/*/Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-13net/rxrpc: Use an IS_ERR test rather than a NULL testJulien Brunel
In case of error, the function rxrpc_get_transport returns an ERR pointer, but never returns a NULL pointer. So after a call to this function, a NULL test should be replaced by an IS_ERR test. A simplified version of the semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @correct_null_test@ expression x,E; statement S1, S2; @@ x = rxrpc_get_transport(...) <... when != x = E if ( ( - x@p2 != NULL + ! IS_ERR ( x ) | - x@p2 == NULL + IS_ERR( x ) ) ) S1 else S2 ...> ? x = E; // </smpl> Signed-off-by: Julien Brunel <brunel@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-25net: convert BUG_TRAP to generic WARN_ONIlpo Järvinen
Removes legacy reinvent-the-wheel type thing. The generic machinery integrates much better to automated debugging aids such as kerneloops.org (and others), and is unambiguous due to better naming. Non-intuively BUG_TRAP() is actually equal to WARN_ON() rather than BUG_ON() though some might actually be promoted to BUG_ON() but I left that to future. I could make at least one BUILD_BUG_ON conversion. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-05MIB: add struct net to UDP_INC_STATS_BHPavel Emelyanov
Two special cases here - one is rxrpc - I put init_net there explicitly, since we haven't touched this part yet. The second place is in __udp4_lib_rcv - we already have a struct net there, but I have to move its initialization above to make it ready at the "drop" label. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-02net: Add missing braces to multi-statement if()sIlpo Järvinen
One finds all kinds of crazy things with some shell pipelining. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-24RxRPC: Fix a regression in the RXKAD security moduleDavid Howells
Fix a regression in the RXKAD security module introduced in: commit 91e916cffec7c0153c5cbaa447151862a7a9a047 Author: Al Viro <viro@ftp.linux.org.uk> Date: Sat Mar 29 03:08:38 2008 +0000 net/rxrpc trivial annotations A variable was declared as a 16-bit type rather than a 32-bit type. Signed-off-by: David Howells <dhowells@redhat.com> Acked-with-apologies-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-of-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-17Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2008-04-16AFS: Do not describe debug parameters with their valuePaul Bolle
Describe debug parameters with their names (and not their values). Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-03rxrpc: remove smp_processor_id() from debug macroSven Schnelle
Signed-off-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-03Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6
2008-03-30net/rxrpc trivial annotationsAl Viro
2008-03-18Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/rt2x00/rt2x00dev.c net/8021q/vlan_dev.c
2008-03-05net: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-05RxRPC: fix rxrpc_recvmsg()'s returning of msg_nameDavid Howells
Fix rxrpc_recvmsg() to return msg_name correctly. We shouldn't overwrite the *msg struct, but should rather write into msg->msg_name (there's a '&' unary operator that shouldn't be there). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-29[NETFILTER/RXRPC]: Don't use seq_release_private where inappropriate.Pavel Emelyanov
Some netfilter code and rxrpc one use seq_open() to open a proc file, but seq_release_private to release one. This is harmless, but ambiguous. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-17net/rxrpc: Use BUG_ONJulia Lawall
if (...) BUG(); should be replaced with BUG_ON(...) when the test has no side-effects to allow a definition of BUG_ON that drops the code completely. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @ disable unlikely @ expression E,f; @@ ( if (<... f(...) ...>) { BUG(); } | - if (unlikely(E)) { BUG(); } + BUG_ON(E); ) @@ expression E,f; @@ ( if (<... f(...) ...>) { BUG(); } | - if (E) { BUG(); } + BUG_ON(E); ) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-07Convert ERR_PTR(PTR_ERR(p)) instances to ERR_CAST(p)David Howells
Convert instances of ERR_PTR(PTR_ERR(p)) to ERR_CAST(p) using: perl -spi -e 's/ERR_PTR[(]PTR_ERR[(](.*)[)][)]/ERR_CAST(\1)/' `grep -rl 'ERR_PTR[(]*PTR_ERR' fs crypto net security` Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31[AF_RXRPC]: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS]: Add namespace parameter to ip_route_output_key.Denis V. Lunev
Needed to propagate it down to the ip_route_output_flow. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[RXRPC]: Use cpu_to_be32() where appropriate.YOSHIFUJI Hideaki
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[UDP]: Restore missing inDatagrams incrementsHerbert Xu
The previous move of the the UDP inDatagrams counter caused the counting of encapsulated packets, SUNRPC data (as opposed to call) packets and RXRPC packets to go missing. This patch restores all of these. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NET]: Name magic constants in sock_wake_async()Pavel Emelyanov
The sock_wake_async() performs a bit different actions depending on "how" argument. Unfortunately this argument ony has numerical magic values. I propose to give names to their constants to help people reading this function callers understand what's going on without looking into this function all the time. I suppose this is 2.6.25 material, but if it's not (or the naming seems poor/bad/awful), I can rework it against the current net-2.6 tree. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-07[AF_RXRPC]: Add a missing gotoDavid Howells
Add a missing goto to error handling in the RXKAD security module for AF_RXRPC. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-30[RXRPC]: Add missing select on CRYPTODavid Howells
AF_RXRPC uses the crypto services, so should depend on or select CRYPTO. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2007-11-12[NET]: Add the helper kernel_sock_shutdown()Trond Myklebust
...and fix a couple of bugs in the NBD, CIFS and OCFS2 socket handlers. Looking at the sock->op->shutdown() handlers, it looks as if all of them take a SHUT_RD/SHUT_WR/SHUT_RDWR argument instead of the RCV_SHUTDOWN/SEND_SHUTDOWN arguments. Add a helper, and then define the SHUT_* enum to ensure that kernel users of shutdown() don't get confused. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com> Acked-by: Mark Fasheh <mark.fasheh@oracle.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-11-02[SG] Get rid of __sg_mark_end()Jens Axboe
sg_mark_end() overwrites the page_link information, but all users want __sg_mark_end() behaviour where we just set the end bit. That is the most natural way to use the sg list, since you'll fill it in and then mark the end point. So change sg_mark_end() to only set the termination bit. Add a sg_magic debug check as well, and clear a chain pointer if it is set. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-11-01[NET]: Forget the zero_it argument of sk_alloc()Pavel Emelyanov
Finally, the zero_it argument can be completely removed from the callers and from the function prototype. Besides, fix the checkpatch.pl warnings about using the assignments inside if-s. This patch is rather big, and it is a part of the previous one. I splitted it wishing to make the patches more readable. Hope this particular split helped. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-30[NET]: Fix incorrect sg_mark_end() calls.David S. Miller
This fixes scatterlist corruptions added by commit 68e3f5dd4db62619fdbe520d36c9ebf62e672256 [CRYPTO] users: Fix up scatterlist conversion errors The issue is that the code calls sg_mark_end() which clobbers the sg_page() pointer of the final scatterlist entry. The first part fo the fix makes skb_to_sgvec() do __sg_mark_end(). After considering all skb_to_sgvec() call sites the most correct solution is to call __sg_mark_end() in skb_to_sgvec() since that is what all of the callers would end up doing anyways. I suspect this might have fixed some problems in virtio_net which is the sole non-crypto user of skb_to_sgvec(). Other similar sg_mark_end() cases were converted over to __sg_mark_end() as well. Arguably sg_mark_end() is a poorly named function because it doesn't just "mark", it clears out the page pointer as a side effect, which is what led to these bugs in the first place. The one remaining plain sg_mark_end() call is in scsi_alloc_sgtable() and arguably it could be converted to __sg_mark_end() if only so that we can delete this confusing interface from linux/scatterlist.h Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-27[CRYPTO] users: Fix up scatterlist conversion errorsHerbert Xu
This patch fixes the errors made in the users of the crypto layer during the sg_init_table conversion. It also adds a few conversions that were missing altogether. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-17KEYS: Make request_key() and co fundamentally asynchronousDavid Howells
Make request_key() and co fundamentally asynchronous to make it easier for NFS to make use of them. There are now accessor functions that do asynchronous constructions, a wait function to wait for construction to complete, and a completion function for the key type to indicate completion of construction. Note that the construction queue is now gone. Instead, keys under construction are linked in to the appropriate keyring in advance, and that anyone encountering one must wait for it to be complete before they can use it. This is done automatically for userspace. The following auxiliary changes are also made: (1) Key type implementation stuff is split from linux/key.h into linux/key-type.h. (2) AF_RXRPC provides a way to allocate null rxrpc-type keys so that AFS does not need to call key_instantiate_and_link() directly. (3) Adjust the debugging macros so that they're -Wformat checked even if they are disabled, and make it so they can be enabled simply by defining __KDEBUG to be consistent with other code of mine. (3) Documentation. [alan@lxorguk.ukuu.org.uk: keys: missing word in documentation] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NET]: Make socket creation namespace safe.Eric W. Biederman
This patch passes in the namespace a new socket should be created in and has the socket code do the appropriate reference counting. By virtue of this all socket create methods are touched. In addition the socket create methods are modified so that they will fail if you attempt to create a socket in a non-default network namespace. Failing if we attempt to create a socket outside of the default network namespace ensures that as we incrementally make the network stack network namespace aware we will not export functionality that someone has not audited and made certain is network namespace safe. Allowing us to partially enable network namespaces before all of the exotic protocols are supported. Any protocol layers I have missed will fail to compile because I now pass an extra parameter into the socket creation code. [ Integrated AF_IUCV build fixes from Andrew Morton... -DaveM ] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
